35#ifndef LIBBSP_ARM_SHARED_ARM_CP15_START_H
36#define LIBBSP_ARM_SHARED_ARM_CP15_START_H
53#define ARMV7_CP15_START_DEFAULT_SECTIONS \
55 .begin = (uint32_t) bsp_section_fast_text_begin, \
56 .end = (uint32_t) bsp_section_fast_text_end, \
57 .flags = ARMV7_MMU_CODE_CACHED \
59 .begin = (uint32_t) bsp_section_fast_data_begin, \
60 .end = (uint32_t) bsp_section_fast_data_end, \
61 .flags = ARMV7_MMU_DATA_READ_WRITE_CACHED \
63 .begin = (uint32_t) bsp_section_start_begin, \
64 .end = (uint32_t) bsp_section_start_end, \
65 .flags = ARMV7_MMU_CODE_CACHED \
67 .begin = (uint32_t) bsp_section_vector_begin, \
68 .end = (uint32_t) bsp_section_vector_end, \
69 .flags = ARMV7_MMU_DATA_READ_WRITE_CACHED \
71 .begin = (uint32_t) bsp_section_text_begin, \
72 .end = (uint32_t) bsp_section_text_end, \
73 .flags = ARMV7_MMU_CODE_CACHED \
75 .begin = (uint32_t) bsp_section_rodata_begin, \
76 .end = (uint32_t) bsp_section_rodata_end, \
77 .flags = ARMV7_MMU_DATA_READ_ONLY_CACHED \
79 .begin = (uint32_t) bsp_section_data_begin, \
80 .end = (uint32_t) bsp_section_data_end, \
81 .flags = ARMV7_MMU_DATA_READ_WRITE_CACHED \
83 .begin = (uint32_t) bsp_section_bss_begin, \
84 .end = (uint32_t) bsp_section_bss_end, \
85 .flags = ARMV7_MMU_DATA_READ_WRITE_CACHED \
87 .begin = (uint32_t) bsp_section_rtemsstack_begin, \
88 .end = (uint32_t) bsp_section_rtemsstack_end, \
89 .flags = ARMV7_MMU_DATA_READ_WRITE_CACHED \
91 .begin = (uint32_t) bsp_section_noinit_begin, \
92 .end = (uint32_t) bsp_section_noinit_end, \
93 .flags = ARMV7_MMU_DATA_READ_WRITE_CACHED \
95 .begin = (uint32_t) bsp_section_work_begin, \
96 .end = (uint32_t) bsp_section_work_end, \
97 .flags = ARMV7_MMU_DATA_READ_WRITE_CACHED \
99 .begin = (uint32_t) bsp_section_stack_begin, \
100 .end = (uint32_t) bsp_section_stack_end, \
101 .flags = ARMV7_MMU_DATA_READ_WRITE_CACHED \
103 .begin = (uint32_t) bsp_section_nocache_begin, \
104 .end = (uint32_t) bsp_section_nocache_end, \
105 .flags = ARMV7_MMU_DEVICE \
107 .begin = (uint32_t) bsp_section_nocachenoload_begin, \
108 .end = (uint32_t) bsp_section_nocachenoload_end, \
109 .flags = ARMV7_MMU_DEVICE \
111 .begin = (uint32_t) bsp_translation_table_base, \
112 .end = (uint32_t) bsp_translation_table_end, \
113 .flags = ARMV7_MMU_DATA_READ_WRITE_CACHED \
116#define ARMV7_CP15_START_WORKSPACE_ENTRY_INDEX 10
119 arm_cp15_start_mmu_config_table[];
121BSP_START_DATA_SECTION
extern const size_t
122 arm_cp15_start_mmu_config_table_size;
124BSP_START_TEXT_SECTION
static inline void
125arm_cp15_start_set_translation_table_entries(
130 if (config->begin != config->end) {
135#ifdef ARM_MMU_USE_SMALL_PAGES
138 pt = &ttb[ARM_MMU_TRANSLATION_TABLE_ENTRY_COUNT];
139 i = ARM_MMU_SMALL_PAGE_GET_INDEX(config->begin);
140 iend = ARM_MMU_SMALL_PAGE_GET_INDEX(ARM_MMU_SMALL_PAGE_MVA_ALIGN_UP(config->end));
141 index_mask = (1U << (32 - ARM_MMU_SMALL_PAGE_BASE_SHIFT)) - 1U;
142 flags = ARM_MMU_SECT_FLAGS_TO_SMALL_PAGE(config->flags);
145 pt[i] = (i << ARM_MMU_SMALL_PAGE_BASE_SHIFT) | flags;
146 i = (i + 1U) & index_mask;
149 i = ARM_MMU_SECT_GET_INDEX(config->begin);
150 iend = ARM_MMU_SECT_GET_INDEX(ARM_MMU_SECT_MVA_ALIGN_UP(config->end));
151 index_mask = (1U << (32 - ARM_MMU_SECT_BASE_SHIFT)) - 1U;
152 flags = config->flags;
155 ttb[i] = (i << ARM_MMU_SECT_BASE_SHIFT) | flags;
156 i = (i + 1U) & index_mask;
162BSP_START_TEXT_SECTION
static inline void
163arm_cp15_start_setup_translation_table(
165 uint32_t client_domain,
170#ifdef ARM_MMU_USE_SMALL_PAGES
176 dac = ARM_CP15_DAC_DOMAIN(client_domain, ARM_CP15_DAC_CLIENT);
177 arm_cp15_set_domain_access_control(dac);
178 arm_cp15_set_translation_table_base(ttb);
181#ifdef ARM_MMU_USE_SMALL_PAGES
182 pt = &ttb[ARM_MMU_TRANSLATION_TABLE_ENTRY_COUNT];
183 for (i = 0; i < ARM_MMU_TRANSLATION_TABLE_ENTRY_COUNT; ++i) {
186 for (j = 0; j < ARM_MMU_SMALL_PAGE_TABLE_ENTRY_COUNT; ++j) {
190 ttb[i] = (uint32_t) pt | (client_domain << ARM_MMU_SECT_DOMAIN_SHIFT)
191 | ARM_MMU_PAGE_TABLE_DEFAULT;
192 pt += ARM_MMU_SMALL_PAGE_TABLE_ENTRY_COUNT;
195 for (i = 0; i < ARM_MMU_TRANSLATION_TABLE_ENTRY_COUNT; ++i) {
200 for (i = 0; i < config_count; ++i) {
201 arm_cp15_start_set_translation_table_entries(ttb, &config_table [i]);
205BSP_START_TEXT_SECTION
static inline void
206arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache(
209 uint32_t client_domain,
214 arm_cp15_start_setup_translation_table(
222 ctrl |= ARM_CP15_CTRL_I | ARM_CP15_CTRL_C | ARM_CP15_CTRL_M;
224 arm_cp15_set_control(ctrl);
227BSP_START_TEXT_SECTION
static inline uint32_t
228arm_cp15_start_setup_mmu_and_cache(uint32_t ctrl_clear, uint32_t ctrl_set)
230 uint32_t ctrl = arm_cp15_get_control();
235 arm_cp15_set_control(ctrl);
237 arm_cp15_tlb_invalidate();
ARM co-processor 15 (CP15) API.
This header file provides interfaces to BSP-specific linker symbols and sections.
Definition: arm-cp15-start.h:47
