RTEMS
7.0-rc1
bsps
powerpc
gen5200
nvram
m93cxx.h
1
2
* RTEMS generic MPC5200 BSP
3
4
* This file contains definitions for the M93Cxx EEPROM devices.
5
6
* M93C46 is a serial microwire EEPROM which contains
7
* 1Kbit (128 bytes/64 words) of non-volatile memory.
8
* The device can be configured for byte- or word-
9
* access. The driver provides a file-like interface
10
* to this memory.
11
12
* MPC5x00 PIN settings:
13
14
* PSC3_6 (output) -> MC93C46 serial data in (D)
15
* PSC3_7 (input) -> MC93C46 serial data out (Q)
16
* PSC3_8 (output) -> MC93C46 chip select input (S)
17
* PSC3_9 (output) -> MC93C46 serial clock (C)
18
19
20
21
* Copyright (C) 2005 embedded brains GmbH & Co. KG
22
* Copyright (C) 2003 IPR Engineering
23
24
25
* modification, are permitted provided that the following conditions
26
* are met:
27
* 1. Redistributions of source code must retain the above copyright
28
* notice, this list of conditions and the following disclaimer.
29
* 2. Redistributions in binary form must reproduce the above copyright
30
* notice, this list of conditions and the following disclaimer in the
31
* documentation and/or other materials provided with the distribution.
32
33
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
34
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
35
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
36
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
37
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
38
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
39
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
40
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
41
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
42
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
43
* POSSIBILITY OF SUCH DAMAGE.
44
45
46
#ifndef __M93CXX_H__
47
#define __M93CXX_H__
48
49
#ifdef __cplusplus
50
extern
"C"
51
#endif
52
53
static
void
m93cxx_enable_write(
void
54
static
void
m93cxx_disable_write(
void
55
static
void
m93cxx_write_byte(uint32_t, uint8_t);
56
static
uint8_t m93cxx_read_byte(uint32_t);
57
void
wait_usec(
unsigned
long
58
59
#define M93CXX_MODE_WORD
60
/*#define M93C46_MODE_BYTE*/
61
#define M93C46
62
#define M93C46_NVRAM_SIZE 128
63
64
#define GPIO_PSC3_6 (1 << 12)
65
#define GPIO_PSC3_7 (1 << 13)
66
#define GPIO_PSC3_8 (1 << 26)
67
#define GPIO_PSC3_9 (1 << 26)
68
69
#define START_BIT 0x1
70
#define EWDS_OPCODE 0x0
71
#define WRAL_OPCODE 0x1
72
#define ERAL_OPCODE 0x2
73
#define EWEN_OPCODE 0x3
74
#define WRITE_OPCODE 0x4
75
#define READ_OPCODE 0x8
76
#define ERASE_OPCODE 0xC
77
78
#define WAIT(i) wait_usec(i)
79
80
#define ENABLE_CHIP_SELECT mpc5200.gpiosido |= GPIO_PSC3_8
81
#define DISABLE_CHIP_SELECT mpc5200.gpiosido &= ~GPIO_PSC3_8
82
#define SET_DATA_BIT_HIGH mpc5200.gpiosdo |= GPIO_PSC3_6
83
#define SET_DATA_BIT_LOW mpc5200.gpiosdo &= ~GPIO_PSC3_6
84
85
#ifdef M93CXX_MODE_BYTE
86
#define GET_DATA_BYTE_SHIFT(val) ((val) |= ((mpc5200.gpiosdi & GPIO_PSC3_7) >> 13)); \
87
((val) <<= 1)
88
#define SET_DATA_BYTE_SHIFT(val) (((val) & 0x80) ? (mpc5200.gpiosdo |= GPIO_PSC3_6) : (mpc5200.gpiosdo &= ~GPIO_PSC3_6)); \
89
((val) <<= 1)
90
#else
91
#define GET_DATA_WORD_SHIFT(val) ((val) |= ((mpc5200.gpiosdi & GPIO_PSC3_7) >> 13)); \
92
((val) <<= 1)
93
#define SET_DATA_WORD_SHIFT(val) (((val) & 0x8000) ? (mpc5200.gpiosdo |= GPIO_PSC3_6) : (mpc5200.gpiosdo &= ~GPIO_PSC3_6)); \
94
((val) <<= 1)
95
#endif
96
97
#define MASK_HEAD_SHIFT(head) ((((head) & 0x80000000) >> 31) ? (mpc5200.gpiosdo |= GPIO_PSC3_6) : (mpc5200.gpiosdo &= ~GPIO_PSC3_6)); \
98
((head) <<= 1)
99
#define DO_CLOCK_CYCLE mpc5200.gpiowdo |= GPIO_PSC3_9; \
100
WAIT(1000); \
101
mpc5200.gpiowdo &= ~GPIO_PSC3_9
102
#define CHECK_WRITE_BUSY while(!(mpc5200.gpiosdi & GPIO_PSC3_7))
103
104
105
106
#ifdef M93C46
107
#define M93C46_EWDS ((START_BIT << 31) | (EWDS_OPCODE << 27))
108
#define M93C46_WRAL ((START_BIT << 31) | (WRAL_OPCODE << 27))
109
#define M93C46_ERAL ((START_BIT << 31) | (ERAL_OPCODE << 27))
110
#define M93C46_EWEN ((START_BIT << 31) | (EWEN_OPCODE << 27))
111
#define M93C46_READ(addr) ((START_BIT << 31) | (READ_OPCODE << 27) | ((addr) << 22))
112
#define M93C46_WRITE(addr) ((START_BIT << 31) | (WRITE_OPCODE << 27) | ((addr) << 22))
113
#define M93C46_ERASE(addr) ((START_BIT << 31) | (ERASE_OPCODE << 27) | ((addr) << 22))
114
#define M93C46_CLOCK_CYCLES 10
115
#endif
116
#else
117
#ifdef M93C46
118
119
120
121
122
#define M93C46_READ(addr) ((START_BIT << 31) | (READ_OPCODE << 27) | ((addr) << 23))
123
#define M93C46_WRITE(addr) ((START_BIT << 31) | (WRITE_OPCODE << 27) | ((addr) << 23))
124
#define M93C46_ERASE(addr) ((START_BIT << 31) | (ERASE_OPCODE << 27) | ((addr) << 23))
125
#define M93C46_CLOCK_CYCLES 9
126
#endif
127
#endif
128
129
#ifdef __cplusplus
130
131
#endif
132
133
#endif
/* __M93CXX_H__ */
