RTEMS 7.0-rc1
lm3s69xx.h
1/* SPDX-License-Identifier: GPL-2.0+-with-RTEMS-exception */
2
11/*
12 * Copyright (c) 2013 Eugeniy Meshcheryakov <eugen@debian.org>
13 *
14 * Copyright (c) 2011 Sebastian Huber. All rights reserved.
15 *
16 * The license and distribution terms for this file may be
17 * found in the file LICENSE in this distribution or at
18 * http://www.rtems.org/license/LICENSE.
19 */
20
21#ifndef LIBBSP_ARM_LM3S69XX_LM3S69XX_H
22#define LIBBSP_ARM_LM3S69XX_LM3S69XX_H
23#include <bspopts.h>
24#include <bsp/utility.h>
25
34#define LM3S69XX_SYSCON_BASE 0x400fe000
35
36#define LM3S69XX_UART_0_BASE 0x4000c000
37#define LM3S69XX_UART_1_BASE 0x4000d000
38#define LM3S69XX_UART_2_BASE 0x4000e000
39
40#ifdef LM3S69XX_USE_AHB_FOR_GPIO
41#define LM3S69XX_GPIO_A_BASE 0x40058000
42#define LM3S69XX_GPIO_B_BASE 0x40059000
43#define LM3S69XX_GPIO_C_BASE 0x4005a000
44#define LM3S69XX_GPIO_D_BASE 0x4005b000
45#define LM3S69XX_GPIO_E_BASE 0x4005c000
46#define LM3S69XX_GPIO_F_BASE 0x4005d000
47#if LM3S69XX_NUM_GPIO_BLOCKS > 6
48#define LM3S69XX_GPIO_G_BASE 0x4005e000
49#if LM3S69XX_NUM_GPIO_BLOCKS > 7
50#define LM3S69XX_GPIO_H_BASE 0x4005f000
51#endif
52#endif
53
54#define LM3S69XX_GPIO(port) ((volatile lm3s69xx_gpio *)(LM3S69XX_GPIO_A_BASE + (port) * 0x1000))
55#else /* LM3S69XX_USE_AHB_FOR_GPIO */
56#define LM3S69XX_GPIO_A_BASE 0x40004000
57#define LM3S69XX_GPIO_B_BASE 0x40005000
58#define LM3S69XX_GPIO_C_BASE 0x40006000
59#define LM3S69XX_GPIO_D_BASE 0x40007000
60#define LM3S69XX_GPIO_E_BASE 0x40024000
61#define LM3S69XX_GPIO_F_BASE 0x40025000
62#if LM3S69XX_NUM_GPIO_BLOCKS > 6
63#define LM3S69XX_GPIO_G_BASE 0x40026000
64#if LM3S69XX_NUM_GPIO_BLOCKS > 7
65#define LM3S69XX_GPIO_H_BASE 0x40027000
66#endif
67#endif
68
69#define LM3S69XX_GPIO(port) ((volatile lm3s69xx_gpio *)(((port) < 4) ? \
70 (LM3S69XX_GPIO_A_BASE + (port) * 0x1000) : \
71 (LM3S69XX_GPIO_E_BASE + ((port) - 4) * 0x1000)))
72#endif /* LM3S69XX_USE_AHB_FOR_GPIO */
73
74#define LM3S69XX_SSI_0_BASE 0x40008000
75#if LM3S69XX_NUM_SSI_BLOCKS > 1
76#define LM3S69XX_SSI_1_BASE 0x40009000
77#if LM3S69XX_NUM_SSI_BLOCKS > 2
78#define LM3S69XX_SSI_2_BASE 0x4000A000
79#if LM3S69XX_NUM_SSI_BLOCKS > 3
80#define LM3S69XX_SSI_3_BASE 0x4000B000
81#endif
82#endif
83#endif
84
85#define LM3S69XX_SYSCON ((volatile lm3s69xx_syscon *)LM3S69XX_SYSCON_BASE)
86
87#define LM3S69XX_PLL_FREQUENCY 400000000U
