RTEMS 6.2-rc3
This group contains the L4STAT interfaces. More...
Modules | |
| Counter 0-15 control register (CCTRL) | |
| This group contains register bit definitions. | |
| Counter 0-15 max/latch register (CSVAL) | |
| Counter 0-15 value register (CVAL) | |
| Timestamp register (TSTAMP) | |
Files | |
| file | l4stat-regs.h |
| This header file defines the L4STAT register block interface. | |
| struct | l4stat |
| This structure defines the L4STAT register block memory map. More... | |
Typedefs | |
| typedef struct l4stat | l4stat |
| This structure defines the L4STAT register block memory map. | |
