RTEMS 6.2-rc2
TIM HAL module driver. This file provides firmware functions to manage the following functionalities of the High Resolution Timer (HRTIM) peripheral: More...
#include "stm32h7xx_hal.h"TIM HAL module driver. This file provides firmware functions to manage the following functionalities of the High Resolution Timer (HRTIM) peripheral:
##### Simple mode v.s. waveform mode #####
[..] The HRTIM HAL API is split into 2 categories:
(#)Simple functions: these functions allow for using a HRTIM timer as a
general purpose timer with high resolution capabilities.
HRTIM simple modes are managed through the set of functions named
HAL_HRTIM_Simple<Function>. These functions are similar in name and usage
to the one defined for the TIM peripheral. When a HRTIM timer operates in
simple mode, only a very limited set of HRTIM features are used.
Following simple modes are proposed:
(++)Output compare mode,
(++)PWM output mode,
(++)Input capture mode,
(++)One pulse mode.
(#)Waveform functions: These functions allow taking advantage of the HRTIM
flexibility to produce numerous types of control signal. When a HRTIM timer
operates in waveform mode, all the HRTIM features are accessible without
any restriction. HRTIM waveform modes are managed through the set of
functions named HAL_HRTIM_Waveform<Function>
##### How to use this driver #####
(#)Initialize the HRTIM low level resources by implementing the
HAL_HRTIM_MspInit() function:
(##)Enable the HRTIM clock source using __HRTIMx_CLK_ENABLE()
(##)Connect HRTIM pins to MCU I/Os
(+++) Enable the clock for the HRTIM GPIOs using the following
function: __HAL_RCC_GPIOx_CLK_ENABLE()
(+++) Configure these GPIO pins in Alternate Function mode using
HAL_GPIO_Init()
(##)When using DMA to control data transfer (e.g HAL_HRTIM_SimpleBaseStart_DMA())
(+++)Enable the DMAx interface clock using __DMAx_CLK_ENABLE()
(+++)Initialize the DMA handle
(+++)Associate the initialized DMA handle to the appropriate DMA
handle of the HRTIM handle using __HAL_LINKDMA()
(+++)Initialize the DMA channel using HAL_DMA_Init()
(+++)Configure the priority and enable the NVIC for the transfer
complete interrupt on the DMA channel using HAL_NVIC_SetPriority()
and HAL_NVIC_EnableIRQ()
(##)In case of using interrupt mode (e.g HAL_HRTIM_SimpleBaseStart_IT())
(+++)Configure the priority and enable the NVIC for the concerned
HRTIM interrupt using HAL_NVIC_SetPriority() and HAL_NVIC_EnableIRQ()
(#)Initialize the HRTIM HAL using HAL_HRTIM_Init(). The HRTIM configuration
structure (field of the HRTIM handle) specifies which global interrupt of
whole HRTIM must be enabled (Burst mode period, System fault, Faults).
It also contains the HRTIM external synchronization configuration. HRTIM
can act as a master (generating a synchronization signal) or as a slave
(waiting for a trigger to be synchronized).
(#) Configure HRTIM resources shared by all HRTIM timers
(##)Burst Mode Controller:
(+++)HAL_HRTIM_BurstModeConfig(): configures the HRTIM burst mode
controller: operating mode (continuous or one-shot mode), clock
(source, prescaler) , trigger(s), period, idle duration.
(##)External Events Conditioning:
(+++)HAL_HRTIM_EventConfig(): configures the conditioning of an
external event channel: source, polarity, edge-sensitivity.
External event can be used as triggers (timer reset, input
capture, burst mode, ADC triggers, delayed protection)
They can also be used to set or reset timer outputs. Up to
10 event channels are available.
(+++)HAL_HRTIM_EventPrescalerConfig(): configures the external
event sampling clock (used for digital filtering).
(##)Fault Conditioning:
(+++)HAL_HRTIM_FaultConfig(): configures the conditioning of a
fault channel: source, polarity, edge-sensitivity. Fault
channels are used to disable the outputs in case of an
abnormal operation. Up to 5 fault channels are available.
(+++)HAL_HRTIM_FaultPrescalerConfig(): configures the fault
(+++)HAL_HRTIM_FaultModeCtl(): Enables or disables fault input(s)
circuitry. By default all fault inputs are disabled.
