RTEMS
7.0-rc1
bsps
arm
csb337
include
at91rm9200.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
13
14
* Copyright (c) 2003 by Cogent Computer Systems
15
* Written by Mike Kelly <mike@cogcomp.com>
16
* Modified by Fernando Nicodemos <fgnicodemos@terra.com.br>
17
* from NCB - Sistemas Embarcados Ltda. (Brazil)
18
19
20
* modification, are permitted provided that the following conditions
21
* are met:
22
* 1. Redistributions of source code must retain the above copyright
23
* notice, this list of conditions and the following disclaimer.
24
* 2. Redistributions in binary form must reproduce the above copyright
25
* notice, this list of conditions and the following disclaimer in the
26
* documentation and/or other materials provided with the distribution.
27
28
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
29
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
30
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
31
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
32
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
33
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
34
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
35
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
36
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
37
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
38
* POSSIBILITY OF SUCH DAMAGE.
39
40
41
#ifndef __AT91RM9200_H__
42
#define __AT91RM9200_H__
43
44
#include "
bits.h
45
46
typedef
volatile
unsigned
long
vulong;
47
48
/* Source Mode Register - 32 of them */
49
#define AIC_SMR_BASE 0xFFFFF000
50
#define AIC_SMR_REG(_x_) *(vulong *)(AIC_SMR_BASE + (_x_ & 0x7c))
51
52
/* Source Vector Register - 32 of them */
53
#define AIC_SVR_BASE 0xFFFFF080
54
#define AIC_SVR_REG(_x_) *(vulong *)(AIC_SVR_BASE + (_x_ & 0x7c))
55
56
/* Control Register - 32 of them */
57
#define AIC_CTL_BASE 0xFFFFF100
58
#define AIC_CTL_REG(_x_) *(vulong *)(AIC_CTL_BASE + (_x_ & 0x7f))
59
60
/* Register Offsets */
61
/* offsets from AIC_SMR_BASE and AIC_SVR_BASE */
62
#define AIC_SMR_FIQ 0x00
/* Advanced Interrupt Controller FIQ */
63
#define AIC_SMR_SYSIRQ 0x04
/* Advanced Interrupt Controller SYSIRQ */
64
#define AIC_SMR_PIOA 0x08
/* Parallel I/O Controller A */
65
#define AIC_SMR_PIOB 0x0c
/* Parallel I/O Controller B */
66
#define AIC_SMR_PIOC 0x10
/* Parallel I/O Controller C */
67
#define AIC_SMR_PIOD 0x14
/* Parallel I/O Controller D */
68
#define AIC_SMR_US0 0x18
/* USART 0 */
69
#define AIC_SMR_US1 0x1c
/* USART 1 */
70
#define AIC_SMR_US2 0x20
/* USART 2 */
71
#define AIC_SMR_US3 0x24
/* USART 3 */
72
#define AIC_SMR_MCI 0x28
/* Multimedia Card Interface */
73
#define AIC_SMR_UDP 0x2c
/* USB Device Port */
74
#define AIC_SMR_TWI 0x30
/* Two-wire Interface */
75
#define AIC_SMR_SPI 0x34
/* Serial Peripheral Interface */
76
#define AIC_SMR_SSC0 0x38
/* Synchronous Serial Controller 0 */
77
#define AIC_SMR_SSC1 0x3c
/* Synchronous Serial Controller 1 */
78
#define AIC_SMR_SSC2 0x40
/* Synchronous Serial Controller 2 */
79
#define AIC_SMR_TC0 0x44
/* Timer/Counter 0 */
80
#define AIC_SMR_TC1 0x48
/* Timer/Counter 1 */
81
#define AIC_SMR_TC2 0x4c
/* Timer/Counter 2 */
82
#define AIC_SMR_TC3 0x50
/* Timer/Counter 3 */
83
#define AIC_SMR_TC4 0x54
/* Timer/Counter 4 */
84
#define AIC_SMR_TC5 0x58
/* Timer/Counter 5 */
85
#define AIC_SMR_UHP 0x5c
