RTEMS 6.2-rc2
Extended HASH HAL module driver. This file provides firmware functions to manage the following functionalities of the HASH peripheral for SHA-224 and SHA-256 algorithms: More...
#include "stm32h7xx_hal.h"Extended HASH HAL module driver. This file provides firmware functions to manage the following functionalities of the HASH peripheral for SHA-224 and SHA-256 algorithms:
##### HASH peripheral extended features #####
The SHA-224 and SHA-256 HASH and HMAC processing can be carried out exactly
the same way as for SHA-1 or MD-5 algorithms.
(#) Three modes are available.
(##) Polling mode: processing APIs are blocking functions
i.e. they process the data and wait till the digest computation is finished,
e.g. HAL_HASHEx_xxx_Start()
(##) Interrupt mode: processing APIs are not blocking functions
i.e. they process the data under interrupt,
e.g. HAL_HASHEx_xxx_Start_IT()
(##) DMA mode: processing APIs are not blocking functions and the CPU is
not used for data transfer i.e. the data transfer is ensured by DMA,
e.g. HAL_HASHEx_xxx_Start_DMA(). Note that in DMA mode, a call to
HAL_HASHEx_xxx_Finish() is then required to retrieve the digest.
(#)Multi-buffer processing is possible in polling, interrupt and DMA modes.
(##) In polling mode, only multi-buffer HASH processing is possible.
API HAL_HASHEx_xxx_Accumulate() must be called for each input buffer, except for the last one.
User must resort to HAL_HASHEx_xxx_Accumulate_End() to enter the last one and retrieve as
well the computed digest.
(##) In interrupt mode, API HAL_HASHEx_xxx_Accumulate_IT() must be called for each input buffer,
User must resort to HAL_HASHEx_xxx_Accumulate_End_IT() to enter the last one and retrieve as
(##) In DMA mode, multi-buffer HASH and HMAC processing are possible.
(+++) HASH processing: once initialization is done, MDMAT bit must be set through
__HAL_HASH_SET_MDMAT() macro.
From that point, each buffer can be fed to the Peripheral through HAL_HASHEx_xxx_Start_DMA() API.
Before entering the last buffer, reset the MDMAT bit with __HAL_HASH_RESET_MDMAT()
macro then wrap-up the HASH processing in feeding the last input buffer through the
same API HAL_HASHEx_xxx_Start_DMA(). The digest can then be retrieved with a call to
API HAL_HASHEx_xxx_Finish().
(+++) HMAC processing (MD-5, SHA-1, SHA-224 and SHA-256 must all resort to
extended functions): after initialization, the key and the first input buffer are entered
in the Peripheral with the API HAL_HMACEx_xxx_Step1_2_DMA(). This carries out HMAC step 1 and
starts step 2.
The following buffers are next entered with the API HAL_HMACEx_xxx_Step2_DMA(). At this
point, the HMAC processing is still carrying out step 2.
Then, step 2 for the last input buffer and step 3 are carried out by a single call
to HAL_HMACEx_xxx_Step2_3_DMA().
The digest can finally be retrieved with a call to API HAL_HASH_xxx_Finish() for
MD-5 and SHA-1, to HAL_HASHEx_xxx_Finish() for SHA-224 and SHA-256.
