RTEMS 6.2-rc3
This header file documents the application configuration options. More...
| #define | CONFIGURE_APPLICATION_NEEDS_LIBBLOCK |
| This configuration option is a boolean feature define. | |
| #define | CONFIGURE_BDBUF_BUFFER_MAX_SIZE |
| This configuration option is an integer define. | |
| #define | CONFIGURE_BDBUF_BUFFER_MIN_SIZE |
| #define | CONFIGURE_BDBUF_CACHE_MEMORY_SIZE |
| #define | CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS |
| #define | CONFIGURE_BDBUF_MAX_WRITE_BLOCKS |
| #define | CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY |
| #define | CONFIGURE_BDBUF_TASK_STACK_SIZE |
| #define | CONFIGURE_SWAPOUT_BLOCK_HOLD |
| #define | CONFIGURE_SWAPOUT_SWAP_PERIOD |
| #define | CONFIGURE_SWAPOUT_TASK_PRIORITY |
| #define | CONFIGURE_SWAPOUT_WORKER_TASKS |
| #define | CONFIGURE_SWAPOUT_WORKER_TASK_PRIORITY |
| #define | CONFIGURE_MAXIMUM_BARRIERS |
| #define | CONFIGURE_MAXIMUM_MESSAGE_QUEUES |
| #define | CONFIGURE_MAXIMUM_PARTITIONS |
| #define | CONFIGURE_MAXIMUM_PERIODS |
| #define | CONFIGURE_MAXIMUM_PORTS |
| #define | CONFIGURE_MAXIMUM_REGIONS |
| #define | CONFIGURE_MAXIMUM_SEMAPHORES |
| #define | CONFIGURE_MAXIMUM_TASKS |
| #define | CONFIGURE_MAXIMUM_TIMERS |
| #define | CONFIGURE_MAXIMUM_USER_EXTENSIONS |
| #define | CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE |
| #define | CONFIGURE_INIT_TASK_ARGUMENTS |
| #define | CONFIGURE_INIT_TASK_ATTRIBUTES |
| #define | CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE |
| #define | CONFIGURE_INIT_TASK_ENTRY_POINT |
| This configuration option is an initializer define. | |
| #define | CONFIGURE_INIT_TASK_INITIAL_MODES |
| #define | CONFIGURE_INIT_TASK_NAME |
| #define | CONFIGURE_INIT_TASK_PRIORITY |
| #define | CONFIGURE_INIT_TASK_STACK_SIZE |
| #define | CONFIGURE_RTEMS_INIT_TASKS_TABLE |
| #define | CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER |
| #define | CONFIGURE_APPLICATION_EXTRA_DRIVERS |
| #define | CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER |
| #define | CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER |
| #define | CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER |
| #define | CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER |
| #define | CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER |
| #define | CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER |
| #define | CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER |
| #define | CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER |
| #define | CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER |
| #define | CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER |
| #define | CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER |
| #define | CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER |
| #define | CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER |
| #define | CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS |
| #define | CONFIGURE_ATA_DRIVER_TASK_PRIORITY |
| #define | CONFIGURE_EXCEPTION_TO_SIGNAL_MAPPING |
| #define | CONFIGURE_MAXIMUM_DRIVERS |
| #define | CONFIGURE_RECORD_EXTENSIONS_ENABLED |
| #define | CONFIGURE_RECORD_FATAL_DUMP_BASE64 |
| #define | CONFIGURE_RECORD_FATAL_DUMP_BASE64_ZLIB |
| #define | CONFIGURE_RECORD_INTERRUPTS_ENABLED |
| #define | CONFIGURE_RECORD_PER_PROCESSOR_ITEMS |
| #define | CONFIGURE_POSIX_TIMERS_FACE_BEHAVIOR |
| #define | CONFIGURE_APPLICATION_DISABLE_FILESYSTEM |
| #define | CONFIGURE_FILESYSTEM_ALL |
| #define | CONFIGURE_FILESYSTEM_DOSFS |
| #define | CONFIGURE_FILESYSTEM_FTPFS |
| #define | CONFIGURE_FILESYSTEM_IMFS |
| #define | CONFIGURE_FILESYSTEM_JFFS2 |
| #define | CONFIGURE_FILESYSTEM_NFS |
| #define | CONFIGURE_FILESYSTEM_RFS |
| #define | CONFIGURE_FILESYSTEM_TFTPFS |
| #define | CONFIGURE_IMFS_DISABLE_CHMOD |
| #define | CONFIGURE_IMFS_DISABLE_CHOWN |
| #define | CONFIGURE_IMFS_DISABLE_LINK |
| #define | CONFIGURE_IMFS_DISABLE_MKNOD |
| #define | CONFIGURE_IMFS_DISABLE_MKNOD_DEVICE |
| #define | CONFIGURE_IMFS_DISABLE_MKNOD_FILE |
