RTEMS 6.2-rc3
This header file defines the Region Manager API. More...
#include <stdint.h>#include <rtems/rtems/attr.h>#include <rtems/rtems/options.h>#include <rtems/rtems/status.h>#include <rtems/rtems/types.h>#include <rtems/score/heapinfo.h>Go to the source code of this file.
| rtems_status_code | rtems_region_get_segment_size (rtems_id id, void *segment, uintptr_t *size) |
| Gets the size of the region segment. | |
| rtems_status_code | rtems_region_create (rtems_name name, void *starting_address, uintptr_t length, uintptr_t page_size, rtems_attribute attribute_set, rtems_id *id) |
| Creates a region. | |
| rtems_status_code | rtems_region_ident (rtems_name name, rtems_id *id) |
| Identifies a region by the object name. | |
| rtems_status_code | rtems_region_delete (rtems_id id) |
| Deletes the region. | |
| rtems_status_code | rtems_region_extend (rtems_id id, void *starting_address, uintptr_t length) |
| Extends the region. | |
| rtems_status_code | rtems_region_get_segment (rtems_id id, uintptr_t size, rtems_option option_set, rtems_interval timeout, void **segment) |
| Gets a segment from the region. | |
| rtems_status_code | rtems_region_return_segment (rtems_id id, void *segment) |
| Returns the segment to the region. | |
| rtems_status_code | rtems_region_resize_segment (rtems_id id, void *segment, uintptr_t size, uintptr_t *old_size) |
| Changes the size of the segment. | |
| rtems_status_code | rtems_region_get_information (rtems_id id, Heap_Information_block *the_info) |
| Gets the region information. | |
| rtems_status_code | rtems_region_get_free_information (rtems_id id, Heap_Information_block *the_info) |
| Gets the region free information. | |
