RTEMS 6.2-rc3
This header file provides interfaces of the Pulse Per Second (PPS) support. More...
| struct | ntp_fp |
| union | pps_timeu |
| struct | pps_info_t |
| struct | pps_info_ffc_t |
| struct | pps_params_t |
| struct | pps_fetch_args |
| struct | pps_fetch_ffc_args |
| struct | pps_kcbind_args |
| #define | PPS_API_VERS_1 1 |
| #define | assert_timestamp assert_tu.tspec |
| #define | clear_timestamp clear_tu.tspec |
| #define | assert_timestamp_ntpfp assert_tu.ntpfp |
| #define | clear_timestamp_ntpfp clear_tu.ntpfp |
| #define | assert_offset assert_off_tu.tspec |
| #define | clear_offset clear_off_tu.tspec |
| #define | assert_offset_ntpfp assert_off_tu.ntpfp |
| #define | clear_offset_ntpfp clear_off_tu.ntpfp |
| #define | PPS_CAPTUREASSERT 0x01 |
| #define | PPS_CAPTURECLEAR 0x02 |
| #define | PPS_CAPTUREBOTH 0x03 |
| #define | PPS_OFFSETASSERT 0x10 |
| #define | PPS_OFFSETCLEAR 0x20 |
| #define | PPS_ECHOASSERT 0x40 |
| #define | PPS_ECHOCLEAR 0x80 |
| #define | PPS_CANWAIT 0x100 |
| #define | PPS_CANPOLL 0x200 |
| #define | PPS_TSFMT_TSPEC 0x1000 |
| #define | PPS_TSFMT_NTPFP 0x2000 |
| #define | PPS_TSCLK_FBCK 0x10000 |
| #define | PPS_TSCLK_FFWD 0x20000 |
| #define | PPS_TSCLK_MASK 0x30000 |
| #define | PPS_KC_HARDPPS 0 |
| #define | PPS_KC_HARDPPS_PLL 1 |
| #define | PPS_KC_HARDPPS_FLL 2 |
| #define | PPS_IOC_CREATE _IO('1', 1) |
| #define | PPS_IOC_DESTROY _IO('1', 2) |
| #define | PPS_IOC_SETPARAMS _IOW('1', 3, pps_params_t) |
| #define | PPS_IOC_GETPARAMS _IOR('1', 4, pps_params_t) |
| #define | PPS_IOC_GETCAP _IOR('1', 5, int) |
| #define | PPS_IOC_FETCH _IOWR('1', 6, struct pps_fetch_args) |
| #define | PPS_IOC_KCBIND _IOW('1', 7, struct pps_kcbind_args) |
| #define | PPS_IOC_FETCH_FFCOUNTER _IOWR('1', 8, struct pps_fetch_ffc_args) |
Typedefs | |
| typedef int | pps_handle_t |
| typedef unsigned | pps_seq_t |
| typedef struct ntp_fp | ntp_fp_t |
| typedef union pps_timeu | pps_timeu_t |
