RTEMS 6.2-rc2
Extended UART HAL module driver. This file provides firmware functions to manage the following extended functionalities of the Universal Asynchronous Receiver Transmitter Peripheral (UART). More...
#include "stm32h7xx_hal.h"Extended UART HAL module driver. This file provides firmware functions to manage the following extended functionalities of the Universal Asynchronous Receiver Transmitter Peripheral (UART).
##### UART peripheral extended features #####
(#) Declare a UART_HandleTypeDef handle structure.
(#) For the UART RS485 Driver Enable mode, initialize the UART registers
by calling the HAL_RS485Ex_Init() API.
(#) FIFO mode enabling/disabling and RX/TX FIFO threshold programming.
-@- When UART operates in FIFO mode, FIFO mode must be enabled prior
starting RX/TX transfers. Also RX/TX FIFO thresholds must be
configured prior starting RX/TX transfers.
