38#ifndef _RTEMS_CONFDEFS_EXTENSIONS_H
39#define _RTEMS_CONFDEFS_EXTENSIONS_H
41#ifndef __CONFIGURATION_TEMPLATE_h
42#error "Do not include this file directly, use <rtems/confdefs.h> instead"
52#ifndef CONFIGURE_MAXIMUM_USER_EXTENSIONS
53 #define CONFIGURE_MAXIMUM_USER_EXTENSIONS 0
56#if CONFIGURE_MAXIMUM_USER_EXTENSIONS > 0
60#ifdef _CONFIGURE_ENABLE_NEWLIB_REENTRANCY
64#if CONFIGURE_RECORD_PER_PROCESSOR_ITEMS > 0
65 #if (CONFIGURE_RECORD_PER_PROCESSOR_ITEMS & (CONFIGURE_RECORD_PER_PROCESSOR_ITEMS - 1)) != 0
66 #error "CONFIGURE_RECORD_PER_PROCESSOR_ITEMS must be a power of two"
69 #if CONFIGURE_RECORD_PER_PROCESSOR_ITEMS < 16
70 #error "CONFIGURE_RECORD_PER_PROCESSOR_ITEMS must be at least 16"
73 #if defined(CONFIGURE_RECORD_EXTENSIONS_ENABLED) \
74 || defined(CONFIGURE_RECORD_FATAL_DUMP_BASE64) \
75 || defined(CONFIGURE_RECORD_FATAL_DUMP_BASE64_ZLIB)
76 #define _CONFIGURE_RECORD_NEED_EXTENSION
80 #include <rtems/record.h>
82 #ifdef CONFIGURE_RECORD_EXTENSIONS_ENABLED
83 #warning "CONFIGURE_RECORD_EXTENSIONS_ENABLED defined without CONFIGURE_RECORD_PER_PROCESSOR_ITEMS"
85 #ifdef CONFIGURE_RECORD_FATAL_DUMP_BASE64
86 #warning "CONFIGURE_RECORD_FATAL_DUMP_BASE64 defined without CONFIGURE_RECORD_PER_PROCESSOR_ITEMS"
88 #ifdef CONFIGURE_RECORD_FATAL_DUMP_BASE64_ZLIB
89 #warning "CONFIGURE_RECORD_FATAL_DUMP_BASE64_ZLIB defined without CONFIGURE_RECORD_PER_PROCESSOR_ITEMS"
93#if !defined(CONFIGURE_STACK_CHECKER_ENABLED) && defined(CONFIGURE_STACK_CHECKER_REPORTER)
94 #error "Stack checker is disabled but a custom reporter is configured"
97#ifdef CONFIGURE_STACK_CHECKER_ENABLED
101#ifdef CONFIGURE_EXCEPTION_TO_SIGNAL_MAPPING
109#if defined(_CONFIGURE_RECORD_NEED_EXTENSION) \
110 || defined(_CONFIGURE_ENABLE_NEWLIB_REENTRANCY) \
111 || defined(CONFIGURE_STACK_CHECKER_ENABLED) \
112 || defined(CONFIGURE_INITIAL_EXTENSIONS) \
113 || defined(BSP_INITIAL_EXTENSION)
115 #ifdef CONFIGURE_EXCEPTION_TO_SIGNAL_MAPPING
118 #ifdef _CONFIGURE_RECORD_NEED_EXTENSION
120 #ifdef CONFIGURE_RECORD_EXTENSIONS_ENABLED
121 _Record_Thread_create,
122 _Record_Thread_start,
123 _Record_Thread_restart,
124 _Record_Thread_delete,
125 _Record_Thread_switch,
126 _Record_Thread_begin,
127 _Record_Thread_exitted,
129 NULL, NULL, NULL, NULL, NULL, NULL, NULL,
131 #ifdef CONFIGURE_RECORD_FATAL_DUMP_BASE64_ZLIB
132 _Record_Fatal_dump_base64_zlib,
133 #elif defined(CONFIGURE_RECORD_FATAL_DUMP_BASE64)
134 _Record_Fatal_dump_base64,
138 #ifdef CONFIGURE_RECORD_EXTENSIONS_ENABLED
139 _Record_Thread_terminate
145 #ifdef _CONFIGURE_ENABLE_NEWLIB_REENTRANCY
146 RTEMS_NEWLIB_EXTENSION,
148 #ifdef CONFIGURE_STACK_CHECKER_ENABLED
151 #ifdef CONFIGURE_INITIAL_EXTENSIONS
154 #if !defined(CONFIGURE_DISABLE_BSP_SETTINGS) && \
155 defined(BSP_INITIAL_EXTENSION)
156 BSP_INITIAL_EXTENSION
169 RTEMS_SYSINIT_INITIAL_EXTENSIONS,
170 RTEMS_SYSINIT_ORDER_MIDDLE
174#if CONFIGURE_MAXIMUM_USER_EXTENSIONS > 0
178#if CONFIGURE_RECORD_PER_PROCESSOR_ITEMS > 0
182 } Record_Configured_control;
184 static Record_Configured_control _Record_Controls[ _CONFIGURE_MAXIMUM_PROCESSORS ];
188 &_Record_Controls[ 0 ].Control
193 RTEMS_SYSINIT_RECORD,
194 RTEMS_SYSINIT_ORDER_MIDDLE
197 #ifdef CONFIGURE_RECORD_INTERRUPTS_ENABLED
206 return &_Record_Interrupt_dispatch_table[ index ];
210 _Record_Interrupt_initialize,
212 RTEMS_SYSINIT_ORDER_MIDDLE
