12#include "fsl_common.h"
26#define FSL_PGMC_RIVER_VERSION (MAKE_VERSION(2, 1, 1))
91 kPGMC_DisableLowPowerControl = 0UL,
92 kPGMC_ControlledByCpuPowerMode = 1UL,
93 kPGMC_ControlledBySetPoint = 2UL,
164#if defined(__cplusplus)
199 uint32_t setPointMap,
219static inline void PGMC_BPC_DisableLowPower(
PGMC_BPC_Type *base)
229static inline void PGMC_BPC_RequestStateRestoreAtRunMode(
231 base->BPC_SSAR_RESTORE_CTRL |= PGMC_BPC_BPC_SSAR_RESTORE_CTRL_RESTORE_AT_RUN_MASK;
241static inline void PGMC_BPC_RequestStateRestoreAtSetPoint(
PGMC_BPC_Type *base, uint32_t setPointMap)
256static inline void PGMC_BPC_AllowUserModeAccess(
bool enable)
260 base->BPC_AUTHEN_CTRL |= PGMC_BPC_BPC_AUTHEN_CTRL_USER_MASK;
264 base->BPC_AUTHEN_CTRL &= ~PGMC_BPC_BPC_AUTHEN_CTRL_USER_MASK;
278static inline void PGMC_BPC_AllowNonSecureModeAccess(
bool enable)
282 base->BPC_AUTHEN_CTRL |= PGMC_BPC_BPC_AUTHEN_CTRL_NONSECURE_MASK;
286 base->BPC_AUTHEN_CTRL &= ~PGMC_BPC_BPC_AUTHEN_CTRL_NONSECURE_MASK;
298static inline void PGMC_BPC_LockAccessSetting(
300 base->BPC_AUTHEN_CTRL |= PGMC_BPC_BPC_AUTHEN_CTRL_LOCK_SETTING_MASK;
311static inline void PGMC_BPC_SetDomainIdWhiteList(
PGMC_BPC_Type *base, uint8_t domainId)
313 base->BPC_AUTHEN_CTRL = (base->BPC_AUTHEN_CTRL & (~PGMC_BPC_BPC_AUTHEN_CTRL_WHITE_LIST_MASK)) |
324static inline void PGMC_BPC_LockDomainIDWhiteList(
326 base->BPC_AUTHEN_CTRL |= PGMC_BPC_BPC_AUTHEN_CTRL_LOCK_LIST_MASK;
336static inline void PGMC_BPC_LockLowPowerConfigurationFields(
338 base->BPC_AUTHEN_CTRL |= PGMC_BPC_BPC_AUTHEN_CTRL_LOCK_CFG_MASK;
366static inline void PGMC_CPC_CORE_PowerOffBySoftwareMode(
PGMC_CPC_Type *base,
bool powerOff)
370 base->CPC_CORE_POWER_CTRL |=
371 (PGMC_CPC_CPC_CORE_POWER_CTRL_PSW_OFF_SOFT_MASK | PGMC_CPC_CPC_CORE_POWER_CTRL_ISO_ON_SOFT_MASK);
375 base->CPC_CORE_POWER_CTRL |=
376 (PGMC_CPC_CPC_CORE_POWER_CTRL_ISO_OFF_SOFT_MASK | PGMC_CPC_CPC_CORE_POWER_CTRL_PSW_ON_SOFT_MASK);
385static inline void PGMC_CPC_CORE_DisableLowPower(
PGMC_CPC_Type *base)
415 uint32_t setPointMap,
423static inline void PGMC_CPC_CACHE_DisableLowPower(
462 uint32_t setPointMap,
470static inline void PGMC_CPC_LMEM_DisableLowPower(
494static inline void PGMC_CPC_AllowUserModeAccess(
bool enable)
498 base->CPC_AUTHEN_CTRL |= PGMC_CPC_CPC_AUTHEN_CTRL_USER_MASK;
502 base->CPC_AUTHEN_CTRL &= ~PGMC_CPC_CPC_AUTHEN_CTRL_USER_MASK;
