RTEMS 6.2-rc3
USART HAL module driver. This file provides firmware functions to manage the following functionalities of the Universal Synchronous/Asynchronous Receiver Transmitter Peripheral (USART). More...
#include "stm32h7xx_hal.h"USART HAL module driver. This file provides firmware functions to manage the following functionalities of the Universal Synchronous/Asynchronous Receiver Transmitter Peripheral (USART).
##### How to use this driver #####
The USART HAL driver can be used as follows:
(#) Declare a USART_HandleTypeDef handle structure (eg. USART_HandleTypeDef husart).
(#) Initialize the USART low level resources by implementing the HAL_USART_MspInit() API:
(++) Enable the USARTx interface clock.
(++) USART pins configuration:
(+++) Enable the clock for the USART GPIOs.
(+++) Configure these USART pins as alternate function pull-up.
(++) NVIC configuration if you need to use interrupt process (HAL_USART_Transmit_IT(),
HAL_USART_Receive_IT() and HAL_USART_TransmitReceive_IT() APIs):
(+++) Configure the USARTx interrupt priority.
(+++) Enable the NVIC USART IRQ handle.
(++) USART interrupts handling:
-@@- The specific USART interrupts (Transmission complete interrupt,
RXNE interrupt and Error Interrupts) will be managed using the macros
__HAL_USART_ENABLE_IT() and __HAL_USART_DISABLE_IT() inside the transmit and receive process.
(++) DMA Configuration if you need to use DMA process (HAL_USART_Transmit_DMA()
HAL_USART_Receive_DMA() and HAL_USART_TransmitReceive_DMA() APIs):
(+++) Declare a DMA handle structure for the Tx/Rx channel.
(+++) Enable the DMAx interface clock.
(+++) Configure the declared DMA handle structure with the required Tx/Rx parameters.
(+++) Configure the DMA Tx/Rx channel.
(+++) Associate the initialized DMA handle to the USART DMA Tx/Rx handle.
(+++) Configure the priority and enable the NVIC for the transfer
complete interrupt on the DMA Tx/Rx channel.
(#) Program the Baud Rate, Word Length, Stop Bit, Parity, and Mode
(Receiver/Transmitter) in the husart handle Init structure.
(#) Initialize the USART registers by calling the HAL_USART_Init() API:
(++) This API configures also the low level Hardware GPIO, CLOCK, CORTEX...etc)
by calling the customized HAL_USART_MspInit(&husart) API.
(@) To configure and enable/disable the USART to wake up the MCU from stop mode, resort to UART API's
HAL_UARTEx_StopModeWakeUpSourceConfig(), HAL_UARTEx_EnableStopMode() and
HAL_UARTEx_DisableStopMode() in casting the USART handle to UART type UART_HandleTypeDef.
##### Callback registration #####
The compilation define USE_HAL_USART_REGISTER_CALLBACKS when set to 1
allows the user to configure dynamically the driver callbacks.
Use Function HAL_USART_RegisterCallback() to register a user callback.
Function HAL_USART_RegisterCallback() allows to register following callbacks:
(+) TxHalfCpltCallback : Tx Half Complete Callback.
(+) TxCpltCallback : Tx Complete Callback.
(+) RxHalfCpltCallback : Rx Half Complete Callback.
(+) RxCpltCallback : Rx Complete Callback.
(+) TxRxCpltCallback : Tx Rx Complete Callback.
(+) ErrorCallback : Error Callback.
(+) AbortCpltCallback : Abort Complete Callback.
(+) RxFifoFullCallback : Rx Fifo Full Callback.
(+) TxFifoEmptyCallback : Tx Fifo Empty Callback.
(+) MspInitCallback : USART MspInit.
(+) MspDeInitCallback : USART MspDeInit.
This function takes as parameters the HAL peripheral handle, the Callback ID
and a pointer to the user callback function.
Use function HAL_USART_UnRegisterCallback() to reset a callback to the default
weak function.
HAL_USART_UnRegisterCallback() takes as parameters the HAL peripheral handle,
and the Callback ID.
This function allows to reset following callbacks:
By default, after the HAL_USART_Init() and when the state is HAL_USART_STATE_RESET
all callbacks are set to the corresponding weak functions:
examples HAL_USART_TxCpltCallback(), HAL_USART_RxHalfCpltCallback().
Exception done for MspInit and MspDeInit functions that are respectively
reset to the legacy weak functions in the HAL_USART_Init()
and HAL_USART_DeInit() only when these callbacks are null (not registered beforehand).
If not, MspInit or MspDeInit are not null, the HAL_USART_Init() and HAL_USART_DeInit()
keep and use the user MspInit/MspDeInit callbacks (registered beforehand).
Callbacks can be registered/unregistered in HAL_USART_STATE_READY state only.
Exception done MspInit/MspDeInit that can be registered/unregistered
in HAL_USART_STATE_READY or HAL_USART_STATE_RESET state, thus registered (user)
MspInit/DeInit callbacks can be used during the Init/DeInit.
In that case first register the MspInit/MspDeInit user callbacks
using HAL_USART_RegisterCallback() before calling HAL_USART_DeInit()
or HAL_USART_Init() function.
When The compilation define USE_HAL_USART_REGISTER_CALLBACKS is set to 0 or
not defined, the callback registration feature is not available
and weak callbacks are used.