217#ifdef CONFIGURE_VERBOSE_SYSTEM_INITIALIZATION
220 RTEMS_SYSINIT_RECORD,
221 RTEMS_SYSINIT_ORDER_LAST
225#ifdef CONFIGURE_STACK_CHECKER_ENABLED
226 #ifdef CONFIGURE_STACK_CHECKER_REPORTER
228 CONFIGURE_STACK_CHECKER_REPORTER;
This header file evaluates configuration options related to the per-CPU configuration.
This header file evaluates configuration options related to the BSP configuration.
This header file provides the interfaces for mapping exceptions to signsls.
void _Exception_Raise_signal(Internal_errors_Source source, bool always_set_to_false, Internal_errors_t code)
Handle an exception frame for the purpose of mapping signals.
Definition: exceptionmapping.c:63
This header file provides data structures used by the implementation and the Application Configuratio...
#define RTEMS_ARRAY_SIZE(_array)
Gets the element count of the array.
Definition: basedefs.h:244
ISR_Vector_number rtems_vector_number
This integer type represents interrupt vector numbers.
Definition: intr.h:102
#define RTEMS_SYSINIT_ITEM(handler, module, order)
Creates the system initialization item associated with the handler, module, and order.
Definition: sysinit.h:204
This configuration option is an integer define.
Definition: appl-config.h:835
#define CONFIGURE_RECORD_PER_PROCESSOR_ITEMS
Definition: appl-config.h:1895
#define CONFIGURE_INITIAL_EXTENSIONS
This configuration option is an initializer define.
Definition: appl-config.h:2807
#define EXTENSION_INFORMATION_DEFINE(max)
Macro to define the objects information for the Classic Extensions objects.
Definition: extensiondata.h:74
void _Sysinit_Verbose(void)
Enables a verbose system initialization.
Definition: sysinitverbose.c:154
User_extensions_Switch_control _User_extensions_Initial_switch_controls[]
A spare switch control for each initial user extension.
void _User_extensions_Handler_initialization(void)
Initializes the user extensions handler.
Definition: userext.c:44
const size_t _User_extensions_Initial_count
The count of initial user extensions.
const User_extensions_Table _User_extensions_Initial_extensions[]
The table of initial user extensions.
const Stack_checker_Reporter_handler Stack_checker_Reporter
The Stack Checker Reporter Initialization Handler.
void(* Stack_checker_Reporter_handler)(const rtems_tcb *running, bool pattern_ok)
Definition: stackchk.h:263
void rtems_stack_checker_reporter_quiet(const rtems_tcb *running, bool pattern_ok)
A Quiet Version of Stack Checker Reporter.
Definition: check.c:314
#define RTEMS_STACK_CHECKER_EXTENSION
Stack Checker Extension Set Definition.
Definition: stackchk.h:241
rtems_interrupt_entry ** bsp_interrupt_get_dispatch_table_slot(rtems_vector_number index)
Gets a reference to the interrupt handler table slot associated with the index.
Definition: irq-generic.c:49
Standard C Library Support.
This header file evaluates configuration options related to the Newlib C Library configuration.
This header file provides the Stack Checker API.
Manages the switch callouts.
Definition: userextdata.h:61
User extension table.
Definition: userext.h:253
This structure represents an interrupt entry.
Definition: intr.h:1070
This header file provides the API of the System Initialization Support.
This header file provides interfaces of the User Extensions Handler which are only used by the implem...
