RTEMS 7.0-rc1
at91rm9200_gpio.h
2
11/*
12 * Copyright (C) 2002 Cogent Computer Systems
13 * Written by Mike Kelly <mike@cogcomp.com>
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37#ifndef AT91RM9200_GPIO_H
38#define AT91RM9200_GPIO_H
39
40#include <bits.h>
41
42/* Register Offsets */
43#define PIO_PER 0x00 /* PIO Enable Register */
44#define PIO_PDR 0x04 /* PIO Disable Register */
45#define PIO_PSR 0x08 /* PIO Status Register */
46#define PIO_OER 0x10 /* Output Enable Register */
47#define PIO_ODR 0x14 /* Output Disable Registerr */
48#define PIO_OSR 0x18 /* Output Status Register */
49#define PIO_IFER 0x20 /* Input Filter Enable Register */
50#define PIO_IFDR 0x24 /* Input Filter Disable Register */
51#define PIO_IFSR 0x28 /* Input Filter Status Register */
52#define PIO_SODR 0x30 /* Set Output Data Register */
53#define PIO_CODR 0x34 /* Clear Output Data Register */
54#define PIO_ODSR 0x38 /* Output Data Status Register */
55#define PIO_PDSR 0x3c /* Pin Data Status Register */
56#define PIO_IER 0x40 /* Interrupt Enable Register */
57#define PIO_IDR 0x44 /* Interrupt Disable Register */
58#define PIO_IMR 0x48 /* Interrupt Mask Register */
59#define PIO_ISR 0x4c /* Interrupt Status Register */
60#define PIO_MDER 0x50 /* Multi-driver Enable Register */
61#define PIO_MDDR 0x54 /* Multi-driver Disable Register */
62#define PIO_MDSR 0x58 /* Multi-driver Status Register */
63#define PIO_PUDR 0x60 /* Pull-up Disable Register */
64#define PIO_PUER 0x64 /* Pull-up Enable Register */
65#define PIO_PUSR 0x68 /* Pad Pull-up Status Register */
66#define PIO_ASR 0x70 /* Select A Register */
67#define PIO_BSR 0x74 /* Select B Register */
68#define PIO_ABSR 0x78 /* AB Select Status Register */
69#define PIO_OWER 0xA0 /* Output Write Enable Register */
70#define PIO_OWDR 0xA4 /* Output Write Disable Register */
71#define PIO_OWSR 0xA8 /* Output Write Status Register */
72
73
74/*
75 * The AT91RM9200 GPIO's are spread across four 32-bit ports A-D.
76 * To make it easier to interface with them and to eliminate the need
77 * to track which GPIO is in which port, we convert the Port x, Bit y
78 * into a single GPIO number 0 - 127.
79 *
80 * Board specific defines will assign the board level signal to a
81 * virutal GPIO.
82 *
83 * PORT A
84 */
85#define GPIO_0 BIT0
86#define GPIO_1 BIT1
87#define GPIO_2 BIT2
88#define GPIO_3 BIT3
89#define GPIO_4 BIT4
90#define GPIO_5 BIT5
91#define GPIO_6 BIT6
92#define GPIO_7 BIT7
93#define GPIO_8 BIT8
94#define GPIO_9 BIT9
95#define GPIO_10 BIT10
96#define GPIO_11 BIT11
97#define GPIO_12 BIT12
98#define GPIO_13 BIT13
99#define GPIO_14 BIT14
100#define GPIO_15 BIT15
101#define GPIO_16 BIT16
