17#ifndef __ATA_INTERNAL_H__
18#define __ATA_INTERNAL_H__
40#define CF_LE_W(v) le16toh(v)
41#define CF_LE_L(v) le32toh(v)
42#define CT_LE_W(v) htole16(v)
43#define CT_LE_L(v) htole32(v)
45#define ATA_UNDEFINED_VALUE (-1)
48#define ATA_SECTOR_SIZE 512
51#define ATA_MAX_CMD_REG_OFFSET 8
57#define ATA_COMMAND_TYPE_NON_DATA 0
58#define ATA_COMMAND_TYPE_PIO_IN 1
59#define ATA_COMMAND_TYPE_PIO_OUT 2
60#define ATA_COMMAND_TYPE_DMA 3
70#define ATA_COMMAND_NOP 0x00
71#define ATA_COMMAND_READ_SECTORS 0x20
72#define ATA_COMMAND_WRITE_SECTORS 0x30
73#define ATA_COMMAND_READ_VERIFY_SECTORS 0x40
74#define ATA_COMMAND_SEEK 0x70
75#define ATA_COMMAND_EXECUTE_DEVICE_DIAGNOSTIC 0x90
76#define ATA_COMMAND_INITIALIZE_DEVICE_PARAMETERS 0x91
77#define ATA_COMMAND_DOWNLOAD_MICROCODE 0x92
78#define ATA_COMMAND_READ_MULTIPLE 0xc4
79#define ATA_COMMAND_WRITE_MULTIPLE 0xc5
80#define ATA_COMMAND_SET_MULTIPLE_MODE 0xc6
81#define ATA_COMMAND_READ_DMA 0xc8
82#define ATA_COMMAND_WRITE_DMA 0xca
83#define ATA_COMMAND_STANDBY_IMMEDIATE 0xe0
84#define ATA_COMMAND_IDLE_IMMEDIATE 0xe1
85#define ATA_COMMAND_STANDBY 0xe2
86#define ATA_COMMAND_IDLE 0xe3
87#define ATA_COMMAND_READ_BUFFER 0xe4
88#define ATA_COMMAND_CHECK_POWER_MODE 0xe5
89#define ATA_COMMAND_SLEEP 0xe6
90#define ATA_COMMAND_WRITE_BUFFER 0xe8
91#define ATA_COMMAND_IDENTIFY_DEVICE 0xec
92#define ATA_COMMAND_SET_FEATURES 0xef
95#define ATA_COMMAND_MEDIA_LOCK 0xde
96#define ATA_COMMAND_MEDIA_UNLOCK 0xdf
97#define ATA_COMMAND_MEDIA_EJECT 0xed
101#define ATA_COMMAND_RECALIBRATE 0x10
102#define ATA_COMMAND_READ_SECTOR_NON_RETRY 0x21
103#define ATA_COMMAND_READ_LONG_RETRY 0x22
104#define ATA_COMMAND_READ_LONG_NON_RETRY 0x23
105#define ATA_COMMAND_WRITE_SECTOR_NON_RETRY 0x31
106#define ATA_COMMAND_WRITE_LONG_RETRY 0x32
107#define ATA_COMMAND_WRITE_LONG_NON_RETRY 0x33
108#define ATA_COMMAND_WRITE_VERIFY 0x3c
109#define ATA_COMMAND_READ_VERIFY_SECTOR_NON_RETRY 0x41
110#define ATA_COMMAND_FORMAT_TRACK 0x50
111#define ATA_COMMAND_READ_DMA_NON_RETRY 0xc9
112#define ATA_COMMAND_WRITE_DMA_NON_RETRY 0xcb
113#define ATA_COMMAND_ACKNOWLEGE_MEDIA_CHANGE 0xdb
114#define ATA_COMMAND_BOOT_POST_BOOT 0xdc
115#define ATA_COMMAND_BOOT_PRE_BOOT 0xdd
116#define ATA_COMMAND_WRITE_SAME 0xe9
119#define ATA_COMMAND_CFA_REQUEST_EXTENDED_ERROR_CODE 0x03
120#define ATA_COMMAND_CFA_WRITE_SECTORS_WITHOUT_ERASE 0x38
121#define ATA_COMMAND_CFA_TRANSLATE_SECTOR 0x87
122#define ATA_COMMAND_CFA_ERASE_SECTORS 0xc0
123#define ATA_COMMAND_CFA_WRITE_MULTIPLE_WITHOUT_ERASE 0xcd
126#define ATA_COMMAND_DEVICE_RESET 0x08
127#define ATA_COMMAND_PACKET 0xa0
128#define ATA_COMMAND_IDENTIFY_PACKET_DEVICE 0xa1
129#define ATA_COMMAND_SERVICE 0xa2
132#define ATA_COMMAND_SECURITY_SET_PASSWORD 0xf1
133#define ATA_COMMAND_SECURITY_UNLOCK 0xf2
134#define ATA_COMMAND_SECURITY_ERASE_PREPARE 0xf3
135#define ATA_COMMAND_SECURITY_ERASE_UNIT 0xf4
136#define ATA_COMMAND_SECURITY_FREEZE_LOCK 0xf5