88
89typedef struct {
90 uint32_t data[256]; /* Masked data registers are included here. */
91 uint32_t dir;
92 uint32_t is;
93 uint32_t ibe;
94 uint32_t iev;
95 uint32_t im;
96 uint32_t ris;
97 uint32_t mis;
98 uint32_t icr;
99 uint32_t afsel;
100
101 uint32_t reserved_0[55];
102
103 uint32_t dr2r;
104 uint32_t dr4r;
105 uint32_t dr8r;
106 uint32_t odr;
107 uint32_t pur;
108 uint32_t pdr;
109 uint32_t slr;
110 uint32_t den;
111 uint32_t lock;
112 uint32_t cr;
113 uint32_t amsel;
115
116typedef struct {
117 uint32_t did0;
118 uint32_t did1;
119
120 uint32_t dc0;
121 uint32_t reserved_0;
122 uint32_t dc1;
123 uint32_t dc2;
124 uint32_t dc3;
125 uint32_t dc4;
126 uint32_t dc5;
127 uint32_t dc6;
128 uint32_t dc7;
129
130 uint32_t reserved_1;
131
132#define SYSCONPBORCTL_BORIOR BSP_BIT32(1)
133 uint32_t pborctl;
134
135#define SYSCONLDOPCTL_VADJ(val) BSP_FLD32(val, 0, 5)
136#define SYSCONLDOPCTL_VADJ_MASK BSP_MSK32(0, 5)
137 uint32_t ldopctl;
138
139 uint32_t reserved_2[2];
140
141 uint32_t srcr0;
142 uint32_t srcr1;
143 uint32_t srcr2;
144
145 uint32_t reserved_3;
146
147#define SYSCONRIS_MOSCPUPRIS BSP_BIT32(8)
148#define SYSCONRIS_USBPLLRIS BSP_BIT32(7)
149#define SYSCONRIS_PLLLRIS BSP_BIT32(6)
150#define SYSCONRIS_BORRIS BSP_BIT32(1)
151 uint32_t ris;
152
153#define SYSCONIMC_MOSCPUPIM BSP_BIT32(8)
154#define SYSCONIMC_USBPLLLIM BSP_BIT32(7)
155#define SYSCONIMC_PLLLIM BSP_BIT32(6)
156#define SYSCONIMC_BORIM BSP_BIT32(1)
157 uint32_t imc;
158
159#define SYSCONMISC_MOSCPUPMIS BSP_BIT32(8)
160#define SYSCONMISC_USBPLLLMIS BSP_BIT32(7)
161#define SYSCONMISC_PLLLMIS BSP_BIT32(6)
162#define SYSCONMISC_BORMIS BSP_BIT32(1)
163 uint32_t misc;
164
165#define SYSCONRESC_MOSCFAIL BSP_BIT32(16)
166#define SYSCONRESC_SW BSP_BIT32(4)
167#define SYSCONRESC_WDT BSP_BIT32(3)
168#define SYSCONRESC_BOR BSP_BIT32(2)
169#define SYSCONRESC_POR BSP_BIT32(1)
170#define SYSCONRESC_EXT BSP_BIT32(0)
171 uint32_t resc;
172
173#define SYSCONRCC_AGC BSP_BIT32(27)
174#define SYSCONRCC_SYSDIV(val) BSP_FLD32(val, 23, 26)
175#define SYSCONRCC_SYSDIV_MSK BSP_MSK32(23, 26)
176#define SYSCONRCC_USESYSDIV BSP_BIT32(22)
177#define SYSCONRCC_USEPWMDIV BSP_BIT32(20)
178#define SYSCONRCC_PWMDIV(val) BSP_FLD32(val, 17, 19)
179#define SYSCONRCC_PWMDIV_DIV2_VAL 0
180#define SYSCONRCC_PWMDIV_DIV4_VAL 1
181#define SYSCONRCC_PWMDIV_DIV8_VAL 2