102#define GPIO_17 BIT17
103#define GPIO_18 BIT18
104#define GPIO_19 BIT19
105#define GPIO_20 BIT20
106#define GPIO_21 BIT21
107#define GPIO_22 BIT22
108#define GPIO_23 BIT23
109#define GPIO_24 BIT24
110#define GPIO_25 BIT25
111#define GPIO_26 BIT26
112#define GPIO_27 BIT27
113#define GPIO_28 BIT28
114#define GPIO_29 BIT29
115#define GPIO_30 BIT30
116#define GPIO_31 BIT31
117/* PORT B */
118#define GPIO_32 BIT0
119#define GPIO_33 BIT1
120#define GPIO_34 BIT2
121#define GPIO_35 BIT3
122#define GPIO_36 BIT4
123#define GPIO_37 BIT5
124#define GPIO_38 BIT6
125#define GPIO_39 BIT7
126#define GPIO_40 BIT8
127#define GPIO_41 BIT9
128#define GPIO_42 BIT10
129#define GPIO_43 BIT11
130#define GPIO_44 BIT12
131#define GPIO_45 BIT13
132#define GPIO_46 BIT14
133#define GPIO_47 BIT15
134#define GPIO_48 BIT16
135#define GPIO_49 BIT17
136#define GPIO_50 BIT18
137#define GPIO_51 BIT19
138#define GPIO_52 BIT20
139#define GPIO_53 BIT21
140#define GPIO_54 BIT22
141#define GPIO_55 BIT23
142#define GPIO_56 BIT24
143#define GPIO_57 BIT25
144#define GPIO_58 BIT26
145#define GPIO_59 BIT27
146#define GPIO_60 BIT28
147#define GPIO_61 BIT29
148#define GPIO_62 BIT30
149#define GPIO_63 BIT31
150/* PORT C */
151#define GPIO_64 BIT0
152#define GPIO_65 BIT1
153#define GPIO_66 BIT2
154#define GPIO_67 BIT3
155#define GPIO_68 BIT4
156#define GPIO_69 BIT5
157#define GPIO_70 BIT6
158#define GPIO_71 BIT7
159#define GPIO_72 BIT8
160#define GPIO_73 BIT9
161#define GPIO_74 BIT10
162#define GPIO_75 BIT11
163#define GPIO_76 BIT12
164#define GPIO_77 BIT13
165#define GPIO_78 BIT14
166#define GPIO_79 BIT15
167#define GPIO_80 BIT16
168#define GPIO_81 BIT17
169#define GPIO_82 BIT18
170#define GPIO_83 BIT19
171#define GPIO_84 BIT20
172#define GPIO_85 BIT21
173#define GPIO_86 BIT22
174#define GPIO_87 BIT23
175#define GPIO_88 BIT24
176#define GPIO_89 BIT25
177#define GPIO_90 BIT26
178#define GPIO_91 BIT27
179#define GPIO_92 BIT28
180#define GPIO_93 BIT29
181#define GPIO_94 BIT30
182#define GPIO_95 BIT31
183/* PORT D */
184#define GPIO_96 BIT0
185#define GPIO_97 BIT1
186#define GPIO_98 BIT2
187#define GPIO_99 BIT3
188#define GPIO_100 BIT4
189#define GPIO_101 BIT5
190#define GPIO_102 BIT6
191#define GPIO_103 BIT7
192#define GPIO_104 BIT8
193#define GPIO_105 BIT9
194#define GPIO_106 BIT10
195#define GPIO_107 BIT11
196#define GPIO_108 BIT12
197#define GPIO_109 BIT13
198#define GPIO_110 BIT14
199#define GPIO_111 BIT15
200#define GPIO_112 BIT16
201#define GPIO_113 BIT17
202#define GPIO_114 BIT18
203#define GPIO_115 BIT19
204#define GPIO_116 BIT20
205#define GPIO_117 BIT21
206#define GPIO_118 BIT22
207#define GPIO_119 BIT23
208#define GPIO_120 BIT24
209#define GPIO_121 BIT25
210#define GPIO_122 BIT26
