RTEMS 7.0-rc1
fsl-mpc567x.h
1/*
2 * Modifications of the original file provided by Freescale are:
3 *
4 * Copyright (c) 2011 embedded brains GmbH & Co. KG
5 *
6 * Redistribution and use in source and binary forms, with or without
7 * modification, are permitted provided that the following conditions
8 * are met:
9 * 1. Redistributions of source code must retain the above copyright
10 * notice, this list of conditions and the following disclaimer.
11 * 2. Redistributions in binary form must reproduce the above copyright
12 * notice, this list of conditions and the following disclaimer in the
13 * documentation and/or other materials provided with the distribution.
14 *
15 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
16 * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
17 * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
18 * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
19 * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
20 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
21 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
22 * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
23 * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
24 * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
25 * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
26 */
27
28/**************************************************************************/
29/* FILE NAME: mpc5674f.h COPYRIGHT (c) Freescale 2009 */
30/* VERSION: 1.04 All Rights Reserved */
31/* */
32/* DESCRIPTION: */
33/* This file contains all of the register and bit field definitions for */
34/* MPC5674F. */
35/*========================================================================*/
36/* UPDATE HISTORY */
37/* REV AUTHOR DATE DESCRIPTION OF CHANGE */
38/* --- ----------- --------- --------------------- */
39/* NOTE: Branch pulled at version 0.87 for mpc5674_c.h version 1.00 */
40/* 1.00 B. Terry Corrected DECFILT addresses and added */
41/* 4 additional filters for Rev. 2 */
42/* 1.01 B. Terry 16/Nov/09 Corrected bit definitions in SIUDIV */
43/* register. */
44/* 1.02 B. Terry 19/Nov/09 Added ISEL8, ISEL9, ISEL10, and ISEL11 */
45/* regs to SIU tag. (Mamba 2 features) */
46/* 1.03 B. Terry 19/Nov/09 Renamed ISEL10 and ISEL11 to DECFIL1 */
47/* and DECFIL2 to match RM. */
48/* 1.04 B. Terry 22/Jan/10 Updated bitfields of MPU RGDx Word2 */
49/* register to reflect Mamba 2. Added */
50/* MXCR and MXSR registers to DecFilt. */
51/* Removed pre-release rev history. */
52/**************************************************************************/
53
54#ifndef _MPC5674F_H_
55#define _MPC5674F_H_
56
57#ifndef ASM
58
59#include <stdint.h>
60
61#include <mpc55xx/regs-edma.h>
62
63#ifdef __cplusplus
64extern "C" {
65#endif
66
67#ifdef __MWERKS__
68#pragma push
69#pragma ANSI_strict off
70#endif
71
72/****************************************************************************/
73/* MODULE : PBRIDGE_A Peripheral Bridge */
74/****************************************************************************/
75
76 struct PBRIDGE_A_tag {
77
78 union { /* Master Privilege Control Register 0*/
79 uint32_t R;
80 struct {
81 uint32_t MBW0:1; /* z7 Core */
82 uint32_t MTR0:1;
83 uint32_t MTW0:1;
84 uint32_t MPL0:1;
85 uint32_t MBW1:1; /* Nexus */
86 uint32_t MTR1:1;
87 uint32_t MTW1:1;
88 uint32_t MPL1:1;
89 uint32_t MBW2:1; /* Reserved */
90 uint32_t MTR2:1;
91 uint32_t MTW2:1;
92 uint32_t MPL2:1;
93 uint32_t MBW3:1; /* Reserved */
94 uint32_t MTR3:1;
95 uint32_t MTW3:1;
96 uint32_t MPL3:1;
97 uint32_t MBW4:1; /* eDMA A */
98 uint32_t MTR4:1;
99 uint32_t MTW4:1;
100 uint32_t MPL4:1;
101 uint32_t MBW5:1; /* eDMA B */
102 uint32_t MTR5:1;
103 uint32_t MTW5:1;
104 uint32_t MPL5:1;
105 uint32_t MBW6:1; /* FLEXRAY */
106 uint32_t MTR6:1;
107 uint32_t MTW6:1;
108 uint32_t MPL6:1;
109 uint32_t MBW7:1; /* EBI */
110 uint32_t MTR7:1;
111 uint32_t MTW7:1;
112 uint32_t MPL7:1;
113 } B;
114 } MPCR;
115
116 union { /* Master Privilege Control Register 1 */
117 uint32_t R;
118 struct {
119 uint32_t:32; /* reserved */
120 } B;
121 } MPCR1;
122
123 uint32_t PBRIDGE_A_reserved0008[6]; /* 0x0008-0x001F */
124
125 union { /* Peripheral Access Control Register 0 */
126 uint32_t R;
127 struct {
128 uint32_t BW0:1; /* PBRIDGE_A */
129 uint32_t SP0:1;
130 uint32_t WP0:1;
131 uint32_t TP0:1;
132 uint32_t:4; /* Reserved */
133 uint32_t:4; /* Reserved */
134 uint32_t:4; /* Reserved */
135 uint32_t:4; /* Reserved */
136 uint32_t:4; /* Reserved */
137 uint32_t:4; /* Reserved */
138 uint32_t:4; /* Reserved */
139 } B;
140 } PACR0;
141
142 uint32_t PBRIDGE_A_reserved0024[7]; /* 0x0024-0x003F */
143
144 union { /* Off-Platform Peripheral Access Control Register 0 */
145 uint32_t R;
146 struct {
147 uint32_t BW0:1; /* FMPLL */
148 uint32_t SP0:1;
149 uint32_t WP0:1;
150 uint32_t TP0:1;
151 uint32_t BW1:1; /* EBI control */
152 uint32_t SP1:1;
153 uint32_t WP1:1;
154 uint32_t TP1:1;
155 uint32_t BW2:1; /* Flash A control */
156 uint32_t SP2:1;
157 uint32_t WP2:1;
158 uint32_t TP2:1;
159 uint32_t BW3:1; /* Flash B control */
160 uint32_t SP3:1;
161 uint32_t WP3:1;
162 uint32_t TP3:1;
163 uint32_t BW4:1; /* SIU */
164 uint32_t SP4:1;
165 uint32_t WP4:1;
166 uint32_t TP4:1;
167 uint32_t:4; /* Reserved */
168 uint32_t:4; /* Reserved */
169 uint32_t:4; /* Reserved */
170 } B;
171 } OPACR0;
172
173 union { /* Off-Platform Peripheral Access Control Register 1 */
174 uint32_t R;
175 struct {
176 uint32_t BW0:1; /* EMIOS */
177 uint32_t SP0:1;
178 uint32_t WP0:1;
179 uint32_t TP0:1;
180 uint32_t:4; /* Reserved */
181 uint32_t:4; /* Reserved */
182 uint32_t:4; /* Reserved */
183 uint32_t:4; /* Reserved */
184 uint32_t:4; /* Reserved */
185 uint32_t:4; /* Reserved */
186 uint32_t BW7:1; /* PMC */
187 uint32_t SP7:1;
188 uint32_t WP7:1;
189 uint32_t TP7:1;
190 } B;
191 } OPACR1;
192
193 union { /* Off-Platform Peripheral Access Control Register 2 */
194 uint32_t R;
195 struct {
196 uint32_t BW0:1; /* eTPU */
197 uint32_t SP0:1;
198 uint32_t WP0:1;
199 uint32_t TP0:1;
200 uint32_t:4; /* Reserved */
201 uint32_t BW2:1; /* eTPU PRAM */
202 uint32_t SP2:1;
203 uint32_t WP2:1;
204 uint32_t TP2:1;
205 uint32_t BW3:1; /* eTPU PRAM mirror */
206 uint32_t SP3:1;
207 uint32_t WP3:1;
208 uint32_t TP3:1;
209 uint32_t BW4:1; /* eTPU SCM */
210 uint32_t SP4:1;
211 uint32_t WP4:1;
212 uint32_t TP4:1;
213 uint32_t BW5:1; /* eTPU SCM */
214 uint32_t SP5:1;
215 uint32_t WP5:1;
216 uint32_t TP5:1;
217 uint32_t:4; /* Reserved */
218 uint32_t:4; /* Reserved */
219 } B;
220 } OPACR2;
221
222 union { /* Off-Platform Peripheral Access Control Register 3 */
223 uint32_t R;
224 struct {
225 uint32_t:4; /* Reserved */
226 uint32_t:4; /* Reserved */
227 uint32_t:4; /* Reserved */
228 uint32_t:4; /* Reserved */
229 uint32_t BW4:1; /* PIT/RTI */
230 uint32_t SP4:1;
231 uint32_t WP4:1;
232 uint32_t TP4:1;
233 uint32_t:4; /* Reserved */
234 uint32_t:4; /* Reserved */
235 uint32_t:4; /* Reserved */
236 } B;
237 } OPACR3;
238
239 uint32_t PBRIDGE_A_reserved0050[4076]; /* 0x0050-0x3FFF */
240
241 };
242
243/****************************************************************************/
244/* MODULE : PBRIDGE_B Peripheral Bridge */
245/****************************************************************************/
246
247 struct PBRIDGE_B_tag {
248
249 union { /* Master Privilege Control Register 0 */
250 uint32_t R;
251 struct {
252 uint32_t MBW0:1; /* z7 Core */
253 uint32_t MTR0:1;
254 uint32_t MTW0:1;
255 uint32_t MPL0:1;
256 uint32_t MBW1:1; /* Nexus */
257 uint32_t MTR1:1;
258 uint32_t MTW1:1;
259 uint32_t MPL1:1;
260 uint32_t MBW2:1; /* Reserved */
261 uint32_t MTR2:1;
262 uint32_t MTW2:1;
263 uint32_t MPL2:1;
264 uint32_t MBW3:1; /* Reserved */
265 uint32_t MTR3:1;
266 uint32_t MTW3:1;
267 uint32_t MPL3:1;
268 uint32_t MBW4:1; /* eDMA A */
269 uint32_t MTR4:1;
270 uint32_t MTW4:1;
271 uint32_t MPL4:1;
272 uint32_t MBW5:1; /* eDMA B */
273 uint32_t MTR5:1;
274 uint32_t MTW5:1;
275 uint32_t MPL5:1;
276 uint32_t MBW6:1; /* FLEXRAY */
277 uint32_t MTR6:1;
278 uint32_t MTW6:1;
279 uint32_t MPL6:1;
280 uint32_t MBW7:1; /* EBI */
281 uint32_t MTR7:1;
282 uint32_t MTW7:1;
283 uint32_t MPL7:1;
284 } B;
285 } MPCR;
286
287 union { /* Master Privilege Control Register 1 */
288 uint32_t R;
289 struct {
290 uint32_t:32; /* Reserved */
291
292 } B;
293 } MPCR1;
294
295 uint32_t PBRIDGE_B_reserved0008[6]; /* 0x0008-0x001F */
296
297 union { /* Peripheral Access Control Register 0 */
298 uint32_t R;
299 struct {
300 uint32_t BW0:1; /* PBRIDGE B */
301 uint32_t SP0:1;
302 uint32_t WP0:1;
303 uint32_t TP0:1;
304 uint32_t BW1:1; /* XBAR */
305 uint32_t SP1:1;
306 uint32_t WP1:1;
307 uint32_t TP1:1;
308 uint32_t:4; /* Reserved */
309 uint32_t:4; /* Reserved */
310 uint32_t BW4:1; /* MPU */
311 uint32_t SP4:1;
312 uint32_t WP4:1;
313 uint32_t TP4:1;
314 uint32_t:4; /* Reserved */
315 uint32_t:4; /* Reserved */
316 uint32_t:4; /* Reserved */
317 } B;
318 } PACR0;
319
320 union { /* Peripheral Access Control Register 1 */
321 uint32_t R;
322 struct {
323 uint32_t:4; /* Reserved */
324 uint32_t:4; /* Reserved */
325 uint32_t:4; /* Reserved */
326 uint32_t:4; /* Reserved */
327 uint32_t:4; /* Reserved */
328 uint32_t:4; /* Reserved */
329 uint32_t BW6:1; /* SWT */
330 uint32_t SP6:1;
331 uint32_t WP6:1;
332 uint32_t TP6:1;
333 uint32_t BW7:1; /* STM */
334 uint32_t SP7:1;
335 uint32_t WP7:1;
336 uint32_t TP7:1;
337 } B;
338 } PACR1;
339
340 union { /* Peripheral Access Control Register 2 */
341 uint32_t R;
342 struct {
343 uint32_t BW0:1; /* ECSM */
344 uint32_t SP0:1;
345 uint32_t WP0:1;
346 uint32_t TP0:1;
347 uint32_t BW1:1; /* eDMA A */
348 uint32_t SP1:1;
349 uint32_t WP1:1;
350 uint32_t TP1:1;
351 uint32_t BW2:1; /* INTC */
352 uint32_t SP2:1;
353 uint32_t WP2:1;
354 uint32_t TP2:1;
355 uint32_t:4; /* Reserved */
356 uint32_t:4; /* Reserved */
357 uint32_t BW5:1; /* eDMA B */
358 uint32_t SP5:1;
359 uint32_t WP5:1;
360 uint32_t TP5:1;
361 uint32_t:4; /* Reserved */
362 uint32_t:4; /* Reserved */
363 } B;
364 } PACR2;
365
366 uint32_t PBRIDGE_B_reserved002C[5]; /* 0x002C-0x003F */
367
368 union { /* Off-Platform Peripheral Access Control Register 0 */
369 uint32_t R;
370 struct {
371 uint32_t BW0:1; /* eQADC A */
372 uint32_t SP0:1;
373 uint32_t WP0:1;
374 uint32_t TP0:1;
375 uint32_t BW1:1; /* eQADC B */
376 uint32_t SP1:1;
377 uint32_t WP1:1;
378 uint32_t TP1:1;
379 uint32_t BW2:1; /* Decimation Filters A, B, C, D */
380 uint32_t SP2:1;
381 uint32_t WP2:1;
382 uint32_t TP2:1;
383 uint32_t:4; /* Reserved */
384 uint32_t BW4:1; /* DSPI_A */
385 uint32_t SP4:1;
386 uint32_t WP4:1;
387 uint32_t TP4:1;
388 uint32_t BW5:1; /* DSPI_B */
389 uint32_t SP5:1;
390 uint32_t WP5:1;
391 uint32_t TP5:1;
392 uint32_t BW6:1; /* DSPI_C */
393 uint32_t SP6:1;
394 uint32_t WP6:1;
395 uint32_t TP6:1;
396 uint32_t BW7:1; /* DSPI_D */
397 uint32_t SP7:1;
398 uint32_t WP7:1;
399 uint32_t TP7:1;
400 } B;
401 } OPACR0;
402
403 union { /* Off-Platform Peripheral Access Control Register 1 */
404 uint32_t R;
405 struct {
406 uint32_t:4; /* Reserved */
407 uint32_t:4; /* Reserved */
408 uint32_t:4; /* Reserved */
409 uint32_t:4; /* Reserved */
410 uint32_t BW4:1; /* ESCI_A */
411 uint32_t SP4:1;
412 uint32_t WP4:1;
413 uint32_t TP4:1;
414 uint32_t BW5:1; /* ESCI_B */
415 uint32_t SP5:1;
416 uint32_t WP5:1;
417 uint32_t TP5:1;
418 uint32_t BW6:1; /* ESCI_C */
419 uint32_t SP6:1;
420 uint32_t WP6:1;
421 uint32_t TP6:1;
422 uint32_t:4; /* Reserved */
423 } B;
424 } OPACR1;
425
426 union { /* Off-Platform Peripheral Access Control Register 2 */
427 uint32_t R;
428 struct {
429 uint32_t BW0:1; /* FlexCAN_A */
430 uint32_t SP0:1;
431 uint32_t WP0:1;
432 uint32_t TP0:1;
433 uint32_t BW1:1; /* FlexCAN_B */
434 uint32_t SP1:1;
435 uint32_t WP1:1;
436 uint32_t TP1:1;
437 uint32_t BW2:1; /* FlexCAN_C */
438 uint32_t SP2:1;
439 uint32_t WP2:1;
440 uint32_t TP2:1;
441 uint32_t BW3:1; /* FlexCAN_D */
442 uint32_t SP3:1;
443 uint32_t WP3:1;
444 uint32_t TP3:1;
445 uint32_t:4; /* Reserved */
446 uint32_t:4; /* Reserved */
447 uint32_t:4; /* Reserved */
448 uint32_t:4; /* Reserved */
449 } B;
450 } OPACR2;
451
452 union { /* Off-Platform Peripheral Access Control Register 3 */
453 uint32_t R;
454 struct {
455 uint32_t BW0:1; /* FlexRAY */
456 uint32_t SP0:1;
457 uint32_t WP0:1;
458 uint32_t TP0:1;
459 uint32_t:4; /* Reserved */
460 uint32_t:4; /* Reserved */
461 uint32_t BW3:1; /* Temp Sensor */
462 uint32_t SP3:1;
463 uint32_t WP3:1;
464 uint32_t TP3:1;
465 uint32_t:4; /* Reserved */
466 uint32_t:4; /* Reserved */
467 uint32_t:4; /* Reserved */
468 uint32_t BW7:1; /* BAM */
469 uint32_t SP7:1;
470 uint32_t WP7:1;
471 uint32_t TP7:1;
472 } B;
473 } OPACR3;
474
475 uint32_t PBRIDGE_B_reserved0050[4076]; /* 0x0050-0x3FFF */
476
477 };
478
479/****************************************************************************/
480/* MODULE : FMPLL */
481/****************************************************************************/
482
483 struct FMPLL_tag {
484
485 uint32_t FMPLL_reserved0000; /* 0x0000-0x0003 */
486
487 union FMPLL_SYNSR_tag { /* FMPLL Synthesizer Status Register */
488 uint32_t R;
489 struct {
490 uint32_t:22;
491 uint32_t LOLF:1;
492 uint32_t LOC:1;
493 uint32_t MODE:1;
494 uint32_t PLLSEL:1;
495 uint32_t PLLREF:1;
496 uint32_t LOCKS:1;
497 uint32_t LOCK:1;
498 uint32_t LOCF:1;
499 uint32_t CALDONE:1;
500 uint32_t CALPASS:1;
501 } B;
502 } SYNSR;
503
504 union FMPLL_ESYNCR1_tag {/* FMPLL Enhanced Synthesizer Control Register 1 */
505 uint32_t R;
506 struct {
507 uint32_t:1;
508 uint32_t CLKCFG:3;
509 uint32_t:8;
510 uint32_t EPREDIV:4;
511 uint32_t :8;
512 uint32_t EMFD:8;
513 } B;
514 } ESYNCR1;
515
516 union FMPLL_ESYNCR2_tag {/* FMPLL Enhanced Synthesizer Control Register 2 */
517 uint32_t R;
518 struct {
519 uint32_t:8;
520 uint32_t LOCEN:1;
521 uint32_t LOLRE:1;
522 uint32_t LOCRE:1;
523 uint32_t LOLIRQ:1;
524 uint32_t LOCIRQ:1;
525 uint32_t:1;
526 uint32_t ERATE:2;
527 uint32_t CLKCFG_DIS:1;
528 uint32_t:4;
529 uint32_t EDEPTH:3;
530 uint32_t:2;
531 uint32_t ERFD:6;
532 } B;
533 } ESYNCR2;
534
535 uint32_t FMPLL_reserved0010[4092]; /* 0x0010-0x3FFF */
536
537 };
538
539/****************************************************************************/
540/* MODULE : External Bus Interface (EBI) */
541/****************************************************************************/
542
543 struct EBI_CS_tag {
544 uint32_t ebi_cs_reserved [2];
545 };
546
547 struct EBI_CAL_CS_tag {
548 union { /* Calibration Base Register Bank */
549 uint32_t R;
550 struct {
551 uint32_t BA:17;
552 uint32_t:3;
553 uint32_t PS:1;
554 uint32_t:3;
555 uint32_t AD_MUX:1;
556 uint32_t BL:1;
557 uint32_t WEBS:1;
558 uint32_t TBDIP:1;
559 uint32_t:1;
560 uint32_t SETA:1;
561 uint32_t BI:1;
562 uint32_t V:1;
563 } B;
564 } BR;
565
566 union { /* Calibration Option Register Bank */
567 uint32_t R;
568 struct {
569 uint32_t AM:17;
570 uint32_t:7;
571 uint32_t SCY:4;
572 uint32_t:1;
573 uint32_t BSCY:2;
574 uint32_t:1;
575 } B;
576 } OR;
577 };
578
579 struct EBI_tag {
580
581 union EBI_MCR_tag { /* Module Configuration Register */
582 uint32_t R;
583 struct {
584 uint32_t:16;
585 uint32_t ACGE:1;
586 uint32_t:8;
587 uint32_t MDIS:1;
588 uint32_t:3;
589 uint32_t D16_31:1;
590 uint32_t AD_MUX:1;
591 uint32_t DBM:1;
592 } B;
593 } MCR;
594
595 uint32_t EBI_reserved0004; /* 0x0004-0x0007 */
596
597 union { /* Transfer Error Status Register */
598 uint32_t R;
599 struct {
600 uint32_t:30;
601 uint32_t TEAF:1;
602 uint32_t BMTF:1;
603 } B;
604 } TESR;
605
606 union { /* Bus Monitor Control Register */
607 uint32_t R;
608 struct {
609 uint32_t:16;
610 uint32_t BMT:8;
611 uint32_t BME:1;
612 uint32_t:7;
613 } B;
614 } BMCR;
615
616 /* Base/Option registers */
617 struct EBI_CS_tag CS[4];
618
619 uint32_t EBI_reserved0030[4]; /* 0x0030-0x003F */
620
621 /* Calibration registers */
622 struct EBI_CAL_CS_tag CAL_CS[4];
623
624 uint32_t EBI_reserved0060[4000]; /* 0x0060-0x3FFF */
625
626 };
627
628/****************************************************************************/
629/* MODULE : FLASH */
630/****************************************************************************/
631
632 struct FLASH_tag {
633
634 union { /* Module Configuration Register */
635 uint32_t R;
636 struct {
637 uint32_t:5;
638 uint32_t SIZE:3;
639 uint32_t:1;
640 uint32_t LAS:3;
641 uint32_t:3;
642 uint32_t MAS:1;
643 uint32_t EER:1;
644 uint32_t RWE:1;
645 uint32_t SBC:1;
646 uint32_t:1;
647 uint32_t PEAS:1;
648 uint32_t DONE:1;
649 uint32_t PEG:1;
650 uint32_t:4;
651 uint32_t PGM:1;
652 uint32_t PSUS:1;
653 uint32_t ERS:1;
654 uint32_t ESUS:1;
655 uint32_t EHV:1;
656 } B;
657 } MCR;
658
659 union LMLR_tag { /* Low/Mid Address Space Block Locking Register */
660 uint32_t R;
661 struct {
662 uint32_t LME:1;
663 uint32_t:10;
664 uint32_t SLOCK:1;
665 uint32_t:2;
666 uint32_t MLOCK:2;
667 uint32_t:6;
668 uint32_t LLOCK:10;
669 } B;
670 } LMLR; /* Legacy naming - refer to LML in Reference Manual */
671
672 union HLR_tag { /* High Address Space Block Locking Register */
673 uint32_t R;
674 struct {
675 uint32_t HBE:1;
676 uint32_t:25;
677 uint32_t HBLOCK:6; /* Legacy naming - refer to HLOCK in Reference Manual */
678 } B;
679 } HLR; /* Legacy naming - refer to HBL in Reference Manual */
680
681 union SLMLR_tag { /* Secondary Low/Mid Block Locking Register */
682 uint32_t R;
683 struct {
684 uint32_t SLE:1;
685 uint32_t:10;
686 uint32_t SSLOCK:1;
687 uint32_t:2;
688 uint32_t SMLOCK:2;
689 uint32_t:6;
690 uint32_t SLLOCK:10;
691 } B;
692 } SLMLR; /* Legacy naming - refer to SLL in Reference Manual */
693
694 union { /* Low/Mid Address Space Block Select Register */
695 uint32_t R;
696 struct {
697 uint32_t:14;
698 uint32_t MSEL:2;
699 uint32_t:6;
700 uint32_t LSEL:10;
701 } B;
702 } LMSR; /* Legacy naming - refer to LMS in Reference Manual */
703
704 union { /* High Address Space Block Select Register */
705 uint32_t R;
706 struct {
707 uint32_t:26;
708 uint32_t HBSEL:6; /* Legacy naming - refer to HSEL in Reference Manual */
709 } B;
710 } HSR; /* Legacy naming - refer to HBS in Reference Manual */
711
712 union { /* Address Register */
713 uint32_t R;
714 struct {
715 uint32_t SAD:1;
716 uint32_t:13;
717 uint32_t ADDR:15;
718 uint32_t:3;
719 } B;
720 } AR; /* Legacy naming - refer to ADR in Reference Manual */
721
722 union { /* Platform Flash Configuration Register 1 */
723 uint32_t R;
724 struct {
725 uint32_t:7;
726 uint32_t M8PFE:1; /* z7 Nexus */
727 uint32_t:1; /* EBI Testing - Reserved */
728 uint32_t M6PFE:1; /* FlexRay */
729 uint32_t M5PFE:1; /* eDMA_B */
730 uint32_t M4PFE:1; /* eDMA_A */
731 uint32_t:1; /* Reserved */
732 uint32_t:1; /* Reserved */
733 uint32_t:1; /* Reserved */
734 uint32_t M0PFE:1; /* z7 Core */
735 uint32_t APC:3;
736 uint32_t WWSC:2;
737 uint32_t RWSC:3;
738 uint32_t:1;
739 uint32_t DPFEN:1;
740 uint32_t:1;
741 uint32_t IPFEN:1;
742 uint32_t:1;
743 uint32_t PFLIM:2;
744 uint32_t BFEN:1;
745 } B;
746 } BIUCR; /* Legacy naming - PFCR1 */
747
748 union { /*Platform Flash Access Protection Register */
749 uint32_t R;
750 struct {
751 uint32_t:14;
752 uint32_t M8AP:2; /* z7 Nexus */
753 uint32_t:2; /* EBI Testing - Reserved */
754 uint32_t M6AP:2; /* FlexRay */
755 uint32_t M5AP:2; /* eDMA_B */
756 uint32_t M4AP:2; /* eDMA_A */
757 uint32_t:2; /* Reserved */
758 uint32_t:2; /* Reserved */
759 uint32_t:2; /* Reserved */
760 uint32_t M0AP:2; /* z7 Core */
761 } B;
762 } BIUAPR; /* Legacy naming - refer to PFAPR in Reference Manual */
763
764 union { /* Platform Flash Configuration Register 2 */
765 uint32_t R;
766 struct {
767 uint32_t LBCFG:2;
768 uint32_t:30;
769 } B;
770 } BIUCR2;
771
772 uint32_t FLASH_reserved0028[4086]; /* 0x0028-0x3FFF */
773 };
774
775/****************************************************************************/
776/* MODULE : SIU */
777/****************************************************************************/
778 struct SIU_tag {
779 int32_t SIU_reserved0000 /* 0x0000-0x0003 */;
780
781 union { /* MCU ID Register */
782 uint32_t R;
783 struct {
784 uint32_t PARTNUM:16;
785 uint32_t PKG:4;
786 uint32_t:4;
787 uint32_t MAJOR_REV:4;
788 uint32_t MINOR_REV:4;
789 } B;
790 } MIDR;
791
792 int32_t SIU_reserved0008; /* 0x0008-0x000B */
793
794 union { /* Reset Status Register */
795 uint32_t R;
796 struct {
797 uint32_t PORS:1;
798 uint32_t ERS:1;
799 uint32_t LLRS:1;
800 uint32_t LCRS:1;
801 uint32_t WDRS:1;
802 uint32_t CRS:1;
803 uint32_t SWTRS:1;
804 uint32_t:7;
805 uint32_t SSRS:1;
806 uint32_t SERF:1;
807 uint32_t WKPCFG:1;
808 uint32_t:11;
809 uint32_t ABR:1;
810 uint32_t BOOTCFG:2;
811 uint32_t RGF:1;
812 } B;
813 } RSR;
814
815 union { /* System Reset Control Register */
816 uint32_t R;
817 struct {
818 uint32_t SSR:1;
819 uint32_t SER:1;
820 uint32_t:30; // Removed CRE bit
821 } B;
822 } SRCR;
823
824 union SIU_EISR_tag { /* External Interrupt Status Register */
825 uint32_t R;
826 struct {
827 uint32_t NMI:1;
828 uint32_t:15;
829 uint32_t EIF15:1;
830 uint32_t EIF14:1;
831 uint32_t EIF13:1;
832 uint32_t EIF12:1;
833 uint32_t EIF11:1;
834 uint32_t EIF10:1;
835 uint32_t EIF9:1;
836 uint32_t EIF8:1;
837 uint32_t EIF7:1;
838 uint32_t EIF6:1;
839 uint32_t EIF5:1;
840 uint32_t EIF4:1;
841 uint32_t EIF3:1;
842 uint32_t EIF2:1;
843 uint32_t EIF1:1;
844 uint32_t EIF0:1;
845 } B;
846 } EISR;
847
848 union SIU_DIRER_tag { /* DMA/Interrupt Request Enable Register */
849 uint32_t R;
850 struct {
851 uint32_t NMISEL8:1;
852 uint32_t:7;
853 uint32_t NMISEL0:1;
854 uint32_t:7;
855 uint32_t EIRE15:1;
856 uint32_t EIRE14:1;
857 uint32_t EIRE13:1;
858 uint32_t EIRE12:1;
859 uint32_t EIRE11:1;
860 uint32_t EIRE10:1;
861 uint32_t EIRE9:1;
862 uint32_t EIRE8:1;
863 uint32_t EIRE7:1;
864 uint32_t EIRE6:1;
865 uint32_t EIRE5:1;
866 uint32_t EIRE4:1;
867 uint32_t EIRE3:1;
868 uint32_t EIRE2:1;
869 uint32_t EIRE1:1;
870 uint32_t EIRE0:1;
871 } B;
872 } DIRER;
873
874 union SIU_DIRSR_tag { /* DMA/Interrupt Request Select Register */
875 uint32_t R;
876 struct {
877 uint32_t:28;
878 uint32_t DIRS3:1;
879 uint32_t DIRS2:1;
880 uint32_t DIRS1:1;
881 uint32_t DIRS0:1;
882 } B;
883 } DIRSR;
884
885 union { /* Overrun Status Register */
886 uint32_t R;
887 struct {
888 uint32_t:16;
889 uint32_t OVF15:1;
890 uint32_t OVF14:1;
891 uint32_t OVF13:1;
892 uint32_t OVF12:1;
893 uint32_t OVF11:1;
894 uint32_t OVF10:1;
895 uint32_t OVF9:1;
896 uint32_t OVF8:1;
897 uint32_t OVF7:1;
898 uint32_t OVF6:1;
899 uint32_t OVF5:1;
900 uint32_t OVF4:1;
901 uint32_t OVF3:1;
902 uint32_t OVF2:1;
903 uint32_t OVF1:1;
904 uint32_t OVF0:1;
905 } B;
906 } OSR;
907
908 union SIU_ORER_tag { /* Overrun Request Enable Register */
909 uint32_t R;
910 struct {
911 uint32_t:16;
912 uint32_t ORE15:1;
913 uint32_t ORE14:1;
914 uint32_t ORE13:1;
915 uint32_t ORE12:1;
916 uint32_t ORE11:1;
917 uint32_t ORE10:1;
918 uint32_t ORE9:1;
919 uint32_t ORE8:1;
920 uint32_t ORE7:1;
921 uint32_t ORE6:1;
922 uint32_t ORE5:1;
923 uint32_t ORE4:1;
924 uint32_t ORE3:1;
925 uint32_t ORE2:1;
926 uint32_t ORE1:1;
927 uint32_t ORE0:1;
928 } B;
929 } ORER;
930
931 union SIU_IREER_tag { /* External IRQ Rising-Edge Event Enable Register */
932 uint32_t R;
933 struct {
934 uint32_t IREE_NMI8:1;
935 uint32_t:7;
936 uint32_t IREE_NMI0:1;
937 uint32_t:7;
938 uint32_t IREE15:1;
939 uint32_t IREE14:1;
940 uint32_t IREE13:1;
941 uint32_t IREE12:1;
942 uint32_t IREE11:1;
943 uint32_t IREE10:1;
944 uint32_t IREE9:1;
945 uint32_t IREE8:1;
946 uint32_t IREE7:1;
947 uint32_t IREE6:1;
948 uint32_t IREE5:1;
949 uint32_t IREE4:1;
950 uint32_t IREE3:1;
951 uint32_t IREE2:1;
952 uint32_t IREE1:1;
953 uint32_t IREE0:1;
954 } B;
955 } IREER;
956
957 union SIU_IFEER_tag { /* External IRQ Falling-Edge Event Enable Register */
958 uint32_t R;
959 struct {
960 uint32_t IFEE_NMI8:1;
961 uint32_t:7;
962 uint32_t IFEE_NMI0:1;
963 uint32_t:7;
964 uint32_t IFEE15:1;
965 uint32_t IFEE14:1;
966 uint32_t IFEE13:1;
967 uint32_t IFEE12:1;
968 uint32_t IFEE11:1;
969 uint32_t IFEE10:1;
970 uint32_t IFEE9:1;
971 uint32_t IFEE8:1;
972 uint32_t IFEE7:1;
973 uint32_t IFEE6:1;
974 uint32_t IFEE5:1;
975 uint32_t IFEE4:1;
976 uint32_t IFEE3:1;
977 uint32_t IFEE2:1;
978 uint32_t IFEE1:1;
979 uint32_t IFEE0:1;
980 } B;
981 } IFEER;
982
983 union SIU_IDFR_tag { /* External IRQ Digital Filter Register */
984 uint32_t R;
985 struct {
986 uint32_t:28;
987 uint32_t DFL:4;
988 } B;
989 } IDFR;
990
991 union { /* External IRQ Filtered Input Register */
992 uint32_t R;
993 struct {
994 uint32_t FI31:1;
995 uint32_t FI30:1;
996 uint32_t FI29:1;
997 uint32_t FI28:1;
998 uint32_t FI27:1;
999 uint32_t FI26:1;
1000 uint32_t FI25:1;