182#define SYSCONRCC_PWMDIV_DIV16_VAL 3
183#define SYSCONRCC_PWMDIV_DIV32_VAL 4
184#define SYSCONRCC_PWMDIV_DIV64_VAL 5
185#define SYSCONRCC_PWMDIV_MSK BSP_MSK32(17, 19)
186#define SYSCONRCC_PWRDN BSP_BIT32(13)
187#define SYSCONRCC_BYPASS BSP_BIT32(11)
188#define SYSCONRCC_XTAL(val) BSP_FLD32(val, 6, 10)
189#define SYSCONRCC_XTAL_MSK BSP_MSK32(6, 10)
190#define SYSCONRCC_OSCSRC(val) BSP_FLD32(val, 4, 5)
191#define SYSCONRCC_OSCSRC_MOSC SYSCONRCC_OSCSRC(0x0)
192#define SYSCONRCC_OSCSRC_IOSC SYSCONRCC_OSCSRC(0x1)
193#define SYSCONRCC_OSCSRC_IOSC_DIV_4 SYSCONRCC_OSCSRC(0x2)
194#define SYSCONRCC_OSCSRC_30KHZ SYSCONRCC_OSCSRC(0x3)
195#define SYSCONRCC_OSCSRC_MSK BSP_MSK32(4, 5)
196#define SYSCONRCC_IOSCDIS BSP_BIT32(1)
197#define SYSCONRCC_MOSCDIS BSP_BIT32(0)
198 uint32_t rcc;
199
200#define SYSCONPLLCFG_F(val) BSP_FLD32(val, 5, 13)
201#define SYSCONPLLCFG_F_MSK BSP_MSK32(5, 13)
202#define SYSCONPLLCFG_R(val) BSP_FLD32(val, 0, 4)
203#define SYSCONPLLCFG_R_MSK BSP_MSK32(0, 4)
204 uint32_t pllcfg;
205
206 uint32_t reserved_4;
207
208#define SYSCONGPIOHBCTL_PORTH BSP_BIT32(7)
209#define SYSCONGPIOHBCTL_PORTG BSP_BIT32(6)
210#define SYSCONGPIOHBCTL_PORTF BSP_BIT32(5)
211#define SYSCONGPIOHBCTL_PORTE BSP_BIT32(4)
212#define SYSCONGPIOHBCTL_PORTD BSP_BIT32(3)
213#define SYSCONGPIOHBCTL_PORTC BSP_BIT32(2)
214#define SYSCONGPIOHBCTL_PORTB BSP_BIT32(1)
215#define SYSCONGPIOHBCTL_PORTA BSP_BIT32(0)
216 uint32_t gpiohbctl;
217
218#define SYSCONRCC2_USERCC2 BSP_BIT32(31)
219#define SYSCONRCC2_DIV400 BSP_BIT32(30)
220#define SYSCONRCC2_SYSDIV2(val) BSP_FLD32(val, 23, 28)
221#define SYSCONRCC2_SYSDIV2_MSK BSP_MSK32(23, 28)
222#define SYSCONRCC2_SYSDIV2EXT(val) BSP_FLD32(val, 22, 28)
223#define SYSCONRCC2_SYSDIV2EXT_MSK BSP_MSK32(22, 28)
224#define SYSCONRCC2_USBPWRDN BSP_BIT32(14)
225#define SYSCONRCC2_PWRDN2 BSP_BIT32(13)
226#define SYSCONRCC2_BYPASS2 BSP_BIT32(11)
227#define SYSCONRCC2_OSCSRC2(val) BSP_FLD32(val, 4, 6)
228#define SYSCONRCC2_OSCSRC2_MSK BSP_MSK32(4, 6)
229 uint32_t rcc2;
230
231 uint32_t reserved_5[2];
232
233#define SYSCONMOSCCTL_CVAL BSP_BIT32(0)
234 uint32_t moscctl;
235
236 uint32_t reserved_6[32];
237
238#define SYSCONRCGC0_PWM BSP_BIT32(20)
239#define SYSCONRCGC0_ADC BSP_BIT32(16)
240#define SYSCONRCGC0_MAXADCSPD(val) BSP_FLD32(val, 8, 9)
241#define SYSCONRCGC0_MAXADCSPD_MSK BSP_MSK32(8, 9)
242#define SYSCONRCGC0_HIB BSP_BIT32(6)
