RTEMS 6.2-rc2
Header file of SMARTCARD HAL module. More...
| struct | SMARTCARD_InitTypeDef |
| SMARTCARD Init Structure definition. More... | |
| struct | SMARTCARD_AdvFeatureInitTypeDef |
| SMARTCARD advanced features initialization structure definition. More... | |
| struct | __SMARTCARD_HandleTypeDef |
| SMARTCARD handle Structure definition. More... | |
| #define | HAL_SMARTCARD_STATE_RESET 0x00000000U |
| #define | HAL_SMARTCARD_STATE_READY 0x00000020U |
| #define | HAL_SMARTCARD_STATE_BUSY 0x00000024U |
| #define | HAL_SMARTCARD_STATE_BUSY_TX 0x00000021U |
| #define | HAL_SMARTCARD_STATE_BUSY_RX 0x00000022U |
| #define | HAL_SMARTCARD_STATE_BUSY_TX_RX 0x00000023U |
| #define | HAL_SMARTCARD_STATE_TIMEOUT 0x000000A0U |
| #define | HAL_SMARTCARD_STATE_ERROR 0x000000E0U |
| #define | HAL_SMARTCARD_ERROR_NONE (0x00000000U) |
| #define | HAL_SMARTCARD_ERROR_PE (0x00000001U) |
| #define | HAL_SMARTCARD_ERROR_NE (0x00000002U) |
| #define | HAL_SMARTCARD_ERROR_FE (0x00000004U) |
| #define | HAL_SMARTCARD_ERROR_ORE (0x00000008U) |
| #define | HAL_SMARTCARD_ERROR_DMA (0x00000010U) |
| #define | HAL_SMARTCARD_ERROR_RTO (0x00000020U) |
| #define | SMARTCARD_WORDLENGTH_9B USART_CR1_M0 |
| #define | SMARTCARD_STOPBITS_0_5 USART_CR2_STOP_0 |
| #define | SMARTCARD_STOPBITS_1_5 USART_CR2_STOP |
| #define | SMARTCARD_PARITY_EVEN USART_CR1_PCE |
| #define | SMARTCARD_PARITY_ODD (USART_CR1_PCE | USART_CR1_PS) |
| #define | SMARTCARD_MODE_RX USART_CR1_RE |
| #define | SMARTCARD_MODE_TX USART_CR1_TE |
| #define | SMARTCARD_MODE_TX_RX (USART_CR1_TE |USART_CR1_RE) |
| #define | SMARTCARD_POLARITY_LOW 0x00000000U |
| #define | SMARTCARD_POLARITY_HIGH USART_CR2_CPOL |
| #define | SMARTCARD_PHASE_1EDGE 0x00000000U |
| #define | SMARTCARD_PHASE_2EDGE USART_CR2_CPHA |
| #define | SMARTCARD_LASTBIT_DISABLE 0x00000000U |
| #define | SMARTCARD_LASTBIT_ENABLE USART_CR2_LBCL |
| #define | SMARTCARD_ONE_BIT_SAMPLE_DISABLE 0x00000000U |
| #define | SMARTCARD_ONE_BIT_SAMPLE_ENABLE USART_CR3_ONEBIT |
| #define | SMARTCARD_NACK_DISABLE 0x00000000U |
| #define | SMARTCARD_NACK_ENABLE USART_CR3_NACK |
| #define | SMARTCARD_TIMEOUT_DISABLE 0x00000000U |
| #define | SMARTCARD_TIMEOUT_ENABLE USART_CR2_RTOEN |
| #define | SMARTCARD_PRESCALER_DIV1 0x00000000U |
| #define | SMARTCARD_PRESCALER_DIV2 0x00000001U |
| #define | SMARTCARD_PRESCALER_DIV4 0x00000002U |
| #define | SMARTCARD_PRESCALER_DIV6 0x00000003U |
| #define | SMARTCARD_PRESCALER_DIV8 0x00000004U |
| #define | SMARTCARD_PRESCALER_DIV10 0x00000005U |
| #define | SMARTCARD_PRESCALER_DIV12 0x00000006U |
