RTEMS 7.0-rc1
mcf5272.h
2
3/*
4 * Coldfire MCF5272 definitions.
5 * Contents of this file based on information provided in
6 * Motorola MCF5272 User's Manual.
7 */
8
9/*
10 * Copyright (C) 2004 Jay Monkman <jtm@lopingdog.com>
11 *
12 * Redistribution and use in source and binary forms, with or without
13 * modification, are permitted provided that the following conditions
14 * are met:
15 * 1. Redistributions of source code must retain the above copyright
16 * notice, this list of conditions and the following disclaimer.
17 * 2. Redistributions in binary form must reproduce the above copyright
18 * notice, this list of conditions and the following disclaimer in the
19 * documentation and/or other materials provided with the distribution.
20 *
21 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31 * POSSIBILITY OF SUCH DAMAGE.
32 */
33
34#ifndef __MCF5272_H__
35#define __MCF5272_H__
36
37#ifndef ASM
38#include <rtems.h>
39#endif
40
41#define bit(x) (1 << (x))
42
43#define MCF5272_SIM_BASE(mbar) ((mbar) + 0x0000)
44#define MCF5272_INT_BASE(mbar) ((mbar) + 0x0020)
45#define MCF5272_CS_BASE(mbar) ((mbar) + 0x0040)
46#define MCF5272_GPIO_BASE(mbar) ((mbar) + 0x0080)
47#define MCF5272_QSPI_BASE(mbar) ((mbar) + 0x00A0)
48#define MCF5272_PWM_BASE(mbar) ((mbar) + 0x00C0)
49#define MCF5272_DMAC_BASE(mbar) ((mbar) + 0x00E0)
50#define MCF5272_UART0_BASE(mbar) ((mbar) + 0x0100)
51#define MCF5272_UART1_BASE(mbar) ((mbar) + 0x0140)
52#define MCF5272_SDRAMC_BASE(mbar) ((mbar) + 0x0180)
53#define MCF5272_TIMER_BASE(mbar) ((mbar) + 0x0200)
54#define MCF5272_PLIC_BASE(mbar) ((mbar) + 0x0300)
55#define MCF5272_ENET_BASE(mbar) ((mbar) + 0x0840)
56#define MCF5272_USB_BASE(mbar) ((mbar) + 0x1000)
57
58
59/* RAMBAR - SRAM Base Address Register */
60#define MCF5272_RAMBAR_BA (0xfffff000) /* SRAM Base Address */
61#define MCF5272_RAMBAR_WP (0x00000100) /* Write Protect */
62#define MCF5272_RAMBAR_CI (0x00000020) /* CPU Space mask */
63#define MCF5272_RAMBAR_SC (0x00000010) /* Supervisor Code Space Mask */
64#define MCF5272_RAMBAR_SD (0x00000008) /* Supervisor Data Space Mask */
65#define MCF5272_RAMBAR_UC (0x00000004) /* User Code Space Mask */
66#define MCF5272_RAMBAR_UD (0x00000002) /* User Data Space Mask */
67#define MCF5272_RAMBAR_V (0x00000001) /* Contents of RAMBAR are valid */
68
69/* MBAR - Module Base Address Register */
70#define MCF5272_MBAR_BA (0xffff0000) /* Base Address */
71#define MCF5272_MBAR_SC (0x00000010) /* Supervisor Code Space Mask */
72#define MCF5272_MBAR_SD (0x00000008) /* Supervisor Data Space Mask */
73#define MCF5272_MBAR_UC (0x00000004) /* User Code Space Mask */
74#define MCF5272_MBAR_UD (0x00000002) /* User Data Space Mask */
75#define MCF5272_MBAR_V (0x00000001) /* Contents of MBAR are valid */
76
77/* CACR - Cache Control Register */
78#define MCF5272_CACR_CENB (0x80000000) /* Cache Enable */
79#define MCF5272_CACR_CPDI (0x10000000) /* Disable CPUSHL Invalidation */
80#define MCF5272_CACR_CFRZ (0x08000000) /* Cache Freeze */
81#define MCF5272_CACR_CINV (0x01000000) /* Cache Invalidate */