243#define SYSCONRCGC0_WDT BSP_BIT32(3)
244 uint32_t rcgc0;
245
246#define SYSCONRCGC1_COMP1 BSP_BIT32(25)
247#define SYSCONRCGC1_COMP0 BSP_BIT32(24)
248#define SYSCONRCGC1_TIMER3 BSP_BIT32(19)
249#define SYSCONRCGC1_TIMER2 BSP_BIT32(18)
250#define SYSCONRCGC1_TIMER1 BSP_BIT32(17)
251#define SYSCONRCGC1_TIMER0 BSP_BIT32(16)
252#define SYSCONRCGC1_I2C1 BSP_BIT32(14)
253#define SYSCONRCGC1_I2C0 BSP_BIT32(12)
254#define SYSCONRCGC1_QEI0 BSP_BIT32(8)
255#if LM3S69XX_NUM_SSI_BLOCKS > 1
256#define SYSCONRCGC1_SSI1 BSP_BIT32(5)
257#endif
258#define SYSCONRCGC1_SSI0 BSP_BIT32(4)
259#define SYSCONRCGC1_UART2 BSP_BIT32(2)
260#define SYSCONRCGC1_UART1 BSP_BIT32(1)
261#define SYSCONRCGC1_UART0 BSP_BIT32(0)
262 uint32_t rcgc1;
263
264#define SYSCONRCGC2_USB0 BSP_BIT32(16)
265#define SYSCONRCGC2_UDMA BSP_BIT32(13)
266#if LM3S69XX_NUM_GPIO_BLOCKS > 7
267#define SYSCONRCGC2_GPIOH BSP_BIT32(7)
268#endif
269#define SYSCONRCGC2_GPIOG BSP_BIT32(6)
270#define SYSCONRCGC2_GPIOF BSP_BIT32(5)
271#define SYSCONRCGC2_GPIOE BSP_BIT32(4)
272#define SYSCONRCGC2_GPIOD BSP_BIT32(3)
273#define SYSCONRCGC2_GPIOC BSP_BIT32(2)
274#define SYSCONRCGC2_GPIOB BSP_BIT32(1)
275#define SYSCONRCGC2_GPIOA BSP_BIT32(0)
276 uint32_t rcgc2;
277
278 uint32_t reserved_7;
279
280 uint32_t scgc0;
281 uint32_t scgc1;
282 uint32_t scgc2;
283
284 uint32_t reserved_8;
285
286 uint32_t dcgc0;
287 uint32_t dcgc1;
288 uint32_t dcgc2;
289
290 uint32_t reserved_9[6];
291
292#define SYSCONDSLPCLKCFG_DSDIVORIDE(val) BSP_FLD32(val, 23, 28)
293#define SYSCONDSLPCLKCFG_DSDIVORIDE_MSK BSP_MSK32(23, 28)
294#define SYSCONDSLPCLKCFG_DSOSCSRC(val) BSP_FLD32(val, 4, 6)
295#define SYSCONDSLPCLKCFG_DSOSCSRC_MSK BSP_MSK32(4, 6)
296 uint32_t dslpclkcfg;
298
299typedef struct {
300#define UARTDR_OE BSP_BIT32(11)
301#define UARTDR_BE BSP_BIT32(10)
302#define UARTDR_PE BSP_BIT32(9)
303#define UARTDR_FE BSP_BIT32(8)
304#define UARTDR_ERROR_MSK BSP_MSK32(8, 11)
305#define UARTDR_DATA(val) BSP_FLD32(val, 0, 7)
306#define UARTDR_DATA_GET(reg) BSP_FLD32GET(reg, 0, 7)
307 uint32_t dr;
308
309 uint32_t rsr_ecr;
310 uint32_t reserved_0[4];
311
312#define UARTFR_TXFE BSP_BIT32(7)
313#define UARTFR_RXFF BSP_BIT32(6)
314#define UARTFR_TXFF BSP_BIT32(5)
315#define UARTFR_RXFE BSP_BIT32(4)
316#define UARTFR_BUSY BSP_BIT32(3)
317 uint32_t fr;
318
319 uint32_t reserved_1;
320
321 uint32_t ilpr;
