RTEMS 6.2-rc3
Header file of GPIO HAL module. More...
| struct | GPIO_InitTypeDef |
| GPIO Init structure definition. More... | |
| #define | GPIO_PIN_0 ((uint16_t)0x0001) /* Pin 0 selected */ |
| #define | GPIO_PIN_1 ((uint16_t)0x0002) /* Pin 1 selected */ |
| #define | GPIO_PIN_2 ((uint16_t)0x0004) /* Pin 2 selected */ |
| #define | GPIO_PIN_3 ((uint16_t)0x0008) /* Pin 3 selected */ |
| #define | GPIO_PIN_4 ((uint16_t)0x0010) /* Pin 4 selected */ |
| #define | GPIO_PIN_5 ((uint16_t)0x0020) /* Pin 5 selected */ |
| #define | GPIO_PIN_6 ((uint16_t)0x0040) /* Pin 6 selected */ |
| #define | GPIO_PIN_7 ((uint16_t)0x0080) /* Pin 7 selected */ |
| #define | GPIO_PIN_8 ((uint16_t)0x0100) /* Pin 8 selected */ |
| #define | GPIO_PIN_9 ((uint16_t)0x0200) /* Pin 9 selected */ |
| #define | GPIO_PIN_10 ((uint16_t)0x0400) /* Pin 10 selected */ |
| #define | GPIO_PIN_11 ((uint16_t)0x0800) /* Pin 11 selected */ |
| #define | GPIO_PIN_12 ((uint16_t)0x1000) /* Pin 12 selected */ |
| #define | GPIO_PIN_13 ((uint16_t)0x2000) /* Pin 13 selected */ |
| #define | GPIO_PIN_14 ((uint16_t)0x4000) /* Pin 14 selected */ |
| #define | GPIO_PIN_15 ((uint16_t)0x8000) /* Pin 15 selected */ |
| #define | GPIO_PIN_All ((uint16_t)0xFFFF) /* All pins selected */ |
| #define | GPIO_PIN_MASK (0x0000FFFFU) /* PIN mask for assert test */ |
| #define | GPIO_MODE_INPUT MODE_INPUT |
| #define | GPIO_MODE_OUTPUT_PP (MODE_OUTPUT | OUTPUT_PP) |
| #define | GPIO_MODE_OUTPUT_OD (MODE_OUTPUT | OUTPUT_OD) |
| #define | GPIO_MODE_AF_PP (MODE_AF | OUTPUT_PP) |
| #define | GPIO_MODE_AF_OD (MODE_AF | OUTPUT_OD) |
| #define | GPIO_MODE_ANALOG MODE_ANALOG |
| #define | GPIO_MODE_IT_RISING (MODE_INPUT | EXTI_IT | TRIGGER_RISING) |
| #define | GPIO_MODE_IT_FALLING (MODE_INPUT | EXTI_IT | TRIGGER_FALLING) |
| #define | GPIO_MODE_IT_RISING_FALLING (MODE_INPUT | EXTI_IT | TRIGGER_RISING | TRIGGER_FALLING) |
| #define | GPIO_MODE_EVT_RISING (MODE_INPUT | EXTI_EVT | TRIGGER_RISING) |
| #define | GPIO_MODE_EVT_FALLING (MODE_INPUT | EXTI_EVT | TRIGGER_FALLING) |
| #define | GPIO_MODE_EVT_RISING_FALLING (MODE_INPUT | EXTI_EVT | TRIGGER_RISING | TRIGGER_FALLING) |
| #define | GPIO_SPEED_FREQ_LOW (0x00000000U) |
| #define | GPIO_SPEED_FREQ_MEDIUM (0x00000001U) |
| #define | GPIO_SPEED_FREQ_HIGH (0x00000002U) |
| #define | GPIO_SPEED_FREQ_VERY_HIGH (0x00000003U) |
| #define | GPIO_NOPULL (0x00000000U) |
| #define | GPIO_PULLUP (0x00000001U) |
| #define | GPIO_PULLDOWN (0x00000002U) |
| #define | __HAL_GPIO_EXTI_GET_FLAG(__EXTI_LINE__) (EXTI->PR1 & (__EXTI_LINE__)) |
