RTEMS 6.3-rc1
This header file defines interfaces to support and use dynamic memory allocation. More...
Typedefs | |
| typedef void *(* | rtems_heap_extend_handler) (Heap_Control *heap, size_t alloc_size) |
| typedef void(* | rtems_malloc_dirtier_t) (void *, size_t) |
| void | _Malloc_Initialize (void) |
| void * | rtems_heap_extend_via_sbrk (Heap_Control *heap, size_t alloc_size) |
| RTEMS Extend Heap via Sbrk. | |
| void * | rtems_heap_null_extend (Heap_Control *heap, size_t alloc_size) |
| void | rtems_heap_set_sbrk_amount (ptrdiff_t sbrk_amount) |
| void | rtems_heap_sbrk_greedy_allocate (Heap_Control *heap, size_t alloc_size) |
| Greedy allocate that empties the sbrk memory. | |
| void | rtems_malloc_dirty_memory (void *start, size_t size) |
| Dirty Memory Function. | |
| int | rtems_memalign (void **pointer, size_t alignment, size_t size) |
| RTEMS Variation on Aligned Memory Allocation. | |
| void * | rtems_heap_allocate_aligned_with_boundary (size_t size, uintptr_t alignment, uintptr_t boundary) RTEMS_MALLOCLIKE RTEMS_ALLOC_SIZE(1) RTEMS_ALLOC_ALIGN(2) RTEMS_WARN_UNUSED_RESULT |
| Allocates a memory area of size size bytes from the heap. | |
| void * | rtems_malloc (size_t size) RTEMS_MALLOCLIKE RTEMS_ALLOC_SIZE(1) RTEMS_WARN_UNUSED_RESULT |
| Allocates a memory area of the specified size from the heap. | |
| void * | rtems_calloc (size_t nelem, size_t elsize) RTEMS_MALLOCLIKE RTEMS_ALLOC_SIZE_2(1 |
| Allocates a memory area for the specified count of elements from the heap. | |
| rtems_status_code | rtems_heap_extend (void *area_begin, uintptr_t area_size) |
| Extends the memory available for the heap using the memory area starting at area_begin of size area_size bytes. | |
| void * | rtems_heap_greedy_allocate (const uintptr_t *block_sizes, size_t block_count) |
| Greedy allocate that empties the heap. | |
| void * | rtems_heap_greedy_allocate_all_except_largest (uintptr_t *allocatable_size) |
| Greedy allocate all blocks except the largest free block. | |
| void | rtems_heap_greedy_free (void *opaque) |
| Frees space of a greedy allocation. | |
| Heap_Control * | RTEMS_Malloc_Heap |
| C program heap control. | |
| const rtems_heap_extend_handler | rtems_malloc_extend_handler |
| rtems_malloc_dirtier_t | rtems_malloc_dirty_helper |
| void | RTEMS_WARN_UNUSED_RESULT |