82#define MCF5272_CACR_CEIB (0x00000400) /* Cache Enable Noncacheable
83 instruction bursting */
84#define MCF5272_CACR_DCM (0x00000200) /* Default cache mode - noncacheable*/
85#define MCF5272_CACR_DBWE (0x00000100) /* Default Buffered Write Enable */
86#define MCF5272_CACR_DWP (0x00000020) /* Default Write Protection */
87#define MCF5272_CACR_CLNF (0x00000003) /* Cache Line Fill */
88
89/* ACRx - Cache Access Control Registers */
90#define MCF5272_ACR_BA (0xff000000) /* Address Base */
91#define MCF5272_ACR_BAM (0x00ff0000) /* Address Mask */
92#define MCF5272_ACR_EN (0x00008000) /* Enable */
93#define MCF5272_ACR_SM_USR (0x00000000) /* Match if user mode */
94#define MCF5272_ACR_SM_SVR (0x00002000) /* Match if supervisor mode */
95#define MCF5272_ACR_SM_ANY (0x00004000) /* Match Always */
96#define MCF527_ACR_CM (0x00000040) /* Cache Mode (1 - noncacheable) */
97#define MCF5272_ACR_BWE (0x00000020) /* Buffered Write Enable */
98#define MCF5272_ACR_WP (0x00000004) /* Write Protect */
99#define MCF5272_ACR_BASE(base) ((base) & MCF5272_ACR_BA)
100#define MCF5272_ACR_MASK(mask) (((mask) >> 8) & MCF5272_ACR_BAM)
101
102
103#define MCF5272_ICR1_INT1_PI (bit(31))
104#define MCF5272_ICR1_INT1_IPL(x) ((x) << 28)
105#define MCF5272_ICR1_INT1_MASK ((7) << 28)
106#define MCF5272_ICR1_INT2_PI (bit(27))
107#define MCF5272_ICR1_INT2_IPL(x) ((x) << 24)
108#define MCF5272_ICR1_INT2_MASK ((7) << 24)
109#define MCF5272_ICR1_INT3_PI (bit(23))
110#define MCF5272_ICR1_INT3_IPL(x) ((x) << 20)
111#define MCF5272_ICR1_INT3_MASK ((7) << 20)
112#define MCF5272_ICR1_INT4_PI (bit(19))
113#define MCF5272_ICR1_INT4_IPL(x) ((x) << 16)
114#define MCF5272_ICR1_INT4_MASK ((7) << 16)
115#define MCF5272_ICR1_TMR0_PI (bit(15))
116#define MCF5272_ICR1_TMR0_IPL(x) ((x) << 12)
117#define MCF5272_ICR1_TMR0_MASK ((7) << 12)
118#define MCF5272_ICR1_TMR1_PI (bit(11))
119#define MCF5272_ICR1_TMR1_IPL(x) ((x) << 8)
120#define MCF5272_ICR1_TMR1_MASK ((7) << 8)
121#define MCF5272_ICR1_TMR2_PI (bit(7))
122#define MCF5272_ICR1_TMR2_IPL(x) ((x) << 4)
123#define MCF5272_ICR1_TMR2_MASK ((7) << 4)
124#define MCF5272_ICR1_TMR3_PI (bit(3))
125#define MCF5272_ICR1_TMR3_IPL(x) ((x) << 0)
126#define MCF5272_ICR1_TMR3_MASK ((7) << 0)
127
128#define MCF5272_ICR3_USB4_PI (bit(31))
129#define MCF5272_ICR3_USB4_IPL(x) ((x) << 28)
130#define MCF5272_ICR3_USB4_MASK ((7) << 28)
131#define MCF5272_ICR3_USB5_PI (bit(27))
132#define MCF5272_ICR3_USB5_IPL(x) ((x) << 24)
133#define MCF5272_ICR3_USB5_MASK ((7) << 24)
134#define MCF5272_ICR3_USB6_PI (bit(23))
135#define MCF5272_ICR3_USB6_IPL(x) ((x) << 20)
136#define MCF5272_ICR3_USB6_MASK ((7) << 20)
137#define MCF5272_ICR3_USB7_PI (bit(19))
138#define MCF5272_ICR3_USB7_IPL(x) ((x) << 16)
139#define MCF5272_ICR3_USB7_MASK ((7) << 16)
140#define MCF5272_ICR3_DMA_PI (bit(15))
141#define MCF5272_ICR3_DMA_IPL(x) ((x) << 12)
142#define MCF5272_ICR3_DMA_MASK ((7) << 12)
143#define MCF5272_ICR3_ERX_PI (bit(11))
144#define MCF5272_ICR3_ERX_IPL(x) ((x) << 8)
145#define MCF5272_ICR3_ERX_MASK ((7) << 8)