(##)ADC trigger:
(+++)HAL_HRTIM_ADCTriggerConfig(): configures the source triggering
the update of the ADC trigger register and the ADC trigger.
4 independent triggers are available to start both the regular
and the injected sequencers of the 2 ADCs
(#) Configure HRTIM timer time base using HAL_HRTIM_TimeBaseConfig(). This
function must be called whatever the HRTIM timer operating mode is
(simple v.s. waveform). It configures mainly:
(##)The HRTIM timer counter operating mode (continuous v.s. one shot)
(##)The HRTIM timer clock prescaler
(##)The HRTIM timer period
(##)The HRTIM timer repetition counter
*** If the HRTIM timer operates in simple mode ***
(#) Start or Stop simple timers
(++)Simple time base: HAL_HRTIM_SimpleBaseStart(),HAL_HRTIM_SimpleBaseStop(),
HAL_HRTIM_SimpleBaseStart_IT(),HAL_HRTIM_SimpleBaseStop_IT(),
HAL_HRTIM_SimpleBaseStart_DMA(),HAL_HRTIM_SimpleBaseStop_DMA().
(++)Simple output compare: HAL_HRTIM_SimpleOCChannelConfig(),
HAL_HRTIM_SimpleOCStart(),HAL_HRTIM_SimpleOCStop(),
HAL_HRTIM_SimpleOCStart_IT(),HAL_HRTIM_SimpleOCStop_IT(),
HAL_HRTIM_SimpleOCStart_DMA(),HAL_HRTIM_SimpleOCStop_DMA(),
(++)Simple PWM output: HAL_HRTIM_SimplePWMChannelConfig(),
HAL_HRTIM_SimplePWMStart(),HAL_HRTIM_SimplePWMStop(),
HAL_HRTIM_SimplePWMStart_IT(),HAL_HRTIM_SimplePWMStop_IT(),
HAL_HRTIM_SimplePWMStart_DMA(),HAL_HRTIM_SimplePWMStop_DMA(),
(++)Simple input capture: HAL_HRTIM_SimpleCaptureChannelConfig(),
HAL_HRTIM_SimpleCaptureStart(),HAL_HRTIM_SimpleCaptureStop(),
HAL_HRTIM_SimpleCaptureStart_IT(),HAL_HRTIM_SimpleCaptureStop_IT(),
HAL_HRTIM_SimpleCaptureStart_DMA(),HAL_HRTIM_SimpleCaptureStop_DMA().
(++)Simple one pulse: HAL_HRTIM_SimpleOnePulseChannelConfig(),
HAL_HRTIM_SimpleOnePulseStart(),HAL_HRTIM_SimpleOnePulseStop(),
HAL_HRTIM_SimpleOnePulseStart_IT(),HAL_HRTIM_SimpleOnePulseStop_It().
*** If the HRTIM timer operates in waveform mode ***
(#) Completes waveform timer configuration
(++)HAL_HRTIM_WaveformTimerConfig(): configuration of a HRTIM timer
operating in wave form mode mainly consists in:
(+++)Enabling the HRTIM timer interrupts and DMA requests.
(+++)Enabling the half mode for the HRTIM timer.
(+++)Defining how the HRTIM timer reacts to external synchronization input.
(+++)Enabling the push-pull mode for the HRTIM timer.
(+++)Enabling the fault channels for the HRTIM timer.
(+++)Enabling the dead-time insertion for the HRTIM timer.
(+++)Setting the delayed protection mode for the HRTIM timer (source and outputs
on which the delayed protection are applied).
(+++)Specifying the HRTIM timer update and reset triggers.
(+++)Specifying the HRTIM timer registers update policy (e.g. pre-load enabling).
(++)HAL_HRTIM_TimerEventFilteringConfig(): configures external
event blanking and windowing circuitry of a HRTIM timer:
(+++)Blanking: to mask external events during a defined time period a defined time period
(+++)Windowing, to enable external events only during a defined time period
(++)HAL_HRTIM_DeadTimeConfig(): configures the dead-time insertion
unit for a HRTIM timer. Allows to generate a couple of
complementary signals from a single reference waveform,
with programmable delays between active state.
