RTEMS 7.0-rc1
cacheimpl.h
1
10/*
11 * Copyright (C) 2014, 2018 embedded brains GmbH & Co. KG
12 * Copyright (C) 1989, 1999 On-Line Applications Research Corporation (OAR)
13 *
16 * are met:
22 *
34 */
35
124#include <rtems.h>
125
126#include <sys/param.h>
127
128#if defined(RTEMS_SMP) && defined(CPU_CACHE_NO_INSTRUCTION_CACHE_SNOOPING)
129#include <rtems/score/smpimpl.h>
131#endif
132
133#if CPU_DATA_CACHE_ALIGNMENT > CPU_CACHE_LINE_BYTES
134#error "CPU_DATA_CACHE_ALIGNMENT is greater than CPU_CACHE_LINE_BYTES"
135#endif
136
137#if CPU_INSTRUCTION_CACHE_ALIGNMENT > CPU_CACHE_LINE_BYTES
138#error "CPU_INSTRUCTION_CACHE_ALIGNMENT is greater than CPU_CACHE_LINE_BYTES"
139#endif
140
149/*
150 * THESE FUNCTIONS ONLY HAVE BODIES IF WE HAVE A DATA CACHE
151 */
152
153/*
154 * This function is called to flush the data cache by performing cache
155 * copybacks. It must determine how many cache lines need to be copied
156 * back and then perform the copybacks.
157 */
158void
159rtems_cache_flush_multiple_data_lines( const void * d_addr, size_t n_bytes )
160{
161#if defined(CPU_DATA_CACHE_ALIGNMENT)
162#if defined(CPU_CACHE_SUPPORT_PROVIDES_RANGE_FUNCTIONS)
163 _CPU_cache_flush_data_range( d_addr, n_bytes );
164#else
165 const void * final_address;
166
167 /*
168 * Set d_addr to the beginning of the cache line; final_address indicates
169 * the last address_t which needs to be pushed. Increment d_addr and push
170 * the resulting line until final_address is passed.
171 */
172
173 if( n_bytes == 0 )
174 /* Do nothing if number of bytes to flush is zero */
175 return;
176
177 final_address = (void *)((size_t)d_addr + n_bytes - 1);
178 d_addr = (void *)((size_t)d_addr & ~(CPU_DATA_CACHE_ALIGNMENT - 1));
179 while( d_addr <= final_address ) {
180 _CPU_cache_flush_1_data_line( d_addr );
181 d_addr = (void *)((size_t)d_addr + CPU_DATA_CACHE_ALIGNMENT);
182 }
183#endif
184#else
185 (void) d_addr;
186 (void) n_bytes;
187#endif
188}
189
190/*
191 * This function is responsible for performing a data cache invalidate.
192 * It must determine how many cache lines need to be invalidated and then
193 * perform the invalidations.
194 */
195void
196rtems_cache_invalidate_multiple_data_lines( const void * d_addr, size_t n_bytes )
197{
198#if defined(CPU_DATA_CACHE_ALIGNMENT)
199#if defined(CPU_CACHE_SUPPORT_PROVIDES_RANGE_FUNCTIONS)
200 _CPU_cache_invalidate_data_range( d_addr, n_bytes );
201#else
202 const void * final_address;
203
204 /*
205 * Set d_addr to the beginning of the cache line; final_address indicates
206 * the last address_t which needs to be invalidated. Increment d_addr and
207 * invalidate the resulting line until final_address is passed.
208 */
209
210 if( n_bytes == 0 )
211 /* Do nothing if number of bytes to invalidate is zero */
212 return;
213
214 final_address = (void *)((size_t)d_addr + n_bytes - 1);
215 d_addr = (void *)((size_t)d_addr & ~(CPU_DATA_CACHE_ALIGNMENT - 1));
216 while( final_address >= d_addr ) {
217 _CPU_cache_invalidate_1_data_line( d_addr );
218 d_addr = (void *)((size_t)d_addr + CPU_DATA_CACHE_ALIGNMENT);
219 }
220#endif
221#else
222 (void) d_addr;
223 (void) n_bytes;
224#endif
225}
226
227/*
228 * This function is responsible for performing a data cache flush.