| #define | SMARTCARD_PRESCALER_DIV16 0x00000007U |
| #define | SMARTCARD_PRESCALER_DIV32 0x00000008U |
| #define | SMARTCARD_PRESCALER_DIV64 0x00000009U |
| #define | SMARTCARD_PRESCALER_DIV128 0x0000000AU |
| #define | SMARTCARD_PRESCALER_DIV256 0x0000000BU |
| #define | SMARTCARD_ADVFEATURE_TXINV_DISABLE 0x00000000U |
| #define | SMARTCARD_ADVFEATURE_TXINV_ENABLE USART_CR2_TXINV |
| #define | SMARTCARD_ADVFEATURE_RXINV_DISABLE 0x00000000U |
| #define | SMARTCARD_ADVFEATURE_RXINV_ENABLE USART_CR2_RXINV |
| #define | SMARTCARD_ADVFEATURE_DATAINV_DISABLE 0x00000000U |
| #define | SMARTCARD_ADVFEATURE_DATAINV_ENABLE USART_CR2_DATAINV |
| #define | SMARTCARD_ADVFEATURE_SWAP_DISABLE 0x00000000U |
| #define | SMARTCARD_ADVFEATURE_SWAP_ENABLE USART_CR2_SWAP |
| #define | SMARTCARD_ADVFEATURE_OVERRUN_ENABLE 0x00000000U |
| #define | SMARTCARD_ADVFEATURE_OVERRUN_DISABLE USART_CR3_OVRDIS |
| #define | SMARTCARD_ADVFEATURE_DMA_ENABLEONRXERROR 0x00000000U |
| #define | SMARTCARD_ADVFEATURE_DMA_DISABLEONRXERROR USART_CR3_DDRE |
| #define | SMARTCARD_ADVFEATURE_MSBFIRST_DISABLE 0x00000000U |
| #define | SMARTCARD_ADVFEATURE_MSBFIRST_ENABLE USART_CR2_MSBFIRST |
| #define | SMARTCARD_RXDATA_FLUSH_REQUEST USART_RQR_RXFRQ |
| #define | SMARTCARD_TXDATA_FLUSH_REQUEST USART_RQR_TXFRQ |
| #define | SMARTCARD_IT_MASK 0x001FU |
| #define | SMARTCARD_CR_MASK 0x00E0U |
| #define | SMARTCARD_CR_POS 5U |
| #define | SMARTCARD_ISR_MASK 0x1F00U |
| #define | SMARTCARD_ISR_POS 8U |
| #define | __HAL_SMARTCARD_RESET_HANDLE_STATE(__HANDLE__) |
| Reset SMARTCARD handle states. | |
| #define | __HAL_SMARTCARD_FLUSH_DRREGISTER(__HANDLE__) |
| Flush the Smartcard Data registers. | |
| #define | __HAL_SMARTCARD_CLEAR_FLAG(__HANDLE__, __FLAG__) ((__HANDLE__)->Instance->ICR = (__FLAG__)) |
| Clear the specified SMARTCARD pending flag. | |
| #define | __HAL_SMARTCARD_CLEAR_PEFLAG(__HANDLE__) __HAL_SMARTCARD_CLEAR_FLAG((__HANDLE__), SMARTCARD_CLEAR_PEF) |
| Clear the SMARTCARD PE pending flag. | |
| #define | __HAL_SMARTCARD_CLEAR_FEFLAG(__HANDLE__) __HAL_SMARTCARD_CLEAR_FLAG((__HANDLE__), SMARTCARD_CLEAR_FEF) |
| Clear the SMARTCARD FE pending flag. | |
| #define | __HAL_SMARTCARD_CLEAR_NEFLAG(__HANDLE__) __HAL_SMARTCARD_CLEAR_FLAG((__HANDLE__), SMARTCARD_CLEAR_NEF) |
| Clear the SMARTCARD NE pending flag. | |
| #define | __HAL_SMARTCARD_CLEAR_OREFLAG(__HANDLE__) __HAL_SMARTCARD_CLEAR_FLAG((__HANDLE__), SMARTCARD_CLEAR_OREF) |
| Clear the SMARTCARD ORE pending flag. | |
| #define | __HAL_SMARTCARD_CLEAR_IDLEFLAG(__HANDLE__) __HAL_SMARTCARD_CLEAR_FLAG((__HANDLE__), SMARTCARD_CLEAR_IDLEF) |
