RTEMS 6.2-rc3
This header file provides the Object Services API. More...
#include <stdbool.h>#include <stddef.h>#include <stdint.h>#include <rtems/rtems/status.h>#include <rtems/rtems/types.h>#include <rtems/score/object.h>Go to the source code of this file.
| struct | rtems_object_api_class_information |
| This structure is used to return information to the application about the objects configured for a specific API/Class combination. More... | |
| #define | RTEMS_OBJECT_ID_FINAL OBJECTS_ID_FINAL |
| This constant represents the highest object identifier value. | |
| #define | RTEMS_OBJECT_ID_FINAL_INDEX OBJECTS_ID_FINAL_INDEX |
| This constant represents the highest value for the index component of an object identifier. | |
| #define | RTEMS_OBJECT_ID_INITIAL(_api, _class, _node) OBJECTS_ID_INITIAL( _api, _class, _node ) |
| Builds the object identifier with the lowest index from the API, class, and MPCI node components. | |
| #define | RTEMS_OBJECT_ID_INITIAL_INDEX OBJECTS_ID_INITIAL_INDEX |
| This constant represents the lowest value for the index component of an object identifier. | |
| #define | RTEMS_SEARCH_ALL_NODES OBJECTS_SEARCH_ALL_NODES |
| This constant indicates that an object name to identifier search should search through all MPCI nodes of the system. | |
| #define | RTEMS_SEARCH_LOCAL_NODE OBJECTS_SEARCH_LOCAL_NODE |
| This constant indicates that an object name to identifier search should search only the local MPCI node of the system. | |
| #define | RTEMS_SEARCH_OTHER_NODES OBJECTS_SEARCH_OTHER_NODES |
| This constant indicates that an object name to identifier search should search through all MPCI nodes of the system except the local node. | |
| #define | RTEMS_WHO_AM_I OBJECTS_WHO_AM_I |
| This constant indicates that an object name to identifier search is being asked for the identifier of the currently executing task. | |
| #define | rtems_build_id(_api, _class, _node, _index) _Objects_Build_id( _api, _class, _node, _index ) |
| #define | rtems_build_name(_c1, _c2, _c3, _c4) _Objects_Build_name( _c1, _c2, _c3, _c4 ) |
| #define | rtems_object_id_get_api(_id) _Objects_Get_API( _id ) |
| #define | rtems_object_id_get_class(_id) _Objects_Get_class( _id ) |
| #define | rtems_object_id_get_node(_id) _Objects_Get_node( _id ) |
| #define | rtems_object_id_get_index(_id) _Objects_Get_index( _id ) |
| #define | rtems_object_id_api_minimum(void) OBJECTS_INTERNAL_API |
| Gets the lowest valid value for the API component of an object identifier. | |
| #define | rtems_object_id_api_maximum(void) OBJECTS_APIS_LAST |
| Gets the highest valid value for the API component of an object identifier. | |
| rtems_id | rtems_build_id (uint32_t api, uint32_t the_class, uint32_t node, uint32_t index) |
| Builds the object identifier from the API, class, MPCI node, and index components. | |
| rtems_name | rtems_build_name (char c1, char c2, char c3, char c4) |
| Builds the object name composed of the four characters. | |
| rtems_status_code | rtems_object_get_classic_name (rtems_id id, rtems_name *name) |
| Gets the object name associated with the object identifier. | |
| char * | rtems_object_get_name (rtems_id id, size_t length, char *name) |
| Gets the object name associated with the object identifier as a string. | |
| rtems_status_code | rtems_object_set_name (rtems_id id, const char *name) |
| Sets the object name of the object associated with the object identifier. | |
| int | rtems_object_id_get_api (rtems_id id) |
| Gets the API component of the object identifier. | |
| int | rtems_object_id_get_class (rtems_id id) |
| Gets the class component of the object identifier. | |
| int | rtems_object_id_get_node (rtems_id id) |
| Gets the MPCI node component of the object identifier. | |
| int | rtems_object_id_get_index (rtems_id id) |
| Gets the index component of the object identifier. | |
| int | rtems_object_api_minimum_class (int api) |
| Gets the lowest valid class value of the object API. | |
| int | rtems_object_api_maximum_class (int api) |
| Gets the highest valid class value of the object API. | |
| const char * | rtems_object_get_api_name (int api) |
| Gets a descriptive name of the object API. | |
| const char * | rtems_object_get_api_class_name (int the_api, int the_class) |
| Gets a descriptive name of the object class of the object API. | |
| rtems_status_code | rtems_object_get_class_information (int the_api, int the_class, rtems_object_api_class_information *info) |
| Gets the object class information of the object class of the object API. | |