229 * It flushes the entire cache.
230 */
231void
233{
234#if defined(CPU_DATA_CACHE_ALIGNMENT)
235 /*
236 * Call the CPU-specific routine
237 */
238 _CPU_cache_flush_entire_data();
239#endif
240}
241
242/*
243 * This function is responsible for performing a data cache
244 * invalidate. It invalidates the entire cache.
245 */
246void
248{
249#if defined(CPU_DATA_CACHE_ALIGNMENT)
250 /*
251 * Call the CPU-specific routine
252 */
253
254 _CPU_cache_invalidate_entire_data();
255#endif
256}
257
258/*
259 * This function returns the data cache granularity.
260 */
261size_t
263{
264#if defined(CPU_DATA_CACHE_ALIGNMENT)
265 return CPU_DATA_CACHE_ALIGNMENT;
266#else
267 return 0;
268#endif
269}
270
271size_t
273{
274#if defined(CPU_CACHE_SUPPORT_PROVIDES_CACHE_SIZE_FUNCTIONS)
275 return _CPU_cache_get_data_cache_size( level );
276#else
277 (void) level;
278
279 return 0;
280#endif
281}
282
283/*
284 * This function freezes the data cache; cache lines
285 * are not replaced.
286 */
287void
289{
290#if defined(CPU_DATA_CACHE_ALIGNMENT)
291 _CPU_cache_freeze_data();
292#endif
293}
294
296{
297#if defined(CPU_DATA_CACHE_ALIGNMENT)
298 _CPU_cache_unfreeze_data();
299#endif
300}
301
302void
304{
305#if defined(CPU_DATA_CACHE_ALIGNMENT)
306 _CPU_cache_enable_data();
307#endif
308}
309
310#if !defined(CPU_CACHE_SUPPORT_PROVIDES_DISABLE_DATA)
311void
313{
314#if defined(CPU_DATA_CACHE_ALIGNMENT)
315 _CPU_cache_disable_data();
316#endif
317}
318#endif
319
320/*
321 * THESE FUNCTIONS ONLY HAVE BODIES IF WE HAVE AN INSTRUCTION CACHE
322 */
323
324#if defined(CPU_INSTRUCTION_CACHE_ALIGNMENT) \
325 && defined(RTEMS_SMP) \
326 && defined(CPU_CACHE_NO_INSTRUCTION_CACHE_SNOOPING)
327
328typedef struct {
329 const void *addr;
330 size_t size;
331} smp_cache_area;
332
333static void smp_cache_inst_inv(void *arg)
334{
335 smp_cache_area *area = arg;
336
337 _CPU_cache_invalidate_instruction_range(area->addr, area->size);
338}
339
340static void smp_cache_inst_inv_all(void *arg)
341{
342 (void) arg;
343 _CPU_cache_invalidate_entire_instruction();
344}
345
346static void smp_cache_broadcast( SMP_Action_handler handler, void *arg )
347{
348 uint32_t isr_level;
349 Per_CPU_Control *cpu_self;
350
351 isr_level = _ISR_Get_level();
352
353 if ( isr_level == 0 ) {
354 cpu_self = _Thread_Dispatch_disable();
355 } else {
356 cpu_self = _Per_CPU_Get();
357 }
358
359 ( *handler )( arg );
360 _SMP_Othercast_action( handler, arg );
361
362 if ( isr_level == 0 ) {
363 _Thread_Dispatch_enable( cpu_self );
364 }
365}
366
367#endif
368
369/*
370 * This function is responsible for performing an instruction cache
371 * invalidate. It must determine how many cache lines need to be invalidated
372 * and then perform the invalidations.
