RTEMS
7.0-rc1
libmisc
shell
hexdump.h
1
2
* Copyright (c) 1989, 1993
3
* The Regents of the University of California. All rights reserved.
4
5
6
* modification, are permitted provided that the following conditions
7
* are met:
8
* 1. Redistributions of source code must retain the above copyright
9
* notice, this list of conditions and the following disclaimer.
10
* 2. Redistributions in binary form must reproduce the above copyright
11
* notice, this list of conditions and the following disclaimer in the
12
* documentation and/or other materials provided with the distribution.
13
* 3. All advertising materials mentioning features or use of this software
14
* must display the following acknowledgement:
15
* This product includes software developed by the University of
16
* California, Berkeley and its contributors.
17
* 4. Neither the name of the University nor the names of its contributors
18
* may be used to endorse or promote products derived from this software
19
* without specific prior written permission.
20
21
* THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
22
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24
* ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
25
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
26
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
27
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
28
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
29
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
30
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
31
* SUCH DAMAGE.
32
33
* @(#)hexdump.h 8.1 (Berkeley) 6/6/93
34
* $FreeBSD: src/usr.bin/hexdump/hexdump.h,v 1.9 2004/07/11 01:11:12 tjr Exp $
35
36
37
#include <wchar.h>
38
39
typedef
struct
_pr
40
struct
_pr
*nextpr;
/* next print unit */
41
#define F_ADDRESS 0x001
/* print offset */
42
#define F_BPAD 0x002
/* blank pad */
43
#define F_C 0x004
/* %_c */
44
#define F_CHAR 0x008
/* %c */
45
#define F_DBL 0x010
/* %[EefGf] */
46
#define F_INT 0x020
/* %[di] */
47
#define F_P 0x040
/* %_p */
48
#define F_STR 0x080
/* %s */
49
#define F_U 0x100
/* %_u */
50
#define F_UINT 0x200
/* %[ouXx] */
51
#define F_TEXT 0x400
/* no conversions */
52
u_int flags;
/* flag values */
53
int
bcnt;
/* byte count */
54
char
*cchar;
/* conversion character */
55
char
*fmt;
/* printf format */
56
char
*nospace;
/* no whitespace version */
57
int
mbleft;
/* bytes left of multibyte char. */
58
mbstate_t mbstate;
/* conversion state */
59
PR
60
61
typedef
struct
_fu
62
struct
_fu
*nextfu;
/* next format unit */
63
struct
_pr
*nextpr;
64
#define F_IGNORE 0x01
/* %_A */
65
#define F_SETREP 0x02
/* rep count set, not default */
66
u_int flags;
/* flag values */
67
int
reps;
/* repetition count */
68
int
bcnt;
/* byte count */
69
char
*fmt;
/* format string */
70
FU
71
72
typedef
struct
_fs
/* format strings */
73
struct
_fs
*nextfs;
/* linked list of format strings */
74
struct
_fu
*nextfu;
/* linked list of format units */
75
int
bcnt;
76
FS
77
78
#if 0
79
extern
FS
*fshead;
/* head of format strings list */
80
extern
FU
*endfu;
/* format at end-of-data */
81
extern
int
blocksize;
/* data block size */
82
extern
int
exitval;
/* final exit value */
83
extern
int
odmode;
/* are we acting as od(1)? */
84
extern
int
length;
/* amount of data to read */
85
extern
off_t skip;
/* amount of data to skip at start */
86
enum
_vflag { ALL, DUP, FIRST, WAIT };
/* -v values */
87
extern
enum
_vflag vflag;
88
#endif
89
90
#include <setjmp.h>
91
93
enum
/* -v values */
94
typedef
struct
rtems_shell_hexdump_globals_t
95
FS
*fshead;
96
FU
*endfu;
97
int
blocksize;
98
int
exitval;
99
int
odmode;
100
int
length;
101
off_t skip;
102
enum
_vflag vflag;
103
104
off_t address;
105
off_t eaddress;
106
int
ateof;
107
u_char *curp;
108
u_char *savp;
109
int
done;
110
111
FILE* hdstdin;
112
113
int
exit_code;
114
jmp_buf exit_jmp;
115
116
117
#define fshead globals->fshead
118
#define endfu globals->endfu
119
#define blocksize globals->blocksize
120
#define exitval globals->exitval
121
#define odmode globals->odmode
122
#define length globals->length
123
#define skip globals->skip
124
#define vflag globals->vflag
125
126
#define address globals->address
127
#define eaddress globals->eaddress
128
#define ateof globals->ateof
129
#define curp globals->curp
130
#define savp globals->savp
131
#define done globals->done
132
133
#define hdstdin globals->hdstdin
134
135
#define exit_jump &(globals->exit_jmp)
136
137
#define add rtems_shell_hexdump_add
138
#define addfile rtems_shell_hexdump_addfile
139
#define badcnt rtems_shell_hexdump_badcnt
140
#define badconv rtems_shell_hexdump_badconv
141
#define badfmt rtems_shell_hexdump_badfmt
142
#define badsfmt rtems_shell_hexdump_badsfmt
143
#define bpad rtems_shell_hexdump_bpad
144
#define conv_c rtems_shell_hexdump_conv_c
145
#define conv_u rtems_shell_hexdump_conv_u
146
#define display rtems_shell_hexdump_display
147
#define doskip rtems_shell_hexdump_doskip
148
#define escape rtems_shell_hexdump_escape
149
#define get rtems_shell_hexdump_get
150
#define newsyntax rtems_shell_hexdump_newsyntax
151
#define next rtems_shell_hexdump_next
152
#define nomem rtems_shell_hexdump_nomem
153
#define oldsyntax rtems_shell_hexdump_oldsyntax
154
#define peek rtems_shell_hexdump_peek
155
#define rewrite rtems_shell_hexdump_rewrite
156
#define size rtems_shell_hexdump_size
157
#define usage rtems_shell_hexdump_usage
158
159
void
add(
const
char
160
void
addfile(
char
161
void
badcnt(
char
162
void
badconv(
char
163
void
badfmt(
const
char
164
void
badsfmt(
165
void
bpad(
PR
166
void
conv_c(
PR
*, u_char *,
size_t
167
void
conv_u(
PR
*, u_char *);
168
void
display(
169
void
doskip(
const
char
int
170
void
escape(
char
171
u_char *get(
172
void
newsyntax(
int
char
173
int
next(
char
174
void
nomem(
void
175
void
oldsyntax(
int
char
176
size_t
peek(
*, u_char *,
size_t
177
void
rewrite(
FS
178
int
size(
FS
179
void
usage(
180
181
#define exit(ec) rtems_shell_hexdump_exit(globals, ec)
182
183
void
* globals,
int
code);
_fs
Definition:
hexdump.h:72
_fu
Definition:
hexdump.h:61
_pr
Definition:
hexdump.h:39
Definition:
hexdump.h:94
