RTEMS
7.0-rc1
bsps
include
grlib
grcan.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
9
10
* COPYRIGHT (c) 2007.
11
* Cobham Gaisler AB.
12
13
14
* modification, are permitted provided that the following conditions
15
* are met:
16
* 1. Redistributions of source code must retain the above copyright
17
* notice, this list of conditions and the following disclaimer.
18
* 2. Redistributions in binary form must reproduce the above copyright
19
* notice, this list of conditions and the following disclaimer in the
20
* documentation and/or other materials provided with the distribution.
21
22
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
23
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
24
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
25
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
26
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
27
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
28
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
29
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
30
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
31
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
32
* POSSIBILITY OF SUCH DAMAGE.
33
34
35
#ifndef __GRCAN_H__
36
#define __GRCAN_H__
37
48
#include <stdint.h>
49
50
#ifdef __cplusplus
51
extern
"C"
52
#endif
53
54
struct
grcan_regs
55
volatile
unsigned
int
conf;
/* 0x00 */
56
volatile
unsigned
int
stat;
/* 0x04 */
57
volatile
unsigned
int
ctrl;
/* 0x08 */
58
volatile
unsigned
int
dummy0[3];
/* 0x0C-0x014 */
59
volatile
unsigned
int
smask;
/* 0x18 */
60
volatile
unsigned
int
scode;
/* 0x1C */
61
62
volatile
unsigned
int
dummy1[8];
/* 0x20-0x3C */
63
64
volatile
unsigned
int
nbtr;
/* 0x40 */
65
volatile
unsigned
int
fdbtr;
/* 0x44 */
66
volatile
unsigned
int
tdelay;
/* 0x48 */
67
68
volatile
unsigned
int
dummy1b[45];
/* 0x4C-0xFC */
69
70
volatile
unsigned
int
pimsr;
/* 0x100 */
71
volatile
unsigned
int
pimr;
/* 0x104 */
72
volatile
unsigned
int
pisr;
/* 0x108 */
73
volatile
unsigned
int
pir;
/* 0x10C */
74
volatile
unsigned
int
imr;
/* 0x110 */
75
volatile
unsigned
int
picr;
/* 0x114 */
76
77
volatile
unsigned
int
dummy2[58];
/* 0x118-0x1FC */
78
79
volatile
unsigned
int
tx0ctrl;
/* 0x200 */
80
volatile
unsigned
int
tx0addr;
/* 0x204 */
81
volatile
unsigned
int
tx0size;
/* 0x208 */
82
volatile
unsigned
int
tx0wr;
/* 0x20C */
83
volatile
unsigned
int
tx0rd;
/* 0x210 */
84
volatile
unsigned
int
tx0irq;
/* 0x214 */
85
86
volatile
unsigned
int
dummy3[58];
/* 0x218-0x2FC */
87
88
volatile
unsigned
int
rx0ctrl;
/* 0x300 */
89
volatile
unsigned
int
rx0addr;
/* 0x304 */
90
volatile
unsigned
int
rx0size;
/* 0x308 */
91
volatile
unsigned
int
rx0wr;
/* 0x30C */
92
volatile
unsigned
int
rx0rd;
/* 0x310 */
93
volatile
unsigned
int
rx0irq;
/* 0x314 */
94
volatile
unsigned
int
rx0mask;
/* 0x318 */
95
volatile
unsigned
int
rx0code;
/* 0x31C */
96
97
98
struct
grcan_stats
99
unsigned
int
passive_cnt;
100
unsigned
int
overrun_cnt;
101
unsigned
int
rxsync_cnt;
102
unsigned
int
txsync_cnt;
103
unsigned
int
txloss_cnt;
104
unsigned
int
ahberr_cnt;
105
unsigned
int
ints;
106
unsigned
int
busoff_cnt;
107
108
109
struct
grcan_timing
110
unsigned
char
scaler;
111
unsigned
char
ps1;
112
unsigned
char
ps2;
113
unsigned
char
rsj;
114
unsigned
char
bpr;
115
116
117
struct
grcanfd_timing
118
unsigned
char
scaler;
119
unsigned
char
ps1;
120
unsigned
char
ps2;
121
unsigned
char