516static inline void PGMC_CPC_AllowNonSecureModeAccess(
bool enable)
520 base->CPC_AUTHEN_CTRL |= PGMC_CPC_CPC_AUTHEN_CTRL_NONSECURE_MASK;
524 base->CPC_AUTHEN_CTRL &= ~PGMC_CPC_CPC_AUTHEN_CTRL_NONSECURE_MASK;
536static inline void PGMC_CPC_LockAccessSetting(
538 base->CPC_AUTHEN_CTRL |= PGMC_CPC_CPC_AUTHEN_CTRL_LOCK_SETTING_MASK;
549static inline void PGMC_CPC_SetDomainIdWhiteList(
PGMC_CPC_Type *base, uint8_t domainId)
551 base->CPC_AUTHEN_CTRL = (base->CPC_AUTHEN_CTRL & (~PGMC_CPC_CPC_AUTHEN_CTRL_WHITE_LIST_MASK)) |
562static inline void PGMC_CPC_LockDomainIDWhiteList(
564 base->CPC_AUTHEN_CTRL |= PGMC_CPC_CPC_AUTHEN_CTRL_LOCK_LIST_MASK;
574static inline void PGMC_CPC_LockLowPowerConfigurationFields(
576 base->CPC_AUTHEN_CTRL |= PGMC_CPC_CPC_AUTHEN_CTRL_LOCK_CFG_MASK;
614static inline void PGMC_MIF_LockLowPowerConfigurationFields(
PGMC_MIF_Type *base)
616 base->MIF_AUTHEN_CTRL |= PGMC_MIF_MIF_AUTHEN_CTRL_LOCK_CFG_MASK;
634static inline void PGMC_PPC_TriggerPMICStandbySoftMode(
PGMC_PPC_Type *base,
bool enable)
641 PGMC_PPC0->PPC_STBY_CM_CTRL |= PGMC_PPC_PPC_STBY_CM_CTRL_STBY_ON_SOFT_MASK;
645 PGMC_PPC0->PPC_STBY_CM_CTRL |= PGMC_PPC_PPC_STBY_CM_CTRL_STBY_OFF_SOFT_MASK;
676static inline void PGMC_PPC_DisableLowPower(
PGMC_PPC_Type *base)
691static inline void PGMC_PPC_AllowUserModeAccess(
bool enable)
695 base->PPC_AUTHEN_CTRL |= PGMC_PPC_PPC_AUTHEN_CTRL_USER_MASK;
699 base->PPC_AUTHEN_CTRL &= ~PGMC_PPC_PPC_AUTHEN_CTRL_USER_MASK;
713static inline void PGMC_PPC_AllowNonSecureModeAccess(
bool enable)
717 base->PPC_AUTHEN_CTRL |= PGMC_PPC_PPC_AUTHEN_CTRL_NONSECURE_MASK;
721 base->PPC_AUTHEN_CTRL &= ~PGMC_PPC_PPC_AUTHEN_CTRL_NONSECURE_MASK;
733static inline void PGMC_PPC_LockAccessSetting(
735 base->PPC_AUTHEN_CTRL |= PGMC_PPC_PPC_AUTHEN_CTRL_LOCK_SETTING_MASK;
746static inline void PGMC_PPC_SetDomainIdWhiteList(
PGMC_PPC_Type *base, uint8_t domainId)
748 base->PPC_AUTHEN_CTRL = (base->PPC_AUTHEN_CTRL & (~PGMC_PPC_PPC_AUTHEN_CTRL_WHITE_LIST_MASK)) |
759static inline void PGMC_PPC_LockDomainIDWhiteList(
761 base->PPC_AUTHEN_CTRL |= PGMC_PPC_PPC_AUTHEN_CTRL_LOCK_LIST_MASK;
771static inline void PGMC_PPC_LockLowPowerConfigurationFields(
773 base->PPC_AUTHEN_CTRL |= PGMC_PPC_PPC_AUTHEN_CTRL_LOCK_CFG_MASK;
780#if defined(__cplusplus)
#define PGMC_BPC_BPC_MODE_CTRL_MODE(x)
Definition: MIMXRT1166_cm4.h:66628
#define PGMC_BPC_BPC_AUTHEN_CTRL_WHITE_LIST(x)