1001 uint32_t FI24:1;
1002 uint32_t FI23:1;
1003 uint32_t FI22:1;
1004 uint32_t FI21:1;
1005 uint32_t FI20:1;
1006 uint32_t FI19:1;
1007 uint32_t FI18:1;
1008 uint32_t FI17:1;
1009 uint32_t FI16:1;
1010 uint32_t FI15:1;
1011 uint32_t FI14:1;
1012 uint32_t FI13:1;
1013 uint32_t FI12:1;
1014 uint32_t FI11:1;
1015 uint32_t FI10:1;
1016 uint32_t FI9:1;
1017 uint32_t FI8:1;
1018 uint32_t FI7:1;
1019 uint32_t FI6:1;
1020 uint32_t FI5:1;
1021 uint32_t FI4:1;
1022 uint32_t FI3:1;
1023 uint32_t FI2:1;
1024 uint32_t FI1:1;
1025 uint32_t FI0:1;
1026 } B;
1027 } IFIR;
1028
1029 int32_t SIU_reserved0038[2]; /* 0x0038-0x003F */
1030
1031 union SIU_PCR_tag { /* Pad Configuration Registers */
1032 uint16_t R;
1033 struct {
1034 uint16_t:3;
1035 uint16_t PA:3;
1036 uint16_t OBE:1;
1037 uint16_t IBE:1;
1038 uint16_t DSC:2;
1039 uint16_t ODE:1;
1040 uint16_t HYS:1;
1041 uint16_t SRC:2;
1042 uint16_t WPE:1;
1043 uint16_t WPS:1;
1044 } B;
1045 } PCR[512];
1046
1047 int16_t SIU_reserved0440[224]; /* 0x0440-0x05FF */
1048
1049 union { /* GPIO Pin Data Output Registers */
1050 uint8_t R;
1051 struct {
1052 uint8_t:7;
1053 uint8_t PDO:1;
1054 } B;
1055 } GPDO[512];
1056
1057 union { /* GPIO Pin Data Input Registers */
1058 uint8_t R;
1059 struct {
1060 uint8_t:7;
1061 uint8_t PDI:1;
1062 } B;
1063 } GPDI[256];
1064
1065 uint32_t SIU_reserved0900; /* 0x0900-0x0903 */
1066
1067 union { /* External IRQ Input Select Register */
1068 uint32_t R;
1069 struct {
1070 uint32_t ESEL15:2;
1071 uint32_t ESEL14:2;
1072 uint32_t ESEL13:2;
1073 uint32_t ESEL12:2;
1074 uint32_t ESEL11:2;
1075 uint32_t ESEL10:2;
1076 uint32_t ESEL9:2;
1077 uint32_t ESEL8:2;
1078 uint32_t ESEL7:2;
1079 uint32_t ESEL6:2;
1080 uint32_t ESEL5:2;
1081 uint32_t ESEL4:2;
1082 uint32_t ESEL3:2;
1083 uint32_t ESEL2:2;
1084 uint32_t ESEL1:2;
1085 uint32_t ESEL0:2;
1086 } B;
1087 } EIISR;
1088
1089 union { /* DSPI Input Select Register */
1090 uint32_t R;
1091 struct {
1092 uint32_t SINSELA:2;
1093 uint32_t SSSELA:2;
1094 uint32_t SCKSELA:2;
1095 uint32_t TRIGSELA:2;
1096 uint32_t SINSELB:2;
1097 uint32_t SSSELB:2;
1098 uint32_t SCKSELB:2;
1099 uint32_t TRIGSELB:2;
1100 uint32_t SINSELC:2;
1101 uint32_t SSSELC:2;
1102 uint32_t SCKSELC:2;
1103 uint32_t TRIGSELC:2;
1104 uint32_t SINSELD:2;
1105 uint32_t SSSELD:2;
1106 uint32_t SCKSELD:2;
1107 uint32_t TRIGSELD:2;
1108 } B;
1109 } DISR;
1110
1111 int32_t SIU_reserved090C; /* 0x090C-0x090F */
1112
1113 union { /* eQADC Command FIFO Trigger Source Select - IMUX Select Registers */
1114 uint32_t R;
1115 struct {
1116 uint32_t:1;
1117 uint32_t CTSEL5_0:7;
1118 uint32_t:1;
1119 uint32_t CTSEL4_0:7;
1120 uint32_t:1;
1121 uint32_t CTSEL3_0:7;
1122 uint32_t:1;
1123 uint32_t CTSEL2_0:7;
1124 } B;
1125 } ISEL4;
1126
1127 union { /* eQADC Command FIFO Trigger Source Select - IMUX Select Registers */
1128 uint32_t R;
1129 struct {
1130 uint32_t:1;
1131 uint32_t CTSEL1_0:7;
1132 uint32_t:1;
1133 uint32_t CTSEL0_0:7;
1134 uint32_t:16;
1135 } B;
1136 } ISEL5;
1137
1138 union { /* eQADC Command FIFO Trigger Source Select - IMUX Select Registers */
1139 uint32_t R;
1140 struct {
1141 uint32_t:1;
1142 uint32_t CTSEL5_1:7;
1143 uint32_t:1;
1144 uint32_t CTSEL4_1:7;
1145 uint32_t:1;
1146 uint32_t CTSEL3_1:7;
1147 uint32_t:1;
1148 uint32_t CTSEL2_1:7;
1149 } B;
1150 } ISEL6;
1151
1152 union { /* eQADC Command FIFO Trigger Source Select - IMUX Select Registers */
1153 uint32_t R;
1154 struct {
1155 uint32_t:1;
1156 uint32_t CTSEL1_1:7;
1157 uint32_t:1;
1158 uint32_t CTSEL0_1:7;
1159 uint32_t:16;
1160 } B;
1161 } ISEL7;
1162
1163 union { /* eTPU Input Select Register */
1164 uint32_t R;
1165 struct {
1166 uint32_t:11;
1167 uint32_t ETPU29:1;
1168 uint32_t:3;
1169 uint32_t ETPU28:1;
1170 uint32_t:3;
1171 uint32_t ETPU27:1;
1172 uint32_t:3;
1173 uint32_t ETPU26:1;
1174 uint32_t:3;
1175 uint32_t ETPU25:1;
1176 uint32_t:3;
1177 uint32_t ETPU24:1;
1178 } B;
1179 } ISEL8;
1180
1181 union { /* eQADC Advanced Trigger Select */
1182 uint32_t R;
1183 struct {
1184 uint32_t:27;
1185 uint32_t ETSEL0A:5;
1186 } B;
1187 } ISEL9;
1188
1189 union { /* DecFilter Integrator Control */
1190 uint32_t R;
1191 struct {
1192 uint32_t ZSELA:4;
1193 uint32_t HSELA:4;
1194 uint32_t ZSELB:4;
1195 uint32_t HSELB:4;
1196 uint32_t ZSELC:4;
1197 uint32_t HSELC:4;
1198 uint32_t ZSELD:4;
1199 uint32_t HSELD:4;
1200 } B;
1201 } DECFIL1;
1202
1203 union { /* DecFilter Integrator Control */
1204 uint32_t R;
1205 struct {
1206 uint32_t ZSELE:4;
1207 uint32_t HSELE:4;
1208 uint32_t ZSELF:4;
1209 uint32_t HSELF:4;
1210 uint32_t ZSELG:4;
1211 uint32_t HSELG:4;
1212 uint32_t ZSELH:4;
1213 uint32_t HSELH:4;
1214 } B;
1215 } DECFIL2;
1216
1217
1218 int32_t SIU_reserved0920[20]; /* 0x0930-0x097F */
1219
1220 union { /* Chip Configuration Register Register */
1221 uint32_t R;
1222 struct {
1223 uint32_t:14;
1224 uint32_t MATCH:1;
1225 uint32_t DISNEX:1;
1226 uint32_t:16;
1227 } B;
1228 } CCR;
1229
1230 union { /* External Clock Configuration Register Register */
1231 uint32_t R;
1232 struct {
1233 uint32_t:16;
1234 uint32_t ENGDIV:8;
1235 uint32_t ECSS:1;
1236 uint32_t:3;
1237 uint32_t EBTS:1;
1238 uint32_t:1;
1239 uint32_t EBDF:2;
1240 } B;
1241 } ECCR;
1242
1243 union { /* Compare A Register High */
1244 uint32_t R;
1245 struct {
1246 uint32_t CMPAH:32;
1247 } B;
1248 } CARH;
1249
1250 union { /* Compare A Register Low */
1251 uint32_t R;
1252 struct {
1253 uint32_t CMPAL:32;
1254 } B;
1255 } CARL;
1256
1257 union { /* Compare B Register High */
1258 uint32_t R;
1259 struct {
1260 uint32_t CMPBH:32;
1261 } B;
1262 } CBRH;
1263
1264 union { /* Compare B Register Low */
1265 uint32_t R;
1266 struct {
1267 uint32_t CMPBL:32;
1268 } B;
1269 } CBRL;
1270
1271 int32_t SIU_reserved0998[2]; /* 0x0998-0x099F */
1272
1273 union { /* System Clock Register */
1274 uint32_t R;
1275 struct {
1276 uint32_t:22;
1277 uint32_t IPCLKDIV:2;
1278 uint32_t:3;
1279 uint32_t BYPASS:1;
1280 uint32_t SYSCLKDIV:2;
1281 uint32_t:2;
1282 } B;
1283 } SYSDIV;
1284
1285 union { /* Halt Register */
1286 uint32_t R;
1287 struct {
1288 uint32_t CPUSTP:1; /* CPU and Platform stop request */
1289 uint32_t:4; /* Reserved */
1290 uint32_t TPUSTP:1; /* eTPU_A stop request */
1291 uint32_t NPCSTP:1; /* Nexus stop request */
1292 uint32_t EBISTP:1; /* EBI stop request*/
1293 uint32_t ADCSTP:1; /* eQADC stop request */
1294 uint32_t:1; /* Reserved */
1295 uint32_t MIOSSTP:1; /* eMIOS stop request */
1296 uint32_t DFILSTP:1; /* Decimation filter stop request */
1297 uint32_t:1; /* Reserved */
1298 uint32_t PITSTP:1; /* PIT stop request */
1299 uint32_t:2; /* Reserved */
1300 uint32_t CNDSTP:1; /* FlexCAN D stop request */
1301 uint32_t CNCSTP:1; /* FlexCAN C stop request */
1302 uint32_t CNBSTP:1; /* FlexCAN B stop request */
1303 uint32_t CNASTP:1; /* FlexCAN A stop request */
1304 uint32_t SPIDSTP:1; /* DSPI D stop request */
1305 uint32_t SPICSTP:1; /* DSPI C stop request */
1306 uint32_t SPIBSTP:1; /* DSPI B stop request */
1307 uint32_t SPIASTP:1; /* DSPI C stop request */
1308 uint32_t:5; /* Reserved */
1309 uint32_t SCICSTP:1; /* eSCI C stop request */
1310 uint32_t SCIBSTP:1; /* eSCI B stop request */
1311 uint32_t SCIASTP:1; /* eSCI A stop request */
1312 } B;
1313 } HLT;
1314
1315 union { /* Halt Acknowledge Register */
1316 uint32_t R;
1317 struct {
1318 uint32_t CPUACK:1; /* CPU and Platform stop acknowledge */
1319 uint32_t:4; /* Reserved */
1320 uint32_t TPUACK:1; /* eTPU_A stop acknowledge */
1321 uint32_t NPCACK:1; /* Nexus stop acknowledge */
1322 uint32_t EBIACK:1; /* EBI stop acknowledge*/
1323 uint32_t ADCACK:1; /* eQADC stop acknowledge */
1324 uint32_t:1; /* Reserved */
1325 uint32_t MIOSACK:1; /* eMIOS stop acknowledge */
1326 uint32_t DFILACK:1; /* Decimation filter stop acknowledge */
1327 uint32_t:1; /* Reserved */
1328 uint32_t PITACK:1; /* PIT stop acknowledge */
1329 uint32_t:2; /* Reserved */
1330 uint32_t CNDACK:1; /* FlexCAN D stop acknowledge */
1331 uint32_t CNCACK:1; /* FlexCAN C stop acknowledge */
1332 uint32_t CNBACK:1; /* FlexCAN B stop acknowledge */
1333 uint32_t CNAACK:1; /* FlexCAN A stop acknowledge */
1334 uint32_t SPIDACK:1; /* DSPI D stop acknowledge */
1335 uint32_t SPICACK:1; /* DSPI C stop acknowledge */
1336 uint32_t SPIBACK:1; /* DSPI B stop acknowledge */
1337 uint32_t SPIAACK:1; /* DSPI C stop acknowledge */
1338 uint32_t:5; /* Reserved */
1339 uint32_t SCICACK:1; /* eSCI C stop acknowledge */
1340 uint32_t SCIBACK:1; /* eSCI B stop acknowledge */
1341 uint32_t SCIAACK:1; /* eSCI A stop acknowledge */
1342 } B;
1343 } HLTACK;
1344
1345 int32_t SIU_reserved09AC[21]; /* 0x09AC-0x09FF */
1346
1347 int32_t SIU_reserved0A00[128]; /* 0x0A00-0x0BFF */
1348
1349 union { /* Parallel GPIO Pin Data Output Register */
1350 uint32_t R;
1351 struct {
1352 uint32_t PGPDO0:1;
1353 uint32_t PGPDO1:1;
1354 uint32_t PGPDO2:1;
1355 uint32_t PGPDO3:1;
1356 uint32_t PGPDO4:1;
1357 uint32_t PGPDO5:1;
1358 uint32_t PGPDO6:1;
1359 uint32_t PGPDO7:1;
1360 uint32_t PGPDO8:1;
1361 uint32_t PGPDO9:1;
1362 uint32_t PGPDO10:1;
1363 uint32_t PGPDO11:1;
1364 uint32_t PGPDO12:1;
1365 uint32_t PGPDO13:1;
1366 uint32_t PGPDO14:1;
1367 uint32_t PGPDO15:1;
1368 uint32_t PGPDO16:1;
1369 uint32_t PGPDO17:1;
1370 uint32_t PGPDO18:1;
1371 uint32_t PGPDO19:1;
1372 uint32_t PGPDO20:1;
1373 uint32_t PGPDO21:1;
1374 uint32_t PGPDO22:1;
1375 uint32_t PGPDO23:1;
1376 uint32_t PGPDO24:1;
1377 uint32_t PGPDO25:1;
1378 uint32_t PGPDO26:1;
1379 uint32_t PGPDO27:1;
1380 uint32_t PGPDO28:1;
1381 uint32_t PGPDO29:1;
1382 uint32_t PGPDO30:1;
1383 uint32_t PGPDO31:1;
1384 } B;
1385 } PGPDO[16];
1386
1387 union { /* Parallel GPIO Pin Data Input Register */
1388 uint32_t R;
1389 struct {
1390 uint32_t PGPDI0:1;
1391 uint32_t PGPDI1:1;
1392 uint32_t PGPDI2:1;
1393 uint32_t PGPDI3:1;
1394 uint32_t PGPDI4:1;
1395 uint32_t PGPDI5:1;
1396 uint32_t PGPDI6:1;
1397 uint32_t PGPDI7:1;
1398 uint32_t PGPDI8:1;
1399 uint32_t PGPDI9:1;
1400 uint32_t PGPDI10:1;
1401 uint32_t PGPDI11:1;
1402 uint32_t PGPDI12:1;
1403 uint32_t PGPDI13:1;
1404 uint32_t PGPDI14:1;
1405 uint32_t PGPDI15:1;
1406 uint32_t PGPDI16:1;
1407 uint32_t PGPDI17:1;
1408 uint32_t PGPDI18:1;
1409 uint32_t PGPDI19:1;
1410 uint32_t PGPDI20:1;
1411 uint32_t PGPDI21:1;
1412 uint32_t PGPDI22:1;
1413 uint32_t PGPDI23:1;
1414 uint32_t PGPDI24:1;
1415 uint32_t PGPDI25:1;
1416 uint32_t PGPDI26:1;
1417 uint32_t PGPDI27:1;
1418 uint32_t PGPDI28:1;
1419 uint32_t PGPDI29:1;
1420 uint32_t PGPDI30:1;
1421 uint32_t PGPDI31:1;
1422 } B;
1423 } PGPDI[16];
1424
1425 union { /* Masked Parallel GPIO Pin Data Input Register */
1426 uint32_t R;
1427 struct {
1428 uint32_t MASK0:1;
1429 uint32_t MASK1:1;
1430 uint32_t MASK2:1;
1431 uint32_t MASK3:1;
1432 uint32_t MASK4:1;
1433 uint32_t MASK5:1;
1434 uint32_t MASK6:1;
1435 uint32_t MASK7:1;
1436 uint32_t MASK8:1;
1437 uint32_t MASK9:1;
1438 uint32_t MASK10:1;
1439 uint32_t MASK11:1;
1440 uint32_t MASK12:1;
1441 uint32_t MASK13:1;
1442 uint32_t MASK14:1;
1443 uint32_t MASK15:1;
1444 uint32_t DATA0:1;
1445 uint32_t DATA1:1;
1446 uint32_t DATA2:1;
1447 uint32_t DATA3:1;
1448 uint32_t DATA4:1;
1449 uint32_t DATA5:1;
1450 uint32_t DATA6:1;
1451 uint32_t DATA7:1;
1452 uint32_t DATA8:1;
1453 uint32_t DATA9:1;
1454 uint32_t DATA10:1;
1455 uint32_t DATA11:1;
1456 uint32_t DATA12:1;
1457 uint32_t DATA13:1;
1458 uint32_t DATA14:1;
1459 uint32_t DATA15:1;
1460 } B;
1461 } MPGPDO[32];
1462
1463 union { /* DSPI_A Mask Output High Register */
1464 uint32_t R;
1465 struct {
1466 uint32_t MASK0:1;
1467 uint32_t MASK1:1;
1468 uint32_t MASK2:1;
1469 uint32_t MASK3:1;
1470 uint32_t MASK4:1;
1471 uint32_t MASK5:1;
1472 uint32_t MASK6:1;
1473 uint32_t MASK7:1;
1474 uint32_t MASK8:1;
1475 uint32_t MASK9:1;
1476 uint32_t MASK10:1;
1477 uint32_t MASK11:1;
1478 uint32_t MASK12:1;
1479 uint32_t MASK13:1;
1480 uint32_t MASK14:1;
1481 uint32_t MASK15:1;
1482 uint32_t DATA0:1;
1483 uint32_t DATA1:1;
1484 uint32_t DATA2:1;
1485 uint32_t DATA3:1;
1486 uint32_t DATA4:1;
1487 uint32_t DATA5:1;
1488 uint32_t DATA6:1;
1489 uint32_t DATA7:1;
1490 uint32_t DATA8:1;
1491 uint32_t DATA9:1;
1492 uint32_t DATA10:1;
1493 uint32_t DATA11:1;
1494 uint32_t DATA12:1;
1495 uint32_t DATA13:1;
1496 uint32_t DATA14:1;
1497 uint32_t DATA15:1;
1498 } B;
1499 } DSPIAH;
1500
1501 union { /* DSPI_A Mask Output Low Register */
1502 uint32_t R;
1503 struct {
1504 uint32_t MASK16:1;
1505 uint32_t MASK17:1;
1506 uint32_t MASK18:1;
1507 uint32_t MASK19:1;
1508 uint32_t MASK20:1;
1509 uint32_t MASK21:1;
1510 uint32_t MASK22:1;
1511 uint32_t MASK23:1;
1512 uint32_t MASK24:1;
1513 uint32_t MASK25:1;
1514 uint32_t MASK26:1;
1515 uint32_t MASK27:1;
1516 uint32_t MASK28:1;
1517 uint32_t MASK29:1;
1518 uint32_t MASK30:1;
1519 uint32_t MASK31:1;
1520 uint32_t DATA16:1;
1521 uint32_t DATA17:1;
1522 uint32_t DATA18:1;
1523 uint32_t DATA19:1;
1524 uint32_t DATA20:1;
1525 uint32_t DATA21:1;
1526 uint32_t DATA22:1;
1527 uint32_t DATA23:1;
1528 uint32_t DATA24:1;
1529 uint32_t DATA25:1;
1530 uint32_t DATA26:1;
1531 uint32_t DATA27:1;
1532 uint32_t DATA28:1;
1533 uint32_t DATA29:1;
1534 uint32_t DATA30:1;
1535 uint32_t DATA31:1;
1536 } B;
1537 } DSPIAL;
1538
1539 union { /* DSPI_B Mask Output High Register */
1540 uint32_t R;
1541 struct {
1542 uint32_t MASK0:1;
1543 uint32_t MASK1:1;
1544 uint32_t MASK2:1;
1545 uint32_t MASK3:1;
1546 uint32_t MASK4:1;
1547 uint32_t MASK5:1;
1548 uint32_t MASK6:1;
1549 uint32_t MASK7:1;
1550 uint32_t MASK8:1;
1551 uint32_t MASK9:1;
1552 uint32_t MASK10:1;
1553 uint32_t MASK11:1;
1554 uint32_t MASK12:1;
1555 uint32_t MASK13:1;
1556 uint32_t MASK14:1;
1557 uint32_t MASK15:1;
1558 uint32_t DATA0:1;
1559 uint32_t DATA1:1;
1560 uint32_t DATA2:1;
1561 uint32_t DATA3:1;
1562 uint32_t DATA4:1;
1563 uint32_t DATA5:1;
1564 uint32_t DATA6:1;
1565 uint32_t DATA7:1;
1566 uint32_t DATA8:1;
1567 uint32_t DATA9:1;
1568 uint32_t DATA10:1;
1569 uint32_t DATA11:1;
1570 uint32_t DATA12:1;
1571 uint32_t DATA13:1;
1572 uint32_t DATA14:1;
1573 uint32_t DATA15:1;
1574 } B;
1575 } DSPIBH;
1576
1577 union { /* DSPI_B Mask Output Low Register */
1578 uint32_t R;
1579 struct {
1580 uint32_t MASK16:1;
1581 uint32_t MASK17:1;
1582 uint32_t MASK18:1;
1583 uint32_t MASK19:1;
1584 uint32_t MASK20:1;
1585 uint32_t MASK21:1;
1586 uint32_t MASK22:1;
1587 uint32_t MASK23:1;
1588 uint32_t MASK24:1;
1589 uint32_t MASK25:1;
1590 uint32_t MASK26:1;
1591 uint32_t MASK27:1;
1592 uint32_t MASK28:1;
1593 uint32_t MASK29:1;
1594 uint32_t MASK30:1;
1595 uint32_t MASK31:1;
1596 uint32_t DATA16:1;
1597 uint32_t DATA17:1;
1598 uint32_t DATA18:1;
1599 uint32_t DATA19:1;
1600 uint32_t DATA20:1;
1601 uint32_t DATA21:1;
1602 uint32_t DATA22:1;
1603 uint32_t DATA23:1;
1604 uint32_t DATA24:1;
1605 uint32_t DATA25:1;
1606 uint32_t DATA26:1;
1607 uint32_t DATA27:1;
1608 uint32_t DATA28:1;
1609 uint32_t DATA29:1;
1610 uint32_t DATA30:1;
1611 uint32_t DATA31:1;
1612 } B;
1613 } DSPIBL;
1614
1615 union { /* DSPI_C Mask Output High Register */
1616 uint32_t R;
1617 struct {
1618 uint32_t MASK0:1;
1619 uint32_t MASK1:1;
1620 uint32_t MASK2:1;
1621 uint32_t MASK3:1;
1622 uint32_t MASK4:1;
1623 uint32_t MASK5:1;
1624 uint32_t MASK6:1;
1625 uint32_t MASK7:1;
1626 uint32_t MASK8:1;
1627 uint32_t MASK9:1;
1628 uint32_t MASK10:1;
1629 uint32_t MASK11:1;
1630 uint32_t MASK12:1;
1631 uint32_t MASK13:1;
1632 uint32_t MASK14:1;
1633 uint32_t MASK15:1;
1634 uint32_t DATA0:1;
1635 uint32_t DATA1:1;
1636 uint32_t DATA2:1;
1637 uint32_t DATA3:1;
1638 uint32_t DATA4:1;
1639 uint32_t DATA5:1;
1640 uint32_t DATA6:1;
1641 uint32_t DATA7:1;
1642 uint32_t DATA8:1;
1643 uint32_t DATA9:1;
1644 uint32_t DATA10:1;
1645 uint32_t DATA11:1;
1646 uint32_t DATA12:1;
1647 uint32_t DATA13:1;
1648 uint32_t DATA14:1;
1649 uint32_t DATA15:1;
1650 } B;
1651 } DSPICH;
1652
1653 union { /* DSPI_C Mask Output Low Register */
1654 uint32_t R;
1655 struct {
1656 uint32_t MASK16:1;
1657 uint32_t MASK17:1;
1658 uint32_t MASK18:1;
1659 uint32_t MASK19:1;
1660 uint32_t MASK20:1;
1661 uint32_t MASK21:1;
1662 uint32_t MASK22:1;
1663 uint32_t MASK23:1;
1664 uint32_t MASK24:1;
1665 uint32_t MASK25:1;
1666 uint32_t MASK26:1;
1667 uint32_t MASK27:1;
1668 uint32_t MASK28:1;
1669 uint32_t MASK29:1;
1670 uint32_t MASK30:1;
1671 uint32_t MASK31:1;
1672 uint32_t DATA16:1;
1673 uint32_t DATA17:1;
1674 uint32_t DATA18:1;
1675 uint32_t DATA19:1;
1676 uint32_t DATA20:1;
1677 uint32_t DATA21:1;
1678 uint32_t DATA22:1;
1679 uint32_t DATA23:1;
1680 uint32_t DATA24:1;
1681 uint32_t DATA25:1;
1682 uint32_t DATA26:1;
1683 uint32_t DATA27:1;
1684 uint32_t DATA28:1;
1685 uint32_t DATA29:1;
1686 uint32_t DATA30:1;
1687 uint32_t DATA31:1;
1688 } B;
1689 } DSPICL;
1690
1691 union { /* DSPI_D Mask Output High Register */
1692 uint32_t R;
1693 struct {
1694 uint32_t MASK0:1;
1695 uint32_t MASK1:1;
1696 uint32_t MASK2:1;
1697 uint32_t MASK3:1;
1698 uint32_t MASK4:1;
1699 uint32_t MASK5:1;
1700 uint32_t MASK6:1;
1701 uint32_t MASK7:1;
1702 uint32_t MASK8:1;
1703 uint32_t MASK9:1;
1704 uint32_t MASK10:1;
1705 uint32_t MASK11:1;
1706 uint32_t MASK12:1;
1707 uint32_t MASK13:1;
1708 uint32_t MASK14:1;
1709 uint32_t MASK15:1;
1710 uint32_t DATA0:1;
1711 uint32_t DATA1:1;
1712 uint32_t DATA2:1;
1713 uint32_t DATA3:1;
1714 uint32_t DATA4:1;
1715 uint32_t DATA5:1;
1716 uint32_t DATA6:1;
1717 uint32_t DATA7:1;
1718 uint32_t DATA8:1;
1719 uint32_t DATA9:1;
1720 uint32_t DATA10:1;
1721 uint32_t DATA11:1;
1722 uint32_t DATA12:1;
1723 uint32_t DATA13:1;
1724 uint32_t DATA14:1;
1725 uint32_t DATA15:1;
1726 } B;
1727 } DSPIDH;
1728
1729 union { /* DSPI_D Mask Output Low Register */
1730 uint32_t R;
1731 struct {
1732 uint32_t MASK16:1;
1733 uint32_t MASK17:1;
1734 uint32_t MASK18:1;
1735 uint32_t MASK19:1;
1736 uint32_t MASK20:1;
1737 uint32_t MASK21:1;
1738 uint32_t MASK22:1;
1739 uint32_t MASK23:1;
1740 uint32_t MASK24:1;
1741 uint32_t MASK25:1;
1742 uint32_t MASK26:1;
1743 uint32_t MASK27:1;
1744 uint32_t MASK28:1;
1745 uint32_t MASK29:1;
1746 uint32_t MASK30:1;
1747 uint32_t MASK31:1;
1748 uint32_t DATA16:1;
1749 uint32_t DATA17:1;
1750 uint32_t DATA18:1;
1751 uint32_t DATA19:1;
1752 uint32_t DATA20:1;
1753 uint32_t DATA21:1;
1754 uint32_t DATA22:1;
1755 uint32_t DATA23:1;
1756 uint32_t DATA24:1;
1757 uint32_t DATA25:1;
1758 uint32_t DATA26:1;
1759 uint32_t DATA27:1;
1760 uint32_t DATA28:1;
1761 uint32_t DATA29:1;
1762 uint32_t DATA30:1;
1763 uint32_t DATA31:1;
1764 } B;
1765 } DSPIDL;
1766
1767 int32_t SIU_reserved0D20[8]; /* 0x0D20-0x0D3F */
1768
1769 union { /* ETPU B Select Register */
1770 uint32_t R;
1771 struct {
1772 uint32_t ETPUB15:1;
1773 uint32_t ETPUB14:1;
1774 uint32_t ETPUB13:1;
1775 uint32_t ETPUB12:1;
1776 uint32_t ETPUB11:1;
1777 uint32_t ETPUB10:1;
1778 uint32_t ETPUB9:1;
1779 uint32_t ETPUB8:1;
1780 uint32_t ETPUB7:1;
1781 uint32_t ETPUB6:1;
1782 uint32_t ETPUB5:1;
1783 uint32_t ETPUB4:1;
1784 uint32_t ETPUB3:1;
1785 uint32_t ETPUB2:1;
1786 uint32_t ETPUB1:1;
1787 uint32_t ETPUB0:1;
1788 uint32_t ETPUB31:1;
1789 uint32_t ETPUB30:1;
1790 uint32_t ETPUB29:1;
1791 uint32_t ETPUB28:1;
1792 uint32_t ETPUB27:1;
1793 uint32_t ETPUB26:1;
1794 uint32_t ETPUB25:1;
1795 uint32_t ETPUB24:1;
1796 uint32_t ETPUB23:1;
1797 uint32_t ETPUB22:1;
1798 uint32_t ETPUB21:1;
1799 uint32_t ETPUB20:1;
1800 uint32_t ETPUB19:1;
1801 uint32_t ETPUB18:1;
1802 uint32_t ETPUB17:1;
1803 uint32_t ETPUB16:1;
1804 } B ;
1805 } ETPUBA;
1806
1807 union { /* EMIOS A Select Register */
1808 uint32_t R;
1809 struct {
1810 uint32_t EMIOS7:1;
1811 uint32_t EMIOS6:1;
1812 uint32_t EMIOS5:1;
1813 uint32_t EMIOS4:1;
1814 uint32_t EMIOS3:1;
1815 uint32_t EMIOS2:1;
1816 uint32_t EMIOS1:1;
1817 uint32_t EMIOS0:1;
1818 uint32_t EMIOS8:1;
1819 uint32_t EMIOS9:1;
1820 uint32_t EMIOS10:1;
1821 uint32_t EMIOS11:1;
1822 uint32_t EMIOS12:1;
1823 uint32_t EMIOS13:1;
1824 uint32_t EMIOS14:1;
1825 uint32_t EMIOS15:1;
1826 uint32_t EMIOS16:1;
1827 uint32_t EMIOS17:1;
1828 uint32_t EMIOS18:1;
1829 uint32_t EMIOS19:1;
1830 uint32_t EMIOS20:1;
1831 uint32_t EMIOS21:1;
1832 uint32_t EMIOS22:1;
1833 uint32_t EMIOS23:1;
1834 uint32_t EMIOS0_0:1;
1835 uint32_t EMIOS1_1:1;
1836 uint32_t EMIOS2_2:1;
1837 uint32_t EMIOS3_3:1;
1838 uint32_t EMIOS4_4:1;
1839 uint32_t EMIOS5_5:1;
1840 uint32_t EMIOS6_6:1;
1841 uint32_t EMIOS7_7:1;
1842 } B;
1843 } EMIOSA;
1844
1845 union { /* DSPIAH/L Select Register for DSPI A */
1846 uint32_t R;
1847 struct {
1848 uint32_t DSPIAH0:1;
1849 uint32_t DSPIAH1:1;
1850 uint32_t DSPIAH2:1;
1851 uint32_t DSPIAH3:1;
1852 uint32_t DSPIAH4:1;
1853 uint32_t DSPIAH5:1;
1854 uint32_t DSPIAH6:1;
1855 uint32_t DSPIAH7:1;
1856 uint32_t DSPIAH8:1;
1857 uint32_t DSPIAH9:1;
1858 uint32_t DSPIAH10:1;
1859 uint32_t DSPIAH11:1;
1860 uint32_t DSPIAH12:1;
1861 uint32_t DSPIAH13:1;
1862 uint32_t DSPIAH14:1;
1863 uint32_t DSPIAH15:1;
1864 uint32_t DSPIAL16:1;
1865 uint32_t DSPIAL17:1;
1866 uint32_t DSPIAL18:1;
1867 uint32_t DSPIAL19:1;
1868 uint32_t DSPIAL20:1;
1869 uint32_t DSPIAL21:1;
1870 uint32_t DSPIAL22:1;
1871 uint32_t DSPIAL23:1;
1872 uint32_t DSPIAL24:1;
1873 uint32_t DSPIAL25:1;
1874 uint32_t DSPIAL26:1;
1875 uint32_t DSPIAL27:1;
1876 uint32_t DSPIAL28:1;
1877 uint32_t DSPIAL29:1;
1878 uint32_t DSPIAL30:1;
1879 uint32_t DSPIAL31:1;
1880 } B;
1881 } DSPIAHLA;
1882
1883 int32_t SIU_reserved0D4C; /* 0x0D4C-0x0D4F */
1884
1885 union { /* ETPU A Select Register */
1886 uint32_t R;
1887 struct {
1888 uint32_t ETPUA23:1;
1889 uint32_t ETPUA22:1;
1890 uint32_t ETPUA21:1;
1891 uint32_t ETPUA20:1;
1892 uint32_t ETPUA19:1;
1893 uint32_t ETPUA18:1;
1894 uint32_t ETPUA17:1;
1895 uint32_t ETPUA16:1;
1896 uint32_t ETPUA29:1;
1897 uint32_t ETPUA28:1;
1898 uint32_t ETPUA27:1;
1899 uint32_t ETPUA26:1;
1900 uint32_t ETPUA25:1;
1901 uint32_t ETPUA24:1;
1902 uint32_t ETPUA31:1;
1903 uint32_t ETPUA30:1;
1904 uint32_t ETPUA12:1;
1905 uint32_t ETPUA13:1;
1906 uint32_t ETPUA14:1;
1907 uint32_t ETPUA15:1;
1908 uint32_t ETPUA0:1;
1909 uint32_t ETPUA1:1;
1910 uint32_t ETPUA2:1;
1911 uint32_t ETPUA3:1;
1912 uint32_t ETPUA4:1;
1913 uint32_t ETPUA5:1;
1914 uint32_t ETPUA6:1;
1915 uint32_t ETPUA7:1;
1916 uint32_t ETPUA8:1;
1917 uint32_t ETPUA9:1;
1918 uint32_t ETPUA10:1;
1919 uint32_t ETPUA11:1;
1920 } B ;
1921 } ETPUAB;
1922
1923 union { /* EMIOS B Select Register */
1924 uint32_t R;
1925 struct {
1926 uint32_t EMIOS11:1;
1927 uint32_t EMIOS10:1;
1928 uint32_t EMIOS9:1;
1929 uint32_t EMIOS8:1;
1930 uint32_t EMIOS6:1;
1931 uint32_t EMIOS5:1;
1932 uint32_t EMIOS4:1;
1933 uint32_t EMIOS3:1;
1934 uint32_t EMIOS2:1;
1935 uint32_t EMIOS1:1;
1936 uint32_t EMIOS0:1;
1937 uint32_t EMIOS23:1;
1938 uint32_t EMIOS15:1;
1939 uint32_t EMIOS14:1;
1940 uint32_t EMIOS13:1;
1941 uint32_t EMIOS12:1;
1942 uint32_t EMIOS23_23:1;
1943 uint32_t EMIOS15_15:1;
1944 uint32_t EMIOS14_14:1;
1945 uint32_t EMIOS13_13:1;
1946 uint32_t EMIOS12_12:1;
1947 uint32_t EMIOS11_11:1;
1948 uint32_t EMIOS10_10:1;
1949 uint32_t EMIOS9_9:1;
1950 uint32_t EMIOS8_8:1;
1951 uint32_t EMIOS6_6:1;
1952 uint32_t EMIOS5_5:1;
1953 uint32_t EMIOS4_4:1;
1954 uint32_t EMIOS3_3:1;
1955 uint32_t EMIOS2_2:1;
1956 uint32_t EMIOS1_1:1;
1957 uint32_t EMIOS0_0:1;
1958 } B;
1959 } EMIOSB;
1960
1961 union { /* DSPIBH/L Select Register for DSPI B */
1962 uint32_t R;
1963 struct {
1964 uint32_t DSPIBH0:1;
1965 uint32_t DSPIBH1:1;
1966 uint32_t DSPIBH2:1;
1967 uint32_t DSPIBH3:1;
1968 uint32_t DSPIBH4:1;
1969 uint32_t DSPIBH5:1;
1970 uint32_t DSPIBH6:1;
1971 uint32_t DSPIBH7:1;
1972 uint32_t DSPIBH8:1;
1973 uint32_t DSPIBH9:1;
1974 uint32_t DSPIBH10:1;
1975 uint32_t DSPIBH11:1;
1976 uint32_t DSPIBH12:1;
1977 uint32_t DSPIBH13:1;
1978 uint32_t DSPIBH14:1;
1979 uint32_t DSPIBH15:1;
1980 uint32_t DSPIBL16:1;
1981 uint32_t DSPIBL17:1;
1982 uint32_t DSPIBL18:1;
1983 uint32_t DSPIBL19:1;
1984 uint32_t DSPIBL20:1;
1985 uint32_t DSPIBL21:1;
1986 uint32_t DSPIBL22:1;
1987 uint32_t DSPIBL23:1;
1988 uint32_t DSPIBL24:1;
1989 uint32_t DSPIBL25:1;
1990 uint32_t DSPIBL26:1;
1991 uint32_t DSPIBL27:1;
1992 uint32_t DSPIBL28:1;
1993 uint32_t DSPIBL29:1;
1994 uint32_t DSPIBL30:1;
1995 uint32_t DSPIBL31:1;
1996 } B;
1997 } DSPIBHLB;
1998
1999 int32_t SIU_reserved0D5C; /* 0x0D5C-0x0D5F */
2000
2001 union { /* ETPU A Select Register */
2002 uint32_t R;
2003 struct {
2004 uint32_t ETPUA12:1;
2005 uint32_t ETPUA13:1;
2006 uint32_t ETPUA14:1;
2007 uint32_t ETPUA15:1;
2008 uint32_t ETPUA0:1;
2009 uint32_t ETPUA1:1;
2010 uint32_t ETPUA2:1;
2011 uint32_t ETPUA3:1;
2012 uint32_t ETPUA4:1;
2013 uint32_t ETPUA5:1;
2014 uint32_t ETPUA6:1;
2015 uint32_t ETPUA7:1;
2016 uint32_t ETPUA8:1;
2017 uint32_t ETPUA9:1;
2018 uint32_t ETPUA10:1;
2019 uint32_t ETPUA11:1;
2020 uint32_t ETPUA23:1;
2021 uint32_t ETPUA22:1;
2022 uint32_t ETPUA21:1;