146#define MCF5272_ICR3_ETX_PI (bit(7))
147#define MCF5272_ICR3_ETX_IPL(x) ((x) << 4)
148#define MCF5272_ICR3_ETX_MASK ((7) << 4)
149#define MCF5272_ICR3_ENTC_PI (bit(3))
150#define MCF5272_ICR3_ENTC_IPL(x) ((x) << 0)
151#define MCF5272_ICR3_ENTC_MASK ((7) << 0)
152
153
154#define MCF5272_USR_RB (bit(7))
155#define MCF5272_USR_FE (bit(6))
156#define MCF5272_USR_PE (bit(5))
157#define MCF5272_USR_OE (bit(4))
158#define MCF5272_USR_TXEMP (bit(3))
159#define MCF5272_USR_TXRDY (bit(2))
160#define MCF5272_USR_FFULL (bit(1))
161#define MCF5272_USR_RXRDY (bit(0))
162
163#define MCF5272_TMR_PS_MASK 0xff00
164#define MCF5272_TMR_PS_SHIFT 8
165#define MCF5272_TMR_CE_DISABLE (0 << 6)
166#define MCF5272_TMR_CE_RISING (1 << 6)
167#define MCF5272_TMR_CE_FALLING (2 << 6)
168#define MCF5272_TMR_CE_ANY (3 << 6)
169#define MCF5272_TMR_OM (bit(5))
170#define MCF5272_TMR_ORI (bit(4))
171#define MCF5272_TMR_FRR (bit(3))
172#define MCF5272_TMR_CLK_STOP (0 << 1)
173#define MCF5272_TMR_CLK_MSTR (1 << 1)
174#define MCF5272_TMR_CLK_MSTR16 (2 << 1)
175#define MCF5272_TMR_CLK_TIN (3 << 1)
176#define MCF5272_TMR_RST (bit(0))
177#define MCF5272_TER_REF (bit(1))
178#define MCF5272_TER_CAP (bit(0))
179
180#define MCF5272_SCR_PRI (bit(8))
181#define MCF5272_SCR_AR (bit(7))
182#define MCF5272_SCR_SRST (bit(6))
183#define MCF5272_SCR_BUSLOCK (bit(3))
184#define MCF5272_SCR_HWR_128 (0)
185#define MCF5272_SCR_HWR_256 (1)
186#define MCF5272_SCR_HWR_512 (2)
187#define MCF5272_SCR_HWR_1024 (3)
188#define MCF5272_SCR_HWR_2048 (4)
189#define MCF5272_SCR_HWR_4096 (5)
190#define MCF5272_SCR_HWR_8192 (6)
191#define MCF5272_SCR_HWR_16384 (7)
192
193#define MCF5272_SPR_ADC (bit(15))
194#define MCF5272_SPR_WPV (bit(15))
195#define MCF5272_SPR_SMV (bit(15))
196#define MCF5272_SPR_PE (bit(15))
197#define MCF5272_SPR_HWT (bit(15))
198#define MCF5272_SPR_RPV (bit(15))
199#define MCF5272_SPR_EXT (bit(15))
200#define MCF5272_SPR_SUV (bit(15))
201#define MCF5272_SPR_ADCEN (bit(15))
202#define MCF5272_SPR_WPVEN (bit(15))
203#define MCF5272_SPR_SMVEN (bit(15))
204#define MCF5272_SPR_PEEN (bit(15))
205#define MCF5272_SPR_HWTEN (bit(15))
206#define MCF5272_SPR_RPVEN (bit(15))
207#define MCF5272_SPR_EXTEN (bit(15))
208#define MCF5272_SPR_SUVEN (bit(15))
209
210#define MCF5272_ENET_TX_RT (bit(25))
211#define MCF5272_ENET_ETHERN_EN (bit(1))
212#define MCF5272_ENET_RESET (bit(0))
213
214#define MCF5272_ENET_EIR_HBERR (bit(31))
215#define MCF5272_ENET_EIR_BABR (bit(30))
216#define MCF5272_ENET_EIR_BABT (bit(29))
217#define MCF5272_ENET_EIR_GRA (bit(28))
218#define MCF5272_ENET_EIR_TXF (bit(27))
219#define MCF5272_ENET_EIR_TXB (bit(26))
220#define MCF5272_ENET_EIR_RXF (bit(25))
221#define MCF5272_ENET_EIR_RXB (bit(24))
222#define MCF5272_ENET_EIR_MII (bit(23))
223#define MCF5272_ENET_EIR_EBERR (bit(22))
224#define MCF5272_ENET_EIR_UMINT (bit(21))
225
226#define MCF5272_ENET_RCR_PROM (bit(3))
227#define MCF5272_ENET_RCR_MII (bit(2))
228#define MCF5272_ENET_RCR_DRT (bit(1))
229#define MCF5272_ENET_RCR_LOOP (bit(0))
230