| Clear the SMARTCARD IDLE pending flag. | |
| #define | __HAL_SMARTCARD_GET_FLAG(__HANDLE__, __FLAG__) (((__HANDLE__)->Instance->ISR & (__FLAG__)) == (__FLAG__)) |
| Check whether the specified Smartcard flag is set or not. | |
| #define | __HAL_SMARTCARD_ENABLE_IT(__HANDLE__, __INTERRUPT__) |
| Enable the specified SmartCard interrupt. | |
| #define | __HAL_SMARTCARD_DISABLE_IT(__HANDLE__, __INTERRUPT__) |
| Disable the specified SmartCard interrupt. | |
| #define | __HAL_SMARTCARD_GET_IT(__HANDLE__, __INTERRUPT__) |
| Check whether the specified SmartCard interrupt has occurred or not. | |
| #define | __HAL_SMARTCARD_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__) |
| Check whether the specified SmartCard interrupt source is enabled or not. | |
| #define | __HAL_SMARTCARD_CLEAR_IT(__HANDLE__, __IT_CLEAR__) ((__HANDLE__)->Instance->ICR |= (uint32_t)(__IT_CLEAR__)) |
| Clear the specified SMARTCARD ISR flag, in setting the proper ICR register flag. | |
| #define | __HAL_SMARTCARD_SEND_REQ(__HANDLE__, __REQ__) ((__HANDLE__)->Instance->RQR |= (uint16_t)(__REQ__)) |
| Set a specific SMARTCARD request flag. | |
| #define | __HAL_SMARTCARD_ONE_BIT_SAMPLE_ENABLE(__HANDLE__) ((__HANDLE__)->Instance->CR3|= USART_CR3_ONEBIT) |
| Enable the SMARTCARD one bit sample method. | |
| #define | __HAL_SMARTCARD_ONE_BIT_SAMPLE_DISABLE(__HANDLE__) |
| Disable the SMARTCARD one bit sample method. | |
| #define | __HAL_SMARTCARD_ENABLE(__HANDLE__) ((__HANDLE__)->Instance->CR1 |= USART_CR1_UE) |
| Enable the USART associated to the SMARTCARD Handle. | |
| #define | __HAL_SMARTCARD_DISABLE(__HANDLE__) ((__HANDLE__)->Instance->CR1 &= ~USART_CR1_UE) |
| Disable the USART associated to the SMARTCARD Handle. | |
| #define | SMARTCARD_GETCLOCKSOURCE(__HANDLE__, __CLOCKSOURCE__) |
| Report the SMARTCARD clock source. | |
| #define | IS_SMARTCARD_BAUDRATE(__BAUDRATE__) ((__BAUDRATE__) < 6250001U) |
| Check the Baud rate range. | |
| #define | IS_SMARTCARD_BLOCKLENGTH(__LENGTH__) ((__LENGTH__) <= 0xFFU) |
| Check the block length range. | |
| #define | IS_SMARTCARD_TIMEOUT_VALUE(__TIMEOUTVALUE__) ((__TIMEOUTVALUE__) <= 0xFFFFFFU) |
| Check the receiver timeout value. | |
| #define | IS_SMARTCARD_AUTORETRY_COUNT(__COUNT__) ((__COUNT__) <= 0x7U) |
| Check the SMARTCARD autoretry counter value. | |
| #define | IS_SMARTCARD_WORD_LENGTH(__LENGTH__) ((__LENGTH__) == SMARTCARD_WORDLENGTH_9B) |
| Ensure that SMARTCARD frame length is valid. | |
| #define | IS_SMARTCARD_STOPBITS(__STOPBITS__) |
| Ensure that SMARTCARD frame number of stop bits is valid. | |