211#define GPIO_123 BIT27
212#define GPIO_124 BIT28
213#define GPIO_125 BIT29
214#define GPIO_126 BIT30
215#define GPIO_127 BIT31
216
217/*
218 * Most of the GPIO pins can have one of two alternate functions
219 * in addition to being GPIO
220 *
221 * Port A, Alternate Function A
222 */
223#define PIOA_ASR_MISO BIT0 /* SPI Master In (RX), Slave out */
224#define PIOA_ASR_MOSI BIT1 /* SPI Master Out (TX), Slave In */
225#define PIOA_ASR_SPCK BIT2 /* SPI Clock */
226#define PIOA_ASR_NPCS0 BIT3 /* SPI Chip Select 0 */
227#define PIOA_ASR_NPCS1 BIT4 /* SPI Chip Select 1 */
228#define PIOA_ASR_NPCS2 BIT5 /* SPI Chip Select 2 */
229#define PIOA_ASR_NPCS3 BIT6 /* SPI Chip Select 3 */
230#define PIOA_ASR_ETXCK BIT7 /* EMAC TX Clock */
231#define PIOA_ASR_ETXEN BIT8 /* EMAC TXEN */
232#define PIOA_ASR_ETX0 BIT9 /* EMAC TXD0 */
233#define PIOA_ASR_ETX1 BIT10 /* EMAC TXD1 */
234#define PIOA_ASR_ECRS BIT11 /* EMAC CRS */
235#define PIOA_ASR_ERX0 BIT12 /* EMAC RXD0 */
236#define PIOA_ASR_ERX1 BIT13 /* EMAC RXD1 */
237#define PIOA_ASR_ERXER BIT14 /* EMAC RXER */
238#define PIOA_ASR_EMDC BIT15 /* EMAC MDC */
239#define PIOA_ASR_EMDIO BIT16 /* EMAC MDIO */
240#define PIOA_ASR_TXD0 BIT17 /* USART 0 Receive */
241#define PIOA_ASR_RXD0 BIT18 /* USART 0 Transmit */
242#define PIOA_ASR_SCK0 BIT19 /* USART 0 Clock */
243#define PIOA_ASR_CTS0 BIT20 /* USART 0 CTS */
244#define PIOA_ASR_RTS0 BIT21 /* USART 0 RTS */
245#define PIOA_ASR_RXD2 BIT22 /* USART 2 Receive */
246#define PIOA_ASR_TXD2 BIT23 /* USART 2 Transmit */
247#define PIOA_ASR_SCK2 BIT24 /* USART 2 Clock */
248#define PIOA_ASR_TWD BIT25 /* Two-Wire (I2C) Data */
249#define PIOA_ASR_TWCK BIT26 /* Two-Wire (I2C) Clock */
250#define PIOA_ASR_MCCK BIT27 /* MMC/SD Card Clock */
251#define PIOA_ASR_MCCDA BIT28 /* MMC/SD Card A Command */
252#define PIOA_ASR_MCDA0 BIT29 /* MMC/SD Card A Data 0 */
253#define PIOA_ASR_DRXD BIT30 /* Debug Uart Receive */
254#define PIOA_ASR_DTXD BIT31 /* Debug Uart Transmit */
255
256/* Port A, Alternate Function B */
257#define PIOA_BSR_PCK3 BIT0 /* Peripheral Clock 3 */
258#define PIOA_BSR_PCK0 BIT1 /* Peripheral Clock 0 */
259#define PIOA_BSR_IRQ4 BIT2 /* IRQ4 */
260#define PIOA_BSR_IRQ5 BIT3 /* IRQ5 */
261/*#define PIOA_BSR_PCK1 BIT4 Peripheral Clock 1 ***DUPLICATED at BIT24 ??? */
262#define PIOA_BSR_TXD3 BIT5 /* USART 3 Transmit */
263#define PIOA_BSR_RXD3 BIT6 /* USART 3 Receive */
264#define PIOA_BSR_PCK2 BIT7 /* Peripheral Clock 2 */
265#define PIOA_BSR_MCCDB BIT8 /* MMC/SD Card B Command */
266#define PIOA_BSR_MCDB0 BIT9 /* MMC/SD Card B Data 0 */
267#define PIOA_BSR_MCDB1 BIT10 /* MMC/SD Card B Data 1 */
268#define PIOA_BSR_MCDB2 BIT11 /* MMC/SD Card B Data 2 */
