RTEMS
7.0-rc1
libfs
src
jffs2
include
linux
kernel-rtems.h
1
2
* Copyright (C) 2013 embedded brains GmbH & Co. KG
3
* Copyright (C) 2016 Chris Johns <chrisj@rtems.org>
4
5
6
* modification, are permitted provided that the following conditions
7
* are met:
8
* 1. Redistributions of source code must retain the above copyright
9
* notice, this list of conditions and the following disclaimer.
10
* 2. Redistributions in binary form must reproduce the above copyright
11
* notice, this list of conditions and the following disclaimer in the
12
* documentation and/or other materials provided with the distribution.
13
14
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
15
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
16
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
17
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
18
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
19
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
20
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
21
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
22
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
23
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
24
* POSSIBILITY OF SUCH DAMAGE.
25
26
27
#ifndef __LINUX_RTEMS_IMPL_H__
28
#define __LINUX_RTEMS_IMPL_H__
29
30
rtems.h
31
rtems/bspIo.h
32
33
static
inline
char
*do_kmemdup(
const
char
*s,
size_t
n)
34
35
char
*dup = malloc(n + 1);
36
37
if
(dup != 0) {
38
dup[n] =
'\0'
39
dup = memcpy(dup, s, n);
40
41
42
return
dup;
43
44
45
46
* Provide a private printk to avoid all the formatting warnings in the JFFS2 code.
47
48
static
inline
int
jffs2_printk(
const
char
* fmt, ...)
49
50
va_list ap;
51
int
r;
52
va_start(ap, fmt);
53
r =
vprintk
(fmt, ap);
54
va_end(ap);
55
return
r;
56
57
58
#undef printk
59
#define printk jffs2_printk
60
61
#endif
/* __LINUX_RTEMS_IMPL_H__ */
bspIo.h
This header file provides the kernel character input/output support API.
vprintk
int vprintk(const char *fmt, va_list ap)
Outputs the characters defined by the format string and the variable argument list to the kernel char...
Definition:
vprintk.c:43
rtems.h