sjw;
122
unsigned
char
resv_zero;
123
124
125
struct
grcan_selection
126
int
selection;
127
int
enable0;
128
int
enable1;
129
130
131
struct
grcan_filter
132
unsigned
long
long
mask;
133
unsigned
long
long
code;
134
135
136
#define GRCAN_FDOPT_NOM 0
137
#define GRCAN_FDOPT_FDBTR 0x01
138
#define GRCAN_FDOPT_FDFRM 0x02
139
#define GRCAN_FDMASK (GRCAN_FDOPT_FDBTR | GRCAN_FDOPT_FDFRM)
140
141
/* CAN MESSAGE */
142
typedef
struct
143
char
extended;
/* 1= Extended Frame (29-bit id), 0= STD Frame (11-bit id) */
144
char
rtr;
/* RTR - Remote Transmission Request */
145
char
unused;
/* Must be 0 to select classic CAN frame */
146
unsigned
char
len;
147
unsigned
char
data[8];
148
unsigned
int
id;
149
CANMsg
150
151
/* CAN-FD MESSAGE */
152
typedef
struct
153
uint8_t extended;
154
uint8_t rtr;
155
uint8_t fdopts;
/* Bit1: 1=Switch bit rate. bit2: 1=FD frame. */
156
uint8_t len;
/* 0-8, 12, 16, 20, 24, 32, 48 or 64 bytes */
157
uint32_t id;
158
union
159
uint64_t dwords[8];
/* up to 64 bytes if FD=1 and len>8 */
160
uint8_t bytes[64];
161
} data;
162
CANFDMsg
163
164
enum
165
GRCAN_RET_OK = 0,
166
GRCAN_RET_INVARG = -1,
167
GRCAN_RET_NOTSTARTED = -2,
168
GRCAN_RET_TIMEOUT = -3,
169
/* Bus-off condition detected (request aborted by driver) */
170
GRCAN_RET_BUSOFF = -4,
171
/* AHB error condition detected (request aborted by driver) */
172
GRCAN_RET_AHBERR = -5,
173
174
175
176
* User functions can cause these transitions:
177
* STATE_STOPPED -> STATE_STARTED
178
* STATE_STARTED -> STATE_STOPPED
179
* STATE_BUSOFF -> STATE_STOPPED
180
* STATE_AHBERR -> STATE_STOPPED
181
182
* ISR can cause these transition
183
* STATE_STARTED -> STATE_BUSOFF
184
* STATE_STARTED -> STATE_AHBERR
185
186
* STATE_BUSOFF is entered from ISR on bus-off condition. STATE_AHBERR is
187
* entered from ISR on AHB DMA errors on RX/TX operations. At transition the ISR
188
* disables DMA, masks all interrupts and releases semaphores.
189
190
enum
grcan_state {
191
STATE_STOPPED = 0,
192
STATE_STARTED = 1,
193
STATE_BUSOFF = 2,
194
STATE_AHBERR = 3,
195
196
197
#define GRCAN_CFG_ABORT 0x00000001
198
#define GRCAN_CFG_ENABLE0 0x00000002
199
#define GRCAN_CFG_ENABLE1 0x00000004
200
#define GRCAN_CFG_SELECTION 0x00000008
201
#define GRCAN_CFG_SILENT 0x00000010
202
#define GRCAN_CFG_BPR 0x00000300
203
#define GRCAN_CFG_RSJ 0x00007000
204
#define GRCAN_CFG_PS1 0x00f00000
205
#define GRCAN_CFG_PS2 0x000f0000
206
#define GRCAN_CFG_SCALER 0xff000000
207
208
#define GRCAN_CFG_BPR_BIT 8
209
#define GRCAN_CFG_RSJ_BIT 12
210
#define GRCAN_CFG_PS1_BIT 20
211
#define GRCAN_CFG_PS2_BIT 16
212
#define GRCAN_CFG_SCALER_BIT 24
213
214
#define GRCAN_CTRL_RESET 0x2
215
#define GRCAN_CTRL_ENABLE 0x1
216
217
#define GRCAN_TXCTRL_ENABLE 1
218
#define GRCAN_TXCTRL_ONGOING 1
219
220
#define GRCAN_RXCTRL_ENABLE 1
221
#define GRCAN_RXCTRL_ONGOING 1
222
223
#define GRCANFD_NBTR_SCALER 0x00ff0000
224
#define GRCANFD_NBTR_PS1 0x0000fc00
225
#define GRCANFD_NBTR_PS2 0x000003e0
226
#define GRCANFD_NBTR_SJW 0x0000001f
227
228
#define GRCANFD_NBTR_SCALER_BIT 16
229
#define GRCANFD_NBTR_PS1_BIT 10
230
#define GRCANFD_NBTR_PS2_BIT 5
231
#define GRCANFD_NBTR_SJW_BIT 0
232
233
#define GRCANFD_FDBTR_SCALER 0x00ff0000
234
#define GRCANFD_FDBTR_PS1 0x00003c00
235
#define GRCANFD_FDBTR_PS2 0x000001e0
236
#define GRCANFD_FDBTR_SJW 0x0000000f
237
238
#define GRCANFD_FDBTR_SCALER_BIT 16
239
#define GRCANFD_FDBTR_PS1_BIT 10
240