269#define PIOA_BSR_MCDB3 BIT12 /* MMC/SD C ard B Data 3 */
270#define PIOA_BSR_TCLK0 BIT13 /* Timer 0 Clock */
271#define PIOA_BSR_TCLK1 BIT14 /* Timer 1 Clck */
272#define PIOA_BSR_TCLK2 BIT15 /* Timer 2 Clock */
273#define PIOA_BSR_IRQ6 BIT16 /* IRQ6 */
274#define PIOA_BSR_TIOA0 BIT17 /* Timer 0 I/O A */
275#define PIOA_BSR_TIOB0 BIT18 /* Timer 0 I/O B */
276#define PIOA_BSR_TIOA1 BIT19 /* Timer 1 I/O A */
277#define PIOA_BSR_TIOB1 BIT20 /* Timer 1 I/O B */
278#define PIOA_BSR_TIOA2 BIT21 /* Timer 2 I/O A */
279#define PIOA_BSR_TIOB2 BIT22 /* Timer 2 I/O B */
280#define PIOA_BSR_IRQ3 BIT23 /* IRQ3 */
281#define PIOA_BSR_PCK1 BIT24 /* Peripheral Clock 1 */
282#define PIOA_BSR_IRQ2 BIT25 /* IRQ2 */
283#define PIOA_BSR_IRQ1 BIT26 /* IRQ1 */
284#define PIOA_BSR_TCLK3 BIT27 /* Timer Block Clock 3 (docs only show 0-2?) */
285#define PIOA_BSR_TCLK4 BIT28 /* Timer Block Clock 4 */
286#define PIOA_BSR_TCLK5 BIT29 /* Timer Block Clock 5 */
287#define PIOA_BSR_CTS2 BIT30 /* USART 2 CTS */
288#define PIOA_BSR_RTS2 BIT31 /* USART 2 RTS */
289
290/* Port B, Function A */
291#define PIOB_ASR_TF0 BIT0 /* AC'97/I2S 0 Transmit Frame */
292#define PIOB_ASR_TK0 BIT1 /* AC'97/I2S 0 Transmit Clock */
293#define PIOB_ASR_TD0 BIT2 /* AC'97/I2S 0 Transmit Data */
294#define PIOB_ASR_RD0 BIT3 /* AC'97/I2S 0 Receive Data */
295#define PIOB_ASR_RK0 BIT4 /* AC'97/I2S 0 Receive Clock */
296#define PIOB_ASR_RF0 BIT5 /* AC'97/I2S 0 Receive Frame */
297#define PIOB_ASR_TF1 BIT6 /* AC'97/I2S 1 Transmit Frame */
298#define PIOB_ASR_TK1 BIT7 /* AC'97/I2S 1 Transmit Clock */
299#define PIOB_ASR_TD1 BIT8 /* AC'97/I2S 1 Transmit Data */
300#define PIOB_ASR_RD1 BIT9 /* AC'97/I2S 1 Receive Data */
301#define PIOB_ASR_RK1 BIT10 /* AC'97/I2S 1 Receive Clock */
302#define PIOB_ASR_RF1 BIT11 /* AC'97/I2S 1 Receive Frame */
303#define PIOB_ASR_TF2 BIT12 /* AC'97/I2S 1 Transmit Frame */
304#define PIOB_ASR_TK2 BIT13 /* AC'97/I2S 1 Transmit Clock */
305#define PIOB_ASR_TD2 BIT14 /* AC'97/I2S 1 Transmit Data */
306#define PIOB_ASR_RD2 BIT15 /* AC'97/I2S 1 Receive Data */
307#define PIOB_ASR_RK2 BIT16 /* AC'97/I2S 1 Receive Clock */
308#define PIOB_ASR_RF2 BIT17 /* AC'97/I2S 1 Receive Frame */
309#define PIOB_ASR_RI1 BIT18 /* USART 1 RI */
310#define PIOB_ASR_DTR1 BIT19 /* USART 1 DTR */
311#define PIOB_ASR_TXD1 BIT20 /* USART 1 TXD */
312#define PIOB_ASR_RXD1 BIT21 /* USART 1 RXD */
313#define PIOB_ASR_SCK1 BIT22 /* USART 1 SCK */
314#define PIOB_ASR_DCD1 BIT23 /* USART 1 DCD */
315#define PIOB_ASR_CTS1 BIT24 /* USART 1 CTS */
316#define PIOB_ASR_DSR1 BIT25 /* USART 1 DSR */
317#define PIOB_ASR_RTS1 BIT26 /* USART 1 RTS */