| Checks whether the specified EXTI line flag is set or not. | |
| #define | __HAL_GPIO_EXTI_CLEAR_FLAG(__EXTI_LINE__) (EXTI->PR1 = (__EXTI_LINE__)) |
| Clears the EXTI's line pending flags. | |
| #define | __HAL_GPIO_EXTI_GET_IT(__EXTI_LINE__) (EXTI->PR1 & (__EXTI_LINE__)) |
| Checks whether the specified EXTI line is asserted or not. | |
| #define | __HAL_GPIO_EXTI_CLEAR_IT(__EXTI_LINE__) (EXTI->PR1 = (__EXTI_LINE__)) |
| Clears the EXTI's line pending bits. | |
| #define | __HAL_GPIO_EXTI_GENERATE_SWIT(__EXTI_LINE__) (EXTI->SWIER1 |= (__EXTI_LINE__)) |
| Generates a Software interrupt on selected EXTI line. | |
| #define | GPIO_MODE_Pos 0u |
| #define | GPIO_MODE (0x3uL << GPIO_MODE_Pos) |
| #define | MODE_INPUT (0x0uL << GPIO_MODE_Pos) |
| #define | MODE_OUTPUT (0x1uL << GPIO_MODE_Pos) |
| #define | MODE_AF (0x2uL << GPIO_MODE_Pos) |
| #define | MODE_ANALOG (0x3uL << GPIO_MODE_Pos) |
| #define | OUTPUT_TYPE_Pos 4u |
| #define | OUTPUT_TYPE (0x1uL << OUTPUT_TYPE_Pos) |
| #define | OUTPUT_PP (0x0uL << OUTPUT_TYPE_Pos) |
| #define | OUTPUT_OD (0x1uL << OUTPUT_TYPE_Pos) |
| #define | EXTI_MODE_Pos 16u |
| #define | EXTI_MODE (0x3uL << EXTI_MODE_Pos) |
| #define | EXTI_IT (0x1uL << EXTI_MODE_Pos) |
| #define | EXTI_EVT (0x2uL << EXTI_MODE_Pos) |
| #define | TRIGGER_MODE_Pos 20u |
| #define | TRIGGER_MODE (0x7uL << TRIGGER_MODE_Pos) |
| #define | TRIGGER_RISING (0x1uL << TRIGGER_MODE_Pos) |
| #define | TRIGGER_FALLING (0x2uL << TRIGGER_MODE_Pos) |
| #define | TRIGGER_LEVEL (0x4uL << TRIGGER_MODE_Pos) |
| #define | IS_GPIO_PIN_ACTION(ACTION) (((ACTION) == GPIO_PIN_RESET) || ((ACTION) == GPIO_PIN_SET)) |
| #define | IS_GPIO_PIN(__PIN__) |
| #define | IS_GPIO_MODE(MODE) |
| #define | IS_GPIO_SPEED(SPEED) |
| #define | IS_GPIO_PULL(PULL) |
Enumerations | |
| enum | GPIO_PinState { GPIO_PIN_RESET = 0U , GPIO_PIN_SET } |
| GPIO Bit SET and Bit RESET enumeration. | |
| void | HAL_GPIO_Init (GPIO_TypeDef *GPIOx, GPIO_InitTypeDef *GPIO_Init) |
| void | HAL_GPIO_DeInit (GPIO_TypeDef *GPIOx, uint32_t GPIO_Pin) |
| GPIO_PinState | HAL_GPIO_ReadPin (GPIO_TypeDef *GPIOx, uint16_t GPIO_Pin) |
| void | HAL_GPIO_WritePin (GPIO_TypeDef *GPIOx, uint16_t GPIO_Pin, GPIO_PinState PinState) |
| void | HAL_GPIO_TogglePin (GPIO_TypeDef *GPIOx, uint16_t GPIO_Pin) |
| HAL_StatusTypeDef | HAL_GPIO_LockPin (GPIO_TypeDef *GPIOx, uint16_t GPIO_Pin) |
| void | HAL_GPIO_EXTI_IRQHandler (uint16_t GPIO_Pin) |
| void | HAL_GPIO_EXTI_Callback (uint16_t GPIO_Pin) |