| #define | IS_SMARTCARD_PARITY(__PARITY__) |
| Ensure that SMARTCARD frame parity is valid. | |
| #define | IS_SMARTCARD_MODE(__MODE__) ((((__MODE__) & 0xFFF3U) == 0x00U) && ((__MODE__) != 0x00U)) |
| Ensure that SMARTCARD communication mode is valid. | |
| #define | IS_SMARTCARD_POLARITY(__CPOL__) |
| Ensure that SMARTCARD frame polarity is valid. | |
| #define | IS_SMARTCARD_PHASE(__CPHA__) (((__CPHA__) == SMARTCARD_PHASE_1EDGE) || ((__CPHA__) == SMARTCARD_PHASE_2EDGE)) |
| Ensure that SMARTCARD frame phase is valid. | |
| #define | IS_SMARTCARD_LASTBIT(__LASTBIT__) |
| Ensure that SMARTCARD frame last bit clock pulse setting is valid. | |
| #define | IS_SMARTCARD_ONE_BIT_SAMPLE(__ONEBIT__) |
| Ensure that SMARTCARD frame sampling is valid. | |
| #define | IS_SMARTCARD_NACK(__NACK__) |
| Ensure that SMARTCARD NACK transmission setting is valid. | |
| #define | IS_SMARTCARD_TIMEOUT(__TIMEOUT__) |
| Ensure that SMARTCARD receiver timeout setting is valid. | |
| #define | IS_SMARTCARD_CLOCKPRESCALER(__CLOCKPRESCALER__) |
| Ensure that SMARTCARD clock Prescaler is valid. | |
| #define | IS_SMARTCARD_ADVFEATURE_INIT(__INIT__) |
| Ensure that SMARTCARD advanced features initialization is valid. | |
| #define | IS_SMARTCARD_ADVFEATURE_TXINV(__TXINV__) |
| Ensure that SMARTCARD frame TX inversion setting is valid. | |
| #define | IS_SMARTCARD_ADVFEATURE_RXINV(__RXINV__) |
| Ensure that SMARTCARD frame RX inversion setting is valid. | |
| #define | IS_SMARTCARD_ADVFEATURE_DATAINV(__DATAINV__) |
| Ensure that SMARTCARD frame data inversion setting is valid. | |
| #define | IS_SMARTCARD_ADVFEATURE_SWAP(__SWAP__) |
| Ensure that SMARTCARD frame RX/TX pins swap setting is valid. | |
| #define | IS_SMARTCARD_OVERRUN(__OVERRUN__) |
| Ensure that SMARTCARD frame overrun setting is valid. | |
| #define | IS_SMARTCARD_ADVFEATURE_DMAONRXERROR(__DMA__) |
| Ensure that SMARTCARD DMA enabling or disabling on error setting is valid. | |
| #define | IS_SMARTCARD_ADVFEATURE_MSBFIRST(__MSBFIRST__) |
| Ensure that SMARTCARD frame MSB first setting is valid. | |
| #define | IS_SMARTCARD_REQUEST_PARAMETER(__PARAM__) |
| Ensure that SMARTCARD request parameter is valid. | |
Typedefs | |
| typedef uint32_t | HAL_SMARTCARD_StateTypeDef |
| HAL SMARTCARD State definition. | |
| typedef struct __SMARTCARD_HandleTypeDef | SMARTCARD_HandleTypeDef |
| SMARTCARD handle Structure definition. | |
Enumerations | |