318#define PIOB_ASR_PCK0 BIT27 /* Peripheral Clock 0 */
319#define PIOB_ASR_FIQ BIT28 /* FIQ */
320#define PIOB_ASR_IRQ0 BIT29 /* IRQ0 */
321
322/* Port B, Function B */
323#define PIOB_BSR_RTS3 BIT0 /* USART 3 */
324#define PIOB_BSR_CTS3 BIT1 /* USART 3 */
325#define PIOB_BSR_SCK3 BIT2 /* USART 3 */
326#define PIOB_BSR_MCDA1 BIT3 /* MMC/SD Card A, Data 1 */
327#define PIOB_BSR_MCDA2 BIT4 /* MMC/SD Card A, Data 2 */
328#define PIOB_BSR_MCDA3 BIT5 /* MMC/SD Card A, Data 3 */
329#define PIOB_BSR_TIOA3 BIT6 /* Timer 3 IO A */
330#define PIOB_BSR_TIOB3 BIT7 /* Timer 3 IO B */
331#define PIOB_BSR_TIOA4 BIT8 /* Timer 4 IO A */
332#define PIOB_BSR_TIOB4 BIT9 /* Timer 4 IO B */
333#define PIOB_BSR_TIOA5 BIT10 /* Timer 5 IO A */
334#define PIOB_BSR_TIOB5 BIT11 /* Timer 5 IO B */
335#define PIOB_BSR_ETX2 BIT12 /* EMAC TXD2 */
336#define PIOB_BSR_ETX3 BIT13 /* EMAC TXD3 */
337#define PIOB_BSR_ETXER BIT14 /* EMAC TXER */
338#define PIOB_BSR_ERX2 BIT15 /* EMAC RXD2 */
339#define PIOB_BSR_ERX3 BIT16 /* EMAC RXD3 */
340#define PIOB_BSR_ERXDV BIT17 /* EMAC RXDV */
341#define PIOB_BSR_ECOL BIT18 /* EMAC COL */
342#define PIOB_BSR_ERXCK BIT19 /* EMAC RX Clock */
343#define PIOB_BSR_EF100 BIT25 /* EMAC Speed 100 (RMII Only) */
344
345/* Port C, Alternate Function A */
346#define PIOC_ASR_BFCK BIT0 /* Burst Flash Clock */
347#define PIOC_ASR_BFRDY BIT1 /* Burst Flash Ready or SMC Card OE */
348#define PIOC_ASR_BFAVD BIT2 /* Burst Flash Address Valid */
349#define PIOC_ASR_BFBAA BIT3 /* Burst Flash Address Advance or SMC Card WE */
350#define PIOC_ASR_BFOE BIT4 /* Burst Flash OE */
351#define PIOC_ASR_BFWE BIT5 /* Burst Flash WE */
352#define PIOC_ASR_NWAIT BIT6 /* WAIT Input */
353#define PIOC_ASR_A23 BIT7 /* A23 */
354#define PIOC_ASR_A24 BIT8 /* A24 */
355#define PIOC_ASR_A25 BIT9 /* A25 or Compact Flash R/W */
356#define PIOC_ASR_NCS4 BIT10 /* CS4 or Compact Flash CS */
357#define PIOC_ASR_NCS5 BIT11 /* CS5 or Compact Flash CE1 */
358#define PIOC_ASR_NCS6 BIT12 /* CS6 or Compact Flash CE2 */
359#define PIOC_ASR_NCS7 BIT13 /* CS7 */
360#define PIOC_ASR_D16 BIT16 /* Databus Bit 16 */
361#define PIOC_ASR_D17 BIT17 /* Databus Bit 17 */
362#define PIOC_ASR_D18 BIT18 /* Databus Bit 18 */
363#define PIOC_ASR_D19 BIT19 /* Databus Bit 19 */
364#define PIOC_ASR_D20 BIT20 /* Databus Bit 20 */
365#define PIOC_ASR_D21 BIT21 /* Databus Bit 21 */
366#define PIOC_ASR_D22 BIT22 /* Databus Bit 22 */
367#define PIOC_ASR_D23 BIT23 /* Databus Bit 23 */
368#define PIOC_ASR_D24 BIT24 /* Databus Bit 24 */
369#define PIOC_ASR_D25 BIT25 /* Databus Bit 25 */
370#define PIOC_ASR_D26 BIT26 /* Databus Bit 26 */
371#define PIOC_ASR_D27 BIT27 /* Databus Bit 27 */
372#define PIOC_ASR_D28 BIT28 /* Databus Bit 28 */
