RTEMS 6.2-rc2
#include <rtems.h>#include <rtems/bspIo.h>#include <rtems/test-info.h>#include <rtems/test.h>#include <rtems/testopts.h>#include <rtems/score/smpimpl.h>#include "ts-config.h"#include "tx-support.h"#include <rtems/confdefs.h>Macros | |
| #define | CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER |
| #define | CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 0 |
| #define | CONFIGURE_MAXIMUM_USER_EXTENSIONS 1 |
| #define | CONFIGURE_DISABLE_NEWLIB_REENTRANCY |
| #define | CONFIGURE_APPLICATION_DISABLE_FILESYSTEM |
| #define | CONFIGURE_IDLE_TASK_STORAGE_SIZE RTEMS_MINIMUM_STACK_SIZE |
| #define | CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION |
| #define | CONFIGURE_IDLE_TASK_BODY ShutdownIdleBody |
| #define | CONFIGURE_INITIAL_EXTENSIONS { .fatal = FatalInitialExtension } |
| #define | CONFIGURE_INIT |
| void | __real_bsp_reset (rtems_fatal_source source, rtems_fatal_code code) |
| void | __wrap_bsp_reset (rtems_fatal_source source, rtems_fatal_code code) |
| void * | __real__CPU_Thread_Idle_body (void *arg) |
| void * | __wrap__CPU_Thread_Idle_body (void *arg) |
| const char | rtems_test_name [] = "TestsuitesBspsFatalExtension" |
| Each test must define a test name string. | |