2023 uint32_t ETPUA20:1;
2024 uint32_t ETPUA19:1;
2025 uint32_t ETPUA18:1;
2026 uint32_t ETPUA17:1;
2027 uint32_t ETPUA16:1;
2028 uint32_t ETPUA29:1;
2029 uint32_t ETPUA28:1;
2030 uint32_t ETPUA27:1;
2031 uint32_t ETPUA26:1;
2032 uint32_t ETPUA25:1;
2033 uint32_t ETPUA24:1;
2034 uint32_t ETPUA31:1;
2035 uint32_t ETPUA30:1;
2036 } B ;
2037 } ETPUAC;
2038
2039 union { /* EMIOS C Select Register */
2040 uint32_t R;
2041 struct {
2042 uint32_t EMIOS12:1;
2043 uint32_t EMIOS13:1;
2044 uint32_t EMIOS14:1;
2045 uint32_t EMIOS15:1;
2046 uint32_t EMIOS23:1;
2047 uint32_t EMIOS0:1;
2048 uint32_t EMIOS1:1;
2049 uint32_t EMIOS2:1;
2050 uint32_t EMIOS3:1;
2051 uint32_t EMIOS4:1;
2052 uint32_t EMIOS5:1;
2053 uint32_t EMIOS6:1;
2054 uint32_t EMIOS8:1;
2055 uint32_t EMIOS9:1;
2056 uint32_t EMIOS10:1;
2057 uint32_t EMIOS11:1;
2058 uint32_t EMIOS23_23:1;
2059 uint32_t EMIOS22:1;
2060 uint32_t EMIOS21:1;
2061 uint32_t EMIOS20:1;
2062 uint32_t EMIOS19:1;
2063 uint32_t EMIOS18:1;
2064 uint32_t EMIOS17:1;
2065 uint32_t EMIOS16:1;
2066 uint32_t EMIOS29:1;
2067 uint32_t EMIOS28:1;
2068 uint32_t EMIOS27:1;
2069 uint32_t EMIOS26:1;
2070 uint32_t EMIOS25:1;
2071 uint32_t EMIOS24:1;
2072 uint32_t EMIOS31:1;
2073 uint32_t EMIOS30:1;
2074 } B;
2075 } EMIOSC;
2076
2077 union { /* DSPICH/L Select Register for DSPI C */
2078 uint32_t R;
2079 struct {
2080 uint32_t DSPICH0:1;
2081 uint32_t DSPICH1:1;
2082 uint32_t DSPICH2:1;
2083 uint32_t DSPICH3:1;
2084 uint32_t DSPICH4:1;
2085 uint32_t DSPICH5:1;
2086 uint32_t DSPICH6:1;
2087 uint32_t DSPICH7:1;
2088 uint32_t DSPICH8:1;
2089 uint32_t DSPICH9:1;
2090 uint32_t DSPICH10:1;
2091 uint32_t DSPICH11:1;
2092 uint32_t DSPICH12:1;
2093 uint32_t DSPICH13:1;
2094 uint32_t DSPICH14:1;
2095 uint32_t DSPICH15:1;
2096 uint32_t DSPICL16:1;
2097 uint32_t DSPICL17:1;
2098 uint32_t DSPICL18:1;
2099 uint32_t DSPICL19:1;
2100 uint32_t DSPICL20:1;
2101 uint32_t DSPICL21:1;
2102 uint32_t DSPICL22:1;
2103 uint32_t DSPICL23:1;
2104 uint32_t DSPICL24:1;
2105 uint32_t DSPICL25:1;
2106 uint32_t DSPICL26:1;
2107 uint32_t DSPICL27:1;
2108 uint32_t DSPICL28:1;
2109 uint32_t DSPICL29:1;
2110 uint32_t DSPICL30:1;
2111 uint32_t DSPICL31:1;
2112 } B;
2113 } DSPICHLC;
2114
2115 int32_t SIU_reserved0D6C; /* 0x0D6C-0x0D6F */
2116
2117 union { /* ETPU B Select Register */
2118 uint32_t R;
2119 struct {
2120 uint32_t ETPUB21:1;
2121 uint32_t ETPUB20:1;
2122 uint32_t ETPUB19:1;
2123 uint32_t ETPUB18:1;
2124 uint32_t ETPUB17:1;
2125 uint32_t ETPUB16:1;
2126 uint32_t:4;
2127 uint32_t ETPUB29:1;
2128 uint32_t ETPUB28:1;
2129 uint32_t ETPUB27:1;
2130 uint32_t ETPUB26:1;
2131 uint32_t ETPUB25:1;
2132 uint32_t ETPUB24:1;
2133 uint32_t:16;
2134 } B ;
2135 } ETPUBD;
2136
2137 union { /* EMIOS D Select Register */
2138 uint32_t R;
2139 struct {
2140 uint32_t:6;
2141 uint32_t EMIOS11:1;
2142 uint32_t EMIOS10:1;
2143 uint32_t EMIOS13:1;
2144 uint32_t EMIOS12:1;
2145 uint32_t:22;
2146 } B;
2147 } EMIOSD;
2148
2149 union { /* DSPIDH/L Select Register for DSPI D */
2150 uint32_t R;
2151 struct {
2152 uint32_t:32;
2153 } B;
2154 } DSPIDHLD;
2155
2156 int32_t SIU_reserved0D7C; /* 0x0D7C-0x0D7F */
2157
2158 int32_t SIU_reserved0D80[32]; /* 0x0D80-0x0DFF */
2159
2160 union { /* GPIO Pin Data Input Registers */
2161 uint8_t R;
2162 struct {
2163 uint8_t:7;
2164 uint8_t PDI:1;
2165 } B;
2166 } GPDI0_511[512];
2167
2168 uint32_t SIU_reserved1000[3072]; /* 0x1000-0x3FFF */
2169 };
2170
2171/****************************************************************************/
2172/* MODULE : EMIOS */
2173/****************************************************************************/
2174
2175 struct EMIOS_tag {
2176
2177 union EMIOS_MCR_tag { /* Module Configuration Register */
2178 uint32_t R;
2179 struct {
2180 uint32_t:1;
2181 uint32_t MDIS:1;
2182 uint32_t FRZ:1;
2183 uint32_t GTBE:1;
2184 uint32_t ETB:1;
2185 uint32_t GPREN:1;
2186 uint32_t:6;
2187 uint32_t SRV:4;
2188 uint32_t GPRE:8;
2189 uint32_t:8;
2190 } B;
2191 } MCR;
2192
2193 union { /* Global FLAG Register */
2194 uint32_t R;
2195 struct {
2196 uint32_t F31:1;
2197 uint32_t F30:1;
2198 uint32_t F29:1;
2199 uint32_t F28:1;
2200 uint32_t F27:1;
2201 uint32_t F26:1;
2202 uint32_t F25:1;
2203 uint32_t F24:1;
2204 uint32_t F23:1;
2205 uint32_t F22:1;
2206 uint32_t F21:1;
2207 uint32_t F20:1;
2208 uint32_t F19:1;
2209 uint32_t F18:1;
2210 uint32_t F17:1;
2211 uint32_t F16:1;
2212 uint32_t F15:1;
2213 uint32_t F14:1;
2214 uint32_t F13:1;
2215 uint32_t F12:1;
2216 uint32_t F11:1;
2217 uint32_t F10:1;
2218 uint32_t F9:1;
2219 uint32_t F8:1;
2220 uint32_t F7:1;
2221 uint32_t F6:1;
2222 uint32_t F5:1;
2223 uint32_t F4:1;
2224 uint32_t F3:1;
2225 uint32_t F2:1;
2226 uint32_t F1:1;
2227 uint32_t F0:1;
2228 } B;
2229 } GFR;
2230
2231 union { /* Output Update Disable Register */
2232 uint32_t R;
2233 struct {
2234 uint32_t OU31:1;
2235 uint32_t OU30:1;
2236 uint32_t OU29:1;
2237 uint32_t OU28:1;
2238 uint32_t OU27:1;
2239 uint32_t OU26:1;
2240 uint32_t OU25:1;
2241 uint32_t OU24:1;
2242 uint32_t OU23:1;
2243 uint32_t OU22:1;
2244 uint32_t OU21:1;
2245 uint32_t OU20:1;
2246 uint32_t OU19:1;
2247 uint32_t OU18:1;
2248 uint32_t OU17:1;
2249 uint32_t OU16:1;
2250 uint32_t OU15:1;
2251 uint32_t OU14:1;
2252 uint32_t OU13:1;
2253 uint32_t OU12:1;
2254 uint32_t OU11:1;
2255 uint32_t OU10:1;
2256 uint32_t OU9:1;
2257 uint32_t OU8:1;
2258 uint32_t OU7:1;
2259 uint32_t OU6:1;
2260 uint32_t OU5:1;
2261 uint32_t OU4:1;
2262 uint32_t OU3:1;
2263 uint32_t OU2:1;
2264 uint32_t OU1:1;
2265 uint32_t OU0:1;
2266 } B;
2267 } OUDR;
2268
2269 uint32_t eMIOS_reserved000C[5]; /* 0x000C-0x001F */
2270
2271 struct EMIOS_CH_tag {
2272 union { /* Channel A Data Register */
2273 uint32_t R;
2274 } CADR;
2275
2276 union { /* Channel B Data Register */
2277 uint32_t R;
2278 } CBDR;
2279
2280 union { /* Channel Counter Register */
2281 uint32_t R;
2282 } CCNTR;
2283
2284 union EMIOS_CCR_tag {/* Channel Control Register */
2285 uint32_t R;
2286 struct {
2287 uint32_t FREN:1;
2288 uint32_t ODIS:1;
2289 uint32_t ODISSL:2;
2290 uint32_t UCPRE:2;
2291 uint32_t UCPREN:1;
2292 uint32_t DMA:1;
2293 uint32_t:1;
2294 uint32_t IF:4;
2295 uint32_t FCK:1;
2296 uint32_t FEN:1;
2297 uint32_t:3;
2298 uint32_t FORCMA:1;
2299 uint32_t FORCMB:1;
2300 uint32_t:1;
2301 uint32_t BSL:2;
2302 uint32_t EDSEL:1;
2303 uint32_t EDPOL:1;
2304 uint32_t MODE:7;
2305 } B;
2306 } CCR;
2307
2308 union EMIOS_CSR_tag {/* Channel Status Register */
2309 uint32_t R;
2310 struct {
2311 uint32_t OVR:1;
2312 uint32_t:15;
2313 uint32_t OVFL:1;
2314 uint32_t:12;
2315 uint32_t UCIN:1;
2316 uint32_t UCOUT:1;
2317 uint32_t FLAG:1;
2318 } B;
2319 } CSR;
2320
2321 union { /* Alternate Channel A Data Register */
2322 uint32_t R;
2323 } ALTA;
2324
2325 uint32_t eMIOS_channel_reserved0018[2]; /* 0x0018-0x001F */
2326
2327 } CH[32];
2328
2329 uint32_t eMIOS_reserved0420[3832]; /* 0x0420-0x3FFF */
2330
2331 };
2332
2333/****************************************************************************/
2334/* MODULE : PMC */
2335/****************************************************************************/
2336
2337 struct PMC_tag {
2338
2339 union {
2340 uint32_t R;
2341 struct {
2342 uint32_t LVRER:1;
2343 uint32_t LVREH:1;
2344 uint32_t LVRE50:1;
2345 uint32_t LVRE33:1;
2346 uint32_t LVREC:1;
2347 uint32_t LVREA:1;
2348 uint32_t:1;
2349 uint32_t:1;
2350 uint32_t LVIER:1;
2351 uint32_t LVIEH:1;
2352 uint32_t LVIE50:1;
2353 uint32_t LVIE33:1;
2354 uint32_t LVIEC:1;
2355 uint32_t LVIEA:1;
2356 uint32_t:1;
2357 uint32_t TLK:1;
2358 uint32_t:16;
2359 } B;
2360 } MCR; /* Module Configuration Register */
2361
2362 union {
2363 uint32_t R;
2364 struct {
2365 uint32_t :8;
2366 uint32_t LVDATRIM:4;
2367 uint32_t LVDREGTRIM:4;
2368 uint32_t VDD33TRIM:4;
2369 uint32_t LVD33TRIM:4;
2370 uint32_t VDDCTRIM:4;
2371 uint32_t LVDCTRIM:4;
2372 } B;
2373 } TRIMR; /* Trimming register */
2374
2375 union {
2376 uint32_t R;
2377 struct {
2378 uint32_t :5;
2379 uint32_t LVFSTBY:1;
2380 uint32_t BGRDY:1;
2381 uint32_t BGTS:1;
2382 uint32_t :5;
2383 uint32_t LVFCSTBY:1;
2384 uint32_t :2;
2385 uint32_t LVFCR:1;
2386 uint32_t LVFCH:1;
2387 uint32_t LVFC50:1;
2388 uint32_t LVFC33:1;
2389 uint32_t LVFCC:1;
2390 uint32_t LVFCA:1;
2391 uint32_t :2;
2392 uint32_t LVFR:1;
2393 uint32_t LVFH:1;
2394 uint32_t LVF50:1;
2395 uint32_t LVF33:1;
2396 uint32_t LVFC:1;
2397 uint32_t LVFA:1;
2398 uint32_t :2;
2399 } B;
2400 } SR; /* status register */
2401
2402 uint32_t PMC_reserved000C[4093]; /* 0x000C-0x3FFF */
2403 };
2404
2405/****************************************************************************/
2406/* MODULE :ETPU */
2407/****************************************************************************/
2408
2409/***************************Configuration Registers**************************/
2410
2411 struct ETPU_tag {
2412 union { /* MODULE CONFIGURATION REGISTER */
2413 uint32_t R;
2414 struct {
2415 uint32_t GEC:1; /* Global Exception Clear */
2416 uint32_t SDMERR:1; /* SDM Read Error */
2417 uint32_t WDTOA:1; /* Watchdog Timeout-eTPU_A */
2418 uint32_t WDTOB:1; /* Watchdog Timeout-eTPU_B */
2419 uint32_t MGE1:1; /* Microcode Global Exception-ETPU_A */
2420 uint32_t MGE2:1; /* Microcode Global Exception-ETPU_B */
2421 uint32_t ILF1:1; /* Illegal Instruction Flag-ETPU_A */
2422 uint32_t ILF2:1; /* Illegal Instruction Flag-ETPU_B */
2423 uint32_t:3;
2424 uint32_t SCMSIZE:5; /* Shared Code Memory size */
2425 uint32_t:4;
2426 uint32_t SCMMISC:1; /* SCM MISC Complete/Clear */
2427 uint32_t SCMMISF:1; /* SCM MISC Flag */
2428 uint32_t SCMMISEN:1; /* SCM MISC Enable */
2429 uint32_t:2;
2430 uint32_t VIS:1; /* SCM Visability */
2431 uint32_t:5;
2432 uint32_t GTBE:1; /* Global Time Base Enable */
2433 } B;
2434 } MCR;
2435
2436 union { /* COHERENT DUAL-PARAMETER CONTROL */
2437 uint32_t R;
2438 struct {
2439 uint32_t STS:1; /* Start Status bit */
2440 uint32_t CTBASE:5; /* Channel Transfer Base */
2441 uint32_t PBASE:10; /* Parameter Buffer Base Address */
2442 uint32_t PWIDTH:1; /* Parameter Width */
2443 uint32_t PARAM0:7; /* Channel Parameter 0 */
2444 uint32_t WR:1; /* Read/Write selection */
2445 uint32_t PARAM1:7; /* Channel Parameter 1 */
2446 } B;
2447 } CDCR;
2448
2449 uint32_t eTPU_reserved0008; /* 0x0008-0x000B */
2450
2451 union { /* MISC Compare Register */
2452 uint32_t R;
2453 struct {
2454 uint32_t ETPUMISCCMP:32;
2455 } B;
2456 } MISCCMPR;
2457
2458 union { /* SCM off-range Date Register */
2459 uint32_t R;
2460 struct {
2461 uint32_t ETPUSCMOFFDATA:32;
2462 } B;
2463 } SCMOFFDATAR;
2464
2465 union { /* ETPU_A Configuration Register */
2466 uint32_t R;
2467 struct {
2468 uint32_t FEND:1; /* Force END */
2469 uint32_t MDIS:1; /* Low power Stop */
2470 uint32_t:1;
2471 uint32_t STF:1; /* Stop Flag */
2472 uint32_t:4;
2473 uint32_t HLTF:1; /* Halt Mode Flag */
2474 uint32_t:3;
2475 uint32_t FCSS:1; /* Filter Clock Source Select */
2476 uint32_t FPSCK:3; /* Filter Prescaler Clock Control */
2477 uint32_t CDFC:2;
2478 uint32_t:1;
2479 uint32_t ERBA:5; /* Engine Relative Base Address */
2480 uint32_t SPPDIS:1; /* Schedule Priority Passing Disable */
2481 uint32_t:2;
2482 uint32_t ETB:5; /* Entry Table Base */
2483 } B;
2484 } ECR_A;
2485
2486 union { /* ETPU_B Configuration Register */
2487 uint32_t R;
2488 struct {
2489 uint32_t FEND:1; /* Force END */
2490 uint32_t MDIS:1; /* Low power Stop */
2491 uint32_t:1;
2492 uint32_t STF:1; /* Stop Flag */
2493 uint32_t:4;
2494 uint32_t HLTF:1; /* Halt Mode Flag */
2495 uint32_t:3;
2496 uint32_t FCSS:1; /* Filter Clock Source Select */
2497 uint32_t FPSCK:3; /* Filter Prescaler Clock Control */
2498 uint32_t CDFC:2;
2499 uint32_t:1;
2500 uint32_t ERBA:5; /* Engine Relative Base Address */
2501 uint32_t SPPDIS:1; /* Schedule Priority Passing Disable */
2502 uint32_t:2;
2503 uint32_t ETB:5; /* Entry Table Base */
2504 } B;
2505 } ECR_B;
2506
2507 uint32_t eTPU_reserved001C; /* 0x001C-0x001F */
2508
2509 union { /* ETPU_A Timebase Configuration Register */
2510 uint32_t R;
2511 struct {
2512 uint32_t TCR2CTL:3; /* TCR2 Clock/Gate Control */
2513 uint32_t TCRCF:2; /* TCRCLK Signal Filter Control */
2514 uint32_t AM:2; /* Angle Mode */
2515 uint32_t:3;
2516 uint32_t TCR2P:6; /* TCR2 Prescaler Control */
2517 uint32_t TCR1CTL:2; /* TCR1 Clock/Gate Control */
2518 uint32_t TCR1CS:1; /* TCR1 Clock Source */
2519 uint32_t:5;
2520 uint32_t TCR1P:8; /* TCR1 Prescaler Control */
2521 } B;
2522 } TBCR_A;
2523
2524 union { /* ETPU_A TCR1 Visibility Register */
2525 uint32_t R;
2526 struct {
2527 uint32_t:8;
2528 uint32_t TCR1:24;
2529 } B;
2530 } TB1R_A;
2531
2532 union { /* ETPU_A TCR2 Visibility Register */
2533 uint32_t R;
2534 struct {
2535 uint32_t:8;
2536 uint32_t TCR2:24;
2537 } B;
2538 } TB2R_A;
2539
2540 union { /* ETPU_A STAC Configuration Register */
2541 uint32_t R;
2542 struct {
2543 uint32_t REN1:1; /* Resource Enable TCR1 */
2544 uint32_t RSC1:1; /* Resource Control TCR1 */
2545 uint32_t:2;
2546 uint32_t SERVER_ID1:4; /* TCR1 Server ID */
2547 uint32_t:4;
2548 uint32_t SRV1:4; /* Resource Server Slot */
2549 uint32_t REN2:1; /* Resource Enable TCR2 */
2550 uint32_t RSC2:1; /* Resource Control TCR2 */
2551 uint32_t:2;
2552 uint32_t SERVER_ID2:4; /* TCR2 Server ID */
2553 uint32_t:4;
2554 uint32_t SRV2:4; /* Resource Server Slot */
2555 } B;
2556 } REDCR_A;
2557
2558 uint32_t eTPU_reserved0030[4]; /* 0x0030-0x003F */
2559
2560 union { /* ETPU_B Timebase Configuration Register */
2561 uint32_t R;
2562 struct {
2563 uint32_t TCR2CTL:3; /* TCR2 Clock/Gate Control */
2564 uint32_t TCRCF:2; /* TCRCLK Signal Filter Control */
2565 uint32_t AM:2; /* Angle Mode */
2566 uint32_t:3;
2567 uint32_t TCR2P:6; /* TCR2 Prescaler Control */
2568 uint32_t TCR1CTL:2; /* TCR1 Clock/Gate Control */
2569 uint32_t TCR1CS:1; /* TCR1 Clock Source */
2570 uint32_t:5;
2571 uint32_t TCR1P:8; /* TCR1 Prescaler Control */
2572 } B;
2573 } TBCR_B;
2574
2575 union { /* ETPU_B TCR1 Visibility Register */
2576 uint32_t R;
2577 struct {
2578 uint32_t:8;
2579 uint32_t TCR1:24;
2580 } B;
2581 } TB1R_B;
2582
2583 union { /* ETPU_B TCR2 Visibility Register */
2584 uint32_t R;
2585 struct {
2586 uint32_t:8;
2587 uint32_t TCR2:24;
2588 } B;
2589 } TB2R_B;
2590
2591 union { /* ETPU_B STAC Configuration Register */
2592 uint32_t R;
2593 struct {
2594 uint32_t REN1:1; /* Resource Enable TCR1 */
2595 uint32_t RSC1:1; /* Resource Control TCR1 */
2596 uint32_t:2;
2597 uint32_t SERVER_ID1:4; /* TCR1 Server ID */
2598 uint32_t:4;
2599 uint32_t SRV1:4; /* Resource Server Slot */
2600 uint32_t REN2:1; /* Resource Enable TCR2 */
2601 uint32_t RSC2:1; /* Resource Control TCR2 */
2602 uint32_t:2;
2603 uint32_t SERVER_ID2:4; /* TCR2 Server ID */
2604 uint32_t:4;
2605 uint32_t SRV2:4; /* Resource Server Slot */
2606 } B;
2607 } REDCR_B;
2608
2609 uint32_t eTPU_reserved0050[4]; /* 0x0050-0x005F */
2610
2611 union { /* Watchdog Timer Register A */
2612 uint32_t R;
2613 struct {
2614 uint32_t WDM:2; /* Watchdog Mode */
2615 uint32_t:14;
2616 uint32_t WDCNT:16; /* Watchdog Count */
2617 } B;
2618 } WDTR_A;
2619
2620 uint32_t eTPU_reserved0064; /* 0x0064-0x0067 */
2621
2622 union { /* Idle Counter Register A*/
2623 uint32_t R;
2624 struct {
2625 uint32_t IDLE_CNT:31;
2626 uint32_t ICLR:1; /* Idle Clear */
2627 } B;
2628
2629 } IDLE_A;
2630
2631 uint32_t eTPU_reserved006C; /* 0x006C-0x006F */
2632
2633 union { /* Watchdog Timer Register B */
2634 uint32_t R;
2635 struct {
2636 uint32_t WDM:2; /* Watchdog Mode */
2637 uint32_t:14;
2638 uint32_t WDCNT:16; /* Watchdog Count */
2639 } B;
2640 } WDTR_B;
2641
2642 uint32_t eTPU_reserved0074; /* 0x0074-0x0077 */
2643
2644 union { /* Idle Counter Register B*/
2645 uint32_t R;
2646 struct {
2647 uint32_t IDLE_CNT:31;
2648 uint32_t ICLR:1; /* Idle Clear */
2649 } B;
2650 } IDLE_B;
2651
2652 uint32_t eTPU_reserved007C; /* 0x007C-0x007F */
2653
2654 uint32_t eTPU_reserved0080[96]; /* 0x0080-0x01FF */
2655
2656/*****************************Status and Control Registers**************************/
2657
2658 union { /* ETPU_A Channel Interrut Status */
2659 uint32_t R;
2660 struct {
2661 uint32_t CIS31:1; /* Channel 31 Interrut Status */
2662 uint32_t CIS30:1; /* Channel 30 Interrut Status */
2663 uint32_t CIS29:1; /* Channel 29 Interrut Status */
2664 uint32_t CIS28:1; /* Channel 28 Interrut Status */
2665 uint32_t CIS27:1; /* Channel 27 Interrut Status */
2666 uint32_t CIS26:1; /* Channel 26 Interrut Status */
2667 uint32_t CIS25:1; /* Channel 25 Interrut Status */
2668 uint32_t CIS24:1; /* Channel 24 Interrut Status */
2669 uint32_t CIS23:1; /* Channel 23 Interrut Status */
2670 uint32_t CIS22:1; /* Channel 22 Interrut Status */
2671 uint32_t CIS21:1; /* Channel 21 Interrut Status */
2672 uint32_t CIS20:1; /* Channel 20 Interrut Status */
2673 uint32_t CIS19:1; /* Channel 19 Interrut Status */
2674 uint32_t CIS18:1; /* Channel 18 Interrut Status */
2675 uint32_t CIS17:1; /* Channel 17 Interrut Status */
2676 uint32_t CIS16:1; /* Channel 16 Interrut Status */
2677 uint32_t CIS15:1; /* Channel 15 Interrut Status */
2678 uint32_t CIS14:1; /* Channel 14 Interrut Status */
2679 uint32_t CIS13:1; /* Channel 13 Interrut Status */
2680 uint32_t CIS12:1; /* Channel 12 Interrut Status */
2681 uint32_t CIS11:1; /* Channel 11 Interrut Status */
2682 uint32_t CIS10:1; /* Channel 10 Interrut Status */
2683 uint32_t CIS9:1; /* Channel 9 Interrut Status */
2684 uint32_t CIS8:1; /* Channel 8 Interrut Status */
2685 uint32_t CIS7:1; /* Channel 7 Interrut Status */
2686 uint32_t CIS6:1; /* Channel 6 Interrut Status */
2687 uint32_t CIS5:1; /* Channel 5 Interrut Status */
2688 uint32_t CIS4:1; /* Channel 4 Interrut Status */
2689 uint32_t CIS3:1; /* Channel 3 Interrut Status */
2690 uint32_t CIS2:1; /* Channel 2 Interrut Status */
2691 uint32_t CIS1:1; /* Channel 1 Interrut Status */
2692 uint32_t CIS0:1; /* Channel 0 Interrut Status */
2693 } B;
2694 } CISR_A;
2695
2696 union { /* ETPU_B Channel Interruput Status */
2697 uint32_t R;
2698 struct {
2699 uint32_t CIS31:1; /* Channel 31 Interrut Status */
2700 uint32_t CIS30:1; /* Channel 30 Interrut Status */
2701 uint32_t CIS29:1; /* Channel 29 Interrut Status */
2702 uint32_t CIS28:1; /* Channel 28 Interrut Status */
2703 uint32_t CIS27:1; /* Channel 27 Interrut Status */
2704 uint32_t CIS26:1; /* Channel 26 Interrut Status */
2705 uint32_t CIS25:1; /* Channel 25 Interrut Status */
2706 uint32_t CIS24:1; /* Channel 24 Interrut Status */
2707 uint32_t CIS23:1; /* Channel 23 Interrut Status */
2708 uint32_t CIS22:1; /* Channel 22 Interrut Status */
2709 uint32_t CIS21:1; /* Channel 21 Interrut Status */
2710 uint32_t CIS20:1; /* Channel 20 Interrut Status */
2711 uint32_t CIS19:1; /* Channel 19 Interrut Status */
2712 uint32_t CIS18:1; /* Channel 18 Interrut Status */
2713 uint32_t CIS17:1; /* Channel 17 Interrut Status */
2714 uint32_t CIS16:1; /* Channel 16 Interrut Status */
2715 uint32_t CIS15:1; /* Channel 15 Interrut Status */
2716 uint32_t CIS14:1; /* Channel 14 Interrut Status */
2717 uint32_t CIS13:1; /* Channel 13 Interrut Status */
2718 uint32_t CIS12:1; /* Channel 12 Interrut Status */
2719 uint32_t CIS11:1; /* Channel 11 Interrut Status */
2720 uint32_t CIS10:1; /* Channel 10 Interrut Status */
2721 uint32_t CIS9:1; /* Channel 9 Interrut Status */
2722 uint32_t CIS8:1; /* Channel 8 Interrut Status */
2723 uint32_t CIS7:1; /* Channel 7 Interrut Status */
2724 uint32_t CIS6:1; /* Channel 6 Interrut Status */
2725 uint32_t CIS5:1; /* Channel 5 Interrut Status */
2726 uint32_t CIS4:1; /* Channel 4 Interrut Status */
2727 uint32_t CIS3:1; /* Channel 3 Interrut Status */
2728 uint32_t CIS2:1; /* Channel 2 Interrut Status */
2729 uint32_t CIS1:1; /* Channel 1 Interrupt Status */
2730 uint32_t CIS0:1; /* Channel 0 Interrupt Status */
2731 } B;
2732 } CISR_B;
2733
2734 uint32_t eTPU_reserved0208[2]; /* 0x0208-0x020F */
2735
2736 union { /* ETPU_A Data Transfer Request Status */
2737 uint32_t R;
2738 struct {
2739 uint32_t DTRS31:1; /* Channel 31 Data Transfer Request Status */
2740 uint32_t DTRS30:1; /* Channel 30 Data Transfer Request Status */
2741 uint32_t DTRS29:1; /* Channel 29 Data Transfer Request Status */
2742 uint32_t DTRS28:1; /* Channel 28 Data Transfer Request Status */
2743 uint32_t DTRS27:1; /* Channel 27 Data Transfer Request Status */
2744 uint32_t DTRS26:1; /* Channel 26 Data Transfer Request Status */
2745 uint32_t DTRS25:1; /* Channel 25 Data Transfer Request Status */
2746 uint32_t DTRS24:1; /* Channel 24 Data Transfer Request Status */
2747 uint32_t DTRS23:1; /* Channel 23 Data Transfer Request Status */
2748 uint32_t DTRS22:1; /* Channel 22 Data Transfer Request Status */
2749 uint32_t DTRS21:1; /* Channel 21 Data Transfer Request Status */
2750 uint32_t DTRS20:1; /* Channel 20 Data Transfer Request Status */
2751 uint32_t DTRS19:1; /* Channel 19 Data Transfer Request Status */
2752 uint32_t DTRS18:1; /* Channel 18 Data Transfer Request Status */
2753 uint32_t DTRS17:1; /* Channel 17 Data Transfer Request Status */
2754 uint32_t DTRS16:1; /* Channel 16 Data Transfer Request Status */
2755 uint32_t DTRS15:1; /* Channel 15 Data Transfer Request Status */
2756 uint32_t DTRS14:1; /* Channel 14 Data Transfer Request Status */
2757 uint32_t DTRS13:1; /* Channel 13 Data Transfer Request Status */
2758 uint32_t DTRS12:1; /* Channel 12 Data Transfer Request Status */
2759 uint32_t DTRS11:1; /* Channel 11 Data Transfer Request Status */
2760 uint32_t DTRS10:1; /* Channel 10 Data Transfer Request Status */
2761 uint32_t DTRS9:1; /* Channel 9 Data Transfer Request Status */
2762 uint32_t DTRS8:1; /* Channel 8 Data Transfer Request Status */
2763 uint32_t DTRS7:1; /* Channel 7 Data Transfer Request Status */
2764 uint32_t DTRS6:1; /* Channel 6 Data Transfer Request Status */
2765 uint32_t DTRS5:1; /* Channel 5 Data Transfer Request Status */
2766 uint32_t DTRS4:1; /* Channel 4 Data Transfer Request Status */
2767 uint32_t DTRS3:1; /* Channel 3 Data Transfer Request Status */
2768 uint32_t DTRS2:1; /* Channel 2 Data Transfer Request Status */
2769 uint32_t DTRS1:1; /* Channel 1 Data Transfer Request Status */
2770 uint32_t DTRS0:1; /* Channel 0 Data Transfer Request Status */
2771 } B;
2772 } CDTRSR_A;
2773
2774 union { /* ETPU_B Data Transfer Request Status */
2775 uint32_t R;
2776 struct {
2777 uint32_t DTRS31:1; /* Channel 31 Data Transfer Request Status */
2778 uint32_t DTRS30:1; /* Channel 30 Data Transfer Request Status */
2779 uint32_t DTRS29:1; /* Channel 29 Data Transfer Request Status */
2780 uint32_t DTRS28:1; /* Channel 28 Data Transfer Request Status */
2781 uint32_t DTRS27:1; /* Channel 27 Data Transfer Request Status */
2782 uint32_t DTRS26:1; /* Channel 26 Data Transfer Request Status */
2783 uint32_t DTRS25:1; /* Channel 25 Data Transfer Request Status */
2784 uint32_t DTRS24:1; /* Channel 24 Data Transfer Request Status */
2785 uint32_t DTRS23:1; /* Channel 23 Data Transfer Request Status */
2786 uint32_t DTRS22:1; /* Channel 22 Data Transfer Request Status */
2787 uint32_t DTRS21:1; /* Channel 21 Data Transfer Request Status */
2788 uint32_t DTRS20:1; /* Channel 20 Data Transfer Request Status */
2789 uint32_t DTRS19:1; /* Channel 19 Data Transfer Request Status */
2790 uint32_t DTRS18:1; /* Channel 18 Data Transfer Request Status */
2791 uint32_t DTRS17:1; /* Channel 17 Data Transfer Request Status */
2792 uint32_t DTRS16:1; /* Channel 16 Data Transfer Request Status */
2793 uint32_t DTRS15:1; /* Channel 15 Data Transfer Request Status */
2794 uint32_t DTRS14:1; /* Channel 14 Data Transfer Request Status */
2795 uint32_t DTRS13:1; /* Channel 13 Data Transfer Request Status */
2796 uint32_t DTRS12:1; /* Channel 12 Data Transfer Request Status */
2797 uint32_t DTRS11:1; /* Channel 11 Data Transfer Request Status */
2798 uint32_t DTRS10:1; /* Channel 10 Data Transfer Request Status */
2799 uint32_t DTRS9:1; /* Channel 9 Data Transfer Request Status */
2800 uint32_t DTRS8:1; /* Channel 8 Data Transfer Request Status */
2801 uint32_t DTRS7:1; /* Channel 7 Data Transfer Request Status */
2802 uint32_t DTRS6:1; /* Channel 6 Data Transfer Request Status */
2803 uint32_t DTRS5:1; /* Channel 5 Data Transfer Request Status */
2804 uint32_t DTRS4:1; /* Channel 4 Data Transfer Request Status */
2805 uint32_t DTRS3:1; /* Channel 3 Data Transfer Request Status */
2806 uint32_t DTRS2:1; /* Channel 2 Data Transfer Request Status */
2807 uint32_t DTRS1:1; /* Channel 1 Data Transfer Request Status */
2808 uint32_t DTRS0:1; /* Channel 0 Data Transfer Request Status */
2809 } B;
2810 } CDTRSR_B;
2811
2812 uint32_t eTPU_reserved0218[2]; /* 0x0218-0x021F */
2813
2814 union { /* ETPU_A Interruput Overflow Status */
