RTEMS 7.0-rc1
boot.h
2
11/*
12 * Copyright (c) 2010 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_ARM_LPC32XX_BOOT_H
37#define LIBBSP_ARM_LPC32XX_BOOT_H
38
39#include <stdint.h>
40
41#ifdef __cplusplus
42extern "C" {
43#endif /* __cplusplus */
44
70#define LPC32XX_BOOT_BLOCK_0 0
71#define LPC32XX_BOOT_BLOCK_1 1
72
73#define LPC32XX_BOOT_ICR_SP_3AC_8IF 0xf0
74#define LPC32XX_BOOT_ICR_SP_4AC_8IF 0xd2
75#define LPC32XX_BOOT_ICR_LP_4AC_8IF 0xb4
76#define LPC32XX_BOOT_ICR_LP_5AC_8IF 0x96
77
78typedef union {
79 struct {
80 uint8_t d0;
81 uint8_t reserved_0 [3];
82 uint8_t d1;
83 uint8_t reserved_1 [3];
84 uint8_t d2;
85 uint8_t reserved_2 [3];
86 uint8_t d3;
87 uint8_t reserved_3 [3];
88 uint8_t d4;
89 uint8_t reserved_4 [3];
90 uint8_t d5;
91 uint8_t reserved_5 [3];
92 uint8_t d6;
93 uint8_t reserved_6 [3];
94 uint8_t d7;
95 uint8_t reserved_7 [3];
96 uint8_t d8;
97 uint8_t reserved_8 [3];
98 uint8_t d9;
99 uint8_t reserved_9 [3];
100 uint8_t d10;
101 uint8_t reserved_10 [3];
102 uint8_t d11;
103 uint8_t reserved_11 [3];
104 uint8_t d12;
105 uint8_t reserved_12 [463];
106 } field;
107 uint32_t data [128];
109
110void lpc32xx_setup_boot_block(
111 lpc32xx_boot_block *boot_block,
112 uint8_t icr,
113 uint8_t page_count
114);
115
116void lpc32xx_set_boot_block_bad(
117 lpc32xx_boot_block *boot_block
118);
119
122#ifdef __cplusplus
123}
124#endif /* __cplusplus */
125
126#endif /* LIBBSP_ARM_LPC32XX_BOOT_H */
Definition: boot.h:78
