9#ifndef _FSL_PDM_SDMA_H_
10#define _FSL_PDM_SDMA_H_
27#define FSL_PDM_SDMA_DRIVER_VERSION (MAKE_VERSION(2, 7, 0))
58#if defined(__cplusplus)
84 sdma_handle_t *dmaHandle,
85 uint32_t eventSource);
133#if defined(__cplusplus)
int32_t status_t
Type used for all status and error return values.
Definition: fsl_common.h:225
#define PDM_XFER_QUEUE_SIZE
PDM XFER QUEUE SIZE.
Definition: fsl_pdm.h:29
void PDM_TransferCreateHandleSDMA(PDM_Type *base, pdm_sdma_handle_t *handle, pdm_sdma_callback_t callback, void *userData, sdma_handle_t *dmaHandle, uint32_t eventSource)
Initializes the PDM eDMA handle.
void PDM_TransferTerminateReceiveSDMA(PDM_Type *base, pdm_sdma_handle_t *handle)
Terminate all the PDM sdma receive transfer.
void PDM_TransferAbortReceiveSDMA(PDM_Type *base, pdm_sdma_handle_t *handle)
Aborts a PDM receive using eDMA.
status_t PDM_TransferReceiveSDMA(PDM_Type *base, pdm_sdma_handle_t *handle, pdm_transfer_t *xfer)
Performs a non-blocking PDM receive using eDMA.
void PDM_SetChannelConfigSDMA(PDM_Type *base, pdm_sdma_handle_t *handle, uint32_t channel, const pdm_channel_config_t *config)
PDM channel configurations.
void(* pdm_sdma_callback_t)(PDM_Type *base, pdm_sdma_handle_t *handle, status_t status, void *userData)
PDM eDMA transfer callback function for finish and error.
Definition: fsl_pdm_sdma.h:33
Definition: MIMXRT1166_cm4.h:65557
Definition: fsl_pdm.h:250
PDM DMA transfer handle, users should not touch the content of the handle.
Definition: fsl_pdm_sdma.h:37
volatile uint8_t queueUser
Definition: fsl_pdm_sdma.h:51
Definition: fsl_pdm_sdma.h:46
uint8_t nbytes
Definition: fsl_pdm_sdma.h:39
uint32_t state
Definition: fsl_pdm_sdma.h:44
volatile uint8_t queueDriver
Definition: fsl_pdm_sdma.h:52
sdma_handle_t * dmaHandle
Definition: fsl_pdm_sdma.h:38
uint8_t endChannel
Definition: fsl_pdm_sdma.h:41
pdm_transfer_t pdmQueue[PDM_XFER_QUEUE_SIZE]
Definition: fsl_pdm_sdma.h:49
uint32_t count
Definition: fsl_pdm_sdma.h:43
uint8_t fifoWidth
Definition: fsl_pdm_sdma.h:40
Definition: fsl_pdm_sdma.h:45
sdma_buffer_descriptor_t bdPool[PDM_XFER_QUEUE_SIZE]
Definition: fsl_pdm_sdma.h:48
void * userData
Definition: fsl_pdm_sdma.h:47
size_t transferSize[PDM_XFER_QUEUE_SIZE]
Definition: fsl_pdm_sdma.h:50
uint8_t channelNums
Definition: fsl_pdm_sdma.h:42
PDM SDMA transfer structure.
Definition: fsl_pdm.h:349