#define GRCANFD_FDBTR_PS2_BIT 5
241
#define GRCANFD_FDBTR_SJW_BIT 0
242
243
/* Relative offset of IRQ sources to AMBA Plug&Play */
244
#define GRCAN_IRQ_IRQ 0
245
#define GRCAN_IRQ_TXSYNC 1
246
#define GRCAN_IRQ_RXSYNC 2
247
248
#define GRCAN_ERR_IRQ 0x1
249
#define GRCAN_OFF_IRQ 0x2
250
#define GRCAN_OR_IRQ 0x4
251
#define GRCAN_RXAHBERR_IRQ 0x8
252
#define GRCAN_TXAHBERR_IRQ 0x10
253
#define GRCAN_RXIRQ_IRQ 0x20
254
#define GRCAN_TXIRQ_IRQ 0x40
255
#define GRCAN_RXFULL_IRQ 0x80
256
#define GRCAN_TXEMPTY_IRQ 0x100
257
#define GRCAN_RX_IRQ 0x200
258
#define GRCAN_TX_IRQ 0x400
259
#define GRCAN_RXSYNC_IRQ 0x800
260
#define GRCAN_TXSYNC_IRQ 0x1000
261
#define GRCAN_RXERR_IRQ 0x2000
262
#define GRCAN_TXERR_IRQ 0x4000
263
#define GRCAN_RXMISS_IRQ 0x8000
264
#define GRCAN_TXLOSS_IRQ 0x10000
265
266
#define GRCAN_STAT_PASS 0x1
267
#define GRCAN_STAT_OFF 0x2
268
#define GRCAN_STAT_OR 0x4
269
#define GRCAN_STAT_AHBERR 0x8
270
#define GRCAN_STAT_ACTIVE 0x10
271
#define GRCAN_STAT_RXERRCNT 0xff00
272
#define GRCAN_STAT_TXERRCNT 0xff0000
273
274
275
* Return number of GRCAN devices available to driver
276
277
extern
int
grcan_dev_count(
void
278
279
280
* Open a GRCAN device
281
282
* dev_no: Device number to open
283
* return: Device handle to use with all other grcan_ API functions. The
284
* function returns NULL if device can not be opened.
285
286
extern
void
*grcan_open(
int
dev_no);
287
288
289
* Open a GRCAN device by name. Finds device index then calls
290
* grcan_open(index).
291
292
* name: Device name to open
293
* dev_no: Device number matching name. Will be set if device found.
294
295
* function returns NULL if device can not be opened or not found.
296
297
extern
void
*grcan_open_by_name(
char
*name,
int
*dev_no);
298
299
300
* Close a GRCAN device
301
302
* return: This function always returns 0 (success)
303
304
extern
int
grcan_close(
void
*d);
305
306
307
* Returns if CAN hardware device is CANFD capable.
308
309
* dev_no: Device handle
310
* return: 0=Not FD capable, 1=FD capable.
311
312
313
extern
int
grcan_canfd_capable(
void
*d);
314
315
316
* Receive CAN messages
317
318
* Multiple CAN messages can be received in one call.
319
320
* d: Device handle
321
* msg: Pointer to receive messages
322
* count: Number of CAN messages to receive
323
324
* return:
325
* >=0: Number of CAN messages received. This can be
326
* less than the count parameter.
327
* GRCAN_RET_INVARG: count parameter less than one or NULL msg.
328
* GRCAN_RET_NOTSTARTED: Device not in started mode
329
* GRCAN_RET_TIMEOUT: Timeout in non-blocking mode
330
* GRCAN_RET_BUSOFF: A read was interrupted by a bus-off error.
331
* Device has left started mode.
332
* GRCAN_RET_AHBERR: Similar to BUSOFF, but was caused by AHB Error.
333
334
extern
int
grcan_read(
335
void
*d,
336
CANMsg
msg
337
size_t
count
338
339
340
341
* Receive CAN messages (only GRCANFD)
342
343
344
345
* d: Device handle
346
347
348
349
* return:
350
351
352
353
354
355
356
357
358
359
extern
int
grcanfd_read(
360
void
*d,
361
CANFDMsg
msg
362
size_t
count
363
364
365
366
* Transmit CAN messages
367
368
* Multiple CAN messages can be transmit in one call.
369
370
* d: Device handle
371
* msg: Pointer to messages to transmit
372
* count: Number of CAN messages to transmit
373
374
* return:
375
* >=0: Number of CAN messages transmitted. This can be
376
377
* GRCAN_RET_INVARG: count parameter less than one.