231#define MCF5272_ENET_TCR_FDEN (bit(2))
232#define MCF5272_ENET_TCR_HBC (bit(1))
233#define MCF5272_ENET_TCR_GTS (bit(0))
234
235
236#ifndef ASM
237typedef struct {
238 volatile uint32_t mbar; /* READ ONLY!! */
239
240 volatile uint16_t scr;
241 volatile uint16_t _res0;
242
243 volatile uint16_t _res1;
244 volatile uint16_t spr;
245
246 volatile uint32_t pmr;
247
248 volatile uint16_t _res2;
249 volatile uint16_t alpr;
250
251 volatile uint32_t dir;
252} sim_regs_t;
254typedef struct {
255 volatile uint32_t icr1;
256 volatile uint32_t icr2;
257 volatile uint32_t icr3;
258 volatile uint32_t icr4;
259 volatile uint32_t isr;
260 volatile uint32_t pitr;
261 volatile uint32_t piwr;
262 volatile uint8_t _res0[3];
263 volatile uint8_t pivr;
266typedef struct {
267 volatile uint32_t csbr0;
268 volatile uint32_t csor0;
269 volatile uint32_t csbr1;
270 volatile uint32_t csor1;
271 volatile uint32_t csbr2;
272 volatile uint32_t csor2;
273 volatile uint32_t csbr3;
274 volatile uint32_t csor3;
275 volatile uint32_t csbr4;
276 volatile uint32_t csor4;
277 volatile uint32_t csbr5;
278 volatile uint32_t csor5;
279 volatile uint32_t csbr6;
280 volatile uint32_t csor6;
281 volatile uint32_t csbr7;
282 volatile uint32_t csor7;
285typedef struct {
286 volatile uint32_t pacnt;
287
288 volatile uint16_t paddr;
289 volatile uint16_t _res0;
290
291 volatile uint16_t _res1;
292 volatile uint16_t padat;
293
294 volatile uint32_t pbcnt;
295
296 volatile uint16_t pbddr;
297 volatile uint16_t _res2;
298
299 volatile uint16_t _res3;
300 volatile uint16_t pbdat;
301
302 volatile uint16_t pcddr;
303 volatile uint16_t _res4;
304
305 volatile uint16_t _res5;
306 volatile uint16_t pcdat;
307
308 volatile uint32_t pdcnt;
311typedef struct {
312 volatile uint32_t qmr;
313 volatile uint32_t qdlyr;
314 volatile uint32_t qwr;
315 volatile uint32_t qir;
316 volatile uint32_t qar;
317 volatile uint32_t qdr;
320typedef struct {
321 volatile uint8_t pwcr1;
322 volatile uint8_t _res0[3];
323
324 volatile uint8_t pwcr2;
325 volatile uint8_t _res1[3];
326
327 volatile uint8_t pwcr3;
328 volatile uint8_t _res2[3];
329
330 volatile uint8_t pwwd1;
331 volatile uint8_t _res3[3];
332
333 volatile uint8_t pwwd2;
334 volatile uint8_t _res4[3];
335
336 volatile uint8_t pwwd3;
337 volatile uint8_t _res5[3];
338} pwm_regs_t;
340typedef struct {
341 volatile uint32_t dcmr;
342
343 volatile uint16_t _res0;
344 volatile uint16_t dcir;
345
346 volatile uint32_t dbcr;
347
348 volatile uint32_t dsar;
349
350 volatile uint32_t ddar;
351} dma_regs_t;
353typedef struct {
354 volatile uint8_t umr; /* 0x000 */
355 volatile uint8_t _res0[3];
356
357 volatile uint8_t ucsr; /* 0x004 */
358 volatile uint8_t _res2[3];
359
360 volatile uint8_t ucr; /* 0x008 */
361 volatile uint8_t _res3[3];
362
363 volatile uint8_t udata; /* 0x00c */
364 volatile uint8_t _res4[3];
365
366 volatile uint8_t uccr; /* 0x010 */
367 volatile uint8_t _res6[3];
368
369 volatile uint8_t uisr; /* 0x014 */
370 volatile uint8_t _res8[3];
371
372 volatile uint8_t ubg1; /* 0x018 */