2815 uint32_t R;
2816 struct {
2817 uint32_t CIOS31:1; /* Channel 31 Interruput Overflow Status */
2818 uint32_t CIOS30:1; /* Channel 30 Interruput Overflow Status */
2819 uint32_t CIOS29:1; /* Channel 29 Interruput Overflow Status */
2820 uint32_t CIOS28:1; /* Channel 28 Interruput Overflow Status */
2821 uint32_t CIOS27:1; /* Channel 27 Interruput Overflow Status */
2822 uint32_t CIOS26:1; /* Channel 26 Interruput Overflow Status */
2823 uint32_t CIOS25:1; /* Channel 25 Interruput Overflow Status */
2824 uint32_t CIOS24:1; /* Channel 24 Interruput Overflow Status */
2825 uint32_t CIOS23:1; /* Channel 23 Interruput Overflow Status */
2826 uint32_t CIOS22:1; /* Channel 22 Interruput Overflow Status */
2827 uint32_t CIOS21:1; /* Channel 21 Interruput Overflow Status */
2828 uint32_t CIOS20:1; /* Channel 20 Interruput Overflow Status */
2829 uint32_t CIOS19:1; /* Channel 19 Interruput Overflow Status */
2830 uint32_t CIOS18:1; /* Channel 18 Interruput Overflow Status */
2831 uint32_t CIOS17:1; /* Channel 17 Interruput Overflow Status */
2832 uint32_t CIOS16:1; /* Channel 16 Interruput Overflow Status */
2833 uint32_t CIOS15:1; /* Channel 15 Interruput Overflow Status */
2834 uint32_t CIOS14:1; /* Channel 14 Interruput Overflow Status */
2835 uint32_t CIOS13:1; /* Channel 13 Interruput Overflow Status */
2836 uint32_t CIOS12:1; /* Channel 12 Interruput Overflow Status */
2837 uint32_t CIOS11:1; /* Channel 11 Interruput Overflow Status */
2838 uint32_t CIOS10:1; /* Channel 10 Interruput Overflow Status */
2839 uint32_t CIOS9:1; /* Channel 9 Interruput Overflow Status */
2840 uint32_t CIOS8:1; /* Channel 8 Interruput Overflow Status */
2841 uint32_t CIOS7:1; /* Channel 7 Interruput Overflow Status */
2842 uint32_t CIOS6:1; /* Channel 6 Interruput Overflow Status */
2843 uint32_t CIOS5:1; /* Channel 5 Interruput Overflow Status */
2844 uint32_t CIOS4:1; /* Channel 4 Interruput Overflow Status */
2845 uint32_t CIOS3:1; /* Channel 3 Interruput Overflow Status */
2846 uint32_t CIOS2:1; /* Channel 2 Interruput Overflow Status */
2847 uint32_t CIOS1:1; /* Channel 1 Interruput Overflow Status */
2848 uint32_t CIOS0:1; /* Channel 0 Interruput Overflow Status */
2849 } B;
2850 } CIOSR_A;
2851
2852 union { /* ETPU_B Interruput Overflow Status */
2853 uint32_t R;
2854 struct {
2855 uint32_t CIOS31:1; /* Channel 31 Interruput Overflow Status */
2856 uint32_t CIOS30:1; /* Channel 30 Interruput Overflow Status */
2857 uint32_t CIOS29:1; /* Channel 29 Interruput Overflow Status */
2858 uint32_t CIOS28:1; /* Channel 28 Interruput Overflow Status */
2859 uint32_t CIOS27:1; /* Channel 27 Interruput Overflow Status */
2860 uint32_t CIOS26:1; /* Channel 26 Interruput Overflow Status */
2861 uint32_t CIOS25:1; /* Channel 25 Interruput Overflow Status */
2862 uint32_t CIOS24:1; /* Channel 24 Interruput Overflow Status */
2863 uint32_t CIOS23:1; /* Channel 23 Interruput Overflow Status */
2864 uint32_t CIOS22:1; /* Channel 22 Interruput Overflow Status */
2865 uint32_t CIOS21:1; /* Channel 21 Interruput Overflow Status */
2866 uint32_t CIOS20:1; /* Channel 20 Interruput Overflow Status */
2867 uint32_t CIOS19:1; /* Channel 19 Interruput Overflow Status */
2868 uint32_t CIOS18:1; /* Channel 18 Interruput Overflow Status */
2869 uint32_t CIOS17:1; /* Channel 17 Interruput Overflow Status */
2870 uint32_t CIOS16:1; /* Channel 16 Interruput Overflow Status */
2871 uint32_t CIOS15:1; /* Channel 15 Interruput Overflow Status */
2872 uint32_t CIOS14:1; /* Channel 14 Interruput Overflow Status */
2873 uint32_t CIOS13:1; /* Channel 13 Interruput Overflow Status */
2874 uint32_t CIOS12:1; /* Channel 12 Interruput Overflow Status */
2875 uint32_t CIOS11:1; /* Channel 11 Interruput Overflow Status */
2876 uint32_t CIOS10:1; /* Channel 10 Interruput Overflow Status */
2877 uint32_t CIOS9:1; /* Channel 9 Interruput Overflow Status */
2878 uint32_t CIOS8:1; /* Channel 8 Interruput Overflow Status */
2879 uint32_t CIOS7:1; /* Channel 7 Interruput Overflow Status */
2880 uint32_t CIOS6:1; /* Channel 6 Interruput Overflow Status */
2881 uint32_t CIOS5:1; /* Channel 5 Interruput Overflow Status */
2882 uint32_t CIOS4:1; /* Channel 4 Interruput Overflow Status */
2883 uint32_t CIOS3:1; /* Channel 3 Interruput Overflow Status */
2884 uint32_t CIOS2:1; /* Channel 2 Interruput Overflow Status */
2885 uint32_t CIOS1:1; /* Channel 1 Interruput Overflow Status */
2886 uint32_t CIOS0:1; /* Channel 0 Interruput Overflow Status */
2887 } B;
2888 } CIOSR_B;
2889
2890 uint32_t eTPU_reserved0228[2]; /* 0x0228-0x022F */
2891
2892 union { /* ETPU_A Data Transfer Overflow Status */
2893 uint32_t R;
2894 struct {
2895 uint32_t DTROS31:1; /* Channel 31 Data Transfer Overflow Status */
2896 uint32_t DTROS30:1; /* Channel 30 Data Transfer Overflow Status */
2897 uint32_t DTROS29:1; /* Channel 29 Data Transfer Overflow Status */
2898 uint32_t DTROS28:1; /* Channel 28 Data Transfer Overflow Status */
2899 uint32_t DTROS27:1; /* Channel 27 Data Transfer Overflow Status */
2900 uint32_t DTROS26:1; /* Channel 26 Data Transfer Overflow Status */
2901 uint32_t DTROS25:1; /* Channel 25 Data Transfer Overflow Status */
2902 uint32_t DTROS24:1; /* Channel 24 Data Transfer Overflow Status */
2903 uint32_t DTROS23:1; /* Channel 23 Data Transfer Overflow Status */
2904 uint32_t DTROS22:1; /* Channel 22 Data Transfer Overflow Status */
2905 uint32_t DTROS21:1; /* Channel 21 Data Transfer Overflow Status */
2906 uint32_t DTROS20:1; /* Channel 20 Data Transfer Overflow Status */
2907 uint32_t DTROS19:1; /* Channel 19 Data Transfer Overflow Status */
2908 uint32_t DTROS18:1; /* Channel 18 Data Transfer Overflow Status */
2909 uint32_t DTROS17:1; /* Channel 17 Data Transfer Overflow Status */
2910 uint32_t DTROS16:1; /* Channel 16 Data Transfer Overflow Status */
2911 uint32_t DTROS15:1; /* Channel 15 Data Transfer Overflow Status */
2912 uint32_t DTROS14:1; /* Channel 14 Data Transfer Overflow Status */
2913 uint32_t DTROS13:1; /* Channel 13 Data Transfer Overflow Status */
2914 uint32_t DTROS12:1; /* Channel 12 Data Transfer Overflow Status */
2915 uint32_t DTROS11:1; /* Channel 11 Data Transfer Overflow Status */
2916 uint32_t DTROS10:1; /* Channel 10 Data Transfer Overflow Status */
2917 uint32_t DTROS9:1; /* Channel 9 Data Transfer Overflow Status */
2918 uint32_t DTROS8:1; /* Channel 8 Data Transfer Overflow Status */
2919 uint32_t DTROS7:1; /* Channel 7 Data Transfer Overflow Status */
2920 uint32_t DTROS6:1; /* Channel 6 Data Transfer Overflow Status */
2921 uint32_t DTROS5:1; /* Channel 5 Data Transfer Overflow Status */
2922 uint32_t DTROS4:1; /* Channel 4 Data Transfer Overflow Status */
2923 uint32_t DTROS3:1; /* Channel 3 Data Transfer Overflow Status */
2924 uint32_t DTROS2:1; /* Channel 2 Data Transfer Overflow Status */
2925 uint32_t DTROS1:1; /* Channel 1 Data Transfer Overflow Status */
2926 uint32_t DTROS0:1; /* Channel 0 Data Transfer Overflow Status */
2927 } B;
2928 } CDTROSR_A;
2929
2930 union { /* ETPU_B Data Transfer Overflow Status */
2931 uint32_t R;
2932 struct {
2933 uint32_t DTROS31:1; /* Channel 31 Data Transfer Overflow Status */
2934 uint32_t DTROS30:1; /* Channel 30 Data Transfer Overflow Status */
2935 uint32_t DTROS29:1; /* Channel 29 Data Transfer Overflow Status */
2936 uint32_t DTROS28:1; /* Channel 28 Data Transfer Overflow Status */
2937 uint32_t DTROS27:1; /* Channel 27 Data Transfer Overflow Status */
2938 uint32_t DTROS26:1; /* Channel 26 Data Transfer Overflow Status */
2939 uint32_t DTROS25:1; /* Channel 25 Data Transfer Overflow Status */
2940 uint32_t DTROS24:1; /* Channel 24 Data Transfer Overflow Status */
2941 uint32_t DTROS23:1; /* Channel 23 Data Transfer Overflow Status */
2942 uint32_t DTROS22:1; /* Channel 22 Data Transfer Overflow Status */
2943 uint32_t DTROS21:1; /* Channel 21 Data Transfer Overflow Status */
2944 uint32_t DTROS20:1; /* Channel 20 Data Transfer Overflow Status */
2945 uint32_t DTROS19:1; /* Channel 19 Data Transfer Overflow Status */
2946 uint32_t DTROS18:1; /* Channel 18 Data Transfer Overflow Status */
2947 uint32_t DTROS17:1; /* Channel 17 Data Transfer Overflow Status */
2948 uint32_t DTROS16:1; /* Channel 16 Data Transfer Overflow Status */
2949 uint32_t DTROS15:1; /* Channel 15 Data Transfer Overflow Status */
2950 uint32_t DTROS14:1; /* Channel 14 Data Transfer Overflow Status */
2951 uint32_t DTROS13:1; /* Channel 13 Data Transfer Overflow Status */
2952 uint32_t DTROS12:1; /* Channel 12 Data Transfer Overflow Status */
2953 uint32_t DTROS11:1; /* Channel 11 Data Transfer Overflow Status */
2954 uint32_t DTROS10:1; /* Channel 10 Data Transfer Overflow Status */
2955 uint32_t DTROS9:1; /* Channel 9 Data Transfer Overflow Status */
2956 uint32_t DTROS8:1; /* Channel 8 Data Transfer Overflow Status */
2957 uint32_t DTROS7:1; /* Channel 7 Data Transfer Overflow Status */
2958 uint32_t DTROS6:1; /* Channel 6 Data Transfer Overflow Status */
2959 uint32_t DTROS5:1; /* Channel 5 Data Transfer Overflow Status */
2960 uint32_t DTROS4:1; /* Channel 4 Data Transfer Overflow Status */
2961 uint32_t DTROS3:1; /* Channel 3 Data Transfer Overflow Status */
2962 uint32_t DTROS2:1; /* Channel 2 Data Transfer Overflow Status */
2963 uint32_t DTROS1:1; /* Channel 1 Data Transfer Overflow Status */
2964 uint32_t DTROS0:1; /* Channel 0 Data Transfer Overflow Status */
2965 } B;
2966 } CDTROSR_B;
2967
2968 uint32_t eTPU_reserved0238[2]; /* 0x0238-0x023F */
2969
2970 union { /* ETPU_A Channel Interruput Enable */
2971 uint32_t R;
2972 struct {
2973 uint32_t CIE31:1; /* Channel 31 Interruput Enable */
2974 uint32_t CIE30:1; /* Channel 30 Interruput Enable */
2975 uint32_t CIE29:1; /* Channel 29 Interruput Enable */
2976 uint32_t CIE28:1; /* Channel 28 Interruput Enable */
2977 uint32_t CIE27:1; /* Channel 27 Interruput Enable */
2978 uint32_t CIE26:1; /* Channel 26 Interruput Enable */
2979 uint32_t CIE25:1; /* Channel 25 Interruput Enable */
2980 uint32_t CIE24:1; /* Channel 24 Interruput Enable */
2981 uint32_t CIE23:1; /* Channel 23 Interruput Enable */
2982 uint32_t CIE22:1; /* Channel 22 Interruput Enable */
2983 uint32_t CIE21:1; /* Channel 21 Interruput Enable */
2984 uint32_t CIE20:1; /* Channel 20 Interruput Enable */
2985 uint32_t CIE19:1; /* Channel 19 Interruput Enable */
2986 uint32_t CIE18:1; /* Channel 18 Interruput Enable */
2987 uint32_t CIE17:1; /* Channel 17 Interruput Enable */
2988 uint32_t CIE16:1; /* Channel 16 Interruput Enable */
2989 uint32_t CIE15:1; /* Channel 15 Interruput Enable */
2990 uint32_t CIE14:1; /* Channel 14 Interruput Enable */
2991 uint32_t CIE13:1; /* Channel 13 Interruput Enable */
2992 uint32_t CIE12:1; /* Channel 12 Interruput Enable */
2993 uint32_t CIE11:1; /* Channel 11 Interruput Enable */
2994 uint32_t CIE10:1; /* Channel 10 Interruput Enable */
2995 uint32_t CIE9:1; /* Channel 9 Interruput Enable */
2996 uint32_t CIE8:1; /* Channel 8 Interruput Enable */
2997 uint32_t CIE7:1; /* Channel 7 Interruput Enable */
2998 uint32_t CIE6:1; /* Channel 6 Interruput Enable */
2999 uint32_t CIE5:1; /* Channel 5 Interruput Enable */
3000 uint32_t CIE4:1; /* Channel 4 Interruput Enable */
3001 uint32_t CIE3:1; /* Channel 3 Interruput Enable */
3002 uint32_t CIE2:1; /* Channel 2 Interruput Enable */
3003 uint32_t CIE1:1; /* Channel 1 Interruput Enable */
3004 uint32_t CIE0:1; /* Channel 0 Interruput Enable */
3005 } B;
3006 } CIER_A;
3007
3008 union { /* ETPU_B Channel Interruput Enable */
3009 uint32_t R;
3010 struct {
3011 uint32_t CIE31:1; /* Channel 31 Interruput Enable */
3012 uint32_t CIE30:1; /* Channel 30 Interruput Enable */
3013 uint32_t CIE29:1; /* Channel 29 Interruput Enable */
3014 uint32_t CIE28:1; /* Channel 28 Interruput Enable */
3015 uint32_t CIE27:1; /* Channel 27 Interruput Enable */
3016 uint32_t CIE26:1; /* Channel 26 Interruput Enable */
3017 uint32_t CIE25:1; /* Channel 25 Interruput Enable */
3018 uint32_t CIE24:1; /* Channel 24 Interruput Enable */
3019 uint32_t CIE23:1; /* Channel 23 Interruput Enable */
3020 uint32_t CIE22:1; /* Channel 22 Interruput Enable */
3021 uint32_t CIE21:1; /* Channel 21 Interruput Enable */
3022 uint32_t CIE20:1; /* Channel 20 Interruput Enable */
3023 uint32_t CIE19:1; /* Channel 19 Interruput Enable */
3024 uint32_t CIE18:1; /* Channel 18 Interruput Enable */
3025 uint32_t CIE17:1; /* Channel 17 Interruput Enable */
3026 uint32_t CIE16:1; /* Channel 16 Interruput Enable */
3027 uint32_t CIE15:1; /* Channel 15 Interruput Enable */
3028 uint32_t CIE14:1; /* Channel 14 Interruput Enable */
3029 uint32_t CIE13:1; /* Channel 13 Interruput Enable */
3030 uint32_t CIE12:1; /* Channel 12 Interruput Enable */
3031 uint32_t CIE11:1; /* Channel 11 Interruput Enable */
3032 uint32_t CIE10:1; /* Channel 10 Interruput Enable */
3033 uint32_t CIE9:1; /* Channel 9 Interruput Enable */
3034 uint32_t CIE8:1; /* Channel 8 Interruput Enable */
3035 uint32_t CIE7:1; /* Channel 7 Interruput Enable */
3036 uint32_t CIE6:1; /* Channel 6 Interruput Enable */
3037 uint32_t CIE5:1; /* Channel 5 Interruput Enable */
3038 uint32_t CIE4:1; /* Channel 4 Interruput Enable */
3039 uint32_t CIE3:1; /* Channel 3 Interruput Enable */
3040 uint32_t CIE2:1; /* Channel 2 Interruput Enable */
3041 uint32_t CIE1:1; /* Channel 1 Interruput Enable */
3042 uint32_t CIE0:1; /* Channel 0 Interruput Enable */
3043 } B;
3044 } CIER_B;
3045
3046 uint32_t eTPU_reserved0248[2]; /* 0x0248-0x024F */
3047
3048 union { /* ETPU_A Channel Data Transfer Request Enable */
3049 uint32_t R;
3050 struct {
3051 uint32_t DTRE31:1; /* Channel 31 Data Transfer Request Enable */
3052 uint32_t DTRE30:1; /* Channel 30 Data Transfer Request Enable */
3053 uint32_t DTRE29:1; /* Channel 29 Data Transfer Request Enable */
3054 uint32_t DTRE28:1; /* Channel 28 Data Transfer Request Enable */
3055 uint32_t DTRE27:1; /* Channel 27 Data Transfer Request Enable */
3056 uint32_t DTRE26:1; /* Channel 26 Data Transfer Request Enable */
3057 uint32_t DTRE25:1; /* Channel 25 Data Transfer Request Enable */
3058 uint32_t DTRE24:1; /* Channel 24 Data Transfer Request Enable */
3059 uint32_t DTRE23:1; /* Channel 23 Data Transfer Request Enable */
3060 uint32_t DTRE22:1; /* Channel 22 Data Transfer Request Enable */
3061 uint32_t DTRE21:1; /* Channel 21 Data Transfer Request Enable */
3062 uint32_t DTRE20:1; /* Channel 20 Data Transfer Request Enable */
3063 uint32_t DTRE19:1; /* Channel 19 Data Transfer Request Enable */
3064 uint32_t DTRE18:1; /* Channel 18 Data Transfer Request Enable */
3065 uint32_t DTRE17:1; /* Channel 17 Data Transfer Request Enable */
3066 uint32_t DTRE16:1; /* Channel 16 Data Transfer Request Enable */
3067 uint32_t DTRE15:1; /* Channel 15 Data Transfer Request Enable */
3068 uint32_t DTRE14:1; /* Channel 14 Data Transfer Request Enable */
3069 uint32_t DTRE13:1; /* Channel 13 Data Transfer Request Enable */
3070 uint32_t DTRE12:1; /* Channel 12 Data Transfer Request Enable */
3071 uint32_t DTRE11:1; /* Channel 11 Data Transfer Request Enable */
3072 uint32_t DTRE10:1; /* Channel 10 Data Transfer Request Enable */
3073 uint32_t DTRE9:1; /* Channel 9 Data Transfer Request Enable */
3074 uint32_t DTRE8:1; /* Channel 8 Data Transfer Request Enable */
3075 uint32_t DTRE7:1; /* Channel 7 Data Transfer Request Enable */
3076 uint32_t DTRE6:1; /* Channel 6 Data Transfer Request Enable */
3077 uint32_t DTRE5:1; /* Channel 5 Data Transfer Request Enable */
3078 uint32_t DTRE4:1; /* Channel 4 Data Transfer Request Enable */
3079 uint32_t DTRE3:1; /* Channel 3 Data Transfer Request Enable */
3080 uint32_t DTRE2:1; /* Channel 2 Data Transfer Request Enable */
3081 uint32_t DTRE1:1; /* Channel 1 Data Transfer Request Enable */
3082 uint32_t DTRE0:1; /* Channel 0 Data Transfer Request Enable */
3083 } B;
3084 } CDTRER_A;
3085
3086 union { /* ETPU_B Channel Data Transfer Request Enable */
3087 uint32_t R;
3088 struct {
3089 uint32_t DTRE31:1; /* Channel 31 Data Transfer Request Enable */
3090 uint32_t DTRE30:1; /* Channel 30 Data Transfer Request Enable */
3091 uint32_t DTRE29:1; /* Channel 29 Data Transfer Request Enable */
3092 uint32_t DTRE28:1; /* Channel 28 Data Transfer Request Enable */
3093 uint32_t DTRE27:1; /* Channel 27 Data Transfer Request Enable */
3094 uint32_t DTRE26:1; /* Channel 26 Data Transfer Request Enable */
3095 uint32_t DTRE25:1; /* Channel 25 Data Transfer Request Enable */
3096 uint32_t DTRE24:1; /* Channel 24 Data Transfer Request Enable */
3097 uint32_t DTRE23:1; /* Channel 23 Data Transfer Request Enable */
3098 uint32_t DTRE22:1; /* Channel 22 Data Transfer Request Enable */
3099 uint32_t DTRE21:1; /* Channel 21 Data Transfer Request Enable */
3100 uint32_t DTRE20:1; /* Channel 20 Data Transfer Request Enable */
3101 uint32_t DTRE19:1; /* Channel 19 Data Transfer Request Enable */
3102 uint32_t DTRE18:1; /* Channel 18 Data Transfer Request Enable */
3103 uint32_t DTRE17:1; /* Channel 17 Data Transfer Request Enable */
3104 uint32_t DTRE16:1; /* Channel 16 Data Transfer Request Enable */
3105 uint32_t DTRE15:1; /* Channel 15 Data Transfer Request Enable */
3106 uint32_t DTRE14:1; /* Channel 14 Data Transfer Request Enable */
3107 uint32_t DTRE13:1; /* Channel 13 Data Transfer Request Enable */
3108 uint32_t DTRE12:1; /* Channel 12 Data Transfer Request Enable */
3109 uint32_t DTRE11:1; /* Channel 11 Data Transfer Request Enable */
3110 uint32_t DTRE10:1; /* Channel 10 Data Transfer Request Enable */
3111 uint32_t DTRE9:1; /* Channel 9 Data Transfer Request Enable */
3112 uint32_t DTRE8:1; /* Channel 8 Data Transfer Request Enable */
3113 uint32_t DTRE7:1; /* Channel 7 Data Transfer Request Enable */
3114 uint32_t DTRE6:1; /* Channel 6 Data Transfer Request Enable */
3115 uint32_t DTRE5:1; /* Channel 5 Data Transfer Request Enable */
3116 uint32_t DTRE4:1; /* Channel 4 Data Transfer Request Enable */
3117 uint32_t DTRE3:1; /* Channel 3 Data Transfer Request Enable */
3118 uint32_t DTRE2:1; /* Channel 2 Data Transfer Request Enable */
3119 uint32_t DTRE1:1; /* Channel 1 Data Transfer Request Enable */
3120 uint32_t DTRE0:1; /* Channel 0 Data Transfer Request Enable */
3121 } B;
3122 } CDTRER_B;
3123
3124 uint32_t eTPU_reserved0258[2]; /* 0x0258-0x025F */
3125
3126 union { /* Watchdog Status Register A */
3127 uint32_t R;
3128 struct {
3129 uint32_t WDS31:1;
3130 uint32_t WDS30:1;
3131 uint32_t WDS29:1;
3132 uint32_t WDS28:1;
3133 uint32_t WDS27:1;
3134 uint32_t WDS26:1;
3135 uint32_t WDS25:1;
3136 uint32_t WDS24:1;
3137 uint32_t WDS23:1;
3138 uint32_t WDS22:1;
3139 uint32_t WDS21:1;
3140 uint32_t WDS20:1;
3141 uint32_t WDS19:1;
3142 uint32_t WDS18:1;
3143 uint32_t WDS17:1;
3144 uint32_t WDS16:1;
3145 uint32_t WDS15:1;
3146 uint32_t WDS14:1;
3147 uint32_t WDS13:1;
3148 uint32_t WDS12:1;
3149 uint32_t WDS11:1;
3150 uint32_t WDS10:1;
3151 uint32_t WDS9:1;
3152 uint32_t WDS8:1;
3153 uint32_t WDS7:1;
3154 uint32_t WDS6:1;
3155 uint32_t WDS5:1;
3156 uint32_t WDS4:1;
3157 uint32_t WDS3:1;
3158 uint32_t WDS2:1;
3159 uint32_t WDS1:1;
3160 uint32_t WDS0:1;
3161 } B;
3162 } WDSR_A;
3163
3164 union { /* Watchdog Status Register B */
3165 uint32_t R;
3166 struct {
3167 uint32_t WDS31:1;
3168 uint32_t WDS30:1;
3169 uint32_t WDS29:1;
3170 uint32_t WDS28:1;
3171 uint32_t WDS27:1;
3172 uint32_t WDS26:1;
3173 uint32_t WDS25:1;
3174 uint32_t WDS24:1;
3175 uint32_t WDS23:1;
3176 uint32_t WDS22:1;
3177 uint32_t WDS21:1;
3178 uint32_t WDS20:1;
3179 uint32_t WDS19:1;
3180 uint32_t WDS18:1;
3181 uint32_t WDS17:1;
3182 uint32_t WDS16:1;
3183 uint32_t WDS15:1;
3184 uint32_t WDS14:1;
3185 uint32_t WDS13:1;
3186 uint32_t WDS12:1;
3187 uint32_t WDS11:1;
3188 uint32_t WDS10:1;
3189 uint32_t WDS9:1;
3190 uint32_t WDS8:1;
3191 uint32_t WDS7:1;
3192 uint32_t WDS6:1;
3193 uint32_t WDS5:1;
3194 uint32_t WDS4:1;
3195 uint32_t WDS3:1;
3196 uint32_t WDS2:1;
3197 uint32_t WDS1:1;
3198 uint32_t WDS0:1;
3199 } B;
3200 } WDSR_B;
3201
3202 uint32_t eTPU_reserved0268[6]; /* 0x0268-0x027F */
3203
3204 union { /* ETPU_A Channel Pending Service Status */
3205 uint32_t R;
3206 struct {
3207 uint32_t SR31:1; /* Channel 31 Pending Service Status */
3208 uint32_t SR30:1; /* Channel 30 Pending Service Status */
3209 uint32_t SR29:1; /* Channel 29 Pending Service Status */
3210 uint32_t SR28:1; /* Channel 28 Pending Service Status */
3211 uint32_t SR27:1; /* Channel 27 Pending Service Status */
3212 uint32_t SR26:1; /* Channel 26 Pending Service Status */
3213 uint32_t SR25:1; /* Channel 25 Pending Service Status */
3214 uint32_t SR24:1; /* Channel 24 Pending Service Status */
3215 uint32_t SR23:1; /* Channel 23 Pending Service Status */
3216 uint32_t SR22:1; /* Channel 22 Pending Service Status */
3217 uint32_t SR21:1; /* Channel 21 Pending Service Status */
3218 uint32_t SR20:1; /* Channel 20 Pending Service Status */
3219 uint32_t SR19:1; /* Channel 19 Pending Service Status */
3220 uint32_t SR18:1; /* Channel 18 Pending Service Status */
3221 uint32_t SR17:1; /* Channel 17 Pending Service Status */
3222 uint32_t SR16:1; /* Channel 16 Pending Service Status */
3223 uint32_t SR15:1; /* Channel 15 Pending Service Status */
3224 uint32_t SR14:1; /* Channel 14 Pending Service Status */
3225 uint32_t SR13:1; /* Channel 13 Pending Service Status */
3226 uint32_t SR12:1; /* Channel 12 Pending Service Status */
3227 uint32_t SR11:1; /* Channel 11 Pending Service Status */
3228 uint32_t SR10:1; /* Channel 10 Pending Service Status */
3229 uint32_t SR9:1; /* Channel 9 Pending Service Status */
3230 uint32_t SR8:1; /* Channel 8 Pending Service Status */
3231 uint32_t SR7:1; /* Channel 7 Pending Service Status */
3232 uint32_t SR6:1; /* Channel 6 Pending Service Status */
3233 uint32_t SR5:1; /* Channel 5 Pending Service Status */
3234 uint32_t SR4:1; /* Channel 4 Pending Service Status */
3235 uint32_t SR3:1; /* Channel 3 Pending Service Status */
3236 uint32_t SR2:1; /* Channel 2 Pending Service Status */
3237 uint32_t SR1:1; /* Channel 1 Pending Service Status */
3238 uint32_t SR0:1; /* Channel 0 Pending Service Status */
3239 } B;
3240 } CPSSR_A;
3241
3242 union { /* ETPU_B Channel Pending Service Status */
3243 uint32_t R;
3244 struct {
3245 uint32_t SR31:1; /* Channel 31 Pending Service Status */
3246 uint32_t SR30:1; /* Channel 30 Pending Service Status */
3247 uint32_t SR29:1; /* Channel 29 Pending Service Status */
3248 uint32_t SR28:1; /* Channel 28 Pending Service Status */
3249 uint32_t SR27:1; /* Channel 27 Pending Service Status */
3250 uint32_t SR26:1; /* Channel 26 Pending Service Status */
3251 uint32_t SR25:1; /* Channel 25 Pending Service Status */
3252 uint32_t SR24:1; /* Channel 24 Pending Service Status */
3253 uint32_t SR23:1; /* Channel 23 Pending Service Status */
3254 uint32_t SR22:1; /* Channel 22 Pending Service Status */
3255 uint32_t SR21:1; /* Channel 21 Pending Service Status */
3256 uint32_t SR20:1; /* Channel 20 Pending Service Status */
3257 uint32_t SR19:1; /* Channel 19 Pending Service Status */
3258 uint32_t SR18:1; /* Channel 18 Pending Service Status */
3259 uint32_t SR17:1; /* Channel 17 Pending Service Status */
3260 uint32_t SR16:1; /* Channel 16 Pending Service Status */
3261 uint32_t SR15:1; /* Channel 15 Pending Service Status */
3262 uint32_t SR14:1; /* Channel 14 Pending Service Status */
3263 uint32_t SR13:1; /* Channel 13 Pending Service Status */
3264 uint32_t SR12:1; /* Channel 12 Pending Service Status */
3265 uint32_t SR11:1; /* Channel 11 Pending Service Status */
3266 uint32_t SR10:1; /* Channel 10 Pending Service Status */
3267 uint32_t SR9:1; /* Channel 9 Pending Service Status */
3268 uint32_t SR8:1; /* Channel 8 Pending Service Status */
3269 uint32_t SR7:1; /* Channel 7 Pending Service Status */
3270 uint32_t SR6:1; /* Channel 6 Pending Service Status */
3271 uint32_t SR5:1; /* Channel 5 Pending Service Status */
3272 uint32_t SR4:1; /* Channel 4 Pending Service Status */
3273 uint32_t SR3:1; /* Channel 3 Pending Service Status */
3274 uint32_t SR2:1; /* Channel 2 Pending Service Status */
3275 uint32_t SR1:1; /* Channel 1 Pending Service Status */
3276 uint32_t SR0:1; /* Channel 0 Pending Service Status */
3277 } B;
3278 } CPSSR_B;
3279
3280 uint32_t eTPU_reserved0288[2]; /* 0x0288-0x028F */
3281
3282 union { /* ETPU_A Channel Service Status */
3283 uint32_t R;
3284 struct {
3285 uint32_t SS31:1; /* Channel 31 Service Status */
3286 uint32_t SS30:1; /* Channel 30 Service Status */
3287 uint32_t SS29:1; /* Channel 29 Service Status */
3288 uint32_t SS28:1; /* Channel 28 Service Status */
3289 uint32_t SS27:1; /* Channel 27 Service Status */
3290 uint32_t SS26:1; /* Channel 26 Service Status */
