RTEMS 7.0-rc1
consoleIo.h
2
8/*
9 * Copyright (c) 1999 Eric Valette <eric.valette@free.fr>
10 *
11 * Redistribution and use in source and binary forms, with or without
12 * modification, are permitted provided that the following conditions
13 * are met:
14 * 1. Redistributions of source code must retain the above copyright
15 * notice, this list of conditions and the following disclaimer.
16 * 2. Redistributions in binary form must reproduce the above copyright
17 * notice, this list of conditions and the following disclaimer in the
18 * documentation and/or other materials provided with the distribution.
19 *
20 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
21 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
22 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
23 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
24 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
25 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
26 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
27 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
28 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
29 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
30 * POSSIBILITY OF SUCH DAMAGE.
31 */
32
33#ifndef __CONSOLE_IO_H
34#define __CONSOLE_IO_H
35
36typedef enum {
37 CONSOLE_LOG = 1,
38 CONSOLE_SERIAL = 2,
39 CONSOLE_VGA = 3,
40 CONSOLE_VACUUM = 4
41}ioType;
42
43typedef volatile unsigned char * __io_ptr;
44
45typedef struct {
46 __io_ptr io_base;
47 __io_ptr isa_mem_base;
49
50extern board_memory_map *ptr_mem_map;
51
52extern int select_console(ioType t);
53/* extern int printk(const char *, ...) __attribute__((format(printf, 1, 2))); */
54extern void debug_putc(const char c);
55extern void debug_putc_onlcr(const char c);
56extern int debug_getc(void);
57extern int debug_tstc(void);
58int kbdreset(void);
59
60#endif
Definition: consoleIo.h:45