(++)HAL_HRTIM_ChopperModeConfig(): configures the parameters of
the high-frequency carrier signal added on top of the timing
unit output. Chopper mode can be enabled or disabled for each
timer output separately (see HAL_HRTIM_WaveformOutputConfig()).
(++)HAL_HRTIM_BurstDMAConfig(): configures the burst DMA burst
controller. Allows having multiple HRTIM registers updated
with a single DMA request. The burst DMA operation is started
by calling HAL_HRTIM_BurstDMATransfer().
(++)HAL_HRTIM_WaveformCompareConfig():configures the compare unit
of a HRTIM timer. This operation consists in setting the
compare value and possibly specifying the auto delayed mode
for compare units 2 and 4 (allows to have compare events
generated relatively to capture events). Note that when auto
delayed mode is needed, the capture unit associated to the
compare unit must be configured separately.
(++)HAL_HRTIM_WaveformCaptureConfig(): configures the capture unit
of a HRTIM timer. This operation consists in specifying the
source(s) triggering the capture (timer register update event,
external event, timer output set/reset event, other HRTIM
timer related events).
(++)HAL_HRTIM_WaveformOutputConfig(): configuration of a HRTIM timer
output mainly consists in:
(+++)Setting the output polarity (active high or active low),
(+++)Defining the set/reset crossbar for the output,
(+++)Specifying the fault level (active or inactive) in IDLE and FAULT states.,
(#) Set waveform timer output(s) level
(++)HAL_HRTIM_WaveformSetOutputLevel(): forces the output to its
active or inactive level. For example, when deadtime insertion
is enabled it is necessary to force the output level by software
to have the outputs in a complementary state as soon as the RUN mode is entered.
(#) Enable or Disable waveform timer output(s)
(++)HAL_HRTIM_WaveformOutputStart(),HAL_HRTIM_WaveformOutputStop().
(#) Start or Stop waveform HRTIM timer(s).
(++)HAL_HRTIM_WaveformCountStart(),HAL_HRTIM_WaveformCountStop(),
(++)HAL_HRTIM_WaveformCountStart_IT(),HAL_HRTIM_WaveformCountStop_IT(),
(++)HAL_HRTIM_WaveformCountStart_DMA(),HAL_HRTIM_WaveformCountStop_DMA(),
(#) Burst mode controller enabling:
(++)HAL_HRTIM_BurstModeCtl(): activates or de-activates the
burst mode controller.
(#) Some HRTIM operations can be triggered by software:
(++)HAL_HRTIM_BurstModeSoftwareTrigger(): calling this function
trigs the burst operation.
(++)HAL_HRTIM_SoftwareCapture(): calling this function trigs the
capture of the HRTIM timer counter.
(++)HAL_HRTIM_SoftwareUpdate(): calling this function trigs the
update of the pre-loadable registers of the HRTIM timer
(++)HAL_HRTIM_SoftwareReset():calling this function resets the
(#) Some functions can be used any time to retrieve HRTIM timer related
information
(++)HAL_HRTIM_GetCapturedValue(): returns actual value of the
capture register of the designated capture unit.
(++)HAL_HRTIM_WaveformGetOutputLevel(): returns actual level
(ACTIVE/INACTIVE) of the designated timer output.
(++)HAL_HRTIM_WaveformGetOutputState():returns actual state
(IDLE/RUN/FAULT) of the designated timer output.
(++)HAL_HRTIM_GetDelayedProtectionStatus():returns actual level
(ACTIVE/INACTIVE) of the designated output when the delayed
protection was triggered.
(++)HAL_HRTIM_GetBurstStatus(): returns the actual status
(ACTIVE/INACTIVE) of the burst mode controller.
(++)HAL_HRTIM_GetCurrentPushPullStatus(): when the push-pull mode
is enabled for the HRTIM timer (see HAL_HRTIM_WaveformTimerConfig()),
the push-pull status indicates on which output the signal is currently
active (e.g signal applied on output 1 and output 2 forced
inactive or vice versa).
(++)HAL_HRTIM_GetIdlePushPullStatus(): when the push-pull mode
the idle push-pull status indicates during which period the
delayed protection request occurred (e.g. protection occurred
when the output 1 was active and output 2 forced inactive or
vice versa).