3291 uint32_t SS25:1; /* Channel 25 Service Status */
3292 uint32_t SS24:1; /* Channel 24 Service Status */
3293 uint32_t SS23:1; /* Channel 23 Service Status */
3294 uint32_t SS22:1; /* Channel 22 Service Status */
3295 uint32_t SS21:1; /* Channel 21 Service Status */
3296 uint32_t SS20:1; /* Channel 20 Service Status */
3297 uint32_t SS19:1; /* Channel 19 Service Status */
3298 uint32_t SS18:1; /* Channel 18 Service Status */
3299 uint32_t SS17:1; /* Channel 17 Service Status */
3300 uint32_t SS16:1; /* Channel 16 Service Status */
3301 uint32_t SS15:1; /* Channel 15 Service Status */
3302 uint32_t SS14:1; /* Channel 14 Service Status */
3303 uint32_t SS13:1; /* Channel 13 Service Status */
3304 uint32_t SS12:1; /* Channel 12 Service Status */
3305 uint32_t SS11:1; /* Channel 11 Service Status */
3306 uint32_t SS10:1; /* Channel 10 Service Status */
3307 uint32_t SS9:1; /* Channel 9 Service Status */
3308 uint32_t SS8:1; /* Channel 8 Service Status */
3309 uint32_t SS7:1; /* Channel 7 Service Status */
3310 uint32_t SS6:1; /* Channel 6 Service Status */
3311 uint32_t SS5:1; /* Channel 5 Service Status */
3312 uint32_t SS4:1; /* Channel 4 Service Status */
3313 uint32_t SS3:1; /* Channel 3 Service Status */
3314 uint32_t SS2:1; /* Channel 2 Service Status */
3315 uint32_t SS1:1; /* Channel 1 Service Status */
3316 uint32_t SS0:1; /* Channel 0 Service Status */
3317 } B;
3318 } CSSR_A;
3319
3320 union { /* ETPU_B Channel Service Status */
3321 uint32_t R;
3322 struct {
3323 uint32_t SS31:1; /* Channel 31 Service Status */
3324 uint32_t SS30:1; /* Channel 30 Service Status */
3325 uint32_t SS29:1; /* Channel 29 Service Status */
3326 uint32_t SS28:1; /* Channel 28 Service Status */
3327 uint32_t SS27:1; /* Channel 27 Service Status */
3328 uint32_t SS26:1; /* Channel 26 Service Status */
3329 uint32_t SS25:1; /* Channel 25 Service Status */
3330 uint32_t SS24:1; /* Channel 24 Service Status */
3331 uint32_t SS23:1; /* Channel 23 Service Status */
3332 uint32_t SS22:1; /* Channel 22 Service Status */
3333 uint32_t SS21:1; /* Channel 21 Service Status */
3334 uint32_t SS20:1; /* Channel 20 Service Status */
3335 uint32_t SS19:1; /* Channel 19 Service Status */
3336 uint32_t SS18:1; /* Channel 18 Service Status */
3337 uint32_t SS17:1; /* Channel 17 Service Status */
3338 uint32_t SS16:1; /* Channel 16 Service Status */
3339 uint32_t SS15:1; /* Channel 15 Service Status */
3340 uint32_t SS14:1; /* Channel 14 Service Status */
3341 uint32_t SS13:1; /* Channel 13 Service Status */
3342 uint32_t SS12:1; /* Channel 12 Service Status */
3343 uint32_t SS11:1; /* Channel 11 Service Status */
3344 uint32_t SS10:1; /* Channel 10 Service Status */
3345 uint32_t SS9:1; /* Channel 9 Service Status */
3346 uint32_t SS8:1; /* Channel 8 Service Status */
3347 uint32_t SS7:1; /* Channel 7 Service Status */
3348 uint32_t SS6:1; /* Channel 6 Service Status */
3349 uint32_t SS5:1; /* Channel 5 Service Status */
3350 uint32_t SS4:1; /* Channel 4 Service Status */
3351 uint32_t SS3:1; /* Channel 3 Service Status */
3352 uint32_t SS2:1; /* Channel 2 Service Status */
3353 uint32_t SS1:1; /* Channel 1 Service Status */
3354 uint32_t SS0:1; /* Channel 0 Service Status */
3355 } B;
3356 } CSSR_B;
3357
3358 uint32_t eTPU_reserved0298[2]; /* 0x0298-0x029F */
3359
3360 uint32_t eTPU_reserved02A0[88]; /* 0x02A0-0x03FF */
3361
3362/*****************************Channels********************************/
3363
3364 struct {
3365 union { /* Channel Configuration Register */
3366 uint32_t R;
3367 struct {
3368 uint32_t CIE:1; /* Channel Interruput Enable */
3369 uint32_t DTRE:1; /* Data Transfer Request Enable */
3370 uint32_t CPR:2; /* Channel Priority */
3371 uint32_t:2;
3372 uint32_t ETPD:1;
3373 uint32_t ETCS:1; /* Entry Table Condition Select */
3374 uint32_t:3;
3375 uint32_t CFS:5; /* Channel Function Select */
3376 uint32_t ODIS:1; /* Output disable */
3377 uint32_t OPOL:1; /* output polarity */
3378 uint32_t:3;
3379 uint32_t CPBA:11; /* Channel Parameter Base Address */
3380 } B;
3381 } CR;
3382
3383 union { /* Channel Status Control Register */
3384 uint32_t R;
3385 struct {
3386 uint32_t CIS:1; /* Channel Interruput Status */
3387 uint32_t CIOS:1; /* Channel Interruput Overflow Status */
3388 uint32_t:6;
3389 uint32_t DTRS:1; /* Data Transfer Status */
3390 uint32_t DTROS:1; /* Data Transfer Overflow Status */
3391 uint32_t:6;
3392 uint32_t IPS:1; /* Input Pin State */
3393 uint32_t OPS:1; /* Output Pin State */
3394 uint32_t OBE:1; /* Output Buffer Enable */
3395 uint32_t:11;
3396 uint32_t FM1:1; /* Function mode */
3397 uint32_t FM0:1; /* Function mode */
3398 } B;
3399 } SCR;
3400
3401 union { /* Channel Host Service Request Register */
3402 uint32_t R;
3403 struct {
3404 uint32_t:29; /* Host Service Request */
3405 uint32_t HSR:3;
3406 } B;
3407 } HSRR;
3408
3409 uint32_t eTPU_ch_reserved00C; /* channel offset 0x00C-0x00F */
3410
3411 } CHAN[127];
3412
3413 uint32_t eTPU_reserved1000[7168]; /* 0x1000-0x7FFF */
3414
3415 };
3416
3417/****************************************************************************/
3418/* MODULE : PIT / RTI */
3419/****************************************************************************/
3420
3421 struct PIT_tag {
3422 union { /* Module Configuration Register */
3423 uint32_t R;
3424 struct {
3425 uint32_t:29;
3426 uint32_t MDIS_RTI:1;
3427 uint32_t MDIS:1;
3428 uint32_t FRZ:1;
3429 } B;
3430 } MCR;
3431
3432 uint32_t PIT_reserved0004[59]; /* 0x0004-0x00EF */
3433
3434 struct {
3435 union {
3436 uint32_t R; /* <URM>TSVn</URM> */
3437 } LDVAL; /* Timer Load Value Register */
3438
3439 union {
3440 uint32_t R; /* <URM>TVLn</URM> */
3441 } CVAL; /* Current Timer Value Register */
3442
3443 union {
3444 uint32_t R;
3445 struct {
3446 uint32_t:30;
3447 uint32_t TIE:1;
3448 uint32_t TEN:1;
3449 } B;
3450 } TCTRL; /* Timer Control Register */
3451
3452 union {
3453 uint32_t R;
3454 struct {
3455 uint32_t:31;
3456 uint32_t TIF:1;
3457 } B;
3458 } TFLG; /* Timer Flag Register */
3459 } RTI; /* RTI Channel */
3460
3461 struct {
3462 union {
3463 uint32_t R;
3464 struct {
3465 uint32_t TSV:32;
3466 } B;
3467 } LDVAL;
3468
3469 union {
3470 uint32_t R;
3471 struct {
3472 uint32_t TVL:32;
3473 } B;
3474 } CVAL;
3475
3476 union {
3477 uint32_t R;
3478 struct {
3479 uint32_t:30;
3480 uint32_t TIE:1;
3481 uint32_t TEN:1;
3482 } B;
3483 } TCTRL;
3484
3485 union {
3486 uint32_t R;
3487 struct {
3488 uint32_t:31;
3489 uint32_t TIF:1;
3490 } B;
3491 } TFLG;
3492 } CH[4];
3493
3494 uint32_t PIT_reserved00140[4016]; /* 0x0140-0x3FFF */
3495 };
3496
3497/****************************************************************************/
3498/* MODULE : XBAR CrossBar */
3499/****************************************************************************/
3500
3501 struct XBAR_tag {
3502
3503 union { /* Master Priority Register for Slave Port 0 */
3504 uint32_t R;
3505 struct {
3506 uint32_t:1;
3507 uint32_t MSTR7:3; /* EBI (development bus) */
3508 uint32_t:1;
3509 uint32_t MSTR6:3; /* FlexRay */
3510 uint32_t:1;
3511 uint32_t MSTR5:3; /* eDMA_B */
3512 uint32_t:1;
3513 uint32_t MSTR4:3; /* eDMA_A */
3514 uint32_t:1;
3515 uint32_t MSTR3:3; /* !!! Unsupported in Mamba !!! - Legacy FEC */
3516 uint32_t:1;
3517 uint32_t MSTR2:3; /* !!! Unsupported in Mamba !!! - Legacy EBI */
3518 uint32_t:1;
3519 uint32_t MSTR1:3; /* e200z7 core-Data, and Nexus 3 - Legacy was eDMA_A */
3520 uint32_t:1;
3521 uint32_t MSTR0:3; /* e200z7 core-CPU Instruction - Legacy was z6 core-Instruction/Data & Nexus */
3522 } B;
3523 } MPR0;
3524
3525 uint32_t XBAR_reserved0004[3]; /* 0x0004-0x000F */
3526
3527 union { /* General Purpose Control Register for Slave Port 0 */
3528 uint32_t R;
3529 struct {
3530 uint32_t RO:1;
3531 uint32_t:21;
3532 uint32_t ARB:2;
3533 uint32_t:2;
3534 uint32_t PCTL:2;
3535 uint32_t:1;
3536 uint32_t PARK:3;
3537 } B;
3538 } SGPCR0;
3539
3540 uint32_t XBAR_reserved0014[59]; /* 0x0014-0x00FF */
3541
3542 union { /* Master Priority Register for Slave Port 1 */
3543 uint32_t R;
3544 struct {
3545 uint32_t:1;
3546 uint32_t MSTR7:3; /* EBI (development bus) */
3547 uint32_t:1;
3548 uint32_t MSTR6:3; /* FlexRay */
3549 uint32_t:1;
3550 uint32_t MSTR5:3; /* eDMA_B */
3551 uint32_t:1;
3552 uint32_t MSTR4:3; /* eDMA_A */
3553 uint32_t:1;
3554 uint32_t MSTR3:3; /* !!! Unsupported in Mamba !!! - Legacy FEC */
3555 uint32_t:1;
3556 uint32_t MSTR2:3; /* !!! Unsupported in Mamba !!! - Legacy EBI */
3557 uint32_t:1;
3558 uint32_t MSTR1:3; /* e200z7 core-Data, and Nexus 3 - Legacy was eDMA_A */
3559 uint32_t:1;
3560 uint32_t MSTR0:3; /* e200z7 core-CPU Instruction - Legacy was z6 core-Instruction/Data & Nexus */
3561 } B;
3562 } MPR1;
3563
3564 uint32_t XBAR_reserved0104[3]; /* 0x0104-0x010F */
3565
3566 union { /* General Purpose Control Register for Slave Port 1 */
3567 uint32_t R;
3568 struct {
3569 uint32_t RO:1;
3570 uint32_t:21;
3571 uint32_t ARB:2;
3572 uint32_t:2;
3573 uint32_t PCTL:2;
3574 uint32_t:1;
3575 uint32_t PARK:3;
3576 } B;
3577 } SGPCR1;
3578
3579 uint32_t XBAR_reserved0114[59]; /* 0x0114-0x01FF */
3580
3581 union { /* Master Priority Register for Slave Port 2 */
3582 uint32_t R;
3583 struct {
3584 uint32_t:1;
3585 uint32_t MSTR7:3; /* EBI (development bus) */
3586 uint32_t:1;
3587 uint32_t MSTR6:3; /* FlexRay */
3588 uint32_t:1;
3589 uint32_t MSTR5:3; /* eDMA_B */
3590 uint32_t:1;
3591 uint32_t MSTR4:3; /* eDMA_A */
3592 uint32_t:1;
3593 uint32_t MSTR3:3; /* !!! Unsupported in Mamba !!! - Legacy FEC */
3594 uint32_t:1;
3595 uint32_t MSTR2:3; /* !!! Unsupported in Mamba !!! - Legacy EBI */
3596 uint32_t:1;
3597 uint32_t MSTR1:3; /* e200z7 core-Data, and Nexus 3 - Legacy was eDMA_A */
3598 uint32_t:1;
3599 uint32_t MSTR0:3; /* e200z7 core-CPU Instruction - Legacy was z6 core-Instruction/Data & Nexus */
3600 } B;
3601 } MPR2;
3602
3603 uint32_t XBAR_reserved0204[3]; /* 0x0204-0x020F */
3604
3605 union { /* General Purpose Control Register for Slave Port 2 */
3606 uint32_t R;
3607 struct {
3608 uint32_t RO:1;
3609 uint32_t:21;
3610 uint32_t ARB:2;
3611 uint32_t:2;
3612 uint32_t PCTL:2;
3613 uint32_t:1;
3614 uint32_t PARK:3;
3615 } B;
3616 } SGPCR2;
3617
3618 uint32_t XBAR_reserved0214[59]; /* 0x0214-0x02FF */
3619
3620 uint32_t XBAR_reserved0300[64]; /* 0x0300-0x03FF */
3621
3622 uint32_t XBAR_reserved0400[64]; /* 0x0400-0x04FF */
3623
3624 uint32_t XBAR_reserved0500[64]; /* 0x0500-0x05FF */
3625
3626 union { /* Master Priority Register for Slave Port 6 */
3627 uint32_t R;
3628 struct {
3629 uint32_t:1;
3630 uint32_t MSTR7:3; /* EBI (development bus) */
3631 uint32_t:1;
3632 uint32_t MSTR6:3; /* FlexRay */
3633 uint32_t:1;
3634 uint32_t MSTR5:3; /* eDMA_B */
3635 uint32_t:1;
3636 uint32_t MSTR4:3; /* eDMA_A */
3637 uint32_t:1;
3638 uint32_t MSTR3:3; /* !!! Unsupported in Mamba !!! - Legacy FEC */
3639 uint32_t:1;
3640 uint32_t MSTR2:3; /* !!! Unsupported in Mamba !!! - Legacy EBI */
3641 uint32_t:1;
3642 uint32_t MSTR1:3; /* e200z7 core-Data, and Nexus 3 - Legacy was eDMA_A */
3643 uint32_t:1;
3644 uint32_t MSTR0:3; /* e200z7 core-CPU Instruction - Legacy was z6 core-Instruction/Data & Nexus */
3645 } B;
3646 } MPR6;
3647
3648 uint32_t XBAR_reserved604[3]; /* 0x0604-0x060F */
3649
3650 union { /* General Purpose Control Register for Slave Port 6 */
3651 uint32_t R;
3652 struct {
3653 uint32_t RO:1;
3654 uint32_t:21;
3655 uint32_t ARB:2;
3656 uint32_t:2;
3657 uint32_t PCTL:2;
3658 uint32_t:1;
3659 uint32_t PARK:3;
3660 } B;
3661 } SGPCR6;
3662
3663 uint32_t XBAR_reserved0614[59]; /* 0x0614-0x06FF */
3664
3665 union { /* Master Priority Register for Slave Port 7 */
3666 uint32_t R;
3667 struct {
3668 uint32_t:1;
3669 uint32_t MSTR7:3; /* EBI (development bus) */
3670 uint32_t:1;
3671 uint32_t MSTR6:3; /* FlexRay */
3672 uint32_t:1;
3673 uint32_t MSTR5:3; /* eDMA_B */
3674 uint32_t:1;
3675 uint32_t MSTR4:3; /* eDMA_A */
3676 uint32_t:1;
3677 uint32_t MSTR3:3; /* !!! Unsupported in Mamba !!! - Legacy FEC */
3678 uint32_t:1;
3679 uint32_t MSTR2:3; /* !!! Unsupported in Mamba !!! - Legacy EBI */
3680 uint32_t:1;
3681 uint32_t MSTR1:3; /* e200z7 core-Data, and Nexus 3 - Legacy was eDMA_A */
3682 uint32_t:1;
3683 uint32_t MSTR0:3; /* e200z7 core-CPU Instruction - Legacy was z6 core-Instruction/Data & Nexus */
3684 } B;
3685 } MPR7;
3686
3687 uint32_t XBAR_reserved704[3]; /* 0x0704-0x070F */
3688
3689 union {
3690 uint32_t R;
3691 struct {
3692 uint32_t RO:1;
3693 uint32_t:21;
3694 uint32_t ARB:2;
3695 uint32_t:2;
3696 uint32_t PCTL:2;
3697 uint32_t:1;
3698 uint32_t PARK:3;
3699 } B;
3700 } SGPCR7; /* General Purpose Control Register for Slave Port 7 */
3701
3702 uint32_t XBAR_reserved0714[59]; /* 0x0714-0x07FF */
3703
3704 uint32_t XBAR_reserved0800[3584]; /* 0x0800-0x3FFF */
3705 };
3706
3707/****************************************************************************/
3708/* MODULE : MPU */
3709/****************************************************************************/
3710
3711 struct MPU_tag {
3712
3713 union { /* Module Control/Error Status Register */
3714 uint32_t R;
3715 struct {
3716 uint32_t SPERR:8;
3717 uint32_t:4;
3718 uint32_t HRL:4;
3719 uint32_t NSP:4;
3720 uint32_t NRGD:4;
3721 uint32_t:7;
3722 uint32_t VLD:1;
3723 } B;
3724 } CESR;
3725
3726 uint32_t MPU_reserved0004[3]; /* 0x0004-0x000F */
3727
3728 struct {
3729 union { /* MPU Error Address Registers */
3730 uint32_t R;
3731 struct {
3732 uint32_t EADDR:32;
3733 } B;
3734 } EAR;
3735
3736 union { /* MPU Error Detail Registers */
3737 uint32_t R;
3738 struct {
3739 uint32_t EACD:16;
3740 uint32_t EPID:8;
3741 uint32_t EMN:4;
3742 uint32_t EATTR:3;
3743 uint32_t ERW:1;
3744 } B;
3745 } EDR;
3746 } PORT[3];
3747
3748 uint32_t MPU_reserved0028[246]; /* 0x0028-0x03FF */
3749
3750 struct {
3751 union { /* Region Descriptor n Word 0 */
3752 uint32_t R;
3753 struct {
3754 uint32_t SRTADDR:27;
3755 uint32_t:5;
3756 } B;
3757 } WORD0;
3758
3759 union { /* Region Descriptor n Word 1 */
3760 uint32_t R;
3761 struct {
3762 uint32_t ENDADDR:27;
3763 uint32_t:5;
3764 } B;
3765 } WORD1;
3766
3767 union { /* Region Descriptor n Word 2 */
3768 uint32_t R;
3769 struct {
3770 uint32_t M7RE:1;
3771 uint32_t M7WE:1;
3772 uint32_t M6RE:1;
3773 uint32_t M6WE:1;
3774 uint32_t M5RE:1;
3775 uint32_t M5WE:1;
3776 uint32_t M4RE:1;
3777 uint32_t M4WE:1;
3778 uint32_t: 18;
3779 uint32_t M0PE:1;
3780 uint32_t M0SM:2;
3781 uint32_t M0UM:3;
3782 } B;
3783 } WORD2;
3784
3785 union { /* Region Descriptor n Word 3 */
3786 uint32_t R;
3787 struct {
3788 uint32_t PID:8;
3789 uint32_t PIDMASK:8;
3790 uint32_t:15;
3791 uint32_t VLD:1;
3792 } B;
3793 } WORD3;
3794 } RGD[16];
3795
3796 uint32_t MPU_reserved0500[192]; /* 0x0500-0x07FF */
3797
3798 union { /* Region Descriptor Alternate Access Control n */
3799 uint32_t R;
3800 struct {
3801 uint32_t:6;
3802 uint32_t M4RE:1;
3803 uint32_t M4WE:1;
3804 uint32_t M3PE:1;
3805 uint32_t M3SM:2;
3806 uint32_t M3UM:3;
3807 uint32_t M2PE:1;
3808 uint32_t M2SM:2;
3809 uint32_t M2UM:3;
3810 uint32_t M1PE:1;
3811 uint32_t M1SM:2;
3812 uint32_t M1UM:3;
3813 uint32_t M0PE:1;
3814 uint32_t M0SM:2;
3815 uint32_t M0UM:3;
3816 } B;
3817 } RGDAAC[16];
3818
3819 uint32_t MPU_reserved0840[3568]; /* 0x0840-0x3FFF */
3820
3821 };
3822
3823/****************************************************************************/
3824/* MODULE : SWT */
3825/****************************************************************************/
3826
3827 struct SWT_tag {
3828
3829 union { /* Module Configuration Register */
3830 uint32_t R;
3831 struct {
3832 uint32_t MAP0:1;
3833 uint32_t MAP1:1;
3834 uint32_t:1;
3835 uint32_t:1;
3836 uint32_t MAP4:1;
3837 uint32_t MAP5:1;
3838 uint32_t MAP6:1;
3839 uint32_t MAP7:1;
3840 uint32_t:14;
3841 uint32_t KEY:1;
3842 uint32_t RIA:1;
3843 uint32_t WND:1;
3844 uint32_t ITR:1;
3845 uint32_t HLK:1;
3846 uint32_t SLK:1;
3847 uint32_t CSL:1;
3848 uint32_t STP:1;
3849 uint32_t FRZ:1;
3850 uint32_t WEN:1;
3851 } B;
3852 } MCR;
3853
3854 union { /* Interrupt register */
3855 uint32_t R;
3856 struct {
3857 uint32_t :31;
3858 uint32_t TIF:1;
3859 } B;
3860 } IR;
3861
3862 union { /* Timeout register */
3863 uint32_t R;
3864 struct {
3865 uint32_t WTO:32;
3866 } B;
3867 } TO;
3868
3869 union { /* Window register */
3870 uint32_t R;
3871 struct {
3872 uint32_t WST:32;
3873 } B;
3874 } WN;
3875
3876 union { /* Service register */
3877 uint32_t R;
3878 struct {
3879 uint32_t :16;
3880 uint32_t WSC:16;
3881 } B;
3882 } SR;
3883
3884 union { /* Counter output register */
3885 uint32_t R;
3886 struct {
3887 uint32_t CNT:32;
3888 } B;
3889 } CO;
3890
3891 union { /* Service key register */
3892 uint32_t R;
3893 struct {
3894 uint32_t :16;
3895 uint32_t SK:16;
3896 } B;
3897 } SK;
3898
3899 uint32_t SWT_reserved001C[4089]; /* 0x001C-0x3FFF */
3900
3901 };
3902
3903/****************************************************************************/
3904/* MODULE : STM */
3905/****************************************************************************/
3906
3907 struct STM_tag {
3908
3909 union { /* Control Register */
3910 uint32_t R;
3911 struct {
3912 uint32_t :16;
3913 uint32_t CPS:8;
3914 uint32_t :6;
3915 uint32_t FRZ:1;
3916 uint32_t TEN:1;
3917 } B;
3918 } CR;
3919
3920 union { /* STM Counter */
3921 uint32_t R;
3922 } CNT;
3923
3924 uint32_t STM_reserved0008[2]; /* 0x0008-0x000F */
3925
3926 /* channel 0 registers */
3927 union {
3928 uint32_t R;
3929 struct {
3930 uint32_t :31;
3931 uint32_t CEN:1;
3932 } B;
3933 } CCR0; /* Chan 0 Control Register */
3934
3935 union {
3936 uint32_t R;
3937 struct {
3938 uint32_t :31;
3939 uint32_t CIF:1;
3940 } B;
3941 } CIR0; /* Chan 0 Interrupt Register */
3942
3943 union {
3944 uint32_t R;
3945 } CMP0; /* Chan 0 Compare Register */
3946
3947 uint32_t STM_reserved2[1];
3948
3949/* channel 1 registers */
3950 union {
3951 uint32_t R;
3952 struct {
3953 uint32_t :31;
3954 uint32_t CEN:1;
3955 } B;
3956 } CCR1; /* Chan 1 Control Register */
3957
3958 union {
3959 uint32_t R;
3960 struct {
3961 uint32_t :31;
3962 uint32_t CIF:1;
3963 } B;
3964 } CIR1; /* Chan 1 Interrupt Register */
3965
3966 union {
3967 uint32_t R;
3968 } CMP1; /* Chan 1 Compare Register */
3969
3970 uint32_t STM_reserved3[1];
3971
3972/* channel 2 registers */
3973 union {
3974 uint32_t R;
3975 struct {
3976 uint32_t :31;
3977 uint32_t CEN:1;
3978 } B;
3979 } CCR2; /* Chan 2 Control Register */
3980
3981 union {
3982 uint32_t R;
3983 struct {
3984 uint32_t :31;
3985 uint32_t CIF:1;
3986 } B;
3987 } CIR2; /* Chan 2 Interrupt Register */
3988
3989 union {
3990 uint32_t R;
3991 } CMP2; /* Chan 2 Compare Register */
3992
3993 uint32_t STM_reserved4[1];
3994
3995/* channel 3 registers */
3996 union {
3997 uint32_t R;
3998 struct {
3999 uint32_t :31;
4000 uint32_t CEN:1;
4001 } B;
4002 } CCR3; /* Chan 3 Control Register */
4003
4004 union {
4005 uint32_t R;
4006 struct {
4007 uint32_t :31;
4008 uint32_t CIF:1;
4009 } B;
4010 } CIR3; /* Chan 3 Interrupt Register */
4011
4012 union {
4013 uint32_t R;
4014 } CMP3; /* Chan 3 Compare Register */
4015
4016 uint32_t STM_reserved0050[4076]; /* 0x0050-0x3FFF */
4017
4018 };
4019
4020/****************************************************************************/
4021/* MODULE : ECSM */
4022/****************************************************************************/
4023
4024 struct ECSM_tag {
4025
4026 union { /* Processor core type */
4027 uint16_t R;
4028 } PCT;
4029
4030 union { /* Platform revision */
4031 uint16_t R;
4032 } REV;
4033
4034 uint32_t ECSM_reserved0004; /* 0x0004-0x0007 */
4035
4036 union { /* IPS Module Configuration */
4037 uint32_t R;
4038 } IMC;
4039
4040 uint8_t ECSM_reserved000C[3]; /* 0x000C-0x000E */
4041
4042 union { /* Miscellaneous Reset Status Register */
4043 uint8_t R;
4044 struct {
4045 uint8_t POR:1;
4046 uint8_t DIR:1;
4047 uint8_t SWTR:1;
4048 uint8_t:5;
4049 } B;
4050 } MRSR;
4051
4052 uint8_t ECSM_reserved0010[51]; /* 0x0010-0x0042 */
4053
4054 union { /* ECC Configuration Register */
4055 uint8_t R;
4056 struct {
4057 uint8_t:2;
4058 uint8_t ER1BR:1;
4059 uint8_t EF1BR:1;
4060 uint8_t:2;
4061 uint8_t ERNCR:1;
4062 uint8_t EFNCR:1;
4063 } B;
4064 } ECR;
4065
4066 uint8_t ECSM_reserved0044[3]; /* 0x0044-0x0046 */
4067
4068 union { /* ECC Status Register */
4069 uint8_t R;
4070 struct {
4071 uint8_t:2;
4072 uint8_t R1BC:1;
4073 uint8_t F1BC:1;
4074 uint8_t:2;
4075 uint8_t RNCE:1;
4076 uint8_t FNCE:1;
4077 } B;
4078 } ESR;
4079
4080 uint16_t ECSM_reserved0048; /* 0x0048-0x0049 */
4081
4082 union { /* ECC Error Generation Register */
4083 uint16_t R;
4084 struct {
4085 uint16_t:2;
4086 uint16_t FRC1BI:1;
4087 uint16_t FR11BI:1;
4088 uint16_t:2;
4089 uint16_t FRCNCI:1;
4090 uint16_t FR1NCI:1;
4091 uint16_t:1;
4092 uint16_t ERRBIT:7;
4093 } B;
4094 } EEGR;
4095
4096 uint32_t ECSM_reserved004C; /* 0x004C-0x004F */
4097
4098 union { /* Flash ECC Address Register */
4099 uint32_t R;
4100 struct {
4101 uint32_t FEAR:32;
4102 } B;
4103 } FEAR;
4104
4105 uint16_t ECSM_reserved0054; /* 0x0054-0x0055 */
4106
4107 union { /* Flash ECC Master Number Register */
4108 uint8_t R;
4109 struct {
4110 uint8_t:4;
4111 uint8_t FEMR:4;
4112 } B;
4113 } FEMR;
4114
4115 union { /* Flash ECC Attributes Register */
4116 uint8_t R;
4117 struct {
4118 uint8_t WRITE:1;
4119 uint8_t SIZE:3;
4120 uint8_t PROT0:1;
4121 uint8_t PROT1:1;
4122 uint8_t PROT2:1;
4123 uint8_t PROT3:1;
4124 } B;
4125 } FEAT;
4126
4127 union { /* Flash ECC Data Register High */
4128 uint32_t R;
4129 struct {
4130 uint32_t FEDH:32;
4131 } B;
4132 } FEDRH;
4133
4134 union { /* Flash ECC Data Register Low */
4135 uint32_t R;
4136 struct {
4137 uint32_t FEDL:32;
4138 } B;
4139 } FEDRL;
4140
4141 union { /* RAM ECC Address Register */
4142 uint32_t R;
4143 struct {
4144 uint32_t REAR:32;
4145 } B;
4146 } REAR;
4147
4148 uint16_t ECSM_reserved0064; /* 0x0064-0x0065 */
4149
4150 union { /* RAM ECC Master Number Register */
4151 uint8_t R;
4152 struct {
4153 uint8_t:4;
4154 uint8_t REMR:4;
4155 } B;
4156 } REMR;
4157
4158 union { /* RAM ECC Attributes Register */
4159 uint8_t R;
4160 struct {
4161 uint8_t WRITE:1;
4162 uint8_t SIZE:3;
4163 uint8_t PROT0:1;
4164 uint8_t PROT1:1;
4165 uint8_t PROT2:1;
4166 uint8_t PROT3:1;
4167 } B;
4168 } REAT;
4169
4170 union { /* RAM ECC Data Register */
4171 uint32_t R;
4172 struct {
4173 uint32_t REDH:32;
4174 } B;
4175 } REDRH;
4176
4177 union { /* RAM ECC Data Register */
4178 uint32_t R;
4179 struct {
4180 uint32_t REDL:32;
4181 } B;
4182 } REDRL;
4183
4184 uint32_t ECSM_reserved0070[4068]; /* 0x0070-0x3FFF */
4185
4186 };
4187
4188/****************************************************************************/
4189/* MODULE : INTC */
4190/****************************************************************************/
4191
4192 struct INTC_tag {
4193
4194 union { /* Module Configuration Register */
4195 uint32_t R;
4196 struct {
4197 uint32_t:26;
4198 uint32_t VTES:1;
4199 uint32_t:4;
4200 uint32_t HVEN:1;
4201 } B;
4202 } MCR;
4203
4204 uint32_t INTC_reserved0004; /* 0x0004-0x0007 */
4205
4206 union { /* Current Priority Register */
4207 uint32_t R;
4208 struct {
4209 uint32_t:28;
4210 uint32_t PRI:4;
4211 } B;
4212 } CPR;
4213
4214 uint32_t INTC_reserved000C; /* 0x000C-0x000F */
4215
4216 union { /* Interrupt Acknowledge Register */
4217 uint32_t R;
4218 struct {
4219 uint32_t VTBA:21;
4220 uint32_t INTVEC:9;
4221 uint32_t:2;
4222 } B;
4223 } IACKR;
4224
4225 uint32_t INTC_reserved0014; /* 0x0014-0x0017 */
4226
4227 union { /* End of Interrupt Register */
4228 uint32_t R;
4229 struct {
4230 uint32_t EOIR:32;
4231 } B;
4232 } EOIR;
4233
4234 uint32_t INTC_reserved001C; /* 0x001C-0x001F */
4235
4236 union { /* Software Set/Clear Interruput Register */
4237 uint8_t R;
4238 struct {
4239 uint8_t:6;
4240 uint8_t SET:1;
4241 uint8_t CLR:1;
4242 } B;
4243 } SSCIR[8];
4244
4245 uint32_t INTC_reserved0028[6]; /* 0x0028-0x003F */
4246
4247 union { /* Software Set/Clear Interrupt Register */
4248 uint8_t R;
4249 struct {
4250 uint8_t:4;
4251 uint8_t PRI:4;
4252 } B;
4253 } PSR[480];
4254
4255 uint16_t INTC_reserved0220[7920]; /* 0x0220-0x3FFF */
4256
4257 };
4258
4259/****************************************************************************/
4260/* MODULE : EQADC */
4261/****************************************************************************/
4262
4263 struct EQADC_tag {
4264
4265 union EQADC_MCR_tag { /* Module Configuration Register */
4266 uint32_t R;
4267 struct {
4268 uint32_t:24;
4269 uint32_t ICEA0:1;
4270 uint32_t ICEA1:1;
4271 uint32_t:1;
4272 uint32_t ESSIE:2;
4273 uint32_t:1;
4274 uint32_t DBG:2;
4275 } B;
4276 } MCR;
4277
4278 uint32_t eQADC_reserved0004; /* 0x0004-0x0007 */
