RTEMS 7.0-rc1
afe_dma.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
49#ifndef _AFE_DMA_
50#define _AFE_DMA_
51
52/*----------------------------------------------------------------------------
53 * Headers
54 *----------------------------------------------------------------------------*/
55
56#include "chip.h"
57
58
59/*----------------------------------------------------------------------------
60 * Types
61 *----------------------------------------------------------------------------*/
62
64typedef void (*AfeCallback)(uint8_t, void *);
65
71typedef struct {
73 uint32_t *pRxBuff;
75 uint16_t RxSize;
79 void *pArgument;
80} AfeCmd;
81
82
85typedef struct {
93 uint8_t afeId;
95 volatile int8_t semaphore;
96} AfeDma;
97
98
99/*------------------------------------------------------------------------------
100 * Definitions
101 *----------------------------------------------------------------------------*/
102#define AFE_OK 0
103#define AFE_ERROR 1
104#define AFE_ERROR_LOCK 2
105/*------------------------------------------------------------------------------
106 * Exported functions
107 *----------------------------------------------------------------------------*/
108extern uint32_t Afe_ConfigureDma(AfeDma *pAfed ,
109 Afec *pAfeHw ,
110 uint8_t AfeId,
111 sXdmad *pXdmad);
112extern uint32_t Afe_SendData(AfeDma *pAfed, AfeCmd *pCommand);
113
114
115#endif /* #ifndef _AFE_DMA_ */
116
uint32_t Afe_ConfigureDma(AfeDma *pAfed, Afec *pAfeHw, uint8_t AfeId, sXdmad *pXdmad)
Initializes the AfeDma structure and the corresponding AFE & DMA . hardware select value....
Definition: afe_dma.c:203
Starts a AFE transfer. This is a non blocking function. It will return as soon as the transfer is sta...
Definition: afe_dma.c:228
void(* AfeCallback)(uint8_t, void *)
Definition: afe_dma.h:64
Chip definitions for STM32U5.
Spi Transfer Request prepared by the application upper layer.
Definition: afe_dma.h:71
uint32_t * pRxBuff
Definition: afe_dma.h:73
uint16_t RxSize
Definition: afe_dma.h:75
void * pArgument
Definition: afe_dma.h:79
AfeCallback callback
Definition: afe_dma.h:77
Definition: afe_dma.h:85
Afec * pAfeHw
Definition: afe_dma.h:87
AfeCmd * pCurrentCommand
Definition: afe_dma.h:89
sXdmad * pXdmad
Definition: afe_dma.h:91
uint8_t afeId
Definition: afe_dma.h:93
Definition: afe_dma.h:95
Afec hardware registers.
Definition: component_afec.h:41
Definition: xdmad.h:127
