RTEMS 6.2-rc2
This file provides firmware functions to manage the following functionalities of the SPDIFRX audio interface: More...
#include "stm32h7xx_hal.h"This file provides firmware functions to manage the following functionalities of the SPDIFRX audio interface:
##### How to use this driver #####
The SPDIFRX HAL driver can be used as follow:
(#) Declare SPDIFRX_HandleTypeDef handle structure.
(#) Initialize the SPDIFRX low level resources by implement the HAL_SPDIFRX_MspInit() API:
(##) Enable the SPDIFRX interface clock.
(##) SPDIFRX pins configuration:
(+++) Enable the clock for the SPDIFRX GPIOs.
(+++) Configure these SPDIFRX pins as alternate function pull-up.
(##) NVIC configuration if you need to use interrupt process (HAL_SPDIFRX_ReceiveCtrlFlow_IT() and
HAL_SPDIFRX_ReceiveDataFlow_IT() API's).
(+++) Configure the SPDIFRX interrupt priority.
(+++) Enable the NVIC SPDIFRX IRQ handle.
(##) DMA Configuration if you need to use DMA process (HAL_SPDIFRX_ReceiveDataFlow_DMA() and
HAL_SPDIFRX_ReceiveCtrlFlow_DMA() API's).
(+++) Declare a DMA handle structure for the reception of the Data Flow channel.
(+++) Declare a DMA handle structure for the reception of the Control Flow channel.
(+++) Enable the DMAx interface clock.
(+++) Configure the declared DMA handle structure CtrlRx/DataRx with the required parameters.
(+++) Configure the DMA Channel.
(+++) Associate the initialized DMA handle to the SPDIFRX DMA CtrlRx/DataRx handle.
(+++) Configure the priority and enable the NVIC for the transfer complete interrupt on the
DMA CtrlRx/DataRx channel.
(#) Program the input selection, re-tries number, wait for activity, channel status selection, data format,
stereo mode and masking of user bits using HAL_SPDIFRX_Init() function.
-@- The specific SPDIFRX interrupts (RXNE/CSRNE and Error Interrupts) will be managed using the macros
__SPDIFRX_ENABLE_IT() and __SPDIFRX_DISABLE_IT() inside the receive process.
-@- Make sure that ck_spdif clock is configured.
(#) Three operation modes are available within this driver :
*** Polling mode for reception operation (for debug purpose) ***
(+) Receive data flow in blocking mode using HAL_SPDIFRX_ReceiveDataFlow()
(+) Receive control flow of data in blocking mode using HAL_SPDIFRX_ReceiveCtrlFlow()
*** Interrupt mode for reception operation ***
(+) Receive an amount of data (Data Flow) in non blocking mode using HAL_SPDIFRX_ReceiveDataFlow_IT()
(+) Receive an amount of data (Control Flow) in non blocking mode using HAL_SPDIFRX_ReceiveCtrlFlow_IT()
(+) At reception end of half transfer HAL_SPDIFRX_RxHalfCpltCallback is executed and user can
add his own code by customization of function pointer HAL_SPDIFRX_RxHalfCpltCallback
(+) At reception end of transfer HAL_SPDIFRX_RxCpltCallback is executed and user can
add his own code by customization of function pointer HAL_SPDIFRX_RxCpltCallback
(+) In case of transfer Error, HAL_SPDIFRX_ErrorCallback() function is executed and user can
add his own code by customization of function pointer HAL_SPDIFRX_ErrorCallback
*** DMA mode for reception operation ***
(+) Receive an amount of data (Data Flow) in non blocking mode (DMA) using HAL_SPDIFRX_ReceiveDataFlow_DMA()
(+) Receive an amount of data (Control Flow) in non blocking mode (DMA) using HAL_SPDIFRX_ReceiveCtrlFlow_DMA()
(+) Stop the DMA Transfer using HAL_SPDIFRX_DMAStop()
*** SPDIFRX HAL driver macros list ***
Below the list of most used macros in SPDIFRX HAL driver.
(+) __HAL_SPDIFRX_IDLE: Disable the specified SPDIFRX peripheral (IDLE State)
(+) __HAL_SPDIFRX_SYNC: Enable the synchronization state of the specified SPDIFRX peripheral (SYNC State)
(+) __HAL_SPDIFRX_RCV: Enable the receive state of the specified SPDIFRX peripheral (RCV State)
(+) __HAL_SPDIFRX_ENABLE_IT : Enable the specified SPDIFRX interrupts
(+) __HAL_SPDIFRX_DISABLE_IT : Disable the specified SPDIFRX interrupts
(+) __HAL_SPDIFRX_GET_FLAG: Check whether the specified SPDIFRX flag is set or not.
(@) You can refer to the SPDIFRX HAL driver header file for more useful macros
*** Callback registration ***
The compilation define USE_HAL_SPDIFRX_REGISTER_CALLBACKS when set to 1
allows the user to configure dynamically the driver callbacks.
Use HAL_SPDIFRX_RegisterCallback() function to register an interrupt callback.
The HAL_SPDIFRX_RegisterCallback() function allows to register the following callbacks:
(+) RxHalfCpltCallback : SPDIFRX Data flow half completed callback.
(+) RxCpltCallback : SPDIFRX Data flow completed callback.
(+) CxHalfCpltCallback : SPDIFRX Control flow half completed callback.
(+) CxCpltCallback : SPDIFRX Control flow completed callback.
(+) ErrorCallback : SPDIFRX error callback.
(+) MspInitCallback : SPDIFRX MspInit.
(+) MspDeInitCallback : SPDIFRX MspDeInit.
This function takes as parameters the HAL peripheral handle, the Callback ID
and a pointer to the user callback function.
Use HAL_SPDIFRX_UnRegisterCallback() function to reset a callback to the default
weak function.
The HAL_SPDIFRX_UnRegisterCallback() function takes as parameters the HAL peripheral handle,
and the Callback ID.
This function allows to reset the following callbacks:
By default, after the HAL_SPDIFRX_Init() and when the state is HAL_SPDIFRX_STATE_RESET
all callbacks are set to the corresponding weak functions :
HAL_SPDIFRX_RxHalfCpltCallback() , HAL_SPDIFRX_RxCpltCallback(), HAL_SPDIFRX_CxHalfCpltCallback(),
HAL_SPDIFRX_CxCpltCallback() and HAL_SPDIFRX_ErrorCallback()
Exception done for MspInit and MspDeInit functions that are
reset to the legacy weak function in the HAL_SPDIFRX_Init()/ HAL_SPDIFRX_DeInit() only when
these callbacks pointers are NULL (not registered beforehand).
If not, MspInit or MspDeInit callbacks pointers are not null, the HAL_SPDIFRX_Init() / HAL_SPDIFRX_DeInit()
keep and use the user MspInit/MspDeInit functions (registered beforehand)
Callbacks can be registered/unregistered in HAL_SPDIFRX_STATE_READY state only.
Exception done MspInit/MspDeInit callbacks that can be registered/unregistered
in HAL_SPDIFRX_STATE_READY or HAL_SPDIFRX_STATE_RESET state,
thus registered (user) MspInit/DeInit callbacks can be used during the Init/DeInit.
In that case first register the MspInit/MspDeInit user callbacks
using HAL_SPDIFRX_RegisterCallback() before calling HAL_SPDIFRX_DeInit()
or HAL_SPDIFRX_Init() function.
When The compilation define USE_HAL_SPDIFRX_REGISTER_CALLBACKS is set to 0 or
not defined, the callback registration feature is not available and all callbacks
are set to the corresponding weak functions.