4279
4280 union EQADC_NMSFR_tag { /* Null Message Send Format Register */
4281 uint32_t R;
4282 struct {
4283 uint32_t:6;
4284 uint32_t NMF:26;
4285 } B;
4286 } NMSFR;
4287
4288 union EQADC_ETDFR_tag { /* External Trigger Digital Filter Register */
4289 uint32_t R;
4290 struct {
4291 uint32_t:28;
4292 uint32_t DFL:4;
4293 } B;
4294 } ETDFR;
4295
4296 union EQADC_CFPR_tag { /* CFIFO Push Registers */
4297 uint32_t R;
4298 struct {
4299 uint32_t CFPUSH:32;
4300 } B;
4301 } CFPR[6];
4302
4303 uint32_t eQADC_reserved0028[2]; /* 0x0028-0x002F */
4304
4305 union EQADC_RFPR_tag { /* Result FIFO Pop Registers */
4306 uint32_t R;
4307 struct {
4308 uint32_t:16;
4309 uint32_t RFPOP:16;
4310 } B;
4311 } RFPR[6];
4312
4313 uint32_t eQADC_reserved0048[2]; /* 0x0048-0x004F */
4314
4315 union EQADC_CFCR_tag { /* CFIFO Control Registers */
4316 uint16_t R;
4317 struct {
4318 uint16_t:3;
4319 uint16_t CFEEE0:1;
4320 uint16_t STRME0:1;
4321 uint16_t SSE:1;
4322 uint16_t CFINV:1;
4323 uint16_t:1;
4324 uint16_t MODE:4;
4325 uint16_t AMODE0:4;
4326 } B;
4327 } CFCR[6];
4328
4329 uint32_t eQADC_reserved005C; /* 0x005C-0x005F */
4330
4331 union EQADC_IDCR_tag { /* Interrupt and DMA Control Registers */
4332 uint16_t R;
4333 struct {
4334 uint16_t NCIE:1;
4335 uint16_t TORIE:1;
4336 uint16_t PIE:1;
4337 uint16_t EOQIE:1;
4338 uint16_t CFUIE:1;
4339 uint16_t:1;
4340 uint16_t CFFE:1;
4341 uint16_t CFFS:1;
4342 uint16_t:4;
4343 uint16_t RFOIE:1;
4344 uint16_t:1;
4345 uint16_t RFDE:1;
4346 uint16_t RFDS:1;
4347 } B;
4348 } IDCR[6];
4349
4350 uint32_t eQADC_reserved006C; /* 0x006C-0x006F */
4351
4352 union { /* FIFO and Interrupt Status Registers */
4353 uint32_t R;
4354 struct {
4355 uint32_t NCF:1;
4356 uint32_t TORF:1;
4357 uint32_t PF:1;
4358 uint32_t EOQF:1;
4359 uint32_t CFUF:1;
4360 uint32_t SSS:1;
4361 uint32_t CFFF:1;
4362 uint32_t:5;
4363 uint32_t RFOF:1;
4364 uint32_t:1;
4365 uint32_t RFDF:1;
4366 uint32_t:1;
4367 uint32_t CFCTR:4;
4368 uint32_t TNXTPTR:4;
4369 uint32_t RFCTR:4;
4370 uint32_t POPNXTPTR:4;
4371 } B;
4372 } FISR[6];
4373
4374 uint32_t eQADC_reserved0088[2]; /* 0x0088-0x008F */
4375
4376 union { /* CFIFO Transfer Counter Registers */
4377 uint16_t R;
4378 struct {
4379 uint16_t:5;
4380 uint16_t TCCF:11; /* Legacy naming - refer to TC_CF in Reference Manual */
4381 } B;
4382 } CFTCR[6];
4383
4384 uint32_t eQADC_reserved009C[1]; /* 0x009F */
4385
4386 union { /* CFIFO Status Register 0 */
4387 uint32_t R;
4388 struct {
4389 uint32_t CFS0:2; /* Legacy naming - refer to CFS0_TCB0 in Reference Manual */
4390 uint32_t CFS1:2; /* Legacy naming - refer to CFS1_TCB0 in Reference Manual */
4391 uint32_t CFS2:2; /* Legacy naming - refer to CFS2_TCB0 in Reference Manual */
4392 uint32_t CFS3:2; /* Legacy naming - refer to CFS3_TCB0 in Reference Manual */
4393 uint32_t CFS4:2; /* Legacy naming - refer to CFS4_TCB0 in Reference Manual */
4394 uint32_t CFS5:2; /* Legacy naming - refer to CFS5_TCB0 in Reference Manual */
4395 uint32_t:5;
4396 uint32_t LCFTCB0:4;
4397 uint32_t TC_LCFTCB0:11;
4398 } B;
4399 } CFSSR0;
4400
4401 union { /* CFIFO Status Register 1 */
4402 uint32_t R;
4403 struct {
4404 uint32_t CFS0:2; /* Legacy naming - refer to CFS0_TCB1 in Reference Manual */
4405 uint32_t CFS1:2; /* Legacy naming - refer to CFS1_TCB1 in Reference Manual */
4406 uint32_t CFS2:2; /* Legacy naming - refer to CFS2_TCB1 in Reference Manual */
4407 uint32_t CFS3:2; /* Legacy naming - refer to CFS3_TCB1 in Reference Manual */
4408 uint32_t CFS4:2; /* Legacy naming - refer to CFS4_TCB1 in Reference Manual */
4409 uint32_t CFS5:2; /* Legacy naming - refer to CFS5_TCB1 in Reference Manual */
4410 uint32_t:5;
4411 uint32_t LCFTCB1:4;
4412 uint32_t TC_LCFTCB1:11;
4413 } B;
4414 } CFSSR1;
4415
4416 union { /* CFIFO Status Register 2 */
4417 uint32_t R;
4418 struct {
4419 uint32_t CFS0:2; /* Legacy naming - refer to CFS0_TSSI in Reference Manual */
4420 uint32_t CFS1:2; /* Legacy naming - refer to CFS1_TSSI in Reference Manual */
4421 uint32_t CFS2:2; /* Legacy naming - refer to CFS2_TSSI in Reference Manual */
4422 uint32_t CFS3:2; /* Legacy naming - refer to CFS3_TSSI in Reference Manual */
4423 uint32_t CFS4:2; /* Legacy naming - refer to CFS4_TSSI in Reference Manual */
4424 uint32_t CFS5:2; /* Legacy naming - refer to CFS5_TSSI in Reference Manual */
4425 uint32_t:4;
4426 uint32_t ECBNI:1;
4427 uint32_t LCFTSSI:4;
4428 uint32_t TC_LCFTSSI:11;
4429 } B;
4430 } CFSSR2;
4431
4432 union { /* CFIFO Status Register */
4433 uint32_t R;
4434 struct {
4435 uint32_t CFS0:2;
4436 uint32_t CFS1:2;
4437 uint32_t CFS2:2;
4438 uint32_t CFS3:2;
4439 uint32_t CFS4:2;
4440 uint32_t CFS5:2;
4441 uint32_t:20;
4442 } B;
4443 } CFSR;
4444
4445 uint32_t eQADC_reserved00B0; /* 0x00B0-0x00B3 */
4446
4447 union EQADC_SSICR_tag { /* SSI Control Register */
4448 uint32_t R;
4449 struct {
4450 uint32_t:21;
4451 uint32_t MDT:3;
4452 uint32_t:4;
4453 uint32_t BR:4;
4454 } B;
4455 } SSICR;
4456
4457 union { /* SSI Recieve Data Register */
4458 uint32_t R;
4459 struct {
4460 uint32_t RDV:1;
4461 uint32_t:5;
4462 uint32_t RDATA:26;
4463 } B;
4464 } SSIRDR;
4465
4466 uint32_t eQADC_reserved00BC[17]; /* 0x00BC-0x00FF */
4467
4468 struct {
4469 union {
4470 uint32_t R;
4471 struct {
4472 uint32_t CFIFO_DATA:32;
4473 } B;
4474 } R[4];
4475
4476 uint32_t eQADC_cf_reserved010[12]; /* CFIFO offset 0x010-0x03F */
4477
4478 } CF[6];
4479
4480 uint32_t eQADC_reserved0280[32]; /* 0x0280-0x02FF */
4481
4482 struct {
4483 union {
4484 uint32_t R;
4485 struct {
4486 uint32_t RFIFO_DATA:32;
4487 } B;
4488 } R[4];
4489
4490 uint32_t eQADC_rf_reserved010[12]; /* RFIFO offset 0x010-0x03F */
4491
4492 } RF[6];
4493
4494 uint32_t eQADC_reserved0480[3808]; /* 0x0480-0x3FFF */
4495 };
4496
4497/****************************************************************************/
4498/* MODULE : Decimation Filter */
4499/****************************************************************************/
4500
4501 struct DECFIL_tag {
4502
4503 union { /* Module Configuration Register */
4504 uint32_t R;
4505 struct {
4506 uint32_t MDIS:1;
4507 uint32_t FREN:1;
4508 uint32_t :1;
4509 uint32_t FRZ:1;
4510 uint32_t SRES:1;
4511 uint32_t CASCD:2;
4512 uint32_t IDEN:1;
4513 uint32_t ODEN:1;
4514 uint32_t ERREN:1;
4515 uint32_t :1;
4516 uint32_t FTYPE:2;
4517 uint32_t :1;
4518 uint32_t SCAL:2;
4519 uint32_t :1;
4520 uint32_t SAT:1;
4521 uint32_t ISEL:1;
4522 uint32_t :1;
4523 uint32_t DEC_RATE:4;
4524 uint32_t :1;
4525 uint32_t DSEL:1;
4526 uint32_t IBIE:1;
4527 uint32_t OBIE:1;
4528 uint32_t EDME:1;
4529 uint32_t TORE:1;
4530 uint32_t TRFE:1;
4531 uint32_t :1;
4532 } B;
4533 } MCR;
4534
4535 union { /* Module Status Register */
4536 uint32_t R;
4537 struct {
4538 uint32_t BSY:1;
4539 uint32_t:1;
4540 uint32_t DEC_COUNTER:4;
4541 uint32_t IDFC:1;
4542 uint32_t ODFC:1;
4543 uint32_t:1;
4544 uint32_t IBIC:1;
4545 uint32_t OBIC:1;
4546 uint32_t:1;
4547 uint32_t DIVRC:1;
4548 uint32_t OVFC:1;
4549 uint32_t OVRC:1;
4550 uint32_t IVRC:1;
4551 uint32_t:6;
4552 uint32_t IDF:1;
4553 uint32_t ODF:1;
4554 uint32_t:1;
4555 uint32_t IBIF:1;
4556 uint32_t OBIF:1;
4557 uint32_t:1;
4558 uint32_t DIVR:1;
4559 uint32_t OVF:1;
4560 uint32_t OVR:1;
4561 uint32_t IVR:1;
4562 } B;
4563 } SR;
4564
4565 union { /* Module Extended Config Register */
4566 uint32_t R;
4567 struct {
4568 uint32_t SDMAE:1;
4569 uint32_t SSIG:1;
4570 uint32_t SSAT:1;
4571 uint32_t SCSAT:1;
4572 uint32_t:10;
4573 uint32_t SRQ:1;
4574 uint32_t SZR0:1;
4575 uint32_t:1;
4576 uint32_t SISEL:1;
4577 uint32_t SZROSEL:2;
4578 uint32_t:2;
4579 uint32_t SHLTSEL:2;
4580 uint32_t:1;
4581 uint32_t SRQSEL:3;
4582 uint32_t:2;
4583 uint32_t SENSEL:2;
4584 } B;
4585 } MXCR;
4586
4587 union { /* Module Extended Status Register */
4588 uint32_t R;
4589 struct {
4590 uint32_t:7;
4591 uint32_t SDFC:1;
4592 uint32_t:2;
4593 uint32_t SSEC:1;
4594 uint32_t SCEC:1;
4595 uint32_t:1;
4596 uint32_t SSOVFC:1;
4597 uint32_t SCOVFC:1;
4598 uint32_t SVRC:1;
4599 uint32_t:7;
4600 uint32_t SDF:1;
4601 uint32_t:2;
4602 uint32_t SSE:1;
4603 uint32_t SCE:1;
4604 uint32_t:1;
4605 uint32_t SSOVF:1;
4606 uint32_t SCOVF:1;
4607 uint32_t SVR:1;
4608 } B;
4609 } MXSR;
4610
4611 union { /* Interface Input Buffer Register */
4612 uint32_t R;
4613 struct {
4614 uint32_t:14;
4615 uint32_t PREFILL:1;
4616 uint32_t FLUSH:1;
4617 uint32_t INPBUF:16;
4618 } B;
4619 } IB;
4620
4621 union { /* Interface Output Buffer Register */
4622 uint32_t R;
4623 struct {
4624 uint32_t:9;
4625 uint32_t TSI:1;
4626 uint32_t:2;
4627 uint32_t OUTTAG:4;
4628 uint32_t OUTBUF:16;
4629 } B;
4630 } OB;
4631
4632 uint32_t DFILT_reserved0018[2]; /* 0x0018-0x001F */
4633
4634 union { /* Coefficient n Register */
4635 int32_t R;
4636 struct {
4637 int32_t:8;
4638 int32_t COEF:24;
4639 } B;
4640 } COEF[9];
4641
4642 uint32_t DFILT_reserved0044[13]; /* 0x0044-0x0077 */
4643
4644 union { /* TAP n Register */
4645 int32_t R;
4646 struct {
4647 int32_t:8;
4648 int32_t TAP:24;
4649 } B;
4650 } TAP[8];
4651
4652 uint32_t DFILT_reserved0098[14]; /* 0x0098-0x00CF */
4653
4654 union { /* EDID Register */
4655 uint32_t R;
4656 struct {
4657 uint32_t:16;
4658 uint32_t SAMP_DATA:16;
4659 } B;
4660 } EDID;
4661
4662 uint32_t DFILT_reserved00D4[459]; /* 0x00D4-0x07FF */
4663
4664 };
4665
4666/****************************************************************************/
4667/* MODULE : DSPI */
4668/****************************************************************************/
4669
4670 struct DSPI_tag {
4671
4672 union DSPI_MCR_tag { /* Module Configuration Register */
4673 uint32_t R;
4674 struct {
4675 uint32_t MSTR:1;
4676 uint32_t CONT_SCKE:1;
4677 uint32_t DCONF:2;
4678 uint32_t FRZ:1;
4679 uint32_t MTFE:1;
4680 uint32_t PCSSE:1;
4681 uint32_t ROOE:1;
4682 uint32_t PCSIS7:1;
4683 uint32_t PCSIS6:1;
4684 uint32_t PCSIS5:1;
4685 uint32_t PCSIS4:1;
4686 uint32_t PCSIS3:1;
4687 uint32_t PCSIS2:1;
4688 uint32_t PCSIS1:1;
4689 uint32_t PCSIS0:1;
4690 uint32_t DOZE:1;
4691 uint32_t MDIS:1;
4692 uint32_t DIS_TXF:1;
4693 uint32_t DIS_RXF:1;
4694 uint32_t CLR_TXF:1;
4695 uint32_t CLR_RXF:1;
4696 uint32_t SMPL_PT:2;
4697 uint32_t:7;
4698 uint32_t HALT:1;
4699 } B;
4700 } MCR;
4701
4702 uint32_t DSPI_reserved0004; /* 0x0004-0x0007 */
4703
4704 union { /* Transfer Count Register */
4705 uint32_t R;
4706 struct {
4707 uint32_t TCNT:16;
4708 uint32_t:16;
4709 } B;
4710 } TCR;
4711
4712 union DSPI_CTAR_tag {/* Clock and Transfer Attributes Registers */
4713 uint32_t R;
4714 struct {
4715 uint32_t DBR:1;
4716 uint32_t FMSZ:4;
4717 uint32_t CPOL:1;
4718 uint32_t CPHA:1;
4719 uint32_t LSBFE:1;
4720 uint32_t PCSSCK:2;
4721 uint32_t PASC:2;
4722 uint32_t PDT:2;
4723 uint32_t PBR:2;
4724 uint32_t CSSCK:4;
4725 uint32_t ASC:4;
4726 uint32_t DT:4;
4727 uint32_t BR:4;
4728 } B;
4729 } CTAR[8];
4730
4731 union DSPI_SR_tag { /* Status Register */
4732 uint32_t R;
4733 struct {
4734 uint32_t TCF:1;
4735 uint32_t TXRXS:1;
4736 uint32_t:1;
4737 uint32_t EOQF:1;
4738 uint32_t TFUF:1;
4739 uint32_t:1;
4740 uint32_t TFFF:1;
4741 uint32_t:5;
4742 uint32_t RFOF:1;
4743 uint32_t:1;
4744 uint32_t RFDF:1;
4745 uint32_t:1;
4746 uint32_t TXCTR:4;
4747 uint32_t TXNXTPTR:4;
4748 uint32_t RXCTR:4;
4749 uint32_t POPNXTPTR:4;
4750 } B;
4751 } SR;
4752
4753 union DSPI_RSER_tag { /* DMA/Interrupt Request Select and Enable Register */
4754 uint32_t R;
4755 struct {
4756 uint32_t TCFRE:1;
4757 uint32_t:2;
4758 uint32_t EOQFRE:1;
4759 uint32_t TFUFRE:1;
4760 uint32_t:1;
4761 uint32_t TFFFRE:1;
4762 uint32_t TFFFDIRS:1;
4763 uint32_t:4;
4764 uint32_t RFOFRE:1;
4765 uint32_t:1;
4766 uint32_t RFDFRE:1;
4767 uint32_t RFDFDIRS:1;
4768 uint32_t:16;
4769 } B;
4770 } RSER;
4771
4772 union DSPI_PUSHR_tag { /* PUSH TX FIFO Register */
4773 uint32_t R;
4774 struct {
4775 uint32_t CONT:1;
4776 uint32_t CTAS:3;
4777 uint32_t EOQ:1;
4778 uint32_t CTCNT:1;
4779 uint32_t:2;
4780 uint32_t PCS7:1;
4781 uint32_t PCS6:1;
4782 uint32_t PCS5:1;
4783 uint32_t PCS4:1;
4784 uint32_t PCS3:1;
4785 uint32_t PCS2:1;
4786 uint32_t PCS1:1;
4787 uint32_t PCS0:1;
4788 uint32_t TXDATA:16;
4789 } B;
4790 } PUSHR;
4791
4792 union DSPI_POPR_tag { /* POP RX FIFO Register */
4793 uint32_t R;
4794 struct {
4795 uint32_t:16;
4796 uint32_t RXDATA:16;
4797 } B;
4798 } POPR;
4799
4800 union { /* Transmit FIFO Registers */
4801 uint32_t R;
4802 struct {
4803 uint32_t TXCMD:16;
4804 uint32_t TXDATA:16;
4805 } B;
4806 } TXFR[4];
4807
4808 uint32_t DSPI_reserved004C[12]; /* 0x004C-0x007B */
4809
4810 union { /* Transmit FIFO Registers */
4811 uint32_t R;
4812 struct {
4813 uint32_t:16;
4814 uint32_t RXDATA:16;
4815 } B;
4816 } RXFR[4];
4817
4818 uint32_t DSPI_reserved008C[12]; /* 0x008C-0x00BB */
4819
4820 union { /* DSI Configuration Register */
4821 uint32_t R;
4822 struct {
4823 uint32_t MTOE:1;
4824 uint32_t:1;
4825 uint32_t MTOCNT:6;
4826 uint32_t:3;
4827 uint32_t TSBC:1;
4828 uint32_t TXSS:1;
4829 uint32_t TPOL:1;
4830 uint32_t TRRE:1;
4831 uint32_t CID:1;
4832 uint32_t DCONT:1;
4833 uint32_t DSICTAS:3;
4834 uint32_t:4;
4835 uint32_t DPCS7:1;
4836 uint32_t DPCS6:1;
4837 uint32_t DPCS5:1;
4838 uint32_t DPCS4:1;
4839 uint32_t DPCS3:1;
4840 uint32_t DPCS2:1;
4841 uint32_t DPCS1:1;
4842 uint32_t DPCS0:1;
4843 } B;
4844 } DSICR;
4845
4846 union { /* DSI Serialization Data Register */
4847 uint32_t R;
4848 struct {
4849 uint32_t SER_DATA:32;
4850 } B;
4851 } SDR;
4852
4853 union { /* DSI Alternate Serialization Data Register */
4854 uint32_t R;
4855 struct {
4856 uint32_t ASER_DATA:32;
4857 } B;
4858 } ASDR;
4859
4860 union { /* DSI Transmit Comparison Register */
4861 uint32_t R;
4862 struct {
4863 uint32_t COMP_DATA:32;
4864 } B;
4865 } COMPR;
4866
4867 union { /* DSI deserialization Data Register */
4868 uint32_t R;
4869 struct {
4870 uint32_t DESER_DATA:32;
4871 } B;
4872 } DDR;
4873
4874 union {
4875 uint32_t R;
4876 struct {
4877 uint32_t:3;
4878 uint32_t TSBCNT:5;
4879 uint32_t:16;
4880 uint32_t DPCS1_7:1;
4881 uint32_t DPCS1_6:1;
4882 uint32_t DPCS1_5:1;
4883 uint32_t DPCS1_4:1;
4884 uint32_t DPCS1_3:1;
4885 uint32_t DPCS1_2:1;
4886 uint32_t DPCS1_1:1;
4887 uint32_t DPCS1_0:1;
4888 } B;
4889 } DSICR1;
4890 uint32_t DSPI_reserved00D4[4043]; /* 0x00D4-0x3FFF */
4891
4892 };
4893
4894/****************************************************************************/
4895/* MODULE : eSCI */
4896/****************************************************************************/
4897
4898 struct ESCI_tag {
4899 union ESCI_CR1_tag { /* Control Register 1 */
4900 uint32_t R;
4901 struct {
4902 uint32_t:3;
4903 uint32_t SBR:13;
4904 uint32_t LOOPS:1;
4905 uint32_t:1;
4906 uint32_t RSRC:1;
4907 uint32_t M:1;
4908 uint32_t WAKE:1;
4909 uint32_t ILT:1;
4910 uint32_t PE:1;
4911 uint32_t PT:1;
4912 uint32_t TIE:1;
4913 uint32_t TCIE:1;
4914 uint32_t RIE:1;
4915 uint32_t ILIE:1;
4916 uint32_t TE:1;
4917 uint32_t RE:1;
4918 uint32_t RWU:1;
4919 uint32_t SBK:1;
4920 } B;
4921 } CR1;
4922
4923 union ESCI_CR2_tag { /* Control Register 2 */
4924 uint16_t R;
4925 struct {
4926 uint16_t MDIS:1;
4927 uint16_t FBR:1;
4928 uint16_t BSTP:1;
4929 uint16_t IEBERR:1;
4930 uint16_t RXDMA:1;
4931 uint16_t TXDMA:1;
4932 uint16_t BRK13:1;
4933 uint16_t TXDIR:1;
4934 uint16_t BESM13:1;
4935 uint16_t SBSTP:1;
4936 uint16_t RXPOL:1;
4937 uint16_t PMSK:1;
4938 uint16_t ORIE:1;
4939 uint16_t NFIE:1;
4940 uint16_t FEIE:1;
4941 uint16_t PFIE:1;
4942 } B;
4943 } CR2;
4944
4945 union ESCI_DR_tag { /* Data Register */
4946 uint16_t R;
4947
4948 struct {
4949 uint16_t RN:1;
4950 uint16_t TN:1;
4951 uint16_t ERR:1;
4952 uint16_t:1;
4953 uint16_t RD_11:4;
4954 uint16_t D:8;
4955 } B;
4956 } DR; /* Legacy naming - refer to SDR in Reference Manual */
4957
4958 union ESCI_SR_tag { /* Status Register */
4959 uint32_t R;
4960 struct {
4961 uint32_t TDRE:1;
4962 uint32_t TC:1;
4963 uint32_t RDRF:1;
4964 uint32_t IDLE:1;
4965 uint32_t OR:1;
4966 uint32_t NF:1;
4967 uint32_t FE:1;
4968 uint32_t PF:1;
4969 uint32_t:3;
4970 uint32_t BERR:1;
4971 uint32_t:2;
4972 uint32_t TACT:1;
4973 uint32_t RAF:1;
4974 uint32_t RXRDY:1;
4975 uint32_t TXRDY:1;
4976 uint32_t LWAKE:1;
4977 uint32_t STO:1;
4978 uint32_t PBERR:1;
4979 uint32_t CERR:1;
4980 uint32_t CKERR:1;
4981 uint32_t FRC:1;
4982 uint32_t:6;
4983 uint32_t UREQ:1;
4984 uint32_t OVFL:1;
4985 } B;
4986 } SR;
4987
4988 union { /* LIN Control Register */
4989 uint32_t R;
4990 struct {
4991 uint32_t LRES:1;
4992 uint32_t WU:1;
4993 uint32_t WUD0:1;
4994 uint32_t WUD1:1;
4995 uint32_t :2;
4996 uint32_t PRTY:1;
4997 uint32_t LIN:1;
4998 uint32_t RXIE:1;
4999 uint32_t TXIE:1;
5000 uint32_t WUIE:1;
5001 uint32_t STIE:1;
5002 uint32_t PBIE:1;
5003 uint32_t CIE:1;
5004 uint32_t CKIE:1;
5005 uint32_t FCIE:1;
5006 uint32_t:6;
5007 uint32_t UQIE:1;
5008 uint32_t OFIE:1;
5009 uint32_t:8;
5010 } B;
5011 } LCR;
5012
5013 union { /* LIN Transmit Register */
5014 uint8_t R;
5015 } LTR;
5016
5017 uint8_t eSCI_reserved0011[3]; /* 0x0011-0x0013 */
5018
5019 union { /* LIN Recieve Register */
5020 uint8_t R;
5021 struct {
5022 uint8_t D:8;
5023 } B;
5024 } LRR;
5025
5026 uint8_t eSCI_reserved0015[3]; /* 0x0015-0x0017 */
5027
5028 union { /* LIN CRC Polynom Register */
5029 uint16_t R;
5030 struct {
5031 uint16_t P:16;
5032 } B;
5033 } LPR;
5034
5035 union { /* Control Register 3 */
5036 uint16_t R;
5037 struct {
5038 uint16_t:3;
5039 uint16_t SYNM:1;
5040 uint16_t EROE:1;
5041 uint16_t ERFE:1;
5042 uint16_t ERPE:1;
5043 uint16_t M2:1;
5044 uint16_t:8;
5045 } B;
5046 } CR3;
5047
5048 uint32_t eSCI_reserved001C; /* 0x001C-0x001F */
5049
5050 uint32_t eSCI_reserved0020[4088]; /* 0x0020-0x3FFF */
5051
5052 };
5053
5054/****************************************************************************/
5055/* MODULE : FlexCAN */
5056/****************************************************************************/
5057
5058 struct FLEXCAN2_tag {
5059 union { /* Module Configuration Register */
5060 uint32_t R;
5061 struct {
5062 uint32_t MDIS:1;
5063 uint32_t FRZ:1;
5064 uint32_t FEN:1;
5065 uint32_t HALT:1;
5066 uint32_t NOTRDY:1;
5067 uint32_t WAK_MSK:1;
5068 uint32_t SOFTRST:1;
5069 uint32_t FRZACK:1;
5070 uint32_t SUPV:1;
5071 uint32_t SLF_WAK:1;
5072 uint32_t WRNEN:1;
5073 uint32_t MDISACK:1;
5074 uint32_t WAK_SRC:1;
5075 uint32_t DOZE:1;
5076 uint32_t SRXDIS:1;
5077 uint32_t BCC:1;
5078 uint32_t:2;
5079 uint32_t LPRIO_EN:1;
5080 uint32_t AEN:1;
5081 uint32_t:2;
5082 uint32_t IDAM:2;
5083 uint32_t:2;
5084 uint32_t MAXMB:6;
5085 } B;
5086 } MCR;
5087
5088 union { /* Control Register */
5089 uint32_t R;
5090 struct {
5091 uint32_t PRESDIV:8;
5092 uint32_t RJW:2;
5093 uint32_t PSEG1:3;
5094 uint32_t PSEG2:3;
5095 uint32_t BOFFMSK:1;
5096 uint32_t ERRMSK:1;
5097 uint32_t CLKSRC:1;
5098 uint32_t LPB:1;
5099 uint32_t TWRNMSK:1;
5100 uint32_t RWRNMSK:1;
5101 uint32_t:2;
5102 uint32_t SMP:1;
5103 uint32_t BOFFREC:1;
5104 uint32_t TSYN:1;
5105 uint32_t LBUF:1;
5106 uint32_t LOM:1;
5107 uint32_t PROPSEG:3;
5108 } B;
5109 } CR; /* Legacy naming - refer to CTRL in Reference Manual */
5110
5111 union { /* Free Running Timer */
5112 uint32_t R;
5113 } TIMER;
5114
5115 int32_t FLEXCAN_reserved000C; /* 0x000C-0x000F */
5116
5117 union { /* RX Global Mask */
5118 uint32_t R;
5119 struct {
5120 uint32_t MI31:1;
5121 uint32_t MI30:1;
5122 uint32_t MI29:1;
5123 uint32_t MI28:1;
5124 uint32_t MI27:1;
5125 uint32_t MI26:1;
5126 uint32_t MI25:1;
5127 uint32_t MI24:1;
5128 uint32_t MI23:1;
5129 uint32_t MI22:1;
5130 uint32_t MI21:1;
5131 uint32_t MI20:1;
5132 uint32_t MI19:1;
5133 uint32_t MI18:1;
5134 uint32_t MI17:1;
5135 uint32_t MI16:1;
5136 uint32_t MI15:1;
5137 uint32_t MI14:1;
5138 uint32_t MI13:1;
5139 uint32_t MI12:1;
5140 uint32_t MI11:1;
5141 uint32_t MI10:1;
5142 uint32_t MI9:1;
5143 uint32_t MI8:1;
5144 uint32_t MI7:1;
5145 uint32_t MI6:1;
5146 uint32_t MI5:1;
5147 uint32_t MI4:1;
5148 uint32_t MI3:1;
5149 uint32_t MI2:1;
5150 uint32_t MI1:1;
5151 uint32_t MI0:1;
5152 } B;
5153 } RXGMASK;
5154
5155 union { /* RX 14 Mask */
5156 uint32_t R;
5157 struct {
5158 uint32_t MI31:1;
5159 uint32_t MI30:1;
5160 uint32_t MI29:1;
5161 uint32_t MI28:1;
5162 uint32_t MI27:1;
5163 uint32_t MI26:1;
5164 uint32_t MI25:1;
5165 uint32_t MI24:1;
5166 uint32_t MI23:1;
5167 uint32_t MI22:1;
5168 uint32_t MI21:1;
5169 uint32_t MI20:1;
5170 uint32_t MI19:1;
5171 uint32_t MI18:1;
5172 uint32_t MI17:1;
5173 uint32_t MI16:1;
5174 uint32_t MI15:1;
5175 uint32_t MI14:1;
5176 uint32_t MI13:1;
5177 uint32_t MI12:1;
5178 uint32_t MI11:1;
5179 uint32_t MI10:1;
5180 uint32_t MI9:1;
5181 uint32_t MI8:1;
5182 uint32_t MI7:1;
5183 uint32_t MI6:1;
5184 uint32_t MI5:1;
5185 uint32_t MI4:1;
5186 uint32_t MI3:1;
5187 uint32_t MI2:1;
5188 uint32_t MI1:1;
5189 uint32_t MI0:1;
5190 } B;
5191 } RX14MASK;
5192
5193 union { /* RX 15 Mask */
5194 uint32_t R;
5195 struct {
5196 uint32_t MI31:1;
5197 uint32_t MI30:1;
5198 uint32_t MI29:1;
5199 uint32_t MI28:1;
5200 uint32_t MI27:1;
5201 uint32_t MI26:1;
5202 uint32_t MI25:1;
5203 uint32_t MI24:1;
5204 uint32_t MI23:1;
5205 uint32_t MI22:1;
5206 uint32_t MI21:1;
5207 uint32_t MI20:1;
5208 uint32_t MI19:1;
5209 uint32_t MI18:1;
5210 uint32_t MI17:1;
5211 uint32_t MI16:1;
5212 uint32_t MI15:1;
5213 uint32_t MI14:1;
5214 uint32_t MI13:1;
5215 uint32_t MI12:1;
5216 uint32_t MI11:1;
5217 uint32_t MI10:1;
5218 uint32_t MI9:1;
5219 uint32_t MI8:1;
5220 uint32_t MI7:1;
5221 uint32_t MI6:1;
5222 uint32_t MI5:1;
5223 uint32_t MI4:1;
5224 uint32_t MI3:1;
5225 uint32_t MI2:1;
5226 uint32_t MI1:1;
5227 uint32_t MI0:1;
5228 } B;
5229 } RX15MASK;
5230
5231 union { /* Error Counter Register */
5232 uint32_t R;
5233 struct {
5234 uint32_t:16;
5235 uint32_t RXECNT:8;
5236 uint32_t TXECNT:8;
5237 } B;
5238 } ECR;
5239
5240 union { /* Error and Status Register */
5241 uint32_t R;
5242 struct {
5243 uint32_t:14;
5244
5245 uint32_t TWRNINT:1;
5246 uint32_t RWRNINT:1;
5247 uint32_t BIT1ERR:1;
5248 uint32_t BIT0ERR:1;
5249 uint32_t ACKERR:1;
5250 uint32_t CRCERR:1;
5251 uint32_t FRMERR:1;
5252 uint32_t STFERR:1;
5253 uint32_t TXWRN:1;
5254 uint32_t RXWRN:1;
5255 uint32_t IDLE:1;
5256 uint32_t TXRX:1;
5257 uint32_t FLTCONF:2;
5258 uint32_t:1;
5259 uint32_t BOFFINT:1;
5260 uint32_t ERRINT:1;
5261 uint32_t WAKINT:1;
5262 } B;
5263 } ESR;
5264
5265 union { /* Interruput Masks Register */
5266 uint32_t R;
5267 struct {
5268 uint32_t BUF63M:1;
5269 uint32_t BUF62M:1;
5270 uint32_t BUF61M:1;
5271 uint32_t BUF60M:1;
5272 uint32_t BUF59M:1;
5273 uint32_t BUF58M:1;
5274 uint32_t BUF57M:1;
5275 uint32_t BUF56M:1;
5276 uint32_t BUF55M:1;
5277 uint32_t BUF54M:1;
5278 uint32_t BUF53M:1;
5279 uint32_t BUF52M:1;
5280 uint32_t BUF51M:1;
5281 uint32_t BUF50M:1;
5282 uint32_t BUF49M:1;
5283 uint32_t BUF48M:1;
5284 uint32_t BUF47M:1;
5285 uint32_t BUF46M:1;
5286 uint32_t BUF45M:1;
5287 uint32_t BUF44M:1;
5288 uint32_t BUF43M:1;
5289 uint32_t BUF42M:1;
5290 uint32_t BUF41M:1;
5291 uint32_t BUF40M:1;
5292 uint32_t BUF39M:1;
5293 uint32_t BUF38M:1;
5294 uint32_t BUF37M:1;
5295 uint32_t BUF36M:1;
5296 uint32_t BUF35M:1;
5297 uint32_t BUF34M:1;
5298 uint32_t BUF33M:1;
5299 uint32_t BUF32M:1;
5300 } B;
5301 } IMRH; /* Legacy naming - refer to IMASK2 in Reference Manual */
5302
5303 union { /* Interruput Masks Register */
5304 uint32_t R;
5305 struct {
5306 uint32_t BUF31M:1;
5307 uint32_t BUF30M:1;
5308 uint32_t BUF29M:1;
5309 uint32_t BUF28M:1;
5310 uint32_t BUF27M:1;
5311 uint32_t BUF26M:1;
5312 uint32_t BUF25M:1;
5313 uint32_t BUF24M:1;
5314 uint32_t BUF23M:1;
5315 uint32_t BUF22M:1;
5316 uint32_t BUF21M:1;
5317 uint32_t BUF20M:1;
5318 uint32_t BUF19M:1;
5319 uint32_t BUF18M:1;
5320 uint32_t BUF17M:1;
5321 uint32_t BUF16M:1;
5322 uint32_t BUF15M:1;
5323 uint32_t BUF14M:1;
5324 uint32_t BUF13M:1;
5325 uint32_t BUF12M:1;
5326 uint32_t BUF11M:1;
5327 uint32_t BUF10M:1;
5328 uint32_t BUF09M:1;
5329 uint32_t BUF08M:1;
5330 uint32_t BUF07M:1;
5331 uint32_t BUF06M:1;
5332 uint32_t BUF05M:1;
5333 uint32_t BUF04M:1;
5334 uint32_t BUF03M:1;
5335 uint32_t BUF02M:1;
5336 uint32_t BUF01M:1;
5337 uint32_t BUF00M:1;
5338 } B;
5339 } IMRL; /* Legacy naming - refer to IMASK1 in Reference Manual */
5340
5341 union { /* Interruput Flag Register */
5342 uint32_t R;
5343 struct {
5344 uint32_t BUF63I:1;
5345 uint32_t BUF62I:1;
5346 uint32_t BUF61I:1;
5347 uint32_t BUF60I:1;
5348 uint32_t BUF59I:1;
5349 uint32_t BUF58I:1;
5350 uint32_t BUF57I:1;
5351 uint32_t BUF56I:1;
5352 uint32_t BUF55I:1;
5353 uint32_t BUF54I:1;
5354 uint32_t BUF53I:1;
5355 uint32_t BUF52I:1;
5356 uint32_t BUF51I:1;
5357 uint32_t BUF50I:1;
5358 uint32_t BUF49I:1;
5359 uint32_t BUF48I:1;
5360 uint32_t BUF47I:1;
5361 uint32_t BUF46I:1;
5362 uint32_t BUF45I:1;
5363 uint32_t BUF44I:1;