137#define ATA_COMMAND_SECURITY_DISABLE_PASSWORD 0xf6
140#define ATA_COMMAND_SMART 0xb0
141#define ATA_COMMAND_READ_DMA_QUEUED 0xc7
142#define ATA_COMMAND_WRITE_DMA_QUEUED 0xcc
143#define ATA_COMMAND_GET_MEDIA_STATUS 0xda
144#define ATA_COMMAND_FLUSH_CACHE 0xe7
145#define ATA_COMMAND_READ_NATIVE_MAX_ADDRESS 0xf8
146#define ATA_COMMAND_SET_MAX_ADDRESS 0xf9
148#define ATA_REGISTERS_VALUE(reg) (1 << (reg))
151#define ATA_IDENT_WORD_RW_MULT 47
152#define ATA_IDENT_WORD_CAPABILITIES 49
153#define ATA_IDENT_WORD_FIELD_VALIDITY 53
154#define ATA_IDENT_WORD_NUM_OF_CURR_LOG_CLNDS 54
155#define ATA_IDENT_WORD_NUM_OF_CURR_LOG_HEADS 55
156#define ATA_IDENT_WORD_NUM_OF_CURR_LOG_SECS 56
157#define ATA_IDENT_WORD_MULT_SECS 59
158#define ATA_IDENT_WORD_NUM_OF_USR_SECS0 60
159#define ATA_IDENT_WORD_NUM_OF_USR_SECS1 61
160#define ATA_IDENT_WORD_PIO_SPPRTD 64
162#define ATA_IDENT_BIT_VALID 0x02
168#define ATA_REGISTERS_POSITION 0xfc
170#define ATA_MAX_RTEMS_INT_VEC_NUMBER 255
172#define ATA_MAX_NAME_LENGTH 10
175#define ATA_DEV0_PASSED_DEV1_PASSED_OR_NOT_PRSNT 0x01
176#define ATA_DEV0_PASSED_DEV1_FAILED 0x81
177#define ATA_DEV1_PASSED_DEV0_FAILED 0x80
182#define ATA_DEV_INFO(controller_minor, dev) \
183 ata_ide_ctrls[controller_minor].device[dev]
213#define ATA_EXEC_CALLBACK(areq, status) \
215 if ((areq)->breq != NULL) \
216 rtems_blkdev_request_done((areq)->breq, status); \
220typedef enum ata_msg_type_s {
224 ATA_MSG_PROCESS_NEXT_EVT
235#define ATA_FILL_MSG(msg, evt_type, ctrl, err)\
237 msg.type = evt_type;\
238 msg.ctrl_minor = ctrl;\
242#define ATA_SEND_EVT(msg, type, ctrl, err)\
244 rtems_status_code rc;\
245 ATA_FILL_MSG(msg, type, ctrl, err);\
246 rc = rtems_message_queue_send(ata_queue_id, &msg,\
247 sizeof(ata_queue_msg_t));\
248 if (rc != RTEMS_SUCCESSFUL)\
249 rtems_fatal_error_occurred(RTEMS_INTERNAL_ERROR);\
279 uint32_t lba_sectors;
284 uint16_t modes_available;
285 uint16_t mode_active;
310 uint16_t *sector_buffer,
314void ata_process_request_on_init_phase(
Block Device Disk Management API.
uint32_t rtems_device_minor_number
This integer type represents the minor number of devices.
Definition: io.h:115
rtems_status_code
Definition: status.h:85
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition: types.h:94
This structure represents a chain node.
Definition: chain.h:78
Definition: ata_internal.h:273
Definition: ata_internal.h:293
Definition: ata_internal.h:265
Definition: ata_internal.h:256
Definition: ata_internal.h:228
Definition: ata_internal.h:188
Definition: ata_internal.h:195
Definition: ata_internal.h:300
The block device transfer request is used to read or write a number of blocks from or to the device.
Definition: blkdev.h:102
Block device scatter or gather buffer structure.
Definition: blkdev.h:68
This header file provides interfaces of the system endianness support.
This union represents a chain control block.
Definition: chain.h:96
