RTEMS 7.0-rc1
ffconf.h
1/*---------------------------------------------------------------------------/
2/ Configurations of FatFs Module
3/---------------------------------------------------------------------------*/
4
5#define FFCONF_DEF 80386 /* Revision ID */
6
7/*---------------------------------------------------------------------------/
8/ Function Configurations
9/---------------------------------------------------------------------------*/
10
11#define FF_FS_READONLY 0
12/* This option switches read-only configuration. (0:Read/Write or 1:Read-only)
13/ Read-only configuration removes writing API functions, f_write(), f_sync(),
14/ f_unlink(), f_mkdir(), f_chmod(), f_rename(), f_truncate(), f_getfree()
15/ and optional writing functions as well. */
16
17
18#define FF_FS_MINIMIZE 0
19/* This option defines minimization level to remove some basic API functions.
20/
21/ 0: Basic functions are fully enabled.
22/ 1: f_stat(), f_getfree(), f_unlink(), f_mkdir(), f_truncate() and f_rename()
23/ are removed.
24/ 2: f_opendir(), f_readdir() and f_closedir() are removed in addition to 1.
25/ 3: f_lseek() function is removed in addition to 2. */
26
27
28#define FF_USE_FIND 0
29/* This option switches filtered directory read functions, f_findfirst() and
30/ f_findnext(). (0:Disable, 1:Enable 2:Enable with matching altname[] too) */
31
32
33#define FF_USE_MKFS 0
34/* This option switches f_mkfs(). (0:Disable or 1:Enable) */
35
36
37#define FF_USE_FASTSEEK 0
38/* This option switches fast seek feature. (0:Disable or 1:Enable) */
39
40
41#define FF_USE_EXPAND 0
42/* This option switches f_expand(). (0:Disable or 1:Enable) */
43
44
45#define FF_USE_CHMOD 0
46/* This option switches attribute control API functions, f_chmod() and f_utime().
47/ (0:Disable or 1:Enable) Also FF_FS_READONLY needs to be 0 to enable this option. */
48
49
50#define FF_USE_LABEL 0
51/* This option switches volume label API functions, f_getlabel() and f_setlabel().
52/ (0:Disable or 1:Enable) */
53
54
55#define FF_USE_FORWARD 0
56/* This option switches f_forward(). (0:Disable or 1:Enable) */
57
58
59#define FF_USE_STRFUNC 0
60#define FF_PRINT_LLI 0
61#define FF_PRINT_FLOAT 0
62#define FF_STRF_ENCODE 0
63/* FF_USE_STRFUNC switches string API functions, f_gets(), f_putc(), f_puts() and
64/ f_printf().
65/
66/ 0: Disable. FF_PRINT_LLI, FF_PRINT_FLOAT and FF_STRF_ENCODE have no effect.
67/ 1: Enable without LF-CRLF conversion.
68/ 2: Enable with LF-CRLF conversion.
69/
70/ FF_PRINT_LLI = 1 makes f_printf() support long long argument and FF_PRINT_FLOAT = 1/2
71/ makes f_printf() support floating point argument. These features want C99 or later.
72/ When FF_LFN_UNICODE >= 1 with LFN enabled, string API functions convert the character
73/ encoding in it. FF_STRF_ENCODE selects assumption of character encoding ON THE FILE
74/ to be read/written via those functions.
75/
76/ 0: ANSI/OEM in current CP
77/ 1: Unicode in UTF-16LE
78/ 2: Unicode in UTF-16BE
79/ 3: Unicode in UTF-8
80*/
81
82
83/*---------------------------------------------------------------------------/
84/ Locale and Namespace Configurations
85/---------------------------------------------------------------------------*/
86
87#define FF_CODE_PAGE 932
88/* This option specifies the OEM code page to be used on the target system.
89/ Incorrect code page setting can cause a file open failure.
90/
91/ 437 - U.S.
92/ 720 - Arabic
93/ 737 - Greek
94/ 771 - KBL
95/ 775 - Baltic
96/ 850 - Latin 1
97/ 852 - Latin 2
98/ 855 - Cyrillic
99/ 857 - Turkish
100/ 860 - Portuguese
101/ 861 - Icelandic
102/ 862 - Hebrew
103/ 863 - Canadian French
104/ 864 - Arabic
105/ 865 - Nordic
106/ 866 - Russian
107/ 869 - Greek 2
108/ 932 - Japanese (DBCS)
109/ 936 - Simplified Chinese (DBCS)
110/ 949 - Korean (DBCS)
111/ 950 - Traditional Chinese (DBCS)
112/ 0 - Include all code pages above and configured by f_setcp()
113*/
114
115
116#define FF_USE_LFN 0
117#define FF_MAX_LFN 255
118/* The FF_USE_LFN switches the support for LFN (long file name).