| #define | CONFIGURE_IMFS_DISABLE_MOUNT |
| #define | CONFIGURE_IMFS_DISABLE_READDIR |
| #define | CONFIGURE_IMFS_DISABLE_READLINK |
| #define | CONFIGURE_IMFS_DISABLE_RENAME |
| #define | CONFIGURE_IMFS_DISABLE_RMNOD |
| #define | CONFIGURE_IMFS_DISABLE_SYMLINK |
| #define | CONFIGURE_IMFS_DISABLE_UNMOUNT |
| #define | CONFIGURE_IMFS_DISABLE_UTIME |
| #define | CONFIGURE_IMFS_ENABLE_MKFIFO |
| #define | CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK |
| #define | CONFIGURE_JFFS2_DELAYED_WRITE_TASK_PRIORITY |
| #define | CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM |
| #define | CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM |
| #define | CONFIGURE_DIRTY_MEMORY |
| #define | CONFIGURE_DISABLE_BSP_SETTINGS |
| #define | CONFIGURE_DISABLE_NEWLIB_REENTRANCY |
| #define | CONFIGURE_EXECUTIVE_RAM_SIZE |
| #define | CONFIGURE_EXTRA_TASK_STACKS |
| #define | CONFIGURE_INIT |
| #define | CONFIGURE_INITIAL_EXTENSIONS |
| #define | CONFIGURE_INTERRUPT_STACK_SIZE |
| #define | CONFIGURE_MALLOC_DIRTY |
| #define | CONFIGURE_MAXIMUM_FILE_DESCRIPTORS |
| #define | CONFIGURE_MAXIMUM_PROCESSORS |
| #define | CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE |
| #define | CONFIGURE_MAXIMUM_THREAD_NAME_SIZE |
| #define | CONFIGURE_MEMORY_OVERHEAD |
| #define | CONFIGURE_MESSAGE_BUFFER_MEMORY |
| #define | CONFIGURE_MICROSECONDS_PER_TICK |
| #define | CONFIGURE_MINIMUM_TASK_STACK_SIZE |
| #define | CONFIGURE_STACK_CHECKER_ENABLED |
| #define | CONFIGURE_TICKS_PER_TIMESLICE |
| #define | CONFIGURE_UNIFIED_WORK_AREAS |
| #define | CONFIGURE_UNLIMITED_ALLOCATION_SIZE |
| #define | CONFIGURE_UNLIMITED_OBJECTS |
| #define | CONFIGURE_VERBOSE_SYSTEM_INITIALIZATION |
| #define | CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY |
| #define | CONFIGURE_IDLE_TASK_BODY |
| #define | CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION |
| #define | CONFIGURE_IDLE_TASK_STACK_SIZE |
| #define | CONFIGURE_IDLE_TASK_STORAGE_SIZE |
| #define | CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK |
| #define | CONFIGURE_MP_APPLICATION |
| #define | CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS |
| #define | CONFIGURE_MP_MAXIMUM_NODES |
| #define | CONFIGURE_MP_MAXIMUM_PROXIES |
| #define | CONFIGURE_MP_MPCI_TABLE_POINTER |
| #define | CONFIGURE_MP_NODE_NUMBER |
| #define | CONFIGURE_MAXIMUM_POSIX_KEYS |
| #define | CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS |
| #define | CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES |
| #define | CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS |
| #define | CONFIGURE_MAXIMUM_POSIX_SEMAPHORES |
| #define | CONFIGURE_MAXIMUM_POSIX_SHMS |
| #define | CONFIGURE_MAXIMUM_POSIX_THREADS |
| #define | CONFIGURE_MAXIMUM_POSIX_TIMERS |
| #define | CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE |
| #define | CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT |
| #define | CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE |
| #define | CONFIGURE_POSIX_INIT_THREAD_TABLE |
| #define | CONFIGURE_CBS_MAXIMUM_SERVERS |
| #define | CONFIGURE_MAXIMUM_PRIORITY |
| #define | CONFIGURE_SCHEDULER_ASSIGNMENTS |
| #define | CONFIGURE_SCHEDULER_CBS |
| #define | CONFIGURE_SCHEDULER_EDF |
| #define | CONFIGURE_SCHEDULER_EDF_SMP |
| #define | CONFIGURE_SCHEDULER_NAME |
| #define | CONFIGURE_SCHEDULER_PRIORITY |
| #define | CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP |
| #define | CONFIGURE_SCHEDULER_PRIORITY_SMP |
| #define | CONFIGURE_SCHEDULER_SIMPLE |
| #define | CONFIGURE_SCHEDULER_SIMPLE_SMP |
| #define | CONFIGURE_SCHEDULER_STRONG_APA |
| #define | CONFIGURE_SCHEDULER_TABLE_ENTRIES |
| #define | CONFIGURE_SCHEDULER_USER |
| #define | CONFIGURE_TASK_STACK_ALLOCATOR |
| #define | CONFIGURE_TASK_STACK_ALLOCATOR_AVOIDS_WORK_SPACE |
| #define | CONFIGURE_TASK_STACK_ALLOCATOR_FOR_IDLE |
| #define | CONFIGURE_TASK_STACK_ALLOCATOR_INIT |
| #define | CONFIGURE_TASK_STACK_DEALLOCATOR |
| #define | CONFIGURE_TASK_STACK_FROM_ALLOCATOR |