/* USB Host Port */
86
#define AIC_SMR_EMAC 0x60
/* Ethernet MAC */
87
#define AIC_SMR_IRQ0 0x64
/* Advanced Interrupt Controller IRQ0 */
88
#define AIC_SMR_IRQ1 0x68
/* Advanced Interrupt Controller IRQ1 */
89
#define AIC_SMR_IRQ2 0x6c
/* Advanced Interrupt Controller IRQ2 */
90
#define AIC_SMR_IRQ3 0x70
/* Advanced Interrupt Controller IRQ3 */
91
#define AIC_SMR_IRQ4 0x74
/* Advanced Interrupt Controller IRQ4 */
92
#define AIC_SMR_IRQ5 0x78
/* Advanced Interrupt Controller IRQ5 */
93
#define AIC_SMR_IRQ6 0x7c
/* Advanced Interrupt Controller IRQ6 */
94
95
/* from AIC_CTL_BASE */
96
#define AIC_IVR 0x00
/* IRQ Vector Register */
97
#define AIC_FVR 0x04
/* FIQ Vector Register */
98
#define AIC_ISR 0x08
/* Interrupt Status Register */
99
#define AIC_IPR 0x0C
/* Interrupt Pending Register */
100
#define AIC_IMR 0x10
/* Interrupt Mask Register */
101
#define AIC_CISR 0x14
/* Core Interrupt Status Register */
102
#define AIC_IECR 0x20
/* Interrupt Enable Command Register */
103
#define AIC_IDCR 0x24
/* Interrupt Disable Command Register */
104
#define AIC_ICCR 0x28
/* Interrupt Clear Command Register */
105
#define AIC_ISCR 0x2C
/* Interrupt Set Command Register */
106
#define AIC_EOICR 0x30
/* End of Interrupt Command Register */
107
#define AIC_SPU 0x34
/* Spurious Vector Register */
108
#define AIC_DCR 0x38
/* Debug Control Register (Protect) */
109
#define AIC_FFER 0x40
/* Fast Forcing Enable Register */
110
#define AIC_FFDR 0x44
/* Fast Forcing Disable Register */
111
#define AIC_FFSR 0x48
/* Fast Forcing Status Register */
112
113
/* Bit Defines */
114
/* AIC_ISR - Interrupt Status Register */
115
#define AIC_ISR_IRQID_MASK 0x1f
/* current interrupt ID */
116
117
/* AIC_CISR - Core Interrupt Status Register */
118
#define AIC_CISR_IRQ BIT1
/* 1 = Core IRQ is active */
119
#define AIC_CISR_FIQ BIT0
/* 1 = Core FIQ is active */
120
121
/* AIC_DCR - Debug Control Register (Protect) */
122
#define AIC_DCR_GMSK BIT1
/* 0 = AIC controls IRQ and FIQ */
123
#define AIC_DCR_PROT BIT0
/* 1 = enable protection mode */
124
125
/* AIC_SMR */
126
#define AIC_SMR_PRIOR(_x_) ((_x_ & 0x07) << 0)
127
#define AIC_SMR_SRC_LVL_LOW (0 << 5)
/* Are these right? docs don't say which is high/low */
128
#define AIC_SMR_SRC_EDGE_LOW (1 << 5)
129
#define AIC_SMR_SRC_LVL_HI (2 << 5)
130
#define AIC_SMR_SRC_EDGE_HI (3 << 5)
131
132
133
/* Debug Unit */
134
135
#define DBGU_BASE 0xFFFFF200
136
#define DBGU_REG(_x_) *(vulong *)(DBGU_BASE + _x_)
137
138
139
#define DBGU_CR 0x00
/* Control Register */
140
#define DBGU_MR 0x04
/* Mode Register */
141
#define DBGU_IER 0x08
/* Interrupt Enable Register */
142
#define DBGU_IDR 0x0C
/* Interrupt Disable Register */
143
#define DBGU_IMR 0x10
144
#define DBGU_CSR 0x14
/* Channel Status Register */
145
#define DBGU_RHR 0x18
/* Receiver Holding Register */
146
#define DBGU_THR 0x1C
/* Transmitter Holding Register */
147
#define DBGU_BRGR 0x20
/* Baud Rate Generator Register */
148
#define DBGU_C1R 0x40
/* Chip ID1 Register */
149
#define DBGU_C2R 0x44
/* Chip ID2 Register */
150
#define DBGU_FNTR 0x48
/* Force NTRST Register */
151
152
153
/* USART 0-3 */
154
155
#define USART0_BASE 0xFFFC0000
156
#define USART1_BASE 0xFFFC4000
157
#define USART2_BASE 0xFFFC8000
158
#define USART3_BASE 0xFFFCC000
159
160
* WARNING: The USART3_BASE at the AT91RM9200 Manual is wrong!!!