5364 uint32_t BUF43I:1;
5365 uint32_t BUF42I:1;
5366 uint32_t BUF41I:1;
5367 uint32_t BUF40I:1;
5368 uint32_t BUF39I:1;
5369 uint32_t BUF38I:1;
5370 uint32_t BUF37I:1;
5371 uint32_t BUF36I:1;
5372 uint32_t BUF35I:1;
5373 uint32_t BUF34I:1;
5374 uint32_t BUF33I:1;
5375 uint32_t BUF32I:1;
5376 } B;
5377 } IFRH; /* Legacy naming - refer to IFLAG2 in Reference Manual */
5378
5379 union { /* Interruput Flag Register */
5380 uint32_t R;
5381 struct {
5382 uint32_t BUF31I:1;
5383 uint32_t BUF30I:1;
5384 uint32_t BUF29I:1;
5385 uint32_t BUF28I:1;
5386 uint32_t BUF27I:1;
5387 uint32_t BUF26I:1;
5388 uint32_t BUF25I:1;
5389 uint32_t BUF24I:1;
5390 uint32_t BUF23I:1;
5391 uint32_t BUF22I:1;
5392 uint32_t BUF21I:1;
5393 uint32_t BUF20I:1;
5394 uint32_t BUF19I:1;
5395 uint32_t BUF18I:1;
5396 uint32_t BUF17I:1;
5397 uint32_t BUF16I:1;
5398 uint32_t BUF15I:1;
5399 uint32_t BUF14I:1;
5400 uint32_t BUF13I:1;
5401 uint32_t BUF12I:1;
5402 uint32_t BUF11I:1;
5403 uint32_t BUF10I:1;
5404 uint32_t BUF09I:1;
5405 uint32_t BUF08I:1;
5406 uint32_t BUF07I:1;
5407 uint32_t BUF06I:1;
5408 uint32_t BUF05I:1;
5409 uint32_t BUF04I:1;
5410 uint32_t BUF03I:1;
5411 uint32_t BUF02I:1;
5412 uint32_t BUF01I:1;
5413 uint32_t BUF00I:1;
5414 } B;
5415 } IFRL; /* Legacy naming - refer to IFLAG1 in Reference Manual */
5416
5417 uint32_t FLEXCAN_reserved0034[19]; /* 0x0034-0x007F */
5418
5419 struct canbuf_t {
5420 union {
5421 uint32_t R;
5422 struct {
5423 uint32_t:4;
5424 uint32_t CODE:4;
5425 uint32_t:1;
5426 uint32_t SRR:1;
5427 uint32_t IDE:1;
5428 uint32_t RTR:1;
5429 uint32_t LENGTH:4;
5430 uint32_t TIMESTAMP:16;
5431 } B;
5432 } CS;
5433
5434 union {
5435 uint32_t R;
5436 struct {
5437 uint32_t PRIO:3;
5438 uint32_t STD_ID:11;
5439 uint32_t EXT_ID:18;
5440 } B;
5441 } ID;
5442
5443 union {
5444 uint8_t B[8]; /* Data buffer in Bytes (8 bits) */
5445 uint16_t H[4]; /* Data buffer in Half-words (16 bits) */
5446 uint32_t W[2]; /* Data buffer in words (32 bits) */
5447 uint32_t R[2]; /* Data buffer in words (32 bits) */
5448 } DATA;
5449
5450 } BUF[64];
5451
5452 int32_t FLEXCAN_reserved0480[256]; /* 0x0480-0x087F */
5453
5454 union { /* RX Individual Mask Registers */
5455 uint32_t R;
5456 struct {
5457 uint32_t MI31:1;
5458 uint32_t MI30:1;
5459 uint32_t MI29:1;
5460 uint32_t MI28:1;
5461 uint32_t MI27:1;
5462 uint32_t MI26:1;
5463 uint32_t MI25:1;
5464 uint32_t MI24:1;
5465 uint32_t MI23:1;
5466 uint32_t MI22:1;
5467 uint32_t MI21:1;
5468 uint32_t MI20:1;
5469 uint32_t MI19:1;
5470 uint32_t MI18:1;
5471 uint32_t MI17:1;
5472 uint32_t MI16:1;
5473 uint32_t MI15:1;
5474 uint32_t MI14:1;
5475 uint32_t MI13:1;
5476 uint32_t MI12:1;
5477 uint32_t MI11:1;
5478 uint32_t MI10:1;
5479 uint32_t MI9:1;
5480 uint32_t MI8:1;
5481 uint32_t MI7:1;
5482 uint32_t MI6:1;
5483 uint32_t MI5:1;
5484 uint32_t MI4:1;
5485 uint32_t MI3:1;
5486 uint32_t MI2:1;
5487 uint32_t MI1:1;
5488 uint32_t MI0:1;
5489 } B;
5490 } RXIMR[64];
5491
5492 int32_t FLEXCAN_reserved0980[3488]; /* 0x0980-0x3FFF */
5493
5494 };
5495
5496/****************************************************************************/
5497/* MODULE : FlexRay */
5498/****************************************************************************/
5499
5500 typedef union uMVR {
5501 uint16_t R;
5502 struct {
5503 uint16_t CHIVER:8; /* CHI Version Number */
5504 uint16_t PEVER:8; /* PE Version Number */
5505 } B;
5506 } MVR_t;
5507
5508 typedef union uMCR {
5509 uint16_t R;
5510 struct {
5511 uint16_t MEN:1; /* module enable */
5512 uint16_t:1;
5513 uint16_t SCMD:1; /* single channel mode */
5514 uint16_t CHB:1; /* channel B enable */
5515 uint16_t CHA:1; /* channel A enable */
5516 uint16_t SFFE:1; /* synchronization frame filter enable */
5517 uint16_t:5;
5518 uint16_t CLKSEL:1; /* protocol engine clock source select */
5519 uint16_t PRESCALE:3; /* protocol engine clock prescaler */
5520 uint16_t:1;
5521 } B;
5522 } MCR_t;
5523
5524 typedef union uSTBSCR {
5525 uint16_t R;
5526 struct {
5527 uint16_t WMD:1; /* write mode */
5528 uint16_t STBSSEL:7; /* strobe signal select */
5529 uint16_t:3;
5530 uint16_t ENB:1; /* strobe signal enable */
5531 uint16_t:2;
5532 uint16_t STBPSEL:2; /* strobe port select */
5533 } B;
5534 } STBSCR_t;
5535 typedef union uSTBPCR {
5536 uint16_t R;
5537 struct {
5538 uint16_t:12;
5539 uint16_t STB3EN:1; /* strobe port enable */
5540 uint16_t STB2EN:1; /* strobe port enable */
5541 uint16_t STB1EN:1; /* strobe port enable */
5542 uint16_t STB0EN:1; /* strobe port enable */
5543 } B;
5544 } STBPCR_t;
5545
5546 typedef union uMBDSR {
5547 uint16_t R;
5548 struct {
5549 uint16_t:1;
5550 uint16_t MBSEG2DS:7; /* message buffer segment 2 data size */
5551 uint16_t:1;
5552 uint16_t MBSEG1DS:7; /* message buffer segment 1 data size */
5553 } B;
5554 } MBDSR_t;
5555 typedef union uMBSSUTR {
5556 uint16_t R;
5557 struct {
5558
5559 uint16_t:1;
5560 uint16_t LAST_MB_SEG1:7; /* last message buffer control register for message buffer segment 1 */
5561 uint16_t:1;
5562 uint16_t LAST_MB_UTIL:7; /* last message buffer utilized */
5563 } B;
5564 } MBSSUTR_t;
5565
5566 typedef union uPOCR {
5567 uint16_t R;
5568 uint8_t byte[2];
5569 struct {
5570 uint16_t WME:1; /* write mode external correction command */
5571 uint16_t:3;
5572 uint16_t EOC_AP:2; /* external offset correction application */
5573 uint16_t ERC_AP:2; /* external rate correction application */
5574 uint16_t BSY:1; /* command write busy / write mode command */
5575 uint16_t:3;
5576 uint16_t POCCMD:4; /* protocol command */
5577 } B;
5578 } POCR_t;
5579/* protocol commands */
5580 typedef union uGIFER {
5581 uint16_t R;
5582 struct {
5583 uint16_t MIF:1; /* module interrupt flag */
5584 uint16_t PRIF:1; /* protocol interrupt flag */
5585 uint16_t CHIF:1; /* CHI interrupt flag */
5586 uint16_t WKUPIF:1; /* wakeup interrupt flag */
5587 uint16_t FNEBIF:1; /* receive FIFO channel B not empty interrupt flag */
5588 uint16_t FNEAIF:1; /* receive FIFO channel A not empty interrupt flag */
5589 uint16_t RBIF:1; /* receive message buffer interrupt flag */
5590 uint16_t TBIF:1; /* transmit buffer interrupt flag */
5591 uint16_t MIE:1; /* module interrupt enable */
5592 uint16_t PRIE:1; /* protocol interrupt enable */
5593 uint16_t CHIE:1; /* CHI interrupt enable */
5594 uint16_t WKUPIE:1; /* wakeup interrupt enable */
5595 uint16_t FNEBIE:1; /* receive FIFO channel B not empty interrupt enable */
5596 uint16_t FNEAIE:1; /* receive FIFO channel A not empty interrupt enable */
5597 uint16_t RBIE:1; /* receive message buffer interrupt enable */
5598 uint16_t TBIE:1; /* transmit buffer interrupt enable */
5599 } B;
5600 } GIFER_t;
5601 typedef union uPIFR0 {
5602 uint16_t R;
5603 struct {
5604 uint16_t FATLIF:1; /* fatal protocol error interrupt flag */
5605 uint16_t INTLIF:1; /* internal protocol error interrupt flag */
5606 uint16_t ILCFIF:1; /* illegal protocol configuration flag */
5607 uint16_t CSAIF:1; /* cold start abort interrupt flag */
5608 uint16_t MRCIF:1; /* missing rate correctio interrupt flag */
5609 uint16_t MOCIF:1; /* missing offset correctio interrupt flag */
5610 uint16_t CCLIF:1; /* clock correction limit reached interrupt flag */
5611 uint16_t MXSIF:1; /* max sync frames detected interrupt flag */
5612 uint16_t MTXIF:1; /* media access test symbol received flag */
5613 uint16_t LTXBIF:1; /* pdLatestTx violation on channel B interrupt flag */
5614 uint16_t LTXAIF:1; /* pdLatestTx violation on channel A interrupt flag */
5615 uint16_t TBVBIF:1; /* Transmission across boundary on channel B Interrupt Flag */
5616 uint16_t TBVAIF:1; /* Transmission across boundary on channel A Interrupt Flag */
5617 uint16_t TI2IF:1; /* timer 2 expired interrupt flag */
5618 uint16_t TI1IF:1; /* timer 1 expired interrupt flag */
5619 uint16_t CYSIF:1; /* cycle start interrupt flag */
5620 } B;
5621 } PIFR0_t;
5622 typedef union uPIFR1 {
5623 uint16_t R;
5624 struct {
5625 uint16_t EMCIF:1; /* error mode changed interrupt flag */
5626 uint16_t IPCIF:1; /* illegal protocol command interrupt flag */
5627 uint16_t PECFIF:1; /* protocol engine communication failure interrupt flag */
5628 uint16_t PSCIF:1; /* Protocol State Changed Interrupt Flag */
5629 uint16_t SSI3IF:1; /* slot status counter incremented interrupt flag */
5630 uint16_t SSI2IF:1; /* slot status counter incremented interrupt flag */
5631 uint16_t SSI1IF:1; /* slot status counter incremented interrupt flag */
5632 uint16_t SSI0IF:1; /* slot status counter incremented interrupt flag */
5633 uint16_t:2;
5634 uint16_t EVTIF:1; /* even cycle table written interrupt flag */
5635 uint16_t ODTIF:1; /* odd cycle table written interrupt flag */
5636 uint16_t:4;
5637 } B;
5638 } PIFR1_t;
5639 typedef union uPIER0 {
5640 uint16_t R;
5641 struct {
5642 uint16_t FATLIE:1; /* fatal protocol error interrupt enable */
5643 uint16_t INTLIE:1; /* internal protocol error interrupt interrupt enable */
5644 uint16_t ILCFIE:1; /* illegal protocol configuration interrupt enable */
5645 uint16_t CSAIE:1; /* cold start abort interrupt enable */
5646 uint16_t MRCIE:1; /* missing rate correctio interrupt enable */
5647 uint16_t MOCIE:1; /* missing offset correctio interrupt enable */
5648 uint16_t CCLIE:1; /* clock correction limit reached interrupt enable */
5649 uint16_t MXSIE:1; /* max sync frames detected interrupt enable */
5650 uint16_t MTXIE:1; /* media access test symbol received interrupt enable */
5651 uint16_t LTXBIE:1; /* pdLatestTx violation on channel B interrupt enable */
5652 uint16_t LTXAIE:1; /* pdLatestTx violation on channel A interrupt enable */
5653 uint16_t TBVBIE:1; /* Transmission across boundary on channel B Interrupt enable */
5654 uint16_t TBVAIE:1; /* Transmission across boundary on channel A Interrupt enable */
5655 uint16_t TI2IE:1; /* timer 2 expired interrupt enable */
5656 uint16_t TI1IE:1; /* timer 1 expired interrupt enable */
5657 uint16_t CYSIE:1; /* cycle start interrupt enable */
5658 } B;
5659 } PIER0_t;
5660 typedef union uPIER1 {
5661 uint16_t R;
5662 struct {
5663 uint16_t EMCIE:1; /* error mode changed interrupt enable */
5664 uint16_t IPCIE:1; /* illegal protocol command interrupt enable */
5665 uint16_t PECFIE:1; /* protocol engine communication failure interrupt enable */
5666 uint16_t PSCIE:1; /* Protocol State Changed Interrupt enable */
5667 uint16_t SSI3IE:1; /* slot status counter incremented interrupt enable */
5668 uint16_t SSI2IE:1; /* slot status counter incremented interrupt enable */
5669 uint16_t SSI1IE:1; /* slot status counter incremented interrupt enable */
5670 uint16_t SSI0IE:1; /* slot status counter incremented interrupt enable */
5671 uint16_t:2;
5672 uint16_t EVTIE:1; /* even cycle table written interrupt enable */
5673 uint16_t ODTIE:1; /* odd cycle table written interrupt enable */
5674 uint16_t:4;
5675 } B;
5676 } PIER1_t;
5677 typedef union uCHIERFR {
5678 uint16_t R;
5679 struct {
5680 uint16_t FRLBEF:1; /* flame lost channel B error flag */
5681 uint16_t FRLAEF:1; /* frame lost channel A error flag */
5682 uint16_t PCMIEF:1; /* command ignored error flag */
5683 uint16_t FOVBEF:1; /* receive FIFO overrun channel B error flag */
5684 uint16_t FOVAEF:1; /* receive FIFO overrun channel A error flag */
5685 uint16_t MSBEF:1; /* message buffer search error flag */
5686 uint16_t MBUEF:1; /* message buffer utilization error flag */
5687 uint16_t LCKEF:1; /* lock error flag */
5688 uint16_t DBLEF:1; /* double transmit message buffer lock error flag */
5689 uint16_t SBCFEF:1; /* system bus communication failure error flag */
5690 uint16_t FIDEF:1; /* frame ID error flag */
5691 uint16_t DPLEF:1; /* dynamic payload length error flag */
5692 uint16_t SPLEF:1; /* static payload length error flag */
5693 uint16_t NMLEF:1; /* network management length error flag */
5694 uint16_t NMFEF:1; /* network management frame error flag */
5695 uint16_t ILSAEF:1; /* illegal access error flag */
5696 } B;
5697 } CHIERFR_t;
5698 typedef union uMBIVEC {
5699 uint16_t R;
5700 struct {
5701
5702 uint16_t:1;
5703 uint16_t TBIVEC:7; /* transmit buffer interrupt vector */
5704 uint16_t:1;
5705 uint16_t RBIVEC:7; /* receive buffer interrupt vector */
5706 } B;
5707 } MBIVEC_t;
5708
5709 typedef union uPSR0 {
5710 uint16_t R;
5711 struct {
5712 uint16_t ERRMODE:2; /* error mode */
5713 uint16_t SLOTMODE:2; /* slot mode */
5714 uint16_t:1;
5715 uint16_t PROTSTATE:3; /* protocol state */
5716 uint16_t SUBSTATE:4; /* protocol sub state */
5717 uint16_t:1;
5718 uint16_t WAKEUPSTATUS:3; /* wakeup status */
5719 } B;
5720 } PSR0_t;
5721
5722/* protocol states */
5723/* protocol sub-states */
5724/* wakeup status */
5725 typedef union uPSR1 {
5726 uint16_t R;
5727 struct {
5728 uint16_t CSAA:1; /* cold start attempt abort flag */
5729 uint16_t SCP:1; /* cold start path */
5730 uint16_t:1;
5731 uint16_t REMCSAT:5; /* remanining coldstart attempts */
5732 uint16_t CPN:1; /* cold start noise path */
5733 uint16_t HHR:1; /* host halt request pending */
5734 uint16_t FRZ:1; /* freeze occured */
5735 uint16_t APTAC:5; /* allow passive to active counter */
5736 } B;
5737 } PSR1_t;
5738 typedef union uPSR2 {
5739 uint16_t R;
5740 struct {
5741 uint16_t NBVB:1; /* NIT boundary violation on channel B */
5742 uint16_t NSEB:1; /* NIT syntax error on channel B */
5743 uint16_t STCB:1; /* symbol window transmit conflict on channel B */
5744 uint16_t SBVB:1; /* symbol window boundary violation on channel B */
5745 uint16_t SSEB:1; /* symbol window syntax error on channel B */
5746 uint16_t MTB:1; /* media access test symbol MTS received on channel B */
5747 uint16_t NBVA:1; /* NIT boundary violation on channel A */
5748 uint16_t NSEA:1; /* NIT syntax error on channel A */
5749 uint16_t STCA:1; /* symbol window transmit conflict on channel A */
5750 uint16_t SBVA:1; /* symbol window boundary violation on channel A */
5751 uint16_t SSEA:1; /* symbol window syntax error on channel A */
5752 uint16_t MTA:1; /* media access test symbol MTS received on channel A */
5753 uint16_t CLKCORRFAILCNT:4; /* clock correction failed counter */
5754 } B;
5755 } PSR2_t;
5756 typedef union uPSR3 {
5757 uint16_t R;
5758 struct {
5759 uint16_t:2;
5760 uint16_t WUB:1; /* wakeup symbol received on channel B */
5761 uint16_t ABVB:1; /* aggregated boundary violation on channel B */
5762 uint16_t AACB:1; /* aggregated additional communication on channel B */
5763 uint16_t ACEB:1; /* aggregated content error on channel B */
5764 uint16_t ASEB:1; /* aggregated syntax error on channel B */
5765 uint16_t AVFB:1; /* aggregated valid frame on channel B */
5766 uint16_t:2;
5767 uint16_t WUA:1; /* wakeup symbol received on channel A */
5768 uint16_t ABVA:1; /* aggregated boundary violation on channel A */
5769 uint16_t AACA:1; /* aggregated additional communication on channel A */
5770 uint16_t ACEA:1; /* aggregated content error on channel A */
5771 uint16_t ASEA:1; /* aggregated syntax error on channel A */
5772 uint16_t AVFA:1; /* aggregated valid frame on channel A */
5773 } B;
5774 } PSR3_t;
5775 typedef union uCIFRR {
5776 uint16_t R;
5777 struct {
5778 uint16_t:8;
5779 uint16_t MIFR:1; /* module interrupt flag */
5780 uint16_t PRIFR:1; /* protocol interrupt flag */
5781 uint16_t CHIFR:1; /* CHI interrupt flag */
5782 uint16_t WUPIFR:1; /* wakeup interrupt flag */
5783 uint16_t FNEBIFR:1; /* receive fifo channel B no empty interrupt flag */
5784 uint16_t FNEAIFR:1; /* receive fifo channel A no empty interrupt flag */
5785 uint16_t RBIFR:1; /* receive message buffer interrupt flag */
5786 uint16_t TBIFR:1; /* transmit buffer interrupt flag */
5787 } B;
5788 } CIFRR_t;
5789 typedef union uSFCNTR {
5790 uint16_t R;
5791 struct {
5792 uint16_t SFEVB:4; /* sync frames channel B, even cycle */
5793 uint16_t SFEVA:4; /* sync frames channel A, even cycle */
5794 uint16_t SFODB:4; /* sync frames channel B, odd cycle */
5795 uint16_t SFODA:4; /* sync frames channel A, odd cycle */
5796 } B;
5797 } SFCNTR_t;
5798
5799 typedef union uSFTCCSR {
5800 uint16_t R;
5801 struct {
5802 uint16_t ELKT:1; /* even cycle tables lock and unlock trigger */
5803 uint16_t OLKT:1; /* odd cycle tables lock and unlock trigger */
5804 uint16_t CYCNUM:6; /* cycle number */
5805 uint16_t ELKS:1; /* even cycle tables lock status */
5806 uint16_t OLKS:1; /* odd cycle tables lock status */
5807 uint16_t EVAL:1; /* even cycle tables valid */
5808 uint16_t OVAL:1; /* odd cycle tables valid */
5809 uint16_t:1;
5810 uint16_t OPT:1; /*one pair trigger */
5811 uint16_t SDVEN:1; /* sync frame deviation table enable */
5812 uint16_t SIDEN:1; /* sync frame ID table enable */
5813 } B;
5814 } SFTCCSR_t;
5815 typedef union uSFIDRFR {
5816 uint16_t R;
5817 struct {
5818 uint16_t:6;
5819 uint16_t SYNFRID:10; /* sync frame rejection ID */
5820 } B;
5821 } SFIDRFR_t;
5822
5823 typedef union uTICCR {
5824 uint16_t R;
5825 struct {
5826 uint16_t:2;
5827 uint16_t T2CFG:1; /* timer 2 configuration */
5828 uint16_t T2REP:1; /* timer 2 repetitive mode */
5829 uint16_t:1;
5830 uint16_t T2SP:1; /* timer 2 stop */
5831 uint16_t T2TR:1; /* timer 2 trigger */
5832 uint16_t T2ST:1; /* timer 2 state */
5833 uint16_t:3;
5834 uint16_t T1REP:1; /* timer 1 repetitive mode */
5835 uint16_t:1;
5836 uint16_t T1SP:1; /* timer 1 stop */
5837 uint16_t T1TR:1; /* timer 1 trigger */
5838 uint16_t T1ST:1; /* timer 1 state */
5839
5840 } B;
5841 } TICCR_t;
5842 typedef union uTI1CYSR {
5843 uint16_t R;
5844 struct {
5845 uint16_t:2;
5846 uint16_t TI1CYCVAL:6; /* timer 1 cycle filter value */
5847 uint16_t:2;
5848 uint16_t TI1CYCMSK:6; /* timer 1 cycle filter mask */
5849
5850 } B;
5851 } TI1CYSR_t;
5852
5853 typedef union uSSSR {
5854 uint16_t R;
5855 struct {
5856 uint16_t WMD:1; /* write mode */
5857 uint16_t:1;
5858 uint16_t SEL:2; /* static slot number */
5859 uint16_t:1;
5860 uint16_t SLOTNUMBER:11; /* selector */
5861 } B;
5862 } SSSR_t;
5863
5864 typedef union uSSCCR {
5865 uint16_t R;
5866 struct {
5867 uint16_t WMD:1; /* write mode */
5868 uint16_t:1;
5869 uint16_t SEL:2; /* selector */
5870 uint16_t:1;
5871 uint16_t CNTCFG:2; /* counter configuration */
5872 uint16_t MCY:1; /* multi cycle selection */
5873 uint16_t VFR:1; /* valid frame selection */
5874 uint16_t SYF:1; /* sync frame selection */
5875 uint16_t NUF:1; /* null frame selection */
5876 uint16_t SUF:1; /* startup frame selection */
5877 uint16_t STATUSMASK:4; /* slot status mask */
5878 } B;
5879 } SSCCR_t;
5880 typedef union uSSR {
5881 uint16_t R;
5882 struct {
5883 uint16_t VFB:1; /* valid frame on channel B */
5884 uint16_t SYB:1; /* valid sync frame on channel B */
5885 uint16_t NFB:1; /* valid null frame on channel B */
5886 uint16_t SUB:1; /* valid startup frame on channel B */
5887 uint16_t SEB:1; /* syntax error on channel B */
5888 uint16_t CEB:1; /* content error on channel B */
5889 uint16_t BVB:1; /* boundary violation on channel B */
5890 uint16_t TCB:1; /* tx conflict on channel B */
5891 uint16_t VFA:1; /* valid frame on channel A */
5892 uint16_t SYA:1; /* valid sync frame on channel A */
5893 uint16_t NFA:1; /* valid null frame on channel A */
5894 uint16_t SUA:1; /* valid startup frame on channel A */
5895 uint16_t SEA:1; /* syntax error on channel A */
5896 uint16_t CEA:1; /* content error on channel A */
5897 uint16_t BVA:1; /* boundary violation on channel A */
5898 uint16_t TCA:1; /* tx conflict on channel A */
5899 } B;
5900 } SSR_t;
5901 typedef union uMTSCFR {
5902 uint16_t R;
5903 struct {
5904 uint16_t MTE:1; /* media access test symbol transmission enable */
5905 uint16_t:1;
5906 uint16_t CYCCNTMSK:6; /* cycle counter mask */
5907 uint16_t:2;
5908 uint16_t CYCCNTVAL:6; /* cycle counter value */
5909 } B;
5910 } MTSCFR_t;
5911 typedef union uRSBIR {
5912 uint16_t R;
5913 struct {
5914 uint16_t WMD:1; /* write mode */
5915 uint16_t:1;
5916 uint16_t SEL:2; /* selector */
5917 uint16_t:4;
5918 uint16_t RSBIDX:8; /* receive shadow buffer index */
5919 } B;
5920 } RSBIR_t;
5921 typedef union uRFDSR {
5922 uint16_t R;
5923 struct {
5924 uint16_t FIFODEPTH:8; /* fifo depth */
5925 uint16_t:1;
5926 uint16_t ENTRYSIZE:7; /* entry size */
5927 } B;
5928 } RFDSR_t;
5929
5930 typedef union uRFRFCFR {
5931 uint16_t R;
5932 struct {
5933 uint16_t WMD:1; /* write mode */
5934 uint16_t IBD:1; /* interval boundary */
5935 uint16_t SEL:2; /* filter number */
5936 uint16_t:1;
5937 uint16_t SID:11; /* slot ID */
5938 } B;
5939 } RFRFCFR_t;
5940
5941 typedef union uRFRFCTR {
5942 uint16_t R;
5943 struct {
5944 uint16_t:4;
5945 uint16_t F3MD:1; /* filter mode */
5946 uint16_t F2MD:1; /* filter mode */
5947 uint16_t F1MD:1; /* filter mode */
5948 uint16_t F0MD:1; /* filter mode */
5949 uint16_t:4;
5950 uint16_t F3EN:1; /* filter enable */
5951 uint16_t F2EN:1; /* filter enable */
5952 uint16_t F1EN:1; /* filter enable */
5953 uint16_t F0EN:1; /* filter enable */
5954 } B;
5955 } RFRFCTR_t;
5956 typedef union uPCR0 {
5957 uint16_t R;
5958 struct {
5959 uint16_t ACTION_POINT_OFFSET:6;
5960 uint16_t STATIC_SLOT_LENGTH:10;
5961 } B;
5962 } PCR0_t;
5963
5964 typedef union uPCR1 {
5965 uint16_t R;
5966 struct {
5967 uint16_t:2;
5968 uint16_t MACRO_AFTER_FIRST_STATIC_SLOT:14;
5969 } B;
5970 } PCR1_t;
5971
5972 typedef union uPCR2 {
5973 uint16_t R;
5974 struct {
5975 uint16_t MINISLOT_AFTER_ACTION_POINT:6;
5976 uint16_t NUMBER_OF_STATIC_SLOTS:10;
5977 } B;
5978 } PCR2_t;
5979
5980 typedef union uPCR3 {
5981 uint16_t R;
5982 struct {
5983 uint16_t WAKEUP_SYMBOL_RX_LOW:6;
5984 uint16_t MINISLOT_ACTION_POINT_OFFSET:5;
5985 uint16_t COLDSTART_ATTEMPTS:5;
5986 } B;
5987 } PCR3_t;
5988
5989 typedef union uPCR4 {
5990 uint16_t R;
5991 struct {
5992 uint16_t CAS_RX_LOW_MAX:7;
5993 uint16_t WAKEUP_SYMBOL_RX_WINDOW:9;
5994 } B;
5995 } PCR4_t;
5996
5997 typedef union uPCR5 {
5998 uint16_t R;
5999 struct {
6000 uint16_t TSS_TRANSMITTER:4;
6001 uint16_t WAKEUP_SYMBOL_TX_LOW:6;
6002 uint16_t WAKEUP_SYMBOL_RX_IDLE:6;
6003 } B;
6004 } PCR5_t;
6005
6006 typedef union uPCR6 {
6007 uint16_t R;
6008 struct {
6009 uint16_t:1;
6010 uint16_t SYMBOL_WINDOW_AFTER_ACTION_POINT:8;
6011 uint16_t MACRO_INITIAL_OFFSET_A:7;
6012 } B;
6013 } PCR6_t;
6014
6015 typedef union uPCR7 {
6016 uint16_t R;
6017 struct {
6018 uint16_t DECODING_CORRECTION_B:9;
6019 uint16_t MICRO_PER_MACRO_NOM_HALF:7;
6020 } B;
6021 } PCR7_t;
6022
6023 typedef union uPCR8 {
6024 uint16_t R;
6025 struct {
6026 uint16_t MAX_WITHOUT_CLOCK_CORRECTION_FATAL:4;
6027 uint16_t MAX_WITHOUT_CLOCK_CORRECTION_PASSIVE:4;
6028 uint16_t WAKEUP_SYMBOL_TX_IDLE:8;
6029 } B;
6030 } PCR8_t;
6031
6032 typedef union uPCR9 {
6033 uint16_t R;
6034 struct {
6035 uint16_t MINISLOT_EXISTS:1;
6036 uint16_t SYMBOL_WINDOW_EXISTS:1;
6037 uint16_t OFFSET_CORRECTION_OUT:14;
6038 } B;
6039 } PCR9_t;
6040
6041 typedef union uPCR10 {
6042 uint16_t R;
6043 struct {
6044 uint16_t SINGLE_SLOT_ENABLED:1;
6045 uint16_t WAKEUP_CHANNEL:1;
6046 uint16_t MACRO_PER_CYCLE:14;
6047 } B;
6048 } PCR10_t;
6049
6050 typedef union uPCR11 {
6051 uint16_t R;
6052 struct {
6053 uint16_t KEY_SLOT_USED_FOR_STARTUP:1;
6054 uint16_t KEY_SLOT_USED_FOR_SYNC:1;
6055 uint16_t OFFSET_CORRECTION_START:14;
6056 } B;
6057 } PCR11_t;
6058
6059 typedef union uPCR12 {
6060 uint16_t R;
6061 struct {
6062 uint16_t ALLOW_PASSIVE_TO_ACTIVE:5;
6063 uint16_t KEY_SLOT_HEADER_CRC:11;
6064 } B;
6065 } PCR12_t;
6066
6067 typedef union uPCR13 {
6068 uint16_t R;
6069 struct {
6070 uint16_t FIRST_MINISLOT_ACTION_POINT_OFFSET:6;
6071 uint16_t STATIC_SLOT_AFTER_ACTION_POINT:10;
6072 } B;
6073 } PCR13_t;
6074
6075 typedef union uPCR14 {
6076 uint16_t R;
6077 struct {
6078 uint16_t RATE_CORRECTION_OUT:11;
6079 uint16_t LISTEN_TIMEOUT_H:5;
6080 } B;
6081 } PCR14_t;
6082
6083 typedef union uPCR15 {
6084 uint16_t R;
6085 struct {
6086 uint16_t LISTEN_TIMEOUT_L:16;
6087 } B;
6088 } PCR15_t;
6089
6090 typedef union uPCR16 {
6091 uint16_t R;
6092 struct {
6093 uint16_t MACRO_INITIAL_OFFSET_B:7;
6094 uint16_t NOISE_LISTEN_TIMEOUT_H:9;
6095 } B;
6096 } PCR16_t;
6097
6098 typedef union uPCR17 {
6099 uint16_t R;
6100 struct {
6101 uint16_t NOISE_LISTEN_TIMEOUT_L:16;
6102 } B;
6103 } PCR17_t;
6104
6105 typedef union uPCR18 {
6106 uint16_t R;
6107 struct {
6108 uint16_t WAKEUP_PATTERN:6;
6109 uint16_t KEY_SLOT_ID:10;
6110 } B;
6111 } PCR18_t;
6112
6113 typedef union uPCR19 {
6114 uint16_t R;
6115 struct {
6116 uint16_t DECODING_CORRECTION_A:9;
6117 uint16_t PAYLOAD_LENGTH_STATIC:7;
6118 } B;
6119 } PCR19_t;
6120
6121 typedef union uPCR20 {
6122 uint16_t R;
6123 struct {
6124 uint16_t MICRO_INITIAL_OFFSET_B:8;
6125 uint16_t MICRO_INITIAL_OFFSET_A:8;
6126 } B;
6127 } PCR20_t;
6128
6129 typedef union uPCR21 {
6130 uint16_t R;