373 volatile uint8_t _res10[3];
374
375 volatile uint8_t ubg2; /* 0x01c */
376 volatile uint8_t _res11[3];
377
378 volatile uint8_t uabr1; /* 0x020 */
379 volatile uint8_t _res12[3];
380
381 volatile uint8_t uabr2; /* 0x024 */
382 volatile uint8_t _res13[3];
383
384 volatile uint8_t utxfcsr; /* 0x028 */
385 volatile uint8_t _res14[3];
386
387 volatile uint8_t urxfcsr; /* 0x02c */
388 volatile uint8_t _res15[3];
389
390 volatile uint8_t ufpdn; /* 0x030 */
391 volatile uint8_t _res16[3];
392
393 volatile uint8_t uip; /* 0x034 */
394 volatile uint8_t _res17[3];
395
396 volatile uint8_t uop1; /* 0x038 */
397 volatile uint8_t _res18[3];
398
399 volatile uint8_t uop0; /* 0x03c */
400 volatile uint8_t _res19[3];
403typedef struct {
404 volatile uint16_t tmr0;
405 volatile uint16_t _res0;
406
407 volatile uint16_t trr0;
408 volatile uint16_t _res1;
409
410 volatile uint16_t tcap0;
411 volatile uint16_t _res2;
412
413 volatile uint16_t tcn0;
414 volatile uint16_t _res3;
415
416 volatile uint16_t ter0;
417 volatile uint16_t _res4;
418
419 volatile uint8_t _res40[12];
420
421 volatile uint16_t tmr1;
422 volatile uint16_t _res5;
423
424 volatile uint16_t trr1;
425 volatile uint16_t _res6;
426
427 volatile uint16_t tcap1;
428 volatile uint16_t _res7;
429
430 volatile uint16_t tcn1;
431 volatile uint16_t _res8;
432
433 volatile uint16_t ter1;
434 volatile uint16_t _res9;
435
436 volatile uint8_t _res91[12];
437
438 volatile uint16_t tmr2;
439 volatile uint16_t _res10;
440
441 volatile uint16_t trr2;
442 volatile uint16_t _res11;
443
444 volatile uint16_t tcap2;
445 volatile uint16_t _res12;
446
447 volatile uint16_t tcn2;
448 volatile uint16_t _res13;
449
450 volatile uint16_t ter2;
451 volatile uint16_t _res14;
452
453 volatile uint8_t _res140[12];
454
455 volatile uint16_t tmr3;
456 volatile uint16_t _res15;
457
458 volatile uint16_t trr3;
459 volatile uint16_t _res16;
460
461 volatile uint16_t tcap3;
462 volatile uint16_t _res17;
463
464 volatile uint16_t tcn3;
465 volatile uint16_t _res18;
466
467 volatile uint16_t ter3;
468 volatile uint16_t _res19;
469
470 volatile uint8_t _res190[12];
471
472 volatile uint16_t wrrr;
473 volatile uint16_t _res20;
474
475 volatile uint16_t wirr;
476 volatile uint16_t _res21;
477
478 volatile uint16_t wcr;
479 volatile uint16_t _res22;
480
481 volatile uint16_t wer;
482 volatile uint16_t _res23;
485typedef struct {
486 volatile uint32_t p0b1rr;
487 volatile uint32_t p1b1rr;
488 volatile uint32_t p2b1rr;
489 volatile uint32_t p3b1rr;
490 volatile uint32_t p0b2rr;
491 volatile uint32_t p1b2rr;
492 volatile uint32_t p2b2rr;
493 volatile uint32_t p3b2rr;
494
495 volatile uint8_t p0drr;
496 volatile uint8_t p1drr;
497 volatile uint8_t p2drr;
498 volatile uint8_t p3drr;
499
500 volatile uint32_t p0b1tr;
501 volatile uint32_t p1b1tr;
502 volatile uint32_t p2b1tr;
503 volatile uint32_t p3b1tr;
504 volatile uint32_t p0b2tr;
505 volatile uint32_t p1b2tr;
506 volatile uint32_t p2b2tr;
507 volatile uint32_t p3b2tr;
508
509 volatile uint8_t p0dtr;
510 volatile uint8_t p1dtr;
