RTEMS
7.0-rc1
bsps
arm
lpc176x
include
bsp
io-defs.h
1
/* SPDX-License-Identifier: GPL-2.0+-with-RTEMS-exception */
2
11
12
* Copyright (c) 2014 Taller Technologies.
13
14
* @author Boretto Martin (martin.boretto@tallertechnologies.com)
15
* @author Diaz Marcos (marcos.diaz@tallertechnologies.com)
16
* @author Lenarduzzi Federico (federico.lenarduzzi@tallertechnologies.com)
17
* @author Daniel Chicco (daniel.chicco@tallertechnologies.com)
18
19
* The license and distribution terms for this file may be
20
* found in the file LICENSE in this distribution or at
21
* http://www.rtems.org/license/LICENSE.
22
23
24
#ifndef LIBBSP_ARM_LPC176X_IO_DEFS_H
25
#define LIBBSP_ARM_LPC176X_IO_DEFS_H
26
27
bsp/lpc176x.h
28
bsp/common-types.h
29
30
#ifdef __cplusplus
31
extern
"C"
32
#endif
/* __cplusplus */
33
34
#define LPC176X_PLL0CON 0XAAU
35
#define LPC176X_PLL0CFG 0X55U
36
37
#define LPC176X_CCLK_PRESCALER_DIVISOR 1000000U
38
39
#define LPC176X_PINSEL ( &PINSEL0 )
40
#define LPC176X_PINMODE ( &PINMODE0 )
41
42
#define LPC176X_PIN_SELECT( index ) ( ( index ) >> 4U )
43
#define LPC176X_PIN_SELECT_SHIFT( index ) ( ( ( index ) & 0xFU ) << 1U )
44
#define LPC176X_PIN_SELECT_MASK 0x3U
45
#define LPC176X_PIN_SELECT_MASK_SIZE 2U
46
#define LPC176X_PIN_UART_0_TXD 2U
47
#define LPC176X_PIN_UART_0_RXD 3U
48
#define LPC176X_PIN_UART_1_TXD 15U
49
#define LPC176X_PIN_UART_1_RXD 16U
50
#define LPC176X_PIN_UART_2_TXD 10U
51
#define LPC176X_PIN_UART_2_RXD 11U
52
#define LPC176X_PIN_UART_3_TXD 0U
53
#define LPC176X_PIN_UART_3_RXD 1U
54
55
#define LPC176X_MODULE_BITS_COUNT 32U
56
#define LPC176X_MODULE_COUNT ( LPC176X_MODULE_USB + 1U )
57
58
#define LPC176X_IO_PORT_COUNT 5U
59
#define LPC176X_IO_INDEX_MAX ( LPC176X_IO_PORT_COUNT * \
60
LPC176X_MODULE_BITS_COUNT )
61
#define LPC176X_IO_INDEX_BY_PORT( port, bit ) ( ( ( port ) << 5U ) + ( bit ) )
62
#define LPC176X_IO_PORT( index ) ( ( index ) >> 5U )
63
#define LPC176X_IO_PORT_BIT( index ) ( ( index ) & 0x1FU )
64
70
typedef
enum
71
LPC176X_PIN_FUNCTION_00,
72
LPC176X_PIN_FUNCTION_01,
73
LPC176X_PIN_FUNCTION_10,
74
LPC176X_PIN_FUNCTION_11,
75
LPC176X_PIN_FUNCTION_COUNT
76
77
lpc176x_pin_function
78
83
typedef
enum
84
LPC176X_PIN_MODE_PULLUP,
85
LPC176X_PIN_MODE_REPEATER,
86
LPC176X_PIN_MODE_NONE,
87
LPC176X_PIN_MODE_PULLDOWN,
88
LPC176X_PIN_MODE_COUNT
89
90
lpc176x_pin_mode
91
97
typedef
enum
98
LPC176X_PIN_TYPE_DEFAULT,
99
LPC176X_PIN_TYPE_ADC,
100
LPC176X_PIN_TYPE_DAC,
101
LPC176X_PIN_TYPE_OPEN_DRAIN
102
lpc176x_pin_type
103
109
typedef
enum
110
LPC176X_SCB_PCLKSEL0,
111
LPC176X_SCB_PCLKSEL1,
112
LPC176X_SCB_PCLKSEL_COUNT
113
lpc176x_scb_value_pclksel
114
118
typedef
struct
122
unsigned
char
power
: 1;
126
unsigned
char
clock
: 1;
130
unsigned
char
index
: 6;
131
lpc176x_module_entry
132
133
#define LPC176X_MODULE_ENTRY( mod, pwr, clk, idx ) \
134
[ mod ] = { \
135
.power = pwr, \
136
.clock = clk, \
137
.index = idx \
138
139
140
#ifdef __cplusplus
141
142
#endif
/* __cplusplus */
143
144
#endif
/* LIBBSP_ARM_LPC176X_IO_DEFS_H */
common-types.h
Definitions types used by some devices in common.
lpc176x_pin_type
lpc176x_pin_type
Defines all type of pins.
Definition:
io-defs.h:97
Defines the functions according to the pin.
Definition:
io-defs.h:70
lpc176x_pin_mode
lpc176x_pin_mode
Defines the pin modes.
Definition:
io-defs.h:83
Represents each pclksel number.
Definition:
io-defs.h:109
lpc176x.h
Specific register definitions according to lpc176x family boards.
Defines the module entry.
Definition:
io-defs.h:118
lpc176x_module_entry::index
unsigned char index
Index entry bits.
Definition:
io-defs.h:130
lpc176x_module_entry::clock
unsigned char clock
Clock entry bit.
Definition:
io-defs.h:126
lpc176x_module_entry::power
unsigned char power
Power entry bit.
Definition:
io-defs.h:122
