RTEMS 7.0-rc1
diskio.h
1/*-----------------------------------------------------------------------/
2/ Low level disk interface modlue include file (C)ChaN, 2025 /
3/-----------------------------------------------------------------------*/
4
5#ifndef _DISKIO_DEFINED
6#define _DISKIO_DEFINED
7
8#ifdef __cplusplus
9extern "C" {
10#endif
11
12/* Status of Disk Functions */
13typedef BYTE DSTATUS;
14
15/* Results of Disk Functions */
16typedef enum {
17 RES_OK = 0, /* 0: Successful */
18 RES_ERROR, /* 1: R/W Error */
19 RES_WRPRT, /* 2: Write Protected */
20 RES_NOTRDY, /* 3: Not Ready */
21 RES_PARERR /* 4: Invalid Parameter */
22} DRESULT;
23
24
25/*---------------------------------------*/
26/* Prototypes for disk control functions */
27
28
29DSTATUS disk_initialize (BYTE pdrv);
30DSTATUS disk_status (BYTE pdrv);
31DRESULT disk_read (BYTE pdrv, BYTE* buff, LBA_t sector, UINT count);
32DRESULT disk_write (BYTE pdrv, const BYTE* buff, LBA_t sector, UINT count);
33DRESULT disk_ioctl (BYTE pdrv, BYTE cmd, void* buff);
34
35
36/* Disk Status Bits (DSTATUS) */
37
38#define STA_NOINIT 0x01 /* Drive not initialized */
39#define STA_NODISK 0x02 /* No medium in the drive */
40#define STA_PROTECT 0x04 /* Write protected */
41
42
43/* Command code for disk_ioctrl fucntion */
44
45/* Generic command (Used by FatFs) */
46#define CTRL_SYNC 0 /* Complete pending write process (needed at FF_FS_READONLY == 0) */
47#define GET_SECTOR_COUNT 1 /* Get media size (needed at FF_USE_MKFS == 1) */
48#define GET_SECTOR_SIZE 2 /* Get sector size (needed at FF_MAX_SS != FF_MIN_SS) */
49#define GET_BLOCK_SIZE 3 /* Get erase block size (needed at FF_USE_MKFS == 1) */
50#define CTRL_TRIM 4 /* Inform device that the data on the block of sectors is no longer used (needed at FF_USE_TRIM == 1) */
51
52/* Generic command (Not used by FatFs) */
53#define CTRL_POWER 5 /* Get/Set power status */
54#define CTRL_LOCK 6 /* Lock/Unlock media removal */
55#define CTRL_EJECT 7 /* Eject media */
56#define CTRL_FORMAT 8 /* Create physical format on the media */
57
58/* MMC/SDC specific ioctl command (Not used by FatFs) */
59#define MMC_GET_TYPE 10 /* Get card type */
60#define MMC_GET_CSD 11 /* Get CSD */
61#define MMC_GET_CID 12 /* Get CID */
62#define MMC_GET_OCR 13 /* Get OCR */
63#define MMC_GET_SDSTAT 14 /* Get SD status */
64#define ISDIO_READ 55 /* Read data form SD iSDIO register */
65#define ISDIO_WRITE 56 /* Write data to SD iSDIO register */
66#define ISDIO_MRITE 57 /* Masked write data to SD iSDIO register */
67
68/* ATA/CF specific ioctl command (Not used by FatFs) */
69#define ATA_GET_REV 20 /* Get F/W revision */
70#define ATA_GET_MODEL 21 /* Get model name */
71#define ATA_GET_SN 22 /* Get serial number */
72
73#ifdef __cplusplus
74}
75#endif
76
77#endif
