RTEMS 7.0-rc1
extension.h
2
11/*
12 * Copyright (C) 2009, 2021 embedded brains GmbH & Co. KG
13 * Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37/*
38 * This file is part of the RTEMS quality process and was automatically
39 * generated. If you find something that needs to be fixed or
40 * worded better please post a report or patch to an RTEMS mailing list
41 * or raise a bug report:
42 *
43 * https://www.rtems.org/bugs.html
44 *
45 * For information on updating and regenerating please refer to the How-To
46 * section in the Software Requirements Engineering chapter of the
47 * RTEMS Software Engineering manual. The manual is provided as a part of
48 * a release. For development sources please refer to the online
49 * documentation at:
50 *
51 * https://docs.rtems.org
52 */
53
54/* Generated from spec:/rtems/userext/if/header */
55
56#ifndef _RTEMS_EXTENSION_H
57#define _RTEMS_EXTENSION_H
58
59#include <rtems/rtems/status.h>
60#include <rtems/rtems/types.h>
61#include <rtems/score/interr.h>
63
64#ifdef __cplusplus
65extern "C" {
66#endif
67
68/* Generated from spec:/rtems/userext/if/group */
69
80/* Generated from spec:/rtems/userext/if/delete */
81
116
117/* Generated from spec:/rtems/userext/if/fatal */
118
148
149/* Generated from spec:/rtems/userext/if/fatal-code */
150
162typedef Internal_errors_t rtems_fatal_code;
163
164/* Generated from spec:/rtems/userext/if/fatal-source */
165
176
177/* Generated from spec:/rtems/userext/if/ident */
178
227
228/* Generated from spec:/rtems/userext/if/table */
229
239
240/* Generated from spec:/rtems/userext/if/create */
241
315 rtems_name name,
316 const rtems_extensions_table *extension_table,
317 rtems_id *id
318);
319
320/* Generated from spec:/rtems/userext/if/task-begin */
321
354
355/* Generated from spec:/rtems/userext/if/task-create */
356
411
412/* Generated from spec:/rtems/userext/if/task-delete */
413
461
462/* Generated from spec:/rtems/userext/if/task-exitted */
463
482
483/* Generated from spec:/rtems/userext/if/task-restart */
484
519
520/* Generated from spec:/rtems/userext/if/task-start */
521
551
552/* Generated from spec:/rtems/userext/if/task-switch */
553
609
610/* Generated from spec:/rtems/userext/if/task-terminate */
611
645
646#ifdef __cplusplus
647}
648#endif
649
650#endif /* _RTEMS_EXTENSION_H */
rtems_status_code
Definition: status.h:85
uint32_t rtems_name
This type represents Classic API object names.
Definition: types.h:226
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition: types.h:94
rtems_status_code rtems_extension_delete(rtems_id id)
Deletes the extension set.
Definition: extensiondelete.c:45
rtems_status_code rtems_extension_ident(rtems_name name, rtems_id *id)
Identifies an extension set by the object name.
Definition: extensionident.c:45
User_extensions_thread_exitted_extension rtems_task_exitted_extension
Task exitted extensions are invoked when a task entry returns.
Definition: extension.h:481
User_extensions_thread_switch_extension rtems_task_switch_extension
Task switch extensions are invoked when a thread switch from an executing thread to a heir thread tak...
Definition: extension.h:608
User_extensions_thread_begin_extension rtems_task_begin_extension
Task begin extensions are invoked when a task begins execution.
Definition: extension.h:353
User_extensions_thread_restart_extension rtems_task_restart_extension
Task restart extensions are invoked when a task restarts.
Definition: extension.h:518
This integer type represents system termination codes.
Definition: extension.h:162
User_extensions_Table rtems_extensions_table
The extensions table contains a set of extensions which may be registered in the system through the C...
Definition: extension.h:238
User_extensions_thread_delete_extension rtems_task_delete_extension
Task delete extensions are invoked when a task is deleted.
Definition: extension.h:460
User_extensions_thread_create_extension rtems_task_create_extension
Task create extensions are invoked when a task is created.
Definition: extension.h:410
User_extensions_thread_terminate_extension rtems_task_terminate_extension
Task terminate extensions are invoked when a task terminates.
Definition: extension.h:644
User_extensions_fatal_extension rtems_fatal_extension
Fatal extensions are invoked when the system should terminate.
Definition: extension.h:147
User_extensions_thread_start_extension rtems_task_start_extension
Task start extensions are invoked when a task was made ready for the first time.
Definition: extension.h:550
Internal_errors_Source rtems_fatal_source
This enumeration represents system termination sources.
Definition: extension.h:175
rtems_status_code rtems_extension_create(rtems_name name, const rtems_extensions_table *extension_table, rtems_id *id)
Creates an extension set.
Definition: extensioncreate.c:48
This type lists the possible sources from which an error can be reported.
Definition: interr.h:63
void(* User_extensions_thread_begin_extension)(struct _Thread_Control *executing)
Task begin extension.
Definition: userext.h:192
bool(* User_extensions_thread_create_extension)(struct _Thread_Control *executing, struct _Thread_Control *created)
Task create extension.
Definition: userext.h:92
void(* User_extensions_thread_start_extension)(struct _Thread_Control *executing, struct _Thread_Control *started)
Task start extension.
Definition: userext.h:132
void(* User_extensions_thread_restart_extension)(struct _Thread_Control *executing, struct _Thread_Control *restarted)
Task restart extension.
Definition: userext.h:154
void(* User_extensions_thread_delete_extension)(struct _Thread_Control *executing, struct _Thread_Control *deleted)
Task delete extension.
Definition: userext.h:112
void(* User_extensions_thread_switch_extension)(struct _Thread_Control *executing, struct _Thread_Control *heir)
Task switch extension.
Definition: userext.h:177
void(* User_extensions_thread_terminate_extension)(struct _Thread_Control *terminated)
Task termination extension.
Definition: userext.h:246
void(* User_extensions_fatal_extension)(Internal_errors_Source source, bool always_set_to_false, Internal_errors_t code)
Fatal error extension.
Definition: userext.h:224
void(* User_extensions_thread_exitted_extension)(struct _Thread_Control *executing)
Task exitted extension.
Definition: userext.h:206
This header file provides types used by the Classic API.
This header file provides the interfaces of the Internal Error Handler.
This header file provides the status codes of Classic API directives and support functions.
User extension table.
Definition: userext.h:253
This header file provides data structures used by the implementation and the Application Configuratio...
