RTEMS 7.0-rc1
efm32gg11_gpio.h
2
11/*
12 * Copyright (C) 2025 Allan N. Hessenflow
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_ARM_EFM32GG11_GPIO_H
37#define LIBBSP_ARM_EFM32GG11_GPIO_H
38
39#include <bspopts.h>
40
41void efm32gg11_gpio_init_0(void);
42void efm32gg11_gpio_init(void);
43
44/* returns a non-negative number on success indicating the interrupt
45 number assigned, or a negative number on failure. */
46int efm32gg11_gpio_int_register(uint8_t port, uint8_t pin,
47 void (*cb)(void *), void *arg);
48
49/* which is the bit number from the em4 wakeup pin registers, range 16 - 31 */
50void efm32gg11_gpio_wake_pin_int_register(unsigned int which,
51 void (*cb)(void *), void *arg);
52
53/* which is the interrupt number provided by efm32gg11_gpio_int_register() */
54void efm32gg11_gpio_int_mode(unsigned int which, bool rising, bool falling);
55
56/* which is the bit number from the em4 wakeup pin registers, range 16 - 31 */
57void efm32gg11_gpio_wake_pin_level(unsigned int which, bool high);
58
59/* which is the interrupt number provided by efm32gg11_gpio_int_register() */
60void efm32gg11_gpio_int_enable(unsigned int which, bool enable);
61
62void efm32gg11_gpio_mode(uint8_t port, uint8_t pin, uint8_t mode);
63
64void efm32gg11_gpio_clear_set(uint8_t port, uint16_t clear, uint16_t set);
65
66#endif /* LIBBSP_ARM_EFM32GG11_GPIO_H */
