RTEMS 6.2-rc2
This file provides firmware functions to manage the following functionalities of the Graphic MMU (GFXMMU) peripheral: More...
#include "stm32h7xx_hal.h"This file provides firmware functions to manage the following functionalities of the Graphic MMU (GFXMMU) peripheral:
##### How to use this driver #####
*** Initialization ***
(#) As prerequisite, fill in the HAL_GFXMMU_MspInit() :
(++) Enable GFXMMU clock interface with __HAL_RCC_GFXMMU_CLK_ENABLE().
(++) If interrupts are used, enable and configure GFXMMU global
interrupt with HAL_NVIC_SetPriority() and HAL_NVIC_EnableIRQ().
(#) Configure the number of blocks per line, default value, physical
buffer addresses, cache and pre-fetch parameters and interrupts
using the HAL_GFXMMU_Init() function.
*** LUT configuration ***
(#) Use HAL_GFXMMU_DisableLutLines() to deactivate all LUT lines (or a
range of lines).
(#) Use HAL_GFXMMU_ConfigLut() to copy LUT from flash to look up RAM.
(#) Use HAL_GFXMMU_ConfigLutLine() to configure one line of LUT.
*** Force flush and/or invalidate of cache ***
(#) Use HAL_GFXMMU_ConfigForceCache() to flush and/or invalidate cache.
*** Modify physical buffer addresses ***
(#) Use HAL_GFXMMU_ModifyBuffers() to modify physical buffer addresses.
*** Modify cache and pre-fetch parameters ***
(#) Use HAL_GFXMMU_ModifyCachePrefetch() to modify cache and pre-fetch
parameters.
*** Error management ***
(#) If interrupts are used, HAL_GFXMMU_IRQHandler() will be called when
an error occurs. This function will call HAL_GFXMMU_ErrorCallback().
Use HAL_GFXMMU_GetError() to get the error code.
*** De-initialization ***
(#) As prerequisite, fill in the HAL_GFXMMU_MspDeInit() :
(++) Disable GFXMMU clock interface with __HAL_RCC_GFXMMU_CLK_ENABLE().
(++) If interrupts has been used, disable GFXMMU global interrupt with
HAL_NVIC_DisableIRQ().
(#) De-initialize GFXMMU using the HAL_GFXMMU_DeInit() function.
*** Callback registration ***
The compilation define USE_HAL_GFXMMU_REGISTER_CALLBACKS when set to 1
allows the user to configure dynamically the driver callbacks.
Use functions HAL_GFXMMU_RegisterCallback() to register a user callback.
Function HAL_GFXMMU_RegisterCallback() allows to register following callbacks:
(+) ErrorCallback : GFXMMU error.
(+) MspInitCallback : GFXMMU MspInit.
(+) MspDeInitCallback : GFXMMU MspDeInit.
This function takes as parameters the HAL peripheral handle, the callback ID
and a pointer to the user callback function.
Use function HAL_GFXMMU_UnRegisterCallback() to reset a callback to the default
weak (surcharged) function.
HAL_GFXMMU_UnRegisterCallback() takes as parameters the HAL peripheral handle,
and the callback ID.
This function allows to reset following callbacks:
By default, after the HAL_GFXMMU_Init and if the state is HAL_GFXMMU_STATE_RESET
all callbacks are reset to the corresponding legacy weak (surcharged) functions:
examples HAL_GFXMMU_ErrorCallback().
Exception done for MspInit and MspDeInit callbacks that are respectively
reset to the legacy weak (surcharged) functions in the HAL_GFXMMU_Init
and HAL_GFXMMU_DeInit only when these callbacks are null (not registered beforehand).
If not, MspInit or MspDeInit are not null, the HAL_GFXMMU_Init and HAL_GFXMMU_DeInit
keep and use the user MspInit/MspDeInit callbacks (registered beforehand).
Callbacks can be registered/unregistered in READY state only.
Exception done for MspInit/MspDeInit callbacks that can be registered/unregistered
in READY or RESET state, thus registered (user) MspInit/DeInit callbacks can be used
during the Init/DeInit.
In that case first register the MspInit/MspDeInit user callbacks
using HAL_GFXMMU_RegisterCallback before calling HAL_GFXMMU_DeInit
or HAL_GFXMMU_Init function.
When the compilation define USE_HAL_GFXMMU_REGISTER_CALLBACKS is set to 0 or
not defined, the callback registering feature is not available
and weak (surcharged) callbacks are used.