Definition: MIMXRT1166_cm4.h:66602
#define PGMC_BPC_BPC_SSAR_RESTORE_CTRL_RESTORE_AT_SP(x)
Definition: MIMXRT1166_cm4.h:66750
#define PGMC_CPC_CPC_CORE_MODE_CTRL_MODE(x)
Definition: MIMXRT1166_cm4.h:66892
#define PGMC_CPC_CPC_LMEM_MODE_CTRL_MODE(x)
Definition: MIMXRT1166_cm4.h:67114
#define PGMC_CPC_CPC_CACHE_MODE_CTRL_MODE(x)
Definition: MIMXRT1166_cm4.h:66962
#define PGMC_CPC_CPC_AUTHEN_CTRL_WHITE_LIST(x)
Definition: MIMXRT1166_cm4.h:66866
#define PGMC_PPC0
Definition: MIMXRT1166_cm4.h:67614
#define PGMC_PPC_PPC_AUTHEN_CTRL_WHITE_LIST(x)
Definition: MIMXRT1166_cm4.h:67514
#define PGMC_PPC_PPC_MODE_CTRL_MODE(x)
Definition: MIMXRT1166_cm4.h:67540
enum _pgmc_mif_signal pgmc_mif_signal_t
The enumeration of MIF signal.
void PGMC_BPC_ControlPowerDomainBySetPointMode(PGMC_BPC_Type *base, uint32_t setPointMap, const pgmc_bpc_setpoint_mode_option_t *option)
Makes the BPC module controlled by the target set points.
Definition: fsl_pgmc.c:106
_pgmc_control_mode
PGMC control modes.
Definition: fsl_pgmc.h:90
_pgmc_cpu_mode
CPU mode.
Definition: fsl_pgmc.h:81
enum _pgmc_memory_low_power_level pgmc_memory_low_power_level_t
The enumeration of memory low power level.
void PGMC_CPC_CACHE_ControlByCpuPowerMode(PGMC_CPC_Type *base, pgmc_cpu_mode_t mode, pgmc_memory_low_power_level_t memoryLowPowerLevel)
Makes the CPC CACHE module controlled by the target CPU power mode, such as Wait mode.
Definition: fsl_pgmc.c:185
void PGMC_PPC_ControlByCpuPowerMode(PGMC_PPC_Type *base, pgmc_cpu_mode_t mode)
Makes the PMIC module controlled by the target CPU power mode, such as Wait mode.
Definition: fsl_pgmc.c:413
void PGMC_CPC_LMEM_ControlBySetPointMode(PGMC_CPC_Type *base, uint32_t setPointMap, pgmc_memory_low_power_level_t memoryLowPowerLevel)
Makes the CPC LMEM module controlled by the target set points.
Definition: fsl_pgmc.c:328
_pgmc_bpc_assign_domain
PGMC BPC assign domain enumeration.
Definition: fsl_pgmc.h:74
enum _pgmc_control_mode pgmc_control_mode_t
PGMC control modes.
void PGMC_CPC_CACHE_ControlBySetPointMode(PGMC_CPC_Type *base, uint32_t setPointMap, pgmc_memory_low_power_level_t memoryLowPowerLevel)
Makes the CPC CACHE module controlled by the target set points.
Definition: fsl_pgmc.c:228
void PGMC_MIF_SetSignalBehaviour(PGMC_MIF_Type *base, pgmc_memory_low_power_level_t memoryLevel, uint32_t mask)
Sets the behaviour of each signal in MIF, such as Sleep signal.
