RTEMS
7.0-rc1
bsps
powerpc
include
libcpu
bat.h
1
/* SPDX-License-Identifier: GPL-2.0+-with-RTEMS-exception */
2
3
4
* bat.h
5
6
* This file contains declaration of C function to
7
* Instantiate 60x/7xx ppc Block Address Translation (BAT) registers.
8
* More detailed information can be found on motorola
9
* site and more precisely in the following book :
10
11
* MPC750
12
* Risc Microporcessor User's Manual
13
* Motorola REF : MPC750UM/AD 8/97
14
15
* Copyright (C) 1999 Eric Valette (eric.valette@free.fr)
16
* Canon Centre Recherche France.
17
18
* The license and distribution terms for this file may be
19
* found in the file LICENSE in this distribution or at
20
* http://www.rtems.org/license/LICENSE.
21
22
23
#ifndef _LIBCPU_BAT_H
24
#define _LIBCPU_BAT_H
25
26
#include <libcpu/mmu.h>
27
#include <libcpu/pgtable.h>
28
29
#define IO_PAGE (_PAGE_NO_CACHE | _PAGE_GUARDED | _PAGE_RW)
30
31
#ifndef ASM
32
/* Take no risks -- the essential parts of this routine run with
33
* interrupts disabled!
34
35
* The routine does basic parameter checks:
36
* - Index must be 0..3 (0..7 on 7455, 7457).
37
* If an index > 3 is requested the 745x is
38
* programmed to enable the higher BATs.
39
* - Size must be a power of two and <= 1<<28
40
* (<=1<<31 on 7455, 7457. Also, on these processors
41
* the special value 0xffffffff is allowed which stands
42
* for 1<<32).
43
* If a size > 1<<28 is requested, the 745x is
44
* programmed to enable the larger block sizes.
45
* - Bat ranges must not overlap.
46
* - Physical & virtual addresses must be aligned
47
* to the size.
48
49
* RETURNS: zero on success, nonzero on failure.
50
51
extern
int
setdbat(
int
bat_index,
unsigned
long
virt,
unsigned
long
phys,
52
unsigned
int
size,
int
flags);
53
54
/* Same as setdbat but sets IBAT */
55
extern
int
setibat(
int
bat_index,
unsigned
long
virt,
unsigned
long
phys,
56
unsigned
int
size,
int
flags);
57
58
/* read DBAT # 'idx' into *pu / *pl. NULL pointers may be passed.
59
* If pu and pl are NULL, the bat contents are dumped to the console (printk).
60
61
* RETURNS: upper BAT contents or (-1) if index is invalid
62
63
extern
int
getdbat(
int
bat_index,
unsigned
long
*pu,
unsigned
long
*pl);
64
65
/* Same as getdbat but reads IBAT */
66
extern
int
getibat(
int
bat_index,
unsigned
long
*pu,
unsigned
long
*pl);
67
68
/* Do not use the asm-routines; they are obsolete; use setdbat() instead */
69
extern
void
asm_setdbat0(
unsigned
int
uperPart,
unsigned
int
lowerPart);
70
extern
void
asm_setdbat1(
unsigned
int
uperPart,
unsigned
int
lowerPart);
71
extern
void
asm_setdbat2(
unsigned
int
uperPart,
unsigned
int
lowerPart);
72
extern
void
asm_setdbat3(
unsigned
int
uperPart,
unsigned
int
lowerPart);
73
#else
74
75
/* Initialize all bats (upper and lower) to zero. This routine should *only*
76
* be called during early BSP initialization when no C-ABI is available
77
* yet.
78
* This routine clobbers r3 and r4.
79
* NOTE: on 7450 CPUs all 8 dbat/ibat units are cleared. On 601 CPUs only
80
* 4 ibats.
81
82
.globl CPU_clear_bats_early
83
.type CPU_clear_bats_early,@function
84
85
#endif
86
87
#endif
/* _LIBCPU_BAT_H */