(#) Some functions can be used any time to retrieve actual HRTIM status
(++)HAL_HRTIM_GetState(): returns actual HRTIM instance HAL state.
*** Callback registration ***
The compilation flag USE_HAL_HRTIM_REGISTER_CALLBACKS when set to 1
allows the user to configure dynamically the driver callbacks.
Use Functions HAL_HRTIM_RegisterCallback() or HAL_HRTIM_TIMxRegisterCallback()
to register an interrupt callback.
Function HAL_HRTIM_RegisterCallback() allows to register following callbacks:
(+) Fault1Callback : Fault 1 interrupt callback function
(+) Fault2Callback : Fault 2 interrupt callback function
(+) Fault3Callback : Fault 3 interrupt callback function
(+) Fault4Callback : Fault 4 interrupt callback function
(+) Fault5Callback : Fault 5 interrupt callback function
(+) SystemFaultCallback : System fault interrupt callback function
(+) BurstModePeriodCallback : Burst mode period interrupt callback function
(+) SynchronizationEventCallback : Sync Input interrupt callback function
(+) ErrorCallback : DMA error callback function
(+) MspInitCallback : HRTIM MspInit callback function
(+) MspDeInitCallback : HRTIM MspInit callback function
Function HAL_HRTIM_TIMxRegisterCallback() allows to register following callbacks:
(+) RegistersUpdateCallback : Timer x Update interrupt callback function
(+) RepetitionEventCallback : Timer x Repetition interrupt callback function
(+) Compare1EventCallback : Timer x Compare 1 match interrupt callback function
(+) Compare2EventCallback : Timer x Compare 2 match interrupt callback function
(+) Compare3EventCallback : Timer x Compare 3 match interrupt callback function
(+) Compare4EventCallback : Timer x Compare 4 match interrupt callback function
(+) Capture1EventCallback : Timer x Capture 1 interrupts callback function
(+) Capture2EventCallback : Timer x Capture 2 interrupts callback function
(+) DelayedProtectionCallback : Timer x Delayed protection interrupt callback function
(+) CounterResetCallback : Timer x counter reset/roll-over interrupt callback function
(+) Output1SetCallback : Timer x output 1 set interrupt callback function
(+) Output1ResetCallback : Timer x output 1 reset interrupt callback function
(+) Output2SetCallback : Timer x output 2 set interrupt callback function
(+) Output2ResetCallback : Timer x output 2 reset interrupt callback function
(+) BurstDMATransferCallback : Timer x Burst DMA completed interrupt callback function
Both functions take as parameters the HAL peripheral handle, the Callback ID
and a pointer to the user callback function.
Use function HAL_HRTIM_UnRegisterCallback or HAL_HRTIM_TIMxUnRegisterCallback
to reset a callback to the default weak function. Both functions take as parameters
the HAL peripheral handle and the Callback ID.
By default, after the HAL_HRTIM_Init() and when the state is HAL_HRTIM_STATE_RESET
all callbacks are set to the corresponding weak functions (e.g HAL_HRTIM_Fault1Callback)
Exception done for MspInit and MspDeInit functions that are reset to the legacy
weak functions in the HAL_HRTIM_Init()/ HAL_HRTIM_DeInit() only when these
callbacks are null (not registered beforehand). If MspInit or MspDeInit are
not null, the HAL_HRTIM_Init()/ HAL_HRTIM_DeInit() keep and use the user
MspInit/MspDeInit callbacks (registered beforehand) whatever the state.
Callbacks can be registered/unregistered in HAL_HRTIM_STATE_READY state only.
Exception done MspInit/MspDeInit functions that can be registered/unregistered
in HAL_HRTIM_STATE_READY or HAL_HRTIM_STATE_RESET states, thus registered
(user) MspInit/DeInit callbacks can be used during the Init/DeInit.
Then, the user first registers the MspInit/MspDeInit user callbacks
using HAL_HRTIM_RegisterCallback() before calling HAL_HRTIM_DeInit()
or HAL_HRTIM_Init() function.
When the compilation flag USE_HAL_HRTIM_REGISTER_CALLBACKS is set to 0 or
not defined, the callback registration feature is not available and all
callbacks are set to the corresponding weak functions.