Definition: fsl_pgmc.c:392
_pgmc_mif_signal
Definition: fsl_pgmc.h:119
void PGMC_CPC_LMEM_ControlByCpuPowerMode(PGMC_CPC_Type *base, pgmc_cpu_mode_t mode, pgmc_memory_low_power_level_t memoryLowPowerLevel)
Makes the CPC LMEM module controlled by the target CPU power mode, such as Wait mode.
Definition: fsl_pgmc.c:284
void PGMC_CPC_CACHE_TriggerMLPLSoftwareChange(PGMC_CPC_Type *base)
Requests CPC cache module's memory low power level change by software mode.
Definition: fsl_pgmc.c:265
Definition: fsl_pgmc.h:100
_pgmc_mif_signal_behaviour
The enumeration of MIF signal behaviour(Such as Sleep Signal, Standby Signal, and so on).
Definition: fsl_pgmc.h:56
struct _pgmc_bpc_cpu_power_mode_option pgmc_bpc_cpu_power_mode_option_t
The control option of the power domain controlled by CPU power mode.
void PGMC_PPC_ControlBySetPointMode(PGMC_PPC_Type *base, uint32_t setPointMap, bool enableStandby)
Makes the PMIC module controlled by the target set points.
Definition: fsl_pgmc.c:447
void PGMC_BPC_ControlPowerDomainBySoftwareMode(PGMC_BPC_Type *base, bool powerOff)
Controls the selected power domain by software mode.
Definition: fsl_pgmc.c:136
enum _pgmc_cpu_mode pgmc_cpu_mode_t
CPU mode.
void PGMC_BPC_ControlPowerDomainByCpuPowerMode(PGMC_BPC_Type *base, pgmc_cpu_mode_t mode, const pgmc_bpc_cpu_power_mode_option_t *option)
Makes the BPC module controlled by the target CPU power mode, such as Wait mode.
Definition: fsl_pgmc.c:48
enum _pgmc_bpc_assign_domain pgmc_bpc_assign_domain_t
void PGMC_CPC_CORE_PowerOffByCpuPowerMode(PGMC_CPC_Type *base, pgmc_cpu_mode_t mode)
Powers off the CPC core module by the target CPU power mode, such as Wait mode.
Definition: fsl_pgmc.c:154
struct _pgmc_bpc_setpoint_mode_option pgmc_bpc_setpoint_mode_option_t
The control option of the power domain controlled by setpoint mode.
void PGMC_CPC_LMEM_TriggerMLPLSoftwareChange(PGMC_CPC_Type *base)
Requests CPC LMEM module's memory low power level change in software mode.
Definition: fsl_pgmc.c:365
@ kPGMC_StopMode
Definition: fsl_pgmc.h:84
@ kPGMC_WaitMode
Definition: fsl_pgmc.h:83
@ kPGMC_RunMode
Definition: fsl_pgmc.h:82
@ kPGMC_SuspendMode
Definition: fsl_pgmc.h:85
@ kPGMC_CM4Core
Definition: fsl_pgmc.h:76
@ kPGMC_CM7Core
Definition: fsl_pgmc.h:75
@ kPGMC_PeripheralPowerDownSignal
Definition: fsl_pgmc.h:126
@ kPGMC_Switch2OffSignal
Definition: fsl_pgmc.h:129
@ kPGMC_InitnSignal
Definition: fsl_pgmc.h:127
@ kPGMC_HighSpeedSignal
Definition: fsl_pgmc.h:123
@ kPGMC_StandbySignal
Definition: fsl_pgmc.h:124
@ kPGMC_ArrayPowerDownSignal
Definition: fsl_pgmc.h:125