119/
120/ 0: Disable LFN. FF_MAX_LFN has no effect.
121/ 1: Enable LFN with static working buffer on the BSS. Always NOT thread-safe.
122/ 2: Enable LFN with dynamic working buffer on the STACK.
123/ 3: Enable LFN with dynamic working buffer on the HEAP.
124/
125/ To enable the LFN, ffunicode.c needs to be added to the project. The LFN feature
126/ requiers certain internal working buffer occupies (FF_MAX_LFN + 1) * 2 bytes and
127/ additional (FF_MAX_LFN + 44) / 15 * 32 bytes when exFAT is enabled.
128/ The FF_MAX_LFN defines size of the working buffer in UTF-16 code unit and it can
129/ be in range of 12 to 255. It is recommended to be set 255 to fully support the LFN
130/ specification.
131/ When use stack for the working buffer, take care on stack overflow. When use heap
132/ memory for the working buffer, memory management functions, ff_memalloc() and
133/ ff_memfree() exemplified in ffsystem.c, need to be added to the project. */
134
135
136#define FF_LFN_UNICODE 0
137/* This option switches the character encoding on the API when LFN is enabled.
138/
139/ 0: ANSI/OEM in current CP (TCHAR = char)
140/ 1: Unicode in UTF-16 (TCHAR = WCHAR)
141/ 2: Unicode in UTF-8 (TCHAR = char)
142/ 3: Unicode in UTF-32 (TCHAR = DWORD)
143/
144/ Also behavior of string I/O functions will be affected by this option.
145/ When LFN is not enabled, this option has no effect. */
146
147
148#define FF_LFN_BUF 255
149#define FF_SFN_BUF 12
150/* This set of options defines size of file name members in the FILINFO structure
151/ which is used to read out directory items. These values should be suffcient for
152/ the file names to read. The maximum possible length of the read file name depends
153/ on character encoding. When LFN is not enabled, these options have no effect. */
154
155
156#define FF_FS_RPATH 0
157/* This option configures support for relative path feature.
158/
159/ 0: Disable relative path and remove related API functions.
160/ 1: Enable relative path and dot names. f_chdir() and f_chdrive() are available.
161/ 2: f_getcwd() is available in addition to 1.
162*/
163
164
165#define FF_PATH_DEPTH 10
166/* This option defines maximum depth of directory in the exFAT volume. It is NOT
167/ relevant to FAT/FAT32 volume.
168/ For example, FF_PATH_DEPTH = 3 will able to follow a path "/dir1/dir2/dir3/file"
169/ but a sub-directory in the dir3 will not able to be followed and set current
170/ directory.
171/ The size of filesystem object (FATFS) increases FF_PATH_DEPTH * 24 bytes.
172/ When FF_FS_EXFAT == 0 or FF_FS_RPATH == 0, this option has no effect.
173*/
174
175
176
177/*---------------------------------------------------------------------------/
178/ Drive/Volume Configurations
179/---------------------------------------------------------------------------*/
180
181#define FF_VOLUMES 1
182/* Number of volumes (logical drives) to be used. (1-10) */
183
184
185#define FF_STR_VOLUME_ID 0
186#define FF_VOLUME_STRS "RAM","NAND","CF","SD","SD2","USB","USB2","USB3"
187/* FF_STR_VOLUME_ID switches support for volume ID in arbitrary strings.
188/ When FF_STR_VOLUME_ID is set to 1 or 2, arbitrary strings can be used as drive
189/ number in the path name. FF_VOLUME_STRS defines the volume ID strings for each
190/ logical drive. Number of items must not be less than FF_VOLUMES. Valid
191/ characters for the volume ID strings are A-Z, a-z and 0-9, however, they are
192/ compared in case-insensitive. If FF_STR_VOLUME_ID >= 1 and FF_VOLUME_STRS is
193/ not defined, a user defined volume string table is needed as:
194/
195/ const char* VolumeStr[FF_VOLUMES] = {"ram","flash","sd","usb",...
196*/
197
198
199#define FF_MULTI_PARTITION 0
200/* This option switches support for multiple volumes on the physical drive.
201/ By default (0), each logical drive number is bound to the same physical drive
202/ number and only an FAT volume found on the physical drive will be mounted.
