RTEMS 6.2-rc3
COMP HAL module driver. This file provides firmware functions to manage the following functionalities of the COMP peripheral: More...
#include "stm32h7xx_hal.h"COMP HAL module driver. This file provides firmware functions to manage the following functionalities of the COMP peripheral:
##### COMP Peripheral features #####
The STM32H7xx device family integrates two analog comparators instances
COMP1 and COMP2:
(#) The COMP input minus (inverting input) and input plus (non inverting input)
can be set to internal references or to GPIO pins
(refer to GPIO list in reference manual).
(#) The COMP output level is available using HAL_COMP_GetOutputLevel()
and can be redirected to other peripherals: GPIO pins (in mode
alternate functions for comparator), timers.
(#) Pairs of comparators instances can be combined in window mode
(2 consecutive instances odd and even COMP<x> and COMP<x+1>).
(#) The comparators have interrupt capability through the EXTI controller
with wake-up from sleep and stop modes:
(++) COMP1 is internally connected to EXTI Line 20
(++) COMP2 is internally connected to EXTI Line 21
From the corresponding IRQ handler, the right interrupt source can be retrieved
using macro __HAL_COMP_COMP1_EXTI_GET_FLAG() and __HAL_COMP_COMP2_EXTI_GET_FLAG().
##### How to use this driver #####
This driver provides functions to configure and program the comparator instances of
STM32H7xx devices.
To use the comparator, perform the following steps:
(#) Initialize the COMP low level resources by implementing the HAL_COMP_MspInit():
(++) Configure the GPIO connected to comparator inputs plus and minus in analog mode
using HAL_GPIO_Init().
(++) If needed, configure the GPIO connected to comparator output in alternate function mode
(++) If required enable the COMP interrupt by configuring and enabling EXTI line in Interrupt mode and
selecting the desired sensitivity level using HAL_GPIO_Init() function. After that enable the comparator
interrupt vector using HAL_NVIC_EnableIRQ() function.
(#) Configure the comparator using HAL_COMP_Init() function:
(++) Select the input minus (inverting input)
(++) Select the input plus (non-inverting input)
(++) Select the hysteresis
(++) Select the blanking source
(++) Select the output polarity
(++) Select the power mode
(++) Select the window mode
-@@- HAL_COMP_Init() calls internally __HAL_RCC_SYSCFG_CLK_ENABLE()
to enable internal control clock of the comparators.
However, this is a legacy strategy.
Therefore, for compatibility anticipation, it is recommended to
implement __HAL_RCC_SYSCFG_CLK_ENABLE() in "HAL_COMP_MspInit()".
In STM32H7,COMP clock enable __HAL_RCC_COMP12_CLK_ENABLE() must
be implemented by user in "HAL_COMP_MspInit()".
(#) Reconfiguration on-the-fly of comparator can be done by calling again
function HAL_COMP_Init() with new input structure parameters values.
(#) Enable the comparator using HAL_COMP_Start() or HAL_COMP_Start_IT()to be enabled
with the interrupt through NVIC of the CPU.
Note: HAL_COMP_Start_IT() must be called after each interrupt otherwise the interrupt
mode will stay disabled.
(#) Use HAL_COMP_GetOutputLevel() or HAL_COMP_TriggerCallback()
functions to manage comparator outputs(output level or events)
(#) Disable the comparator using HAL_COMP_Stop() or HAL_COMP_Stop_IT()
to disable the interrupt too.
(#) De-initialize the comparator using HAL_COMP_DeInit() function.
(#) For safety purpose, comparator configuration can be locked using HAL_COMP_Lock() function.
The only way to unlock the comparator is a device hardware reset.
*** Callback registration ***
The compilation flag USE_HAL_COMP_REGISTER_CALLBACKS, when set to 1,
allows the user to configure dynamically the driver callbacks.
Use Functions HAL_COMP_RegisterCallback()
to register an interrupt callback.
Function HAL_COMP_RegisterCallback() allows to register following callbacks:
(+) TriggerCallback : callback for COMP trigger.
(+) MspInitCallback : callback for Msp Init.
(+) MspDeInitCallback : callback for Msp DeInit.
This function takes as parameters the HAL peripheral handle, the Callback ID
and a pointer to the user callback function.
Use function HAL_COMP_UnRegisterCallback to reset a callback to the default
weak function.
HAL_COMP_UnRegisterCallback takes as parameters the HAL peripheral handle,
and the Callback ID.
This function allows to reset following callbacks:
By default, after the HAL_COMP_Init() and when the state is HAL_COMP_STATE_RESET
all callbacks are set to the corresponding weak functions:
example HAL_COMP_TriggerCallback().
Exception done for MspInit and MspDeInit functions that are
reset to the legacy weak functions in the HAL_COMP_Init()/ HAL_COMP_DeInit() only when
these callbacks are null (not registered beforehand).
If MspInit or MspDeInit are not null, the HAL_COMP_Init()/ HAL_COMP_DeInit()
keep and use the user MspInit/MspDeInit callbacks (registered beforehand) whatever the state.
Callbacks can be registered/unregistered in HAL_COMP_STATE_READY state only.
Exception done MspInit/MspDeInit functions that can be registered/unregistered
in HAL_COMP_STATE_READY or HAL_COMP_STATE_RESET state,
thus registered (user) MspInit/DeInit callbacks can be used during the Init/DeInit.
Then, the user first registers the MspInit/MspDeInit user callbacks
using HAL_COMP_RegisterCallback() before calling HAL_COMP_DeInit()
or HAL_COMP_Init() function.
When the compilation flag USE_HAL_COMP_REGISTER_CALLBACKS is set to 0 or
not defined, the callback registration feature is not available and all callbacks
are set to the corresponding weak functions.Table 1. COMP inputs and output for STM32H7xx devices +------------------------------------------------------—+
| COMP1 | COMP2 | ||
| IO1 | PB0 | PE9 | |
| Input plus | IO2 | PB2 | PE11 |
|-------------—|-------------—|--------------------—| | | 1/4 VrefInt | Available | Available | | | 1/2 VrefInt | Available | Available | | | 3/4 VrefInt | Available | Available | | Input minus | VrefInt | Available | Available | | | DAC1 channel 1 | Available | Available | | | DAC1 channel 2 | Available | Available | | | IO1 | PB1 | PE10 |
| IO2 | PC4 | PE7 | |
+------------------------------------------------------—+ | Output | | PC5 (1) | PE8 (1) | | | | PE12 (1) | PE13 (1) | | | | TIM (2) | TIM (2) | +------------------------------------------------------—+ (1) GPIO must be set to alternate function for comparator (2) Comparators output to timers is set in timers instances.