373 */
374#if defined(CPU_INSTRUCTION_CACHE_ALIGNMENT) \
375 && !defined(CPU_CACHE_SUPPORT_PROVIDES_RANGE_FUNCTIONS)
376static void
377_CPU_cache_invalidate_instruction_range(
378 const void * i_addr,
379 size_t n_bytes
380)
381{
382 const void * final_address;
383
384 /*
385 * Set i_addr to the beginning of the cache line; final_address indicates
386 * the last address_t which needs to be invalidated. Increment i_addr and
387 * invalidate the resulting line until final_address is passed.
388 */
389
390 if( n_bytes == 0 )
391 /* Do nothing if number of bytes to invalidate is zero */
392 return;
393
394 final_address = (void *)((size_t)i_addr + n_bytes - 1);
395 i_addr = (void *)((size_t)i_addr & ~(CPU_INSTRUCTION_CACHE_ALIGNMENT - 1));
396 while( final_address >= i_addr ) {
397 _CPU_cache_invalidate_1_instruction_line( i_addr );
398 i_addr = (void *)((size_t)i_addr + CPU_INSTRUCTION_CACHE_ALIGNMENT);
399 }
400}
401#endif
402
403void
405 const void * i_addr,
406 size_t n_bytes
407)
408{
409#if defined(CPU_INSTRUCTION_CACHE_ALIGNMENT)
410#if defined(RTEMS_SMP) && defined(CPU_CACHE_NO_INSTRUCTION_CACHE_SNOOPING)
411 smp_cache_area area = { i_addr, n_bytes };
412
413 smp_cache_broadcast( smp_cache_inst_inv, &area );
414#else
415 _CPU_cache_invalidate_instruction_range( i_addr, n_bytes );
416#endif
417#else
418 (void) i_addr;
419 (void) n_bytes;
420#endif
421}
422
423/*
424 * This function is responsible for performing an instruction cache
425 * invalidate. It invalidates the entire cache.
426 */
427void
429{
430#if defined(CPU_INSTRUCTION_CACHE_ALIGNMENT)
431#if defined(RTEMS_SMP) && defined(CPU_CACHE_NO_INSTRUCTION_CACHE_SNOOPING)
432 smp_cache_broadcast( smp_cache_inst_inv_all, NULL );
433#else
434 _CPU_cache_invalidate_entire_instruction();
435#endif
436#endif
437}
438
439/*
440 * This function returns the instruction cache granularity.
441 */
442size_t
444{
445#if defined(CPU_INSTRUCTION_CACHE_ALIGNMENT)
446 return CPU_INSTRUCTION_CACHE_ALIGNMENT;
447#else
448 return 0;
449#endif
450}
451
452size_t
454{
455#if defined(CPU_CACHE_SUPPORT_PROVIDES_CACHE_SIZE_FUNCTIONS)
456 return _CPU_cache_get_instruction_cache_size( level );
457#else
458 (void) level;
459
460 return 0;
461#endif
462}
463
464/*
465 * This function freezes the instruction cache; cache lines
466 * are not replaced.
467 */
468void
470{
471#if defined(CPU_INSTRUCTION_CACHE_ALIGNMENT)
472 _CPU_cache_freeze_instruction();
473#endif
474}
475
477{
478#if defined(CPU_INSTRUCTION_CACHE_ALIGNMENT)
479 _CPU_cache_unfreeze_instruction();
480#endif
481}
482
483void
485{
486#if defined(CPU_INSTRUCTION_CACHE_ALIGNMENT)
487 _CPU_cache_enable_instruction();
488#endif
489}
490
491void
493{
494#if defined(CPU_INSTRUCTION_CACHE_ALIGNMENT)
495 _CPU_cache_disable_instruction();
496#endif
497}
498
499/* Returns the maximal cache line size of all cache kinds in bytes. */
501{
502#if defined(CPU_MAXIMAL_CACHE_ALIGNMENT)
503 return CPU_MAXIMAL_CACHE_ALIGNMENT;
504#endif
505 size_t data_line_size =
506#if defined(CPU_DATA_CACHE_ALIGNMENT)
507 CPU_DATA_CACHE_ALIGNMENT;
508#else
509 0;
510#endif
511 size_t instruction_line_size =
512#if defined(CPU_INSTRUCTION_CACHE_ALIGNMENT)
513 CPU_INSTRUCTION_CACHE_ALIGNMENT;
514#else
515 0;
516#endif
517 return MAX( data_line_size, instruction_line_size );
518}
519
520/*
521 * Purpose is to synchronize caches after code has been loaded
522 * or self modified. Actual implementation is simple only
523 * but it can and should be repaced by optimized version
524 * which does not need flush and invalidate all cache levels
525 * when code is changed.