6131 struct {
6132 uint16_t EXTERN_RATE_CORRECTION:3;
6133 uint16_t LATEST_TX:13;
6134 } B;
6135 } PCR21_t;
6136
6137 typedef union uPCR22 {
6138 uint16_t R;
6139 struct {
6140 uint16_t:1;
6141 uint16_t COMP_ACCEPTED_STARTUP_RANGE_A:11;
6142 uint16_t MICRO_PER_CYCLE_H:4;
6143 } B;
6144 } PCR22_t;
6145
6146 typedef union uPCR23 {
6147 uint16_t R;
6148 struct {
6149 uint16_t micro_per_cycle_l:16;
6150 } B;
6151 } PCR23_t;
6152
6153 typedef union uPCR24 {
6154 uint16_t R;
6155 struct {
6156 uint16_t CLUSTER_DRIFT_DAMPING:5;
6157 uint16_t MAX_PAYLOAD_LENGTH_DYNAMIC:7;
6158 uint16_t MICRO_PER_CYCLE_MIN_H:4;
6159 } B;
6160 } PCR24_t;
6161
6162 typedef union uPCR25 {
6163 uint16_t R;
6164 struct {
6165 uint16_t MICRO_PER_CYCLE_MIN_L:16;
6166 } B;
6167 } PCR25_t;
6168
6169 typedef union uPCR26 {
6170 uint16_t R;
6171 struct {
6172 uint16_t ALLOW_HALT_DUE_TO_CLOCK:1;
6173 uint16_t COMP_ACCEPTED_STARTUP_RANGE_B:11;
6174 uint16_t MICRO_PER_CYCLE_MAX_H:4;
6175 } B;
6176 } PCR26_t;
6177
6178 typedef union uPCR27 {
6179 uint16_t R;
6180 struct {
6181 uint16_t MICRO_PER_CYCLE_MAX_L:16;
6182 } B;
6183 } PCR27_t;
6184
6185 typedef union uPCR28 {
6186 uint16_t R;
6187 struct {
6188 uint16_t DYNAMIC_SLOT_IDLE_PHASE:2;
6189 uint16_t MACRO_AFTER_OFFSET_CORRECTION:14;
6190 } B;
6191 } PCR28_t;
6192
6193 typedef union uPCR29 {
6194 uint16_t R;
6195 struct {
6196 uint16_t EXTERN_OFFSET_CORRECTION:3;
6197 uint16_t MINISLOTS_MAX:13;
6198 } B;
6199 } PCR29_t;
6200
6201 typedef union uPCR30 {
6202 uint16_t R;
6203 struct {
6204 uint16_t:12;
6205 uint16_t SYNC_NODE_MAX:4;
6206 } B;
6207 } PCR30_t;
6208
6209 typedef struct uMSG_BUFF_CCS {
6210 union {
6211 uint16_t R;
6212 struct {
6213 uint16_t:1;
6214 uint16_t MCM:1; /* message buffer commit mode */
6215 uint16_t MBT:1; /* message buffer type */
6216 uint16_t MTD:1; /* message buffer direction */
6217 uint16_t CMT:1; /* commit for transmission */
6218 uint16_t EDT:1; /* enable / disable trigger */
6219 uint16_t LCKT:1; /* lock request trigger */
6220 uint16_t MBIE:1; /* message buffer interrupt enable */
6221 uint16_t:3;
6222 uint16_t DUP:1; /* data updated */
6223 uint16_t DVAL:1; /* data valid */
6224 uint16_t EDS:1; /* lock status */
6225 uint16_t LCKS:1; /* enable / disable status */
6226 uint16_t MBIF:1; /* message buffer interrupt flag */
6227 } B;
6228 } MBCCSR;
6229 union {
6230 uint16_t R;
6231 struct {
6232 uint16_t MTM:1; /* message buffer transmission mode */
6233 uint16_t CHNLA:1; /* channel assignement */
6234 uint16_t CHNLB:1; /* channel assignement */
6235 uint16_t CCFE:1; /* cycle counter filter enable */
6236 uint16_t CCFMSK:6; /* cycle counter filter mask */
6237 uint16_t CCFVAL:6; /* cycle counter filter value */
6238 } B;
6239 } MBCCFR;
6240 union {
6241 uint16_t R;
6242 struct {
6243 uint16_t:5;
6244 uint16_t FID:11; /* frame ID */
6245 } B;
6246 } MBFIDR;
6247 union {
6248 uint16_t R;
6249 struct {
6250 uint16_t:8;
6251 uint16_t MBIDX:8; /* message buffer index */
6252 } B;
6253 } MBIDXR;
6255 typedef union uSYSBADHR {
6256 uint16_t R;
6257 } SYSBADHR_t;
6258 typedef union uSYSBADLR {
6259 uint16_t R;
6260 } SYSBADLR_t;
6261 typedef union uPDAR {
6262 uint16_t R;
6263 } PDAR_t;
6264 typedef union uCASERCR {
6265 uint16_t R;
6266 } CASERCR_t;
6267 typedef union uCBSERCR {
6268 uint16_t R;
6269 } CBSERCR_t;
6270 typedef union uCYCTR {
6271 uint16_t R;
6272 } CYCTR_t;
6273 typedef union uMTCTR {
6274 uint16_t R;
6275 } MTCTR_t;
6276 typedef union uSLTCTAR {
6277 uint16_t R;
6278 } SLTCTAR_t;
6279 typedef union uSLTCTBR {
6280 uint16_t R;
6281 } SLTCTBR_t;
6282 typedef union uRTCORVR {
6283 uint16_t R;
6284 } RTCORVR_t;
6285 typedef union uOFCORVR {
6286 uint16_t R;
6287 } OFCORVR_t;
6288 typedef union uSFTOR {
6289 uint16_t R;
6290 } SFTOR_t;
6291 typedef union uSFIDAFVR {
6292 uint16_t R;
6293 } SFIDAFVR_t;
6294 typedef union uSFIDAFMR {
6295 uint16_t R;
6296 } SFIDAFMR_t;
6297 typedef union uNMVR {
6298 uint16_t R;
6299 } NMVR_t;
6300 typedef union uNMVLR {
6301 uint16_t R;
6302 } NMVLR_t;
6303 typedef union uT1MTOR {
6304 uint16_t R;
6305 } T1MTOR_t;
6306 typedef union uTI2CR0 {
6307 uint16_t R;
6308 } TI2CR0_t;
6309 typedef union uTI2CR1 {
6310 uint16_t R;
6311 } TI2CR1_t;
6312 typedef union uSSCR {
6313 uint16_t R;
6314 } SSCR_t;
6315 typedef union uRFSR {
6316 uint16_t R;
6317 } RFSR_t;
6318 typedef union uRFSIR {
6319 uint16_t R;
6320 } RFSIR_t;
6321 typedef union uRFARIR {
6322 uint16_t R;
6323 } RFARIR_t;
6324 typedef union uRFBRIR {
6325 uint16_t R;
6326 } RFBRIR_t;
6327 typedef union uRFMIDAFVR {
6328 uint16_t R;
6329 } RFMIDAFVR_t;
6330 typedef union uRFMIAFMR {
6331 uint16_t R;
6332 } RFMIAFMR_t;
6333 typedef union uRFFIDRFVR {
6334 uint16_t R;
6335 } RFFIDRFVR_t;
6336 typedef union uRFFIDRFMR {
6337 uint16_t R;
6338 } RFFIDRFMR_t;
6339 typedef union uLDTXSLAR {
6340 uint16_t R;
6341 } LDTXSLAR_t;
6342 typedef union uLDTXSLBR {
6343 uint16_t R;
6344 } LDTXSLBR_t;
6345
6346 typedef struct FR_tag {
6347 volatile MVR_t MVR; /*module version register *//*0 */
6348 volatile MCR_t MCR; /*module configuration register *//*2 */
6349 volatile SYSBADHR_t SYSBADHR; /*system memory base address high register *//*4 */
6350 volatile SYSBADLR_t SYSBADLR; /*system memory base address low register *//*6 */
6351 volatile STBSCR_t STBSCR; /*strobe signal control register *//*8 */
6352 volatile STBPCR_t STBPCR; /*strobe port control register *//*A */
6353 volatile MBDSR_t MBDSR; /*message buffer data size register *//*C */
6354 volatile MBSSUTR_t MBSSUTR; /*message buffer segment size and utilization register *//*E */
6355 uint16_t reserved3a[1]; /*10 */
6356 volatile PDAR_t PDAR; /*PE data register *//*12 */
6357 volatile POCR_t POCR; /*Protocol operation control register *//*14 */
6358 volatile GIFER_t GIFER; /*global interrupt flag and enable register *//*16 */
6359 volatile PIFR0_t PIFR0; /*protocol interrupt flag register 0 *//*18 */
6360 volatile PIFR1_t PIFR1; /*protocol interrupt flag register 1 *//*1A */
6361 volatile PIER0_t PIER0; /*protocol interrupt enable register 0 *//*1C */
6362 volatile PIER1_t PIER1; /*protocol interrupt enable register 1 *//*1E */
6363 volatile CHIERFR_t CHIERFR; /*CHI error flag register *//*20 */
6364 volatile MBIVEC_t MBIVEC; /*message buffer interrupt vector register *//*22 */
6365 volatile CASERCR_t CASERCR; /*channel A status error counter register *//*24 */
6366 volatile CBSERCR_t CBSERCR; /*channel B status error counter register *//*26 */
6367 volatile PSR0_t PSR0; /*protocol status register 0 *//*28 */
6368 volatile PSR1_t PSR1; /*protocol status register 1 *//*2A */
6369 volatile PSR2_t PSR2; /*protocol status register 2 *//*2C */
6370 volatile PSR3_t PSR3; /*protocol status register 3 *//*2E */
6371 volatile MTCTR_t MTCTR; /*macrotick counter register *//*30 */
6372 volatile CYCTR_t CYCTR; /*cycle counter register *//*32 */
6373 volatile SLTCTAR_t SLTCTAR; /*slot counter channel A register *//*34 */
6374 volatile SLTCTBR_t SLTCTBR; /*slot counter channel B register *//*36 */
6375 volatile RTCORVR_t RTCORVR; /*rate correction value register *//*38 */
6376 volatile OFCORVR_t OFCORVR; /*offset correction value register *//*3A */
6377 volatile CIFRR_t CIFRR; /*combined interrupt flag register *//*3C */
6378 uint16_t reserved3[1]; /*3E */
6379 volatile SFCNTR_t SFCNTR; /*sync frame counter register *//*40 */
6380 volatile SFTOR_t SFTOR; /*sync frame table offset register *//*42 */
6381 volatile SFTCCSR_t SFTCCSR; /*sync frame table configuration, control, status register *//*44 */
6382 volatile SFIDRFR_t SFIDRFR; /*sync frame ID rejection filter register *//*46 */
6383 volatile SFIDAFVR_t SFIDAFVR; /*sync frame ID acceptance filter value regiater *//*48 */
6384 volatile SFIDAFMR_t SFIDAFMR; /*sync frame ID acceptance filter mask register *//*4A */
6385 volatile NMVR_t NMVR[6]; /*network management vector registers (12 bytes) *//*4C */
6386 volatile NMVLR_t NMVLR; /*network management vector length register *//*58 */
6387 volatile TICCR_t TICCR; /*timer configuration and control register *//*5A */
6388 volatile TI1CYSR_t TI1CYSR; /*timer 1 cycle set register *//*5C */
6389 volatile T1MTOR_t T1MTOR; /*timer 1 macrotick offset register *//*5E */
6390 volatile TI2CR0_t TI2CR0; /*timer 2 configuration register 0 *//*60 */
6391 volatile TI2CR1_t TI2CR1; /*timer 2 configuration register 1 *//*62 */
6392 volatile SSSR_t SSSR; /*slot status selection register *//*64 */
6393 volatile SSCCR_t SSCCR; /*slot status counter condition register *//*66 */
6394 volatile SSR_t SSR[8]; /*slot status registers 0-7 *//*68 */
6395 volatile SSCR_t SSCR[4]; /*slot status counter registers 0-3 *//*78 */
6396 volatile MTSCFR_t MTSACFR; /*mts a config register *//*80 */
6397 volatile MTSCFR_t MTSBCFR; /*mts b config register *//*82 */
6398 volatile RSBIR_t RSBIR; /*receive shadow buffer index register *//*84 */
6399 volatile RFSR_t RFSR; /*receive fifo selection register *//*86 */
6400 volatile RFSIR_t RFSIR; /*receive fifo start index register *//*88 */
6401 volatile RFDSR_t RFDSR; /*receive fifo depth and size register *//*8A */
6402 volatile RFARIR_t RFARIR; /*receive fifo a read index register *//*8C */
6403 volatile RFBRIR_t RFBRIR; /*receive fifo b read index register *//*8E */
6404 volatile RFMIDAFVR_t RFMIDAFVR; /*receive fifo message ID acceptance filter value register *//*90 */
6405 volatile RFMIAFMR_t RFMIAFMR; /*receive fifo message ID acceptance filter mask register *//*92 */
6406 volatile RFFIDRFVR_t RFFIDRFVR; /*receive fifo frame ID rejection filter value register *//*94 */
6407 volatile RFFIDRFMR_t RFFIDRFMR; /*receive fifo frame ID rejection filter mask register *//*96 */
6408 volatile RFRFCFR_t RFRFCFR; /*receive fifo range filter configuration register *//*98 */
6409 volatile RFRFCTR_t RFRFCTR; /*receive fifo range filter control register *//*9A */
6410 volatile LDTXSLAR_t LDTXSLAR; /*last dynamic transmit slot channel A register *//*9C */
6411 volatile LDTXSLBR_t LDTXSLBR; /*last dynamic transmit slot channel B register *//*9E */
6412 volatile PCR0_t PCR0; /*protocol configuration register 0 *//*A0 */
6413 volatile PCR1_t PCR1; /*protocol configuration register 1 *//*A2 */
6414 volatile PCR2_t PCR2; /*protocol configuration register 2 *//*A4 */
6415 volatile PCR3_t PCR3; /*protocol configuration register 3 *//*A6 */
6416 volatile PCR4_t PCR4; /*protocol configuration register 4 *//*A8 */
6417 volatile PCR5_t PCR5; /*protocol configuration register 5 *//*AA */
6418 volatile PCR6_t PCR6; /*protocol configuration register 6 *//*AC */
6419 volatile PCR7_t PCR7; /*protocol configuration register 7 *//*AE */
6420 volatile PCR8_t PCR8; /*protocol configuration register 8 *//*B0 */
6421 volatile PCR9_t PCR9; /*protocol configuration register 9 *//*B2 */
6422 volatile PCR10_t PCR10; /*protocol configuration register 10 *//*B4 */
6423 volatile PCR11_t PCR11; /*protocol configuration register 11 *//*B6 */
6424 volatile PCR12_t PCR12; /*protocol configuration register 12 *//*B8 */
6425 volatile PCR13_t PCR13; /*protocol configuration register 13 *//*BA */
6426 volatile PCR14_t PCR14; /*protocol configuration register 14 *//*BC */
6427 volatile PCR15_t PCR15; /*protocol configuration register 15 *//*BE */
6428 volatile PCR16_t PCR16; /*protocol configuration register 16 *//*C0 */
6429 volatile PCR17_t PCR17; /*protocol configuration register 17 *//*C2 */
6430 volatile PCR18_t PCR18; /*protocol configuration register 18 *//*C4 */
6431 volatile PCR19_t PCR19; /*protocol configuration register 19 *//*C6 */
6432 volatile PCR20_t PCR20; /*protocol configuration register 20 *//*C8 */
6433 volatile PCR21_t PCR21; /*protocol configuration register 21 *//*CA */
6434 volatile PCR22_t PCR22; /*protocol configuration register 22 *//*CC */
6435 volatile PCR23_t PCR23; /*protocol configuration register 23 *//*CE */
6436 volatile PCR24_t PCR24; /*protocol configuration register 24 *//*D0 */
6437 volatile PCR25_t PCR25; /*protocol configuration register 25 *//*D2 */
6438 volatile PCR26_t PCR26; /*protocol configuration register 26 *//*D4 */
6439 volatile PCR27_t PCR27; /*protocol configuration register 27 *//*D6 */
6440 volatile PCR28_t PCR28; /*protocol configuration register 28 *//*D8 */
6441 volatile PCR29_t PCR29; /*protocol configuration register 29 *//*DA */
6442 volatile PCR30_t PCR30; /*protocol configuration register 30 *//*DC */
6443 uint16_t reserved2[17];
6444 volatile MSG_BUFF_CCS_t MBCCS[128]; /* message buffer configuration, control & status registers 0-31 *//*100 */
6445 } FR_tag_t;
6446
6447 typedef union uF_HEADER /* frame header */
6448 {
6449 struct {
6450 uint16_t:5;
6451 uint16_t HDCRC:11; /* Header CRC */
6452 uint16_t:2;
6453 uint16_t CYCCNT:6; /* Cycle Count */
6454 uint16_t:1;
6455 uint16_t PLDLEN:7; /* Payload Length */
6456 uint16_t:1;
6457 uint16_t PPI:1; /* Payload Preamble Indicator */
6458 uint16_t NUF:1; /* Null Frame Indicator */
6459 uint16_t SYF:1; /* Sync Frame Indicator */
6460 uint16_t SUF:1; /* Startup Frame Indicator */
6461 uint16_t FID:11; /* Frame ID */
6462 } B;
6463 uint16_t WORDS[3];
6464 } F_HEADER_t;
6465 typedef union uS_STSTUS /* slot status */
6466 {
6467 struct {
6468 uint16_t VFB:1; /* Valid Frame on channel B */
6469 uint16_t SYB:1; /* Sync Frame Indicator channel B */
6470 uint16_t NFB:1; /* Null Frame Indicator channel B */
6471 uint16_t SUB:1; /* Startup Frame Indicator channel B */
6472 uint16_t SEB:1; /* Syntax Error on channel B */
6473 uint16_t CEB:1; /* Content Error on channel B */
6474 uint16_t BVB:1; /* Boundary Violation on channel B */
6475 uint16_t CH:1; /* Channel */
6476 uint16_t VFA:1; /* Valid Frame on channel A */
6477 uint16_t SYA:1; /* Sync Frame Indicator channel A */
6478 uint16_t NFA:1; /* Null Frame Indicator channel A */
6479 uint16_t SUA:1; /* Startup Frame Indicator channel A */
6480 uint16_t SEA:1; /* Syntax Error on channel A */
6481 uint16_t CEA:1; /* Content Error on channel A */
6482 uint16_t BVA:1; /* Boundary Violation on channel A */
6483 uint16_t:1;
6484 } RX;
6485 struct {
6486 uint16_t VFB:1; /* Valid Frame on channel B */
6487 uint16_t SYB:1; /* Sync Frame Indicator channel B */
6488 uint16_t NFB:1; /* Null Frame Indicator channel B */
6489 uint16_t SUB:1; /* Startup Frame Indicator channel B */
6490 uint16_t SEB:1; /* Syntax Error on channel B */
6491 uint16_t CEB:1; /* Content Error on channel B */
6492 uint16_t BVB:1; /* Boundary Violation on channel B */
6493 uint16_t TCB:1; /* Tx Conflict on channel B */
6494 uint16_t VFA:1; /* Valid Frame on channel A */
6495 uint16_t SYA:1; /* Sync Frame Indicator channel A */
6496 uint16_t NFA:1; /* Null Frame Indicator channel A */
6497 uint16_t SUA:1; /* Startup Frame Indicator channel A */
6498 uint16_t SEA:1; /* Syntax Error on channel A */
6499 uint16_t CEA:1; /* Content Error on channel A */
6500 uint16_t BVA:1; /* Boundary Violation on channel A */
6501 uint16_t TCA:1; /* Tx Conflict on channel A */
6502 } TX;
6503 uint16_t R;
6504 } S_STATUS_t;
6505
6506 typedef struct uMB_HEADER /* message buffer header */
6507 {
6508 F_HEADER_t FRAME_HEADER;
6509 uint16_t DATA_OFFSET;
6510 S_STATUS_t SLOT_STATUS;
6511 } MB_HEADER_t;
6512
6513/* Define memories */
6514
6515#define SRAM_START 0x40000000
6516#define SRAM_SIZE 0x40000
6517#define SRAM_END 0x4003FFFF
6518
6519#define FLASH_START 0x00000000
6520#define FLASH_SIZE 0x400000
6521#define FLASH_END 0x003FFFFF
6522
6523/* Define instances of modules */
6524#define PBRIDGE_A (*( volatile struct PBRIDGE_A_tag *) 0xC3F00000)
6525#define FMPLL (*( volatile struct FMPLL_tag *) 0xC3F80000)
6526#define EBI (*( volatile struct EBI_tag *) 0xC3F84000)
6527#define FLASH_A (*( volatile struct FLASH_tag *) 0xC3F88000)
6528#define FLASH FLASH_A
6529#define FLASH_B (*( volatile struct FLASH_tag *) 0xC3F8C000)
6530#define SIU (*( volatile struct SIU_tag *) 0xC3F90000)
6531
6532#define EMIOS (*( volatile struct EMIOS_tag *) 0xC3FA0000)
6533#define PMC (*( volatile struct PMC_tag *) 0xC3FBC000)
6534
6535#define ETPU (*( volatile struct ETPU_tag *) 0xC3FC0000)
6536#define ETPU_DATA_RAM (*( uint32_t *) 0xC3FC8000)
6537#define ETPU_DATA_RAM_END 0xC3FC8FFC
6538#define ETPU_DATA_RAM_EXT (*( uint32_t *) 0xC3FCC000)
6539#define CODE_RAM (*( uint32_t *) 0xC3FD0000)
6540#define ETPU_CODE_RAM (*( uint32_t *) 0xC3FD0000)
6541
6542#define PIT (*( volatile struct PIT_tag *) 0xC3FF0000)
6543
6544#define PBRIDGE_B (*( volatile struct PBRIDGE_B_tag *) 0xFFF00000)
6545#define XBAR (*( volatile struct XBAR_tag *) 0xFFF04000)
6546#define MPU (*( volatile struct MPU_tag *) 0xFFF10000)
6547#define SWT (*( volatile struct SWT_tag *) 0xFFF38000)
6548#define STM (*( volatile struct STM_tag *) 0xFFF3C000)
6549#define ECSM (*( volatile struct ECSM_tag *) 0xFFF40000)
6550#define EDMA_A (*( volatile struct EDMA_tag *) 0xFFF44000)
6551#define EDMA EDMA_A
6552#define INTC (*( volatile struct INTC_tag *) 0xFFF48000)
6553#define EDMA_B (*( volatile struct EDMA_tag *) 0xFFF54000)
6554
6555#define EQADC_A (*( volatile struct EQADC_tag *) 0xFFF80000)
6556#define EQADC EQADC_A
6557#define EQADC_B (*( volatile struct EQADC_tag *) 0xFFF84000)
6558
6559#define DECFIL_A (*( volatile struct DECFIL_tag *) 0xFFF88000)
6560#define DECFIL_B (*( volatile struct DECFIL_tag *) 0xFFF88800)
6561#define DECFIL_C (*( volatile struct DECFIL_tag *) 0xFFF89000)
6562#define DECFIL_D (*( volatile struct DECFIL_tag *) 0xFFF89800)
6563#define DECFIL_E (*( volatile struct DECFIL_tag *) 0xFFF8A000)
6564#define DECFIL_F (*( volatile struct DECFIL_tag *) 0xFFF8A800)
6565#define DECFIL_G (*( volatile struct DECFIL_tag *) 0xFFF8B000)
6566#define DECFIL_H (*( volatile struct DECFIL_tag *) 0xFFF8B800)
6567
6568#define DSPI_A (*( volatile struct DSPI_tag *) 0xFFF90000)
6569#define DSPI_B (*( volatile struct DSPI_tag *) 0xFFF94000)
6570#define DSPI_C (*( volatile struct DSPI_tag *) 0xFFF98000)
6571#define DSPI_D (*( volatile struct DSPI_tag *) 0xFFF9C000)
6572
6573#define ESCI_A (*( volatile struct ESCI_tag *) 0xFFFB0000)
6574#define ESCI_B (*( volatile struct ESCI_tag *) 0xFFFB4000)
6575#define ESCI_C (*( volatile struct ESCI_tag *) 0xFFFB8000)
6576#define ESCI_D (*( volatile struct ESCI_tag *) 0xFFFBC000)
6577
6578#define CAN_A (*( volatile struct FLEXCAN2_tag *) 0xFFFC0000)
6579#define CAN_B (*( volatile struct FLEXCAN2_tag *) 0xFFFC4000)
6580#define CAN_C (*( volatile struct FLEXCAN2_tag *) 0xFFFC8000)
6581#define CAN_D (*( volatile struct FLEXCAN2_tag *) 0xFFFCC000)
6582
6583#define FR (*( volatile struct FR_tag *) 0xFFFE0000)
6584#define TSENS (*( volatile struct TSENS_tag *) 0xFFFEC000)
6585
6586#ifdef __MWERKS__
6587#pragma pop
6588#endif
6589
6590#ifdef __cplusplus
6591}
6592#endif
6593#endif /* ASM */
6594#endif /* ifdef _MPC5674_H */
6595/*********************************************************************
6596 *
6597 * Copyright:
6598 * Freescale Semiconductor, INC. All Rights Reserved.
6599 * You are hereby granted a copyright license to use, modify, and
6600 * distribute the SOFTWARE so long as this entire notice is
6601 * retained without alteration in any modified and/or redistributed
6602 * versions, and that such modified versions are clearly identified
6603 * as such. No licenses are granted by implication, estoppel or
6604 * otherwise under any patents or trademarks of Freescale
6605 * Semiconductor, Inc. This software is provided on an "AS IS"
6606 * basis and without warranty.
6607 *
6608 * To the maximum extent permitted by applicable law, Freescale
6609 * Semiconductor DISCLAIMS ALL WARRANTIES WHETHER EXPRESS OR IMPLIED,
6610 * INCLUDING IMPLIED WARRANTIES OF MERCHANTABILITY OR FITNESS FOR A
6611 * PARTICULAR PURPOSE AND ANY WARRANTY AGAINST INFRINGEMENT WITH
6612 * REGARD TO THE SOFTWARE (INCLUDING ANY MODIFIED VERSIONS THEREOF)
6613 * AND ANY ACCOMPANYING WRITTEN MATERIALS.
6614 *
6615 * To the maximum extent permitted by applicable law, IN NO EVENT
6616 * SHALL Freescale Semiconductor BE LIABLE FOR ANY DAMAGES WHATSOEVER
6617 * (INCLUDING WITHOUT LIMITATION, DAMAGES FOR LOSS OF BUSINESS PROFITS,
6618 * BUSINESS INTERRUPTION, LOSS OF BUSINESS INFORMATION, OR OTHER
6619 * PECUNIARY LOSS) ARISING OF THE USE OR INABILITY TO USE THE SOFTWARE.
6620 *
6621 * Freescale Semiconductor assumes no responsibility for the
6622 * maintenance and support of this software
6623 *
6624 ********************************************************************/
Definition: fsl-mpc567x.h:4501
Definition: ff.h:241
Definition: fsl-mpc551x.h:238
Definition: fsl-mpc551x.h:473
Definition: fsl-mpc551x.h:441
Definition: fsl-mpc551x.h:477
Definition: fsl-mpc555x.h:2173
Definition: fsl-mpc551x.h:525
Definition: fsl-mpc551x.h:710
Definition: fsl-mpc551x.h:893
Definition: fsl-mpc555x.h:1130
Definition: fsl-mpc551x.h:1021
Definition: fsl-mpc555x.h:2993
Definition: fsl-mpc551x.h:1478
Definition: fsl-mpc551x.h:3616
Definition: fsl-mpc551x.h:1597
Definition: fsl-mpc551x.h:1837
Definition: fsl-mpc555x.h:118
Definition: fsl-mpc555x.h:230
Definition: fsl-mpc551x.h:1985
Definition: fsl-mpc567x.h:2337
Definition: fsl-mpc551x.h:2215
Definition: fsl-mpc5668.h:6461
Definition: fsl-mpc5668.h:6570
Definition: fsl-mpc555x.h:1976
Definition: fsl-mpc551x.h:3777
Definition: fsl-mpc551x.h:3475
Definition: fsl-mpc564xL.h:16580
Definition: fsl-mpc564xL.h:16535
Definition: fsl-mpc564xL.h:16692
Definition: fsl-mpc564xL.h:16672
Definition: fsl-mpc564xL.h:16621
Definition: fsl-mpc564xL.h:16599
Definition: fsl-mpc555x.h:2445
Definition: fsl-mpc567x.h:4296
Definition: fsl-mpc567x.h:4288
Definition: fsl-mpc567x.h:4265
Definition: fsl-mpc567x.h:4280
Definition: fsl-mpc567x.h:4305
Definition: fsl-mpc567x.h:4447
Definition: fsl-mpc564xL.h:960
Definition: fsl-mpc551x.h:3534
Definition: fsl-mpc551x.h:3537
Definition: fsl-mpc551x.h:2933
Definition: fsl-mpc551x.h:3031
Definition: fsl-mpc551x.h:3540
Definition: fsl-mpc551x.h:3718
Definition: fsl-mpc551x.h:2836
Definition: fsl-mpc551x.h:3609
Definition: fsl-mpc551x.h:3612
Definition: fsl-mpc551x.h:2801
Definition: fsl-mpc551x.h:2954
Definition: fsl-mpc551x.h:2811
Definition: fsl-mpc551x.h:2775
Definition: fsl-mpc551x.h:3543
Definition: fsl-mpc551x.h:3165
Definition: fsl-mpc551x.h:2767
Definition: fsl-mpc551x.h:3570
Definition: fsl-mpc551x.h:3567
Definition: fsl-mpc551x.h:3555
Definition: fsl-mpc551x.h:3222
Definition: fsl-mpc551x.h:3307
Definition: fsl-mpc551x.h:3316
Definition: fsl-mpc551x.h:3325
Definition: fsl-mpc551x.h:3333
Definition: fsl-mpc551x.h:3341
Definition: fsl-mpc551x.h:3349
Definition: fsl-mpc551x.h:3356
Definition: fsl-mpc551x.h:3364
Definition: fsl-mpc551x.h:3371
Definition: fsl-mpc551x.h:3379
Definition: fsl-mpc551x.h:3230
Definition: fsl-mpc551x.h:3387
Definition: fsl-mpc551x.h:3395
Definition: fsl-mpc551x.h:3403
Definition: fsl-mpc551x.h:3412
Definition: fsl-mpc551x.h:3419
Definition: fsl-mpc551x.h:3428
Definition: fsl-mpc551x.h:3435
Definition: fsl-mpc551x.h:3444
Definition: fsl-mpc551x.h:3451
Definition: fsl-mpc551x.h:3459
Definition: fsl-mpc551x.h:3238
Definition: fsl-mpc551x.h:3467
Definition: fsl-mpc551x.h:3246
Definition: fsl-mpc551x.h:3255
Definition: fsl-mpc551x.h:3263
Definition: fsl-mpc551x.h:3272
Definition: fsl-mpc551x.h:3281
Definition: fsl-mpc551x.h:3289
Definition: fsl-mpc551x.h:3298
Definition: fsl-mpc551x.h:3531
Definition: fsl-mpc551x.h:2895
Definition: fsl-mpc551x.h:2916
Definition: fsl-mpc551x.h:2857
Definition: fsl-mpc551x.h:2878
Definition: fsl-mpc551x.h:2822
Definition: fsl-mpc551x.h:2965
Definition: fsl-mpc551x.h:2981
Definition: fsl-mpc551x.h:2994
Definition: fsl-mpc551x.h:3012
Definition: fsl-mpc551x.h:3591
Definition: fsl-mpc551x.h:3594
Definition: fsl-mpc551x.h:3187
Definition: fsl-mpc551x.h:3606
Definition: fsl-mpc551x.h:3603
Definition: fsl-mpc551x.h:3600
Definition: fsl-mpc551x.h:3597
Definition: fsl-mpc551x.h:3196
Definition: fsl-mpc551x.h:3207
Definition: fsl-mpc551x.h:3588
Definition: fsl-mpc551x.h:3585
Definition: fsl-mpc551x.h:3176
Definition: fsl-mpc551x.h:3552
Definition: fsl-mpc551x.h:3053
Definition: fsl-mpc551x.h:3564
Definition: fsl-mpc551x.h:3561
Definition: fsl-mpc551x.h:3079
Definition: fsl-mpc551x.h:3063
Definition: fsl-mpc551x.h:3558
Definition: fsl-mpc551x.h:3546
Definition: fsl-mpc551x.h:3549
Definition: fsl-mpc551x.h:3128
Definition: fsl-mpc551x.h:3582
Definition: fsl-mpc551x.h:3144
Definition: fsl-mpc551x.h:3117
Definition: fsl-mpc556x.h:3490
Definition: fsl-mpc551x.h:2790
Definition: fsl-mpc551x.h:3522
Definition: fsl-mpc551x.h:3525
Definition: fsl-mpc551x.h:3736
Definition: fsl-mpc551x.h:3573
Definition: fsl-mpc551x.h:3106
Definition: fsl-mpc551x.h:3576
Definition: fsl-mpc551x.h:3579
Definition: fsl-mpc551x.h:3087
