RTEMS 6.2-rc3
This test suite for SMP-only test cases provides enough resources to run basic tests for all specified managers and functions. More...
Modules | |
| spec:/acfg/val/scheduler-edf-smp | |
| Tests the effect of application configuration options. | |
| spec:/rtems/intr/val/intr-smp-only | |
| Tests some Interrupt Manager directives. | |
| spec:/rtems/scheduler/val/smp-only | |
| This test case collection provides validation test cases for SMP-only requirements of the Scheduler Manager. | |
| spec:/rtems/sem/req/mrsp-obtain | |
| spec:/rtems/sem/val/smp | |
| Tests SMP-specific semaphore behaviour. | |
| spec:/rtems/task/val/smp | |
| This test case collection provides SMP-specific validation test cases for requirements of the Task Manager. | |
| spec:/score/sched/smp/edf/req/set-affinity | |
| spec:/score/sched/smp/edf/val/edf | |
| Tests for operations of the EDF SMP scheduler. | |
| spec:/score/sched/smp/val/smp | |
| Tests SMP-specific scheduler behaviour. | |
| spec:/score/smp/val/per-cpu-jobs | |
| Tests the processing order of per-processor jobs. | |
| spec:/score/thread/val/smp | |
| Tests SMP-specific thread behaviour. | |
| spec:/score/tq/val/smp | |
| Tests SMP-specific thread queue behaviour. | |
Files | |
| file | ts-validation-smp-only-0.c |
| #define | CONFIGURE_MAXIMUM_PROCESSORS 5 |
| const char | rtems_test_name [] = "TestsuitesValidationSmpOnly0" |
| Each test must define a test name string. | |
Up to three scheduler instances using the SMP EDF scheduler are provided using up to four processors.