161
* Manual revision: Rev. 1768H-ATARM-16-Jun-09
162
* USART3_BASE is NOT 0xFFECC000
163
164
165
166
/* System Timer */
167
168
#define ST_BASE 0xFFFFFD00
169
#define ST_REG(_x_) *(vulong *)(ST_BASE + _x_)
170
171
172
#define ST_CR 0x00
173
#define ST_PIMR 0x04
/* Period Interval Mode Register */
174
#define ST_WDMR 0x08
/* Watchdog Mode Register */
175
#define ST_RTMR 0x0C
/* Real-time Mode Register */
176
#define ST_SR 0x10
/* Status Register */
177
#define ST_IER 0x14
178
#define ST_IDR 0x18
179
#define ST_IMR 0x1C
180
#define ST_RTAR 0x20
/* Real-time Alarm Register */
181
#define ST_CRTR 0x24
/* Current Real-time Register */
182
183
/* Bit Defines */
184
/* ST_CR - Control Register */
185
#define ST_CR_WDRST BIT0
/* write 1 to reload WD counter */
186
187
/* ST_PIMR - Period Interval Mode Register */
188
#define ST_PIMR_PIV_MASK 0x0000ffff
189
190
/* ST_WDMR - Watchdog Mode Register */
191
#define ST_WDMR_EXTEN BIT17
/* WDOVF is not implemented on AT91RM9200 */
192
#define ST_WDMR_RSTEN BIT16
/* 1 = reset the AT91RM9200 when WD overflows */
193
#define ST_WDMR_WDV_MASK 0x0000ffff
/* WD counter is in the lower 16-bits */
194
195
/* ST_RTMR - Real-time Mode Register */
196
#define ST_RTMR_RTPRES_MASK 0x0000ffff
/* Real-Time Prescaler */
197
198
/* ST_SR - Status Register - Read Only */
199
/* ST_IER - Interrupt Enable Register - Write Only */
200
/* ST_IDR - Interrupt Disable Register - Write Only */
201
/* ST_IMR - Interrupt Mask Register - Read Only */
202
#define ST_SR_ALMS BIT3
203
#define ST_SR_RTTINC BIT2
204
#define ST_SR_WDOVF BIT1
205
#define ST_SR_PITS BIT0
206
207
/* ST_RTAR - Real-time Alarm Register */
208
#define ST_RTAR_ALMV_MASK 0x000fffff
209
210
/* ST_CRTR - Current Real-time Register */
211
#define ST_CRTR_CRTV_MASK 0x000fffff
212
213
214
215
* Peripheral Data Control (DMA)
216
* Note that each of the following peripherals has it's own
217
* set of these registers starting at offset 0x100 from it's
218
* base address: DBGU, SPI, USART and SSC
219
* To access the DMA for a peripheral, use the macro for that
220
* peripheral but with these register offsets
221
222
223
#define PDC_RPR 0x100
/* Receive Pointer Register */
224
#define PDC_RCR 0x104
/* Receive Counter Register */
225
#define PDC_TPR 0x108
/* Transmit Pointer Register */
226
#define PDC_TCR 0x10c
/* Transmit Counter Register */
227
#define PDC_RNPR 0x110
/* Receive Next Pointer Register */
228
#define PDC_RNCR 0x114
/* Receive Next Counter Register */
229
#define PDC_TNPR 0x118
/* Transmit Next Pointer Register */
230
#define PDC_TNCR 0x11c
/* Transmit Next Counter Register */
231
#define PDC_PTCR 0x120
/* PDC Transfer Control Register */
232
#define PDC_PTSR 0x124