511 volatile uint8_t p2dtr;
512 volatile uint8_t p3dtr;
513
514 volatile uint16_t p0cr;
515 volatile uint16_t p1cr;
516 volatile uint16_t p2cr;
517 volatile uint16_t p3cr;
518 volatile uint16_t p0icr;
519 volatile uint16_t p1icr;
520 volatile uint16_t p2icr;
521 volatile uint16_t p3icr;
522 volatile uint16_t p0gmr;
523 volatile uint16_t p1gmr;
524 volatile uint16_t p2gmr;
525 volatile uint16_t p3gmr;
526 volatile uint16_t p0gmt;
527 volatile uint16_t p1gmt;
528 volatile uint16_t p2gmt;
529 volatile uint16_t p3gmt;
530
531 volatile uint8_t _res0;
532 volatile uint8_t pgmts;
533 volatile uint8_t pgmta;
534 volatile uint8_t _res1;
535 volatile uint8_t p0gcir;
536 volatile uint8_t p1gcir;
537 volatile uint8_t p2gcir;
538 volatile uint8_t p3gcir;
539 volatile uint8_t p0gcit;
540 volatile uint8_t p1gcit;
541 volatile uint8_t p2gcit;
542 volatile uint8_t p3gcit;
543 volatile uint8_t _res3[3];
544 volatile uint8_t pgcitsr;
545 volatile uint8_t _res4[3];
546 volatile uint8_t pdcsr;
547
548 volatile uint16_t p0psr;
549 volatile uint16_t p1psr;
550 volatile uint16_t p2psr;
551 volatile uint16_t p3psr;
552 volatile uint16_t pasr;
553 volatile uint8_t _res5;
554 volatile uint8_t plcr;
555 volatile uint16_t _res6;
556 volatile uint16_t pdrqr;
557 volatile uint16_t p0sdr;
558 volatile uint16_t p1sdr;
559 volatile uint16_t p2sdr;
560 volatile uint16_t p3sdr;
561 volatile uint16_t _res7;
562 volatile uint16_t pcsr;
565typedef struct {
566 volatile uint32_t ecr;
567 volatile uint32_t eir;
568 volatile uint32_t eimr;
569 volatile uint32_t ivsr;
570 volatile uint32_t rdar;
571 volatile uint32_t tdar;
572 volatile uint32_t _res0[10];
573 volatile uint32_t mmfr;
574 volatile uint32_t mscr;
575 volatile uint32_t _res1[17];
576 volatile uint32_t frbr;
577 volatile uint32_t frsr;
578 volatile uint32_t _res2[4];
579 volatile uint32_t tfwr;
580 volatile uint32_t _res3[1];
581 volatile uint32_t tfsr;
582 volatile uint32_t _res4[21];
583 volatile uint32_t rcr;
584 volatile uint32_t mflr;
585 volatile uint32_t _res5[14];
586 volatile uint32_t tcr;
587 volatile uint32_t _res6[158];
588 volatile uint32_t malr;
589 volatile uint32_t maur;
590 volatile uint32_t htur;
591 volatile uint32_t htlr;
592 volatile uint32_t erdsr;
593 volatile uint32_t etdsr;
594 volatile uint32_t emrbr;
595/* volatile uint8_t fifo[448]; */
598typedef struct {
599 volatile uint16_t _res0;
600 volatile uint16_t fnr;
601 volatile uint16_t _res1;
602 volatile uint16_t fnmr;
603 volatile uint16_t _res2;
604 volatile uint16_t rfmr;
605 volatile uint16_t _res3;
606 volatile uint16_t rfmmr;
607 volatile uint8_t _res4[3];
608 volatile uint8_t far;
609 volatile uint32_t asr;
610 volatile uint32_t drr1;
611 volatile uint32_t drr2;
612 volatile uint16_t _res5;
613 volatile uint16_t specr;
614 volatile uint16_t _res6;
615 volatile uint16_t ep0sr;
616
617 volatile uint32_t iep0cfg;
618 volatile uint32_t oep0cfg;
619 volatile uint32_t ep1cfg;
620 volatile uint32_t ep2cfg;
621 volatile uint32_t ep3cfg;
622 volatile uint32_t ep4cfg;
