RTEMS 6.2-rc3
Header file of CRC HAL extended module. More...
#include "stm32h7xx_hal_def.h"Go to the source code of this file.
| #define | CRC_INPUTDATA_INVERSION_NONE 0x00000000U |
| #define | CRC_INPUTDATA_INVERSION_BYTE CRC_CR_REV_IN_0 |
| #define | CRC_INPUTDATA_INVERSION_HALFWORD CRC_CR_REV_IN_1 |
| #define | CRC_INPUTDATA_INVERSION_WORD CRC_CR_REV_IN |
| #define | CRC_OUTPUTDATA_INVERSION_DISABLE 0x00000000U |
| #define | CRC_OUTPUTDATA_INVERSION_ENABLE CRC_CR_REV_OUT |
| #define | __HAL_CRC_OUTPUTREVERSAL_ENABLE(__HANDLE__) ((__HANDLE__)->Instance->CR |= CRC_CR_REV_OUT) |
| Set CRC output reversal. | |
| #define | __HAL_CRC_OUTPUTREVERSAL_DISABLE(__HANDLE__) ((__HANDLE__)->Instance->CR &= ~(CRC_CR_REV_OUT)) |
| Unset CRC output reversal. | |
| #define | __HAL_CRC_POLYNOMIAL_CONFIG(__HANDLE__, __POLYNOMIAL__) ((__HANDLE__)->Instance->POL = (__POLYNOMIAL__)) |
| Set CRC non-default polynomial. | |
| #define | IS_CRC_INPUTDATA_INVERSION_MODE(MODE) |
| #define | IS_CRC_OUTPUTDATA_INVERSION_MODE(MODE) |
| HAL_StatusTypeDef | HAL_CRCEx_Polynomial_Set (CRC_HandleTypeDef *hcrc, uint32_t Pol, uint32_t PolyLength) |
| HAL_StatusTypeDef | HAL_CRCEx_Input_Data_Reverse (CRC_HandleTypeDef *hcrc, uint32_t InputReverseMode) |
| HAL_StatusTypeDef | HAL_CRCEx_Output_Data_Reverse (CRC_HandleTypeDef *hcrc, uint32_t OutputReverseMode) |