/* PDC Transfer Status Register */
233
234
235
* Parallel I/O Unit
236
* There are four PIO blocks - A, B, C and D. They all have the
237
* same register set, but different base addresses
238
239
/* Port A */
240
#define PIOA_BASE 0xFFFFF400
241
#define PIOA_REG(_x_) *(vulong *)(PIOA_BASE + _x_)
242
243
/* Port B */
244
#define PIOB_BASE 0xFFFFF600
245
#define PIOB_REG(_x_) *(vulong *)(PIOB_BASE + _x_)
246
247
/* Port C */
248
#define PIOC_BASE 0xFFFFF800
249
#define PIOC_REG(_x_) *(vulong *)(PIOC_BASE + _x_)
250
251
/* Port D */
252
#define PIOD_BASE 0xFFFFFA00
253
#define PIOD_REG(_x_) *(vulong *)(PIOD_BASE + _x_)
254
255
256
* Power Management and Clock Control
257
258
#define PMC_BASE 0xFFFFFC00
259
#define PMC_REG(_x_) *(vulong *)(PMC_BASE + _x_)
260
261
262
* MAC Unit
263
264
#define EMAC_BASE 0xFFFBC000
265
#define EMAC_REG(_x_) *(vulong *)(EMAC_BASE + _x_)
266
267
268
* Timer/Counter Unit
269
270
#define TC_BASE 0xFFFA0000
271
#define TC_REG(_x_) *(vulong *)(TC_BASE + 0x00 + _x_)
272
#define TC_TC0_REG(_x_) *(vulong *)(TC_BASE + 0x00 + _x_)
273
#define TC_TC1_REG(_x_) *(vulong *)(TC_BASE + 0x40 + _x_)
274
#define TC_TC2_REG(_x_) *(vulong *)(TC_BASE + 0x80 + _x_)
275
276
/* Offsets from TC_TC?_REG */
277
#define TC_CCR 0x00
/* Channel Control Register */
278
#define TC_CMR 0x04
/* Channel Mode Register */
279
#define TC_CV 0x10
/* Counter Value */
280
#define TC_RA 0x14
/* Register A */
281
#define TC_RB 0x18
/* Register B */
282
#define TC_RC 0x1C
/* Register C */
283
#define TC_SR 0x20
284
#define TC_IER 0x24
285
#define TC_IDR 0x28
286
#define TC_IMR 0x2C
287
288
/* Offsets from TC_BASE */
289
#define TC_BCR 0xc0
290
#define TC_BMR 0xc4
291
292
/* Block control register */
293
#define TC_BCR_SYNC BIT1
/* Set to syncronize channels */
294
295
/* Block mode register */
296
#define TC_BMR_TC0(_x_) ((_x_ & 0x3) << 0)
/* TC0 clock source */
297
#define TC_BMR_TC1(_x_) ((_x_ & 0x3) << 2)
/* TC1 clock source */
298
#define TC_BMR_TC2(_x_) ((_x_ & 0x3) << 4)
/* TC2 clock source */
299
300
/* Channel Control register */
301
#define TC_CCR_CLKEN BIT0
/* Enable clock */
302
#define TC_CCR_CLKDIS BIT1
/* Disable clock */
303
#define TC_CCR_SWTRG BIT2
/* Software trigger command */
304
305
/* Channel mode register */
306
#define TC_CMR_TCCLKS(_x_) ((_x_ & 0x7) << 0)
/* Clock source */
307
#define TC_CMR_CLKI BIT3
/* Clock invert */
308
#define TC_BURST(_x_) ((_x_ & 0x3 << 4)
/* Burst signal selection */
309
#define TC_WAVE BIT15
/* 0 for catpure, 1 for wave */
310
311
/* Channel mode register - capture mode (TC_WAVE = 0) */
312
#define TC_CMR_LDBSTOP BIT6
/* Set to stop clock when RB loads */
313
#define TC_CMR_LDBDIS BIT7
/* Set to disable clock when RB loads */