203/ When this feature is enabled (1), each logical drive number can be bound to
204/ arbitrary physical drive and partition listed in the VolToPart[]. Also f_fdisk()
205/ will be available. */
206
207
208#define FF_MIN_SS 512
209#define FF_MAX_SS 512
210/* This set of options configures the range of sector size to be supported. (512,
211/ 1024, 2048 or 4096) Always set both 512 for most systems, generic memory card and
212/ harddisk, but a larger value may be required for on-board flash memory and some
213/ type of optical media. When FF_MAX_SS is larger than FF_MIN_SS, FatFs is
214/ configured for variable sector size mode and disk_ioctl() needs to implement
215/ GET_SECTOR_SIZE command. */
216
217
218#define FF_LBA64 0
219/* This option switches support for 64-bit LBA. (0:Disable or 1:Enable)
220/ To enable the 64-bit LBA, also exFAT needs to be enabled. (FF_FS_EXFAT == 1) */
221
222
223#define FF_MIN_GPT 0x10000000
224/* Minimum number of sectors to switch GPT as partitioning format in f_mkfs() and
225/ f_fdisk(). 2^32 sectors maximum. This option has no effect when FF_LBA64 == 0. */
226
227
228#define FF_USE_TRIM 0
229/* This option switches support for ATA-TRIM. (0:Disable or 1:Enable)
230/ To enable this feature, also CTRL_TRIM command should be implemented to
231/ the disk_ioctl(). */
232
233
234
235/*---------------------------------------------------------------------------/
236/ System Configurations
237/---------------------------------------------------------------------------*/
238
239#define FF_FS_TINY 0
240/* This option switches tiny buffer configuration. (0:Normal or 1:Tiny)
241/ At the tiny configuration, size of file object (FIL) is reduced FF_MAX_SS bytes.
242/ Instead of private sector buffer eliminated from the file object, common sector
243/ buffer in the filesystem object (FATFS) is used for the file data transfer. */
244
245
246#define FF_FS_EXFAT 0
247/* This option switches support for exFAT filesystem. (0:Disable or 1:Enable)
248/ To enable exFAT, also LFN needs to be enabled. (FF_USE_LFN >= 1)
249/ Note that enabling exFAT discards ANSI C (C89) compatibility. */
250
251
252#define FF_FS_NORTC 0
253#define FF_NORTC_MON 1
254#define FF_NORTC_MDAY 1
255#define FF_NORTC_YEAR 2025
256/* The option FF_FS_NORTC switches timestamp feature. If the system does not have
257/ an RTC or valid timestamp is not needed, set FF_FS_NORTC = 1 to disable the
258/ timestamp feature. Every object modified by FatFs will have a fixed timestamp
259/ defined by FF_NORTC_MON, FF_NORTC_MDAY and FF_NORTC_YEAR in local time.
260/ To enable timestamp function (FF_FS_NORTC = 0), get_fattime() need to be added
261/ to the project to read current time form real-time clock. FF_NORTC_MON,
262/ FF_NORTC_MDAY and FF_NORTC_YEAR have no effect.
263/ These options have no effect in read-only configuration (FF_FS_READONLY = 1). */
264
265
266#define FF_FS_CRTIME 0
267/* This option enables(1)/disables(0) the timestamp of the file created. When
268/ set 1, the file created time is available in FILINFO structure. */
269
270
271#define FF_FS_NOFSINFO 0
272/* If you need to know the correct free space on the FAT32 volume, set bit 0 of
273/ this option, and f_getfree() on the first time after volume mount will force
274/ a full FAT scan. Bit 1 controls the use of last allocated cluster number.
275/
276/ bit0=0: Use free cluster count in the FSINFO if available.
277/ bit0=1: Do not trust free cluster count in the FSINFO.
278/ bit1=0: Use last allocated cluster number in the FSINFO if available.
279/ bit1=1: Do not trust last allocated cluster number in the FSINFO.
280*/
281
282
283#define FF_FS_LOCK 0
284/* The option FF_FS_LOCK switches file lock function to control duplicated file open
285/ and illegal operation to open objects. This option must be 0 when FF_FS_READONLY
286/ is 1.
287/
288/ 0: Disable file lock function. To avoid volume corruption, application program
289/ should avoid illegal open, remove and rename to the open objects.
290/ >0: Enable file lock function. The value defines how many files/sub-directories
291/ can be opened simultaneously under file lock control. Note that the file
292/ lock control is independent of re-entrancy. */
293
294
295#define FF_FS_REENTRANT 0
296#define FF_FS_TIMEOUT 1000
297/* The option FF_FS_REENTRANT switches the re-entrancy (thread safe) of the FatFs
298/ module itself. Note that regardless of this option, file access to different
299/ volume is always re-entrant and volume control functions, f_mount(), f_mkfs()
300/ and f_fdisk(), are always not re-entrant. Only file/directory access to
301/ the same volume is under control of this featuer.
302/
303/ 0: Disable re-entrancy. FF_FS_TIMEOUT have no effect.
304/ 1: Enable re-entrancy. Also user provided synchronization handlers,
305/ ff_mutex_create(), ff_mutex_delete(), ff_mutex_take() and ff_mutex_give(),
306/ must be added to the project. Samples are available in ffsystem.c.
307/
308/ The FF_FS_TIMEOUT defines timeout period in unit of O/S time tick.
309*/
310
311
312
313/*--- End of configuration options ---*/
