RTEMS 6.3-rc1
xnandpsu_flashdev.h
2
11/*
12 * Copyright (C) 2025 On-Line Applications Research (OAR) Corporation
13 *
16 * are met:
22 *
23 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS AS IS
34 */
35
36#ifndef XNANDPSU_FLASHDEV_H
37#define XNANDPSU_FLASHDEV_H
38
39#include <dev/flash/flashdev.h>
40#include <dev/nand/xnandpsu.h>
41
42#ifdef __cplusplus
43extern "C" {
44#endif
45
58
59#ifdef __cplusplus
60}
61#endif
62
63#endif /* XNANDPSU_FLASHDEV_H */
Generic Flash API.
Definition: xnandpsu.h:393
Flash device.
Definition: flashdev.h:358
rtems_flashdev * xnandpsu_flashdev_init(XNandPsu *nandpsu)
Initializes a flash device using Xilinx's xnandpsu flash driver.
Definition: xnandpsu_flashdev.c:445