526 */
528 const void *code_addr,
529 size_t n_bytes
530)
531{
532#if defined(CPU_CACHE_SUPPORT_PROVIDES_INSTRUCTION_SYNC_FUNCTION)
533 _CPU_cache_instruction_sync_after_code_change( code_addr, n_bytes );
534#else
535 rtems_cache_flush_multiple_data_lines( code_addr, n_bytes );
537#endif
538}
void rtems_cache_unfreeze_instruction(void)
Unfreezes the instruction cache.
Definition: cacheimpl.h:476
void rtems_cache_unfreeze_data(void)
Unfreezes the data cache.
Definition: cacheimpl.h:295
void rtems_cache_freeze_instruction(void)
Freezes the instruction caches.
Definition: cacheimpl.h:469
void rtems_cache_freeze_data(void)
Freezes the data caches.
Definition: cacheimpl.h:288
void rtems_cache_instruction_sync_after_code_change(const void *code_addr, size_t n_bytes)
Ensures necessary synchronization required after code changes.
Definition: cacheimpl.h:527
size_t rtems_cache_get_maximal_line_size(void)
Gets the maximal cache line size in bytes of all caches (data, instruction, or unified).
Definition: cacheimpl.h:500
void rtems_cache_invalidate_entire_instruction(void)
Invalidates the entire instruction cache.
Definition: cacheimpl.h:428
void rtems_cache_invalidate_entire_data(void)
Invalidates the entire data cache.
Definition: cacheimpl.h:247
void rtems_cache_invalidate_multiple_instruction_lines(const void *i_addr, size_t n_bytes)
Invalidates the instruction cache lines covering the memory area.
Definition: cacheimpl.h:404
size_t rtems_cache_get_data_cache_size(uint32_t level)
Gets the data cache size in bytes for the cache level.
Definition: cacheimpl.h:272
void rtems_cache_enable_data(void)
Enables the data cache.
Definition: cacheimpl.h:303
void rtems_cache_disable_instruction(void)
Disables the instruction cache.
Definition: cacheimpl.h:492
void rtems_cache_disable_data(void)
Disables the data cache.
Definition: cacheimpl.h:312
size_t rtems_cache_get_instruction_cache_size(uint32_t level)
Gets the instruction cache size in bytes for the cache level.
Definition: cacheimpl.h:453
void rtems_cache_invalidate_multiple_data_lines(const void *d_addr, size_t n_bytes)
Invalidates the data cache lines covering the memory area.
Definition: cacheimpl.h:196
void rtems_cache_flush_entire_data(void)
Flushes the entire data cache.
Definition: cacheimpl.h:232
void rtems_cache_flush_multiple_data_lines(const void *d_addr, size_t n_bytes)
Flushes the data cache lines covering the memory area.
Definition: cacheimpl.h:159
size_t rtems_cache_get_instruction_line_size(void)
Gets the instruction cache line size in bytes.
Definition: cacheimpl.h:443
size_t rtems_cache_get_data_line_size(void)
Gets the data cache line size in bytes.
Definition: cacheimpl.h:262
void rtems_cache_enable_instruction(void)
Enables the instruction cache.
Definition: cacheimpl.h:484
#define _ISR_Get_level()
Return current interrupt level.
Definition: isrlevel.h:147
void _Thread_Dispatch_enable(Per_CPU_Control *cpu_self)
Enables thread dispatching.
This header file provides interfaces of the SMP Support which are only used by the implementation.
Per CPU Core Structure.
Definition: percpu.h:384
This header file provides the interfaces of the Thread Handler related to thread dispatching.
