9#ifndef _FSL_SMARTCARD_PHY_H_
10#define _FSL_SMARTCARD_PHY_H_
12#include "fsl_smartcard.h"
26#define SMARTCARD_ATR_DURATION_ADJUSTMENT (360u)
31#define SMARTCARD_INIT_DELAY_CLOCK_CYCLES_ADJUSTMENT (4200u)
37#if defined(__cplusplus)
116#if defined(USING_PHY_TDA8035)
121#if defined(__cplusplus)
int32_t status_t
Type used for all status and error return values.
Definition: fsl_common.h:225
status_t SMARTCARD_PHY_Control(void *base, smartcard_context_t *context, smartcard_interface_control_t control, uint32_t param)
Controls the Smart card interface IC.
Definition: fsl_smartcard_phy_emvsim.c:192
void SMARTCARD_PHY_GetDefaultConfig(smartcard_interface_config_t *config)
Fills in the configuration structure with default values.
Definition: fsl_smartcard_phy_emvsim.c:54
void SMARTCARD_PHY_Deinit(void *base, smartcard_interface_config_t const *config)
De-initializes a Smart card interface, stops the Smart card clock, and disables the VCC.
Definition: fsl_smartcard_phy_emvsim.c:91
status_t SMARTCARD_PHY_Deactivate(void *base, smartcard_context_t *context)
De-activates the Smart card IC.
Definition: fsl_smartcard_phy_emvsim.c:166
status_t SMARTCARD_PHY_Activate(void *base, smartcard_context_t *context, smartcard_reset_type_t resetType)
Activates the Smart card IC.
Definition: fsl_smartcard_phy_emvsim.c:98
status_t SMARTCARD_PHY_Init(void *base, smartcard_interface_config_t const *config, uint32_t srcClock_Hz)
Initializes a Smart card interface instance.
Definition: fsl_smartcard_phy_emvsim.c:65
enum _smartcard_interface_control smartcard_interface_control_t
Defines Smart card interface IC control types.
enum _smartcard_reset_type smartcard_reset_type_t
Defines Smart card reset types.
Runtime state of the Smart card driver.
Definition: fsl_smartcard.h:239
Defines user specified configuration of Smart card interface.
Definition: fsl_smartcard.h:204
Definition: intercom.c:87