@ kPGMC_Switch1OffSignal
Definition: fsl_pgmc.h:128
@ kPGMC_InputGateSignal
Definition: fsl_pgmc.h:121
@ kPGMC_IsoSignal
Definition: fsl_pgmc.h:130
@ kPGMC_LowSpeedSignal
Definition: fsl_pgmc.h:122
@ kPGMC_SleepSignal
Definition: fsl_pgmc.h:120
@ kPGMC_MLPLArrOffPerOn
Definition: fsl_pgmc.h:108
@ kPGMC_MLPLInputGating
Definition: fsl_pgmc.h:104
@ kPGMC_MLPLArrOffPerOff
Definition: fsl_pgmc.h:109
@ kPGMC_MLPLArrOnPerOff
Definition: fsl_pgmc.h:107
@ kPGMC_MLPLNormal
Definition: fsl_pgmc.h:102
@ kPGMC_MLPLSw2PerOff
Definition: fsl_pgmc.h:111
@ kPGMC_MLPLSleep
Definition: fsl_pgmc.h:106
@ kPGMC_MLPLLowSpeed
Definition: fsl_pgmc.h:103
@ kPGMC_MLPLStandby
Definition: fsl_pgmc.h:105
@ kPGMC_MLPLSw1PerOff
Definition: fsl_pgmc.h:112
@ kPGMC_MLPLHighSpeed
Definition: fsl_pgmc.h:101
@ kPGMC_MLPLSw2
Definition: fsl_pgmc.h:110
@ kPGMC_AssertStandbySignal
Definition: fsl_pgmc.h:61
@ kPGMC_AssertSwitch2OffSignal
Definition: fsl_pgmc.h:66
@ kPGMC_AssetLowSpeedSignal
Definition: fsl_pgmc.h:59
@ kPGMC_AssertIsoSignal
Definition: fsl_pgmc.h:67
@ kPGMC_AssertPeripheralPowerDownSignal
Definition: fsl_pgmc.h:63
@ kPGMC_AssertSwitch1OffSignal
Definition: fsl_pgmc.h:65
@ kPGMC_AssertHighSpeedSignal
Definition: fsl_pgmc.h:60
@ kPGMC_AssertInitnSignal
Definition: fsl_pgmc.h:64
@ kPGMC_AssertInputGateSignal
Definition: fsl_pgmc.h:58
@ kPGMC_AssertArrayPowerDownSignal
Definition: fsl_pgmc.h:62
@ kPGMC_AssertSleepSignal
Definition: fsl_pgmc.h:57
@ kPGMC_SetPoint9
Definition: fsl_pgmc.h:43
@ kPGMC_SetPoint2
Definition: fsl_pgmc.h:36
@ kPGMC_SetPoint7
Definition: fsl_pgmc.h:41
@ kPGMC_SetPoint4
Definition: fsl_pgmc.h:38
@ kPGMC_SetPoint8
Definition: fsl_pgmc.h:42
@ kPGMC_SetPoint11
Definition: fsl_pgmc.h:45
@ kPGMC_SetPoint10
Definition: fsl_pgmc.h:44
@ kPGMC_SetPoint13
Definition: fsl_pgmc.h:47
@ kPGMC_SetPoint0
Definition: fsl_pgmc.h:34
@ kPGMC_SetPoint14
Definition: fsl_pgmc.h:48
@ kPGMC_SetPoint5
Definition: fsl_pgmc.h:39
@ kPGMC_SetPoint15
Definition: fsl_pgmc.h:49
@ kPGMC_SetPoint3
Definition: fsl_pgmc.h:37
@ kPGMC_SetPoint1
Definition: fsl_pgmc.h:35
@ kPGMC_SetPoint6
Definition: fsl_pgmc.h:40
@ kPGMC_SetPoint12
Definition: fsl_pgmc.h:46
Definition: MIMXRT1166_cm4.h:66551
Definition: MIMXRT1166_cm4.h:66812
Definition: MIMXRT1166_cm4.h:67290
Definition: MIMXRT1166_cm4.h:67471
Definition: fsl_pgmc.h:137
bool stateSave
Definition: fsl_pgmc.h:140
pgmc_bpc_assign_domain_t assignDomain
Definition: fsl_pgmc.h:138
bool powerOff
Definition: fsl_pgmc.h:143
Definition: fsl_pgmc.h:152
bool powerOff
Definition: fsl_pgmc.h:156
bool stateSave
Definition: fsl_pgmc.h:153