322 uint32_t ibrd;
323 uint32_t fbrd;
324
325#define UARTLCRH_SPS BSP_BIT32(7)
326#define UARTLCRH_WLEN(val) BSP_FLD32(val, 5, 6)
327#define UARTLCRH_FEN BSP_BIT32(4)
328#define UARTLCRH_STP2 BSP_BIT32(3)
329#define UARTLCRH_EPS BSP_BIT32(2)
330#define UARTLCRH_PEN BSP_BIT32(1)
331#define UARTLCRH_BRK BSP_BIT32(0)
332 uint32_t lcrh;
333
334#define UARTCTL_RXE BSP_BIT32(9)
335#define UARTCTL_TXE BSP_BIT32(8)
336#define UARTCTL_LBE BSP_BIT32(7)
337#define UARTCTL_SIRLP BSP_BIT32(2)
338#define UARTCTL_SIREN BSP_BIT32(1)
339#define UARTCTL_UARTEN BSP_BIT32(0)
340 uint32_t ctl;
341
342#define UARTIFLS_RXIFLSEL(val) BSP_FLD32(val, 3, 5)
343#define UARTIFLS_TXIFLSEL(val) BSP_FLD32(val, 0, 2)
344 uint32_t ifls;
345
346#define UARTI_OE BSP_BIT32(10)
347#define UARTI_BE BSP_BIT32(9)
348#define UARTI_PE BSP_BIT32(8)
349#define UARTI_FE BSP_BIT32(7)
350#define UARTI_RT BSP_BIT32(6)
351#define UARTI_TX BSP_BIT32(5)
352#define UARTI_RX BSP_BIT32(4)
353 uint32_t im;
354 uint32_t ris;
355 uint32_t mis;
356 uint32_t icr;
357#if LM3S69XX_HAS_UDMA
358 uint32_t dmactl;
359#endif
361
362typedef struct {
363#define SSICR0_SCR(val) BSP_FLD32(val, 8, 15)
364#define SSICR0_SPH BSP_BIT32(7)
365#define SSICR0_SPO BSP_BIT32(6)
366#define SSICR0_FRF(val) BSP_FLD32(val, 4, 5)
367#define SSICR0_DSS(val) BSP_FLD32(val, 0, 3)
368 uint32_t cr0;
369
370#define SSICR1_SOD BSP_BIT32(3)
371#define SSICR1_MS BSP_BIT32(2)
372#define SSICR1_SSE BSP_BIT32(1)
373#define SSICR1_LBM BSP_BIT32(0)
374 uint32_t cr1;
375 uint32_t dr;
376
377#define SSISR_BSY BSP_BIT32(4)
378#define SSISR_RFF BSP_BIT32(3)
379#define SSISR_RNE BSP_BIT32(2)
380#define SSISR_TNF BSP_BIT32(1)
381#define SSISR_TFE BSP_BIT32(0)
382 uint32_t sr;
383
384#define SSI_CPSRDIV(val) BSP_FLD32(val, 0, 7)
385 uint32_t cpsr;
386
387#define SSII_TX BSP_BIT32(3)
388#define SSII_RX BSP_BIT32(2)
389#define SSII_RT BSP_BIT32(1)
390#define SSII_ROR BSP_BIT32(0)
391 uint32_t im;
392 uint32_t ris;
393 uint32_t mis;
394 uint32_t icr;
395
396#if LM3S69XX_HAS_UDMA
397#define SSIDMACTL_TXDMAE BSP_BIT32(1)
398#define SSIDMACTL_RXDMAE BSP_BIT32(0)
399 uint32_t dmactl;
400#endif /* LM3S69XX_HAS_UDMA */
402
403#endif /* LIBBSP_ARM_LM3S69XX_LM3S69XX_H */
This header file provides utility macros for BSPs.
Definition: lm3s69xx.h:89
Definition: lm3s69xx.h:362
Definition: lm3s69xx.h:116
Definition: lm3s69xx.h:299