378
379
380
* GRCAN_RET_BUSOFF: A write was interrupted by a Bus-off error.
381
382
383
384
extern
int
grcan_write(
385
void
*d,
386
CANMsg
msg
387
size_t
count
388
389
390
391
* Transmit CAN-FD complient messages (only GRCANFD)
392
393
394
395
* d: Device handle
396
397
398
399
* return:
400
401
402
403
404
405
406
407
408
409
extern
int
grcanfd_write(
410
void
*d,
411
CANFDMsg
msg
412
size_t
ucount
413
414
415
416
* Returns current GRCAN software state
417
418
* If STATE_BUSOFF or STATE_AHBERR is returned then the function grcan_stop()
419
* shall be called before continue using the driver.
420
421
* d: Device handle
422
* return:
423
* STATE_STOPPED Stopped
424
* STATE_STARTED Started
425
* STATE_BUSOFF Bus-off has been detected
426
* STATE_AHBERR AHB error has been detected
427
428
extern
int
grcan_get_state(
void
*d);
429
430
/* The remaining functions return 0 on success and non-zero on failure. */
431
432
/* Functions controlling operational
433
* mode
434
435
/* Bring the link up after open or bus-off */
436
extern
int
grcan_start(
void
*d);
437
/* stop to change baud rate/config or closing down */
438
extern
int
grcan_stop(
void
*d);
439
/* Wait until all TX messages have been sent */
440
extern
int
grcan_flush(
void
*d);
441
442
/* Functions that require connection
443
* to be stopped
444
445
/* enable silent mode read only state */
446
extern
int
grcan_set_silent(
void
*d,
int
silent);
447
/* enable/disable stopping link on AHB Error */
448
extern
int
grcan_set_abort(
void
*d,
int
abort);
449
/* Set Enable0,Enable1,Selection */
450
extern
int
grcan_set_selection(
void
*d,
const
struct
grcan_selection
*selection);
451
/* Set baudrate by using driver's baud rate timing calculation routines */
452
extern
int
grcan_set_speed(
void
*d,
unsigned
int
hz);
453
/* Set baudrate by specifying the timing registers manually */
454
extern
int
grcan_set_btrs(
void
*d,
const
struct
grcan_timing
*timing);
455
456
/* Set the Nominal and FD baudrate by using driver's baud rate timing
457
* calculation routines
458
459
extern
int
grcanfd_set_speed(
void
*d,
unsigned
int
nomhz,
unsigned
int
fdhz);
460
/* Set Nominal and FD baudrate by specifying the timing registers manually*/
461
extern
int
grcanfd_set_btrs(
462
void
*d,
463
const
struct
grcanfd_timing
*nominal,
464
const
struct
grcanfd_timing
*fd);
465
466
/* Functions can be called whenever */
467
/* Enable/disable Blocking on reception (until at least one message has been received) */
468
int
grcan_set_rxblock(
void
* d,
int
block);
469
/* Enable/disable Blocking on transmission (until at least one message has been transmitted) */
470
int
grcan_set_txblock(
void
* d,
int
block);
471
/* Enable/disable Blocking until all requested messages has been sent */
472
int
grcan_set_txcomplete(
void
* d,
int
complete);
473
/* Enable/disable Blocking until all requested has been received */
474
int
grcan_set_rxcomplete(
void
* d,
int
complete);
475
/* Get statistics */
476
extern
int
grcan_get_stats(
void
*d,
struct
grcan_stats
*stats);
477
/* Clear statistics */
478
extern
int
grcan_clr_stats(
void
*d);
479
/* Set Acceptance filters, provide pointer to "struct grcan_filter" or NULL to disable filtering (let all messages pass) */
480
extern
int
grcan_set_afilter(
void
*d,
const
struct
grcan_filter
*filter);
481
/* Set Sync Messages RX/TX filters, NULL disables the IRQ completely */
482
extern
int
grcan_set_sfilter(
void
*d,
const
struct
grcan_filter
*filter);
483
/* Get status register of GRCAN core */
484
extern
int
grcan_get_status(
void
*d,
unsigned
int
*status);
485
486
void
grcan_register_drv(
void
487
488
#ifdef __cplusplus
489
490
#endif
491
494
#endif
CANFDMsg
Definition:
grcan.h:152
CANMsg
Definition:
grcan.h:142
grcan_filter
Definition:
grcan.h:131
grcan_regs
Definition:
grcan.h:54
grcan_selection
Definition:
grcan.h:125
grcan_stats
Definition:
grcan.h:98
grcan_timing
Definition:
grcan.h:109
grcanfd_timing
Definition:
grcan.h:117
msg
Definition:
b1553brm.c:94