| enum | SMARTCARD_ClockSourceTypeDef { SMARTCARD_CLOCKSOURCE_D2PCLK1 = 0x00U , SMARTCARD_CLOCKSOURCE_D2PCLK2 = 0x01U , SMARTCARD_CLOCKSOURCE_HSI = 0x04U , SMARTCARD_CLOCKSOURCE_CSI = 0x08U , SMARTCARD_CLOCKSOURCE_LSE = 0x20U , SMARTCARD_CLOCKSOURCE_PLL2Q = 0x40U , SMARTCARD_CLOCKSOURCE_PLL3Q = 0x80U , SMARTCARD_CLOCKSOURCE_UNDEFINED = 0x10U } |
| SMARTCARD clock sources. More... | |
| HAL_StatusTypeDef | HAL_SMARTCARD_Init (SMARTCARD_HandleTypeDef *hsmartcard) |
| HAL_StatusTypeDef | HAL_SMARTCARD_DeInit (SMARTCARD_HandleTypeDef *hsmartcard) |
| void | HAL_SMARTCARD_MspInit (SMARTCARD_HandleTypeDef *hsmartcard) |
| void | HAL_SMARTCARD_MspDeInit (SMARTCARD_HandleTypeDef *hsmartcard) |
| HAL_StatusTypeDef | HAL_SMARTCARD_Transmit (SMARTCARD_HandleTypeDef *hsmartcard, const uint8_t *pData, uint16_t Size, uint32_t Timeout) |
| HAL_StatusTypeDef | HAL_SMARTCARD_Receive (SMARTCARD_HandleTypeDef *hsmartcard, uint8_t *pData, uint16_t Size, uint32_t Timeout) |
| HAL_StatusTypeDef | HAL_SMARTCARD_Transmit_IT (SMARTCARD_HandleTypeDef *hsmartcard, const uint8_t *pData, uint16_t Size) |
| HAL_StatusTypeDef | HAL_SMARTCARD_Receive_IT (SMARTCARD_HandleTypeDef *hsmartcard, uint8_t *pData, uint16_t Size) |
| HAL_StatusTypeDef | HAL_SMARTCARD_Transmit_DMA (SMARTCARD_HandleTypeDef *hsmartcard, const uint8_t *pData, uint16_t Size) |
| HAL_StatusTypeDef | HAL_SMARTCARD_Receive_DMA (SMARTCARD_HandleTypeDef *hsmartcard, uint8_t *pData, uint16_t Size) |
| HAL_StatusTypeDef | HAL_SMARTCARD_Abort (SMARTCARD_HandleTypeDef *hsmartcard) |
| HAL_StatusTypeDef | HAL_SMARTCARD_AbortTransmit (SMARTCARD_HandleTypeDef *hsmartcard) |
| HAL_StatusTypeDef | HAL_SMARTCARD_AbortReceive (SMARTCARD_HandleTypeDef *hsmartcard) |
| HAL_StatusTypeDef | HAL_SMARTCARD_Abort_IT (SMARTCARD_HandleTypeDef *hsmartcard) |
| HAL_StatusTypeDef | HAL_SMARTCARD_AbortTransmit_IT (SMARTCARD_HandleTypeDef *hsmartcard) |
| HAL_StatusTypeDef | HAL_SMARTCARD_AbortReceive_IT (SMARTCARD_HandleTypeDef *hsmartcard) |
| void | HAL_SMARTCARD_IRQHandler (SMARTCARD_HandleTypeDef *hsmartcard) |
| void | HAL_SMARTCARD_TxCpltCallback (SMARTCARD_HandleTypeDef *hsmartcard) |
| void | HAL_SMARTCARD_RxCpltCallback (SMARTCARD_HandleTypeDef *hsmartcard) |
| void | HAL_SMARTCARD_ErrorCallback (SMARTCARD_HandleTypeDef *hsmartcard) |
| void | HAL_SMARTCARD_AbortCpltCallback (SMARTCARD_HandleTypeDef *hsmartcard) |
| void | HAL_SMARTCARD_AbortTransmitCpltCallback (SMARTCARD_HandleTypeDef *hsmartcard) |
| void | HAL_SMARTCARD_AbortReceiveCpltCallback (SMARTCARD_HandleTypeDef *hsmartcard) |
| HAL_SMARTCARD_StateTypeDef | HAL_SMARTCARD_GetState (const SMARTCARD_HandleTypeDef *hsmartcard) |
| uint32_t | HAL_SMARTCARD_GetError (const SMARTCARD_HandleTypeDef *hsmartcard) |