373#define PIOC_ASR_D29 BIT29 /* Databus Bit 29 */
374#define PIOC_ASR_D30 BIT30 /* Databus Bit 30 */
375#define PIOC_ASR_D31 BIT31 /* Databus Bit 31 */
376
377/* Port C, Alternate Function B - None */
378
379/* Port D, Alternate Function A */
380#define PIOD_ASR_ETX0 BIT0 /* EMAC TXD0 */
381#define PIOD_ASR_ETX1 BIT1 /* EMAC TXD1 */
382#define PIOD_ASR_ETX2 BIT2 /* EMAC TXD2 */
383#define PIOD_ASR_ETX3 BIT3 /* EMAC TXD3 */
384#define PIOD_ASR_ETXEN BIT4 /* EMAC TXEN */
385#define PIOD_ASR_ETXER BIT5 /* EMAC TXER */
386#define PIOD_ASR_DTXD BIT6 /* Debug UART Transmit */
387#define PIOD_ASR_PCK0 BIT7 /* Peripheral Clock 0 */
388#define PIOD_ASR_PCK1 BIT8 /* Peripheral Clock 1 */
389#define PIOD_ASR_PCK2 BIT9 /* Peripheral Clock 2 */
390#define PIOD_ASR_PCK3 BIT10 /* Peripheral Clock 3 */
391#define PIOD_ASR_TD0 BIT15 /* AC'97/I2S 0 Transmit Data */
392#define PIOD_ASR_TD1 BIT16 /* AC'97/I2S 1 Transmit Data */
393#define PIOD_ASR_TD2 BIT17 /* AC'97/I2S 2 Transmit Data */
394#define PIOD_ASR_NPCS1 BIT18 /* SPI Chip Select 1 */
395#define PIOD_ASR_NPCS2 BIT19 /* SPI Chip Select 2 */
396#define PIOD_ASR_NPCS3 BIT20 /* SPI Chip Select 3 */
397#define PIOD_ASR_RTS0 BIT21 /* USART 0 RTS */
398#define PIOD_ASR_RTS1 BIT22 /* USART 1 RTS */
399#define PIOD_ASR_RTS2 BIT23 /* USART 2 RTS */
400#define PIOD_ASR_RTS3 BIT24 /* USART 3 RTS */
401#define PIOD_ASR_DTR1 BIT25 /* USART 1 DTR */
402
403/* Port D, Alternate Function B */
404
405#define PIOC_ASR_TSYNC BIT7 /* ETM Sync */
406#define PIOC_ASR_TCLK BIT8 /* ETM Clock */
407#define PIOC_ASR_TPS0 BIT9 /* ETM Processor Status 0 */
408#define PIOC_ASR_TPS1 BIT10 /* ETM Processor Status 1 */
409#define PIOC_ASR_TPS2 BIT11 /* ETM Processor Status 2 */
410#define PIOC_ASR_TPK0 BIT12 /* ETM Packet Data 0 */
411#define PIOC_ASR_TPK1 BIT13 /* ETM Packet Data 1 */
412#define PIOC_ASR_TPK2 BIT14 /* ETM Packet Data 2 */
413#define PIOC_ASR_TPK3 BIT15 /* ETM Packet Data 3 */
414#define PIOC_ASR_TPK4 BIT16 /* ETM Packet Data 4 */
415#define PIOC_ASR_TPK5 BIT17 /* ETM Packet Data 5 */
416#define PIOC_ASR_TPK6 BIT18 /* ETM Packet Data 6 */
417#define PIOC_ASR_TPK7 BIT19 /* ETM Packet Data 7 */
418#define PIOC_ASR_TPK8 BIT20 /* ETM Packet Data 8 */
419#define PIOC_ASR_TPK9 BIT21 /* ETM Packet Data 9 */
420#define PIOC_ASR_TPK10 BIT22 /* ETM Packet Data 10 */
421#define PIOC_ASR_TPK11 BIT23 /* ETM Packet Data 11 */
422#define PIOC_ASR_TPK12 BIT24 /* ETM Packet Data 12 */
423#define PIOC_ASR_TPK13 BIT25 /* ETM Packet Data 13 */
424#define PIOC_ASR_TPK14 BIT26 /* ETM Packet Data 14 */
425#define PIOC_ASR_TPK15 BIT27 /* ETM Packet Data 15 */
426
427#endif
Contains bit position definitions.