314
#define TC_CMR_ETRGEDG(_x_) ((_x_ & 0x3) << 8)
/* Select edge triggering mode */
315
#define TC_CMR_ABETRG BIT10
/* Select ext trigger source */
316
#define TC_CMR_CPCTRG BIT14
/* RC Compare trigger enable */
317
#define TC_CMR_LDRA(_x_) ((_x_ & 0x3) << 16)
/* RA loading selection */
318
#define TC_CMR_LDRB(_x_) ((_x_ & 0x3) << 18)
/* RB loading selection */
319
320
/* Channel mode register - wave mode (TC_WAVE = 1) */
321
#define TC_CMR_CPCSTOP BIT6
/* Clock stopped w/ RC compare */
322
#define TC_CMR_CPCDIS BIT7
/* Clock disabled w/ RC compare */
323
#define TC_CMR_EEVTEDG(_x_) ((_x_ & 0x3) << 8)
/* Ext event edge selection */
324
#define TC_CMR_EEVT(_x_) ((_x_ & 0x3) << 10)
/* Ext event selection */
325
#define TC_CMR_ENETRG BIT12
/* Ext event trigger enable */
326
#define TC_CMR_WAVESEL(_x_) ((_x_ & 0x3) << 13)
/* Waveform selection */
327
#define TC_CMR_ACPA(_x_) ((_x_ & 0x3) << 16)
/* RA compare effect on TIOA */
328
#define TC_CMR_ACPC(_x_) ((_x_ & 0x3) << 18)
/* RC compare effect on TIOA */
329
#define TC_CMR_AEEVT(_x_) ((_x_ & 0x3) << 20)
/* Ext event effect on TIOA */
330
#define TC_CMR_ASWTRG(_x_) ((_x_ & 0x3) << 22)
/* SW trigger effect on TIOA */
331
#define TC_CMR_BCPB(_x_) ((_x_ & 0x3) << 24)
/* RB compare effect on TIOB */
332
#define TC_CMR_BCPC(_x_) ((_x_ & 0x3) << 26)
/* RC compare effect on TIOB */
333
#define TC_CMR_BEEVT(_x_) ((_x_ & 0x3) << 28)
/* Ext event effect on TIOB */
334
#define TC_CMR_BSWTRG(_x_) ((_x_ & 0x3) << 30)
/* SW trigger effect on TIOB */
335
336
/* Counter value */
337
#define TC_CV_MASK 0xffff
/* Timer counter mask */
338
339
/* Status, Interrupt enable, Interrupt disable, and Interrupt mask registers */
340
#define TC_SR_COVFS BIT0
/* Counter overflow status */
341
#define TC_SR_LOVRS BIT1
/* Load overrun status */
342
#define TC_SR_CPAS BIT2
/* RA compare status */
343
#define TC_SR_CPBS BIT3
/* RB compare status */
344
#define TC_SR_CPCS BIT4
/* RC compare status */
345
#define TC_SR_LDRAS BIT5
/* RA loading status */
346
#define TC_SR_LDRBS BIT6
/* RB loading status */
347
#define TC_SR_ETRGS BIT7
/* External trigger status */
348
#define TC_SR_CLKSTA BIT16
/* Clock enabling status */
349
#define TC_SR_MTIOA BIT17
/* TIOA Mirror */
350
#define TC_SR_MTIOB BIT18
/* TIOB Mirror */
351
352
353
* External Bus Interface Unit
354
355
#define EBI_BASE 0xFFFFFF60
356
#define EBI_REG(_x_) *(vulong *)(EBI_BASE + _x_)
357
358
359
* Static Memory Interface Unit
360
361
#define SMC_REG(_x_) *(vulong *)(EBI_BASE + 0x10 + _x_)
362
363
364
* SDRAM Memory Interface Unit
365
366
#define SDRC_REG(_x_) *(vulong *)(EBI_BASE + 0x30 + _x_)
367
368
#endif
/* __AT91RM9200_H__ */
369
bits.h
Contains bit position definitions.