623 volatile uint32_t ep5cfg;
624 volatile uint32_t ep6cfg;
625 volatile uint32_t ep7cfg;
626 volatile uint32_t ep0ctl;
627
628 volatile uint16_t _res7;
629 volatile uint16_t ep1ctl;
630 volatile uint16_t _res8;
631 volatile uint16_t ep2ctl;
632 volatile uint16_t _res9;
633 volatile uint16_t ep3ctl;
634 volatile uint16_t _res10;
635 volatile uint16_t ep4ctl;
636 volatile uint16_t _res11;
637 volatile uint16_t ep5ctl;
638 volatile uint16_t _res12;
639 volatile uint16_t ep6ctl;
640 volatile uint16_t _res13;
641 volatile uint16_t ep7ctl;
642
643 volatile uint32_t ep0isr;
644
645 volatile uint16_t _res14;
646 volatile uint16_t ep1isr;
647 volatile uint16_t _res15;
648 volatile uint16_t ep2isr;
649 volatile uint16_t _res16;
650 volatile uint16_t ep3isr;
651 volatile uint16_t _res17;
652 volatile uint16_t ep4isr;
653 volatile uint16_t _res18;
654 volatile uint16_t ep5isr;
655 volatile uint16_t _res19;
656 volatile uint16_t ep6isr;
657 volatile uint16_t _res20;
658 volatile uint16_t ep7isr;
659
660 volatile uint32_t ep0imr;
661
662 volatile uint16_t _res21;
663 volatile uint16_t ep1imr;
664 volatile uint16_t _res22;
665 volatile uint16_t ep2imr;
666 volatile uint16_t _res23;
667 volatile uint16_t ep3imr;
668 volatile uint16_t _res24;
669 volatile uint16_t ep4imr;
670 volatile uint16_t _res25;
671 volatile uint16_t ep5imr;
672 volatile uint16_t _res26;
673 volatile uint16_t ep6imr;
674 volatile uint16_t _res27;
675 volatile uint16_t ep7imr;
676
677 volatile uint32_t ep0dr;
678 volatile uint32_t ep1dr;
679 volatile uint32_t ep2dr;
680 volatile uint32_t ep3dr;
681 volatile uint32_t ep4dr;
682 volatile uint32_t ep5dr;
683 volatile uint32_t ep6dr;
684 volatile uint32_t ep7dr;
685
686 volatile uint16_t _res28;
687 volatile uint16_t ep0dpr;
688 volatile uint16_t _res29;
689 volatile uint16_t ep1dpr;
690 volatile uint16_t _res30;
691 volatile uint16_t ep2dpr;
692 volatile uint16_t _res31;
693 volatile uint16_t ep3dpr;
694 volatile uint16_t _res32;
695 volatile uint16_t ep4dpr;
696 volatile uint16_t _res33;
697 volatile uint16_t ep5dpr;
698 volatile uint16_t _res34;
699 volatile uint16_t ep6dpr;
700 volatile uint16_t _res35;
701 volatile uint16_t ep7dpr;
702/* uint8_t ram[1024]; */
703} usb_regs_t;
704
705extern intctrl_regs_t *g_intctrl_regs;
706extern chipsel_regs_t *g_chipsel_regs;
707extern gpio_regs_t *g_gpio_regs;
708extern qspi_regs_t *g_qspi_regs;
709extern pwm_regs_t *g_pwm_regs;
710extern dma_regs_t *g_dma_regs;
711extern uart_regs_t *g_uart0_regs;
712extern uart_regs_t *g_uart1_regs;
713extern timer_regs_t *g_timer_regs;
714extern plic_regs_t *g_plic_regs;
715extern enet_regs_t *g_enet_regs;
716extern usb_regs_t *g_usb_regs;
717
718#endif /* ASM */
719
720#endif /* __MCF5272_H__ */
Definition: mcf5272.h:265
Definition: mcf5272.h:339
Definition: mcf5272.h:564
Definition: mcf5272.h:284
Definition: mcf5272.h:253
Definition: mcf5272.h:484
Definition: mcf5272.h:319
Definition: mcf5272.h:310
Definition: mcf5272.h:236
Definition: mcf5272.h:402
Definition: mcf5272.h:352
Definition: mcf5272.h:597
