RTEMS
6.3-rc1
bsps
powerpc
include
bsp
motload-gev-net-env.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
3
4
* Copyright (c) 2026 Chris Johns <chrisj@rtems.org>. All rights reserved.
5
6
7
* modification, are permitted provided that the following conditions
8
* are met:
9
* 1. Redistributions of source code must retain the above copyright
10
* notice, this list of conditions and the following disclaimer.
11
* 2. Redistributions in binary form must reproduce the above copyright
12
* notice, this list of conditions and the following disclaimer in the
13
* documentation and/or other materials provided with the distribution.
14
15
* THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
16
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18
* ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
19
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
20
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
21
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
22
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
23
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
24
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
25
* SUCH DAMAGE.
26
27
28
29
* MOTLoad RTEMS Network Environment Variables
30
31
* Set the environment variables based on the GEV settings. The
32
* pattern for scanning follows the parsing that was in EPICS Base's
33
* `setBootConfigFromNVRAM.c`. The code was moved to RTEMS as part of
34
* a clean up of EPICS code.
35
36
37
#ifndef _POWERPC_MOTLOAD_GEV_NET_ENV_h
38
#define _POWERPC_MOTLOAD_GEV_NET_ENV_h
39
40
#include <stdbool.h>
41
#include <stdint.h>
42
43
#ifdef __cplusplus
44
extern
"C"
45
#endif
/* __cplusplus */
46
47
48
* Set the RTEMS network environment vairables from GEV variables for
49
* the specified network interface
50
51
* @param nvram_base Base address if the byte addressable NVRAM
52
* @param unit Network interface unit number, ie `0` for `enet0`
53
* @param label Network interface unit label, ie `0` for `em0`
54
55
void
motload_gev_set_net_envs(uintptr_t nvram_base,
const
size_t
unit,
56
const
char
* label);
57
58
#ifdef __cplusplus
59
60
#endif
/* __cplusplus */
61
62
#endif
