RTEMS 6.2-rc2
OPAMP HAL module driver. This file provides firmware functions to manage the following functionalities of the operational amplifier(s) peripheral: More...
#include "stm32h7xx_hal.h"OPAMP HAL module driver. This file provides firmware functions to manage the following functionalities of the operational amplifier(s) peripheral:
##### OPAMP Peripheral Features #####
[..] The device integrates 2 operational amplifiers OPAMP1 & OPAMP2
(#) The OPAMP(s) provides several exclusive running modes.
(++) Standalone mode
(++) Programmable Gain Amplifier (PGA) modes
(++) Follower mode
(#) Each OPAMP(s) can be configured in normal and high speed mode.
(#) The OPAMP(s) provide(s) calibration capabilities.
(++) Calibration aims at correcting some offset for running mode.
(++) The OPAMP uses either factory calibration settings OR user defined
calibration (trimming) settings (i.e. trimming mode).
(++) The user defined settings can be figured out using self calibration
handled by HAL_OPAMP_SelfCalibrate, HAL_OPAMPEx_SelfCalibrateAll
(++) HAL_OPAMP_SelfCalibrate:
(+++) Runs automatically the calibration in 2 steps.
(90% of VDDA for NMOS transistors, 10% of VDDA for PMOS transistors).
(As OPAMP is Rail-to-rail input/output, these 2 steps calibration is
appropriate and enough in most cases).
(+++) Runs automatically the calibration.
(+++) Enables the user trimming mode
(+++) Updates the init structure with trimming values with fresh calibration
results.
The user may store the calibration results for larger
(ex monitoring the trimming as a function of temperature
for instance)
(+++) HAL_OPAMPEx_SelfCalibrateAll
runs calibration of all OPAMPs in parallel to save search time.
(#) Running mode: Standalone mode
(++) Gain is set externally (gain depends on external loads).
(++) Follower mode also possible externally by connecting the inverting input to
the output.
(#) Running mode: Follower mode
(++) No Inverting Input is connected.
(#) Running mode: Programmable Gain Amplifier (PGA) mode
(Resistor feedback output)
(#) The OPAMP(s) output(s) can be internally connected to resistor feedback
output.
(#) OPAMP gain can be selected as :
(##) Gain of x2, x4, x8 or x16 for non inverting mode with:
(+++) VREF- referenced.
(+++) Filtering on VINM0, VREF- referenced.
(+++) VINM0 node for bias voltage and VINP0 for input signal.
(+++) VINM0 node for bias voltage and VINP0 for input signal, VINM1 node for filtering.
(##) Gain of x-1, x-3, x-7 or x-15 for inverting mode with:
(+++) VINM0 node for input signal and VINP0 for bias.
(+++) VINM0 node for input signal and VINP0 for bias voltage, VINM1 node for filtering.
(#) The OPAMPs inverting input can be selected according to the Reference Manual
"OPAMP functional description" chapter.
(#) The OPAMPs non inverting input can be selected according to the Reference Manual
##### How to use this driver #####
*** High speed / normal power mode ***
[..] To run in high speed mode:
(#) Configure the OPAMP using HAL_OPAMP_Init() function:
(++) Select OPAMP_POWERMODE_HIGHSPEED
(++) Otherwise select OPAMP_POWERMODE_NORMAL
*** Calibration ***
[..] To run the OPAMP calibration self calibration:
(#) Start calibration using HAL_OPAMP_SelfCalibrate.
Store the calibration results.
*** Running mode ***
[..] To use the OPAMP, perform the following steps:
(#) Fill in the HAL_OPAMP_MspInit() to
(++) Enable the OPAMP Peripheral clock using macro __HAL_RCC_OPAMP_CLK_ENABLE()
(++) Configure the OPAMP input AND output in analog mode using
HAL_GPIO_Init() to map the OPAMP output to the GPIO pin.
(#) Registrate Callbacks
(++) The compilation define USE_HAL_OPAMP_REGISTER_CALLBACKS when set to 1
allows the user to configure dynamically the driver callbacks.
(++) Use Functions HAL_OPAMP_RegisterCallback() to register a user callback,
it allows to register following callbacks:
(+++) MspInitCallback : OPAMP MspInit.
(+++) MspDeInitCallback : OPAMP MspDeInit.
This function takes as parameters the HAL peripheral handle, the Callback ID
and a pointer to the user callback function.
(++) Use function HAL_OPAMP_UnRegisterCallback() to reset a callback to the default
weak (overridden) function. It allows to reset following callbacks:
(+++) All Callbacks
(++) Select the mode
(++) Select the inverting input
(++) Select the non-inverting input
(++) If PGA mode is enabled, Select if inverting input is connected.
(++) Select either factory or user defined trimming mode.
(++) If the user-defined trimming mode is enabled, select PMOS & NMOS trimming values
(typically values set by HAL_OPAMP_SelfCalibrate function).
(#) Enable the OPAMP using HAL_OPAMP_Start() function.
(#) Disable the OPAMP using HAL_OPAMP_Stop() function.
(#) Lock the OPAMP in running mode using HAL_OPAMP_Lock() function.
Caution: On STM32H7, HAL OPAMP lock is software lock only (not
hardware lock as on some other STM32 devices)
(#) If needed, unlock the OPAMP using HAL_OPAMPEx_Unlock() function.
*** Running mode: change of configuration while OPAMP ON ***
[..] To Re-configure OPAMP when OPAMP is ON (change on the fly)
(#) If needed, fill in the HAL_OPAMP_MspInit()
(++) This is the case for instance if you wish to use new OPAMP I/O
(++) As in configure case, select first the parameters you wish to modify.
(#) Change from high speed mode to normal power mode (& vice versa) requires
first HAL_OPAMP_DeInit() (force OPAMP OFF) and then HAL_OPAMP_Init().
In other words, of OPAMP is ON, HAL_OPAMP_Init can NOT change power mode
alone.Table 1. OPAMPs inverting/non-inverting inputs for the STM32H7 devices:
| OPAMP1 | OPAMP2 | ||
| Inverting Input | VM_SEL | VINM0-> PC5 | VINM0-> PE8 |
| VINM1-> PA7 | VINM1-> PG1 | ||
| Internal: | Internal: | ||
| ADC1_IN9 | OPAMP2_OUT | ||
| ADC2_IN9 | PGA mode | ||
| OPAMP1_OUT | |||
| PGA mode | |||
| Non Inverting | VP_SEL | ||
| VP0 -> PB0 (GPIO) | VP0 -> PE9 (GPIO) | ||
| Input | DAC1_CH1_int | DAC1_CH2_int | |
| ADC1_IN8 | DAC2_CH1_int | ||
| ADC2_IN8 | COMP2_INP | ||
| COMP1_INP |
[..] Table 2. OPAMPs outputs for the STM32H7 devices:
| Output | VOUT | PC4 | PE7 |
| | | & ADC1_IN4| | & COMP2_INN7 if | | | | ADC2_IN4 |connected internally | | | | COMP1_INN7 if | | | | | connected internally | | |--------------—|-----—|--------------------—|------------------—|
