RTEMS 6.2-rc2
CRYP HAL module driver. This file provides firmware functions to manage the following functionalities of the Cryptography (CRYP) peripheral: More...
#include "stm32h7xx_hal.h"CRYP HAL module driver. This file provides firmware functions to manage the following functionalities of the Cryptography (CRYP) peripheral:
##### How to use this driver #####
The CRYP HAL driver can be used in CRYP IP as follows:
(#)Initialize the CRYP low level resources by implementing the HAL_CRYP_MspInit():
(##) Enable the CRYP interface clock using __HAL_RCC_CRYP_CLK_ENABLE()
(##) In case of using interrupts (e.g. HAL_CRYP_Encrypt_IT())
(+++) Configure the CRYP interrupt priority using HAL_NVIC_SetPriority()
(+++) Enable the CRYP IRQ handler using HAL_NVIC_EnableIRQ()
(+++) In CRYP IRQ handler, call HAL_CRYP_IRQHandler()
(##) In case of using DMA to control data transfer (e.g. HAL_CRYP_Encrypt_DMA())
(+++) Enable the DMAx interface clock using __RCC_DMAx_CLK_ENABLE()
(+++) Configure and enable two DMA streams one for managing data transfer from
memory to peripheral (input stream) and another stream for managing data
transfer from peripheral to memory (output stream)
(+++) Associate the initialized DMA handle to the CRYP DMA handle
using __HAL_LINKDMA()
(+++) Configure the priority and enable the NVIC for the transfer complete
interrupt on the two DMA Streams. The output stream should have higher
priority than the input stream HAL_NVIC_SetPriority() and HAL_NVIC_EnableIRQ()
(#)Initialize the CRYP according to the specified parameters :
(##) The data type: bit swap(1-bit data), byte swap(8-bit data), half word swap(16-bit data)
or no swap(32-bit data).
(##) The key size: 128, 192 or 256.
(##) The AlgoMode DES/ TDES Algorithm ECB/CBC or AES Algorithm ECB/CBC/CTR/GCM or CCM.
(##) The initialization vector (counter). It is not used in ECB mode.
(##) The key buffer used for encryption/decryption.
(##) The Header used only in AES GCM and CCM Algorithm for authentication.
(##) The HeaderSize The size of header buffer in word.
(##) The B0 block is the first authentication block used only in AES CCM mode.
(#)Three processing (encryption/decryption) functions are available:
(##) Polling mode: encryption and decryption APIs are blocking functions
i.e. they process the data and wait till the processing is finished,
e.g. HAL_CRYP_Encrypt & HAL_CRYP_Decrypt
(##) Interrupt mode: encryption and decryption APIs are not blocking functions
i.e. they process the data under interrupt,
e.g. HAL_CRYP_Encrypt_IT & HAL_CRYP_Decrypt_IT
(##) DMA mode: encryption and decryption APIs are not blocking functions
i.e. the data transfer is ensured by DMA,
e.g. HAL_CRYP_Encrypt_DMA & HAL_CRYP_Decrypt_DMA
(#)When the processing function is called at first time after HAL_CRYP_Init()
the CRYP peripheral is configured and processes the buffer in input.
At second call, no need to Initialize the CRYP, user have to get current configuration via
HAL_CRYP_GetConfig() API, then only HAL_CRYP_SetConfig() is requested to set
new parametres, finally user can start encryption/decryption.
(#)Call HAL_CRYP_DeInit() to deinitialize the CRYP peripheral.
(#)To process a single message with consecutive calls to HAL_CRYP_Encrypt() or HAL_CRYP_Decrypt()
without having to configure again the Key or the Initialization Vector between each API call,
the field KeyIVConfigSkip of the initialization structure must be set to CRYP_KEYIVCONFIG_ONCE.
Same is true for consecutive calls of HAL_CRYP_Encrypt_IT(), HAL_CRYP_Decrypt_IT(), HAL_CRYP_Encrypt_DMA()
or HAL_CRYP_Decrypt_DMA().
The cryptographic processor supports following standards:
(#) The data encryption standard (DES) and Triple-DES (TDES) supported only by CRYP1 IP:
(##)64-bit data block processing
(##) chaining modes supported :
(+++) Electronic Code Book(ECB)
(+++) Cipher Block Chaining (CBC)
(##) keys length supported :64-bit, 128-bit and 192-bit.
(#) The advanced encryption standard (AES) supported by CRYP1:
(##)128-bit data block processing
(+++) Counter mode (CTR)
(+++) Galois/counter mode (GCM/GMAC)
(+++) Counter with Cipher Block Chaining-Message(CCM)
(##) keys length Supported :
(+++) for CRYP1 IP: 128-bit, 192-bit and 256-bit.
[..] This section describes the AES Galois/counter mode (GCM) supported by both CRYP1 IP:
(#) Algorithm supported :
(##) Galois/counter mode (GCM)
(##) Galois message authentication code (GMAC) :is exactly the same as
GCM algorithm composed only by an header.
(#) Four phases are performed in GCM :
(##) Init phase: IP prepares the GCM hash subkey (H) and do the IV processing
(##) Header phase: IP processes the Additional Authenticated Data (AAD), with hash
computation only.
(##) Payload phase: IP processes the plaintext (P) with hash computation + keystream
encryption + data XORing. It works in a similar way for ciphertext (C).
(##) Final phase: IP generates the authenticated tag (T) using the last block of data.
HAL_CRYPEx_AESGCM_GenerateAuthTAG API used in this phase to generate 4 words which correspond
to the Tag. user should consider only part of this 4 words, if Tag length is less than 128 bits.
(#) structure of message construction in GCM is defined as below :
(##) 16 bytes Initial Counter Block (ICB)composed of IV and counter
(##) The authenticated header A (also knows as Additional Authentication Data AAD)
this part of the message is only authenticated, not encrypted.
(##) The plaintext message P is both authenticated and encrypted as ciphertext.
GCM standard specifies that ciphertext has same bit length as the plaintext.
(##) The last block is composed of the length of A (on 64 bits) and the length of ciphertext
(on 64 bits)
[..] This section describe The AES Counter with Cipher Block Chaining-Message
Authentication Code (CCM) supported by both CRYP1 IP:
(#) Specific parameters for CCM :
(##) B0 block : According to NIST Special Publication 800-38C,
The first block B0 is formatted as follows, where l(m) is encoded in
most-significant-byte first order(see below table 3)
(+++) Q: a bit string representation of the octet length of P (plaintext)
(+++) q The octet length of the binary representation of the octet length of the payload
(+++) A nonce (N), n The octet length of the where n+q=15.
(+++) Flags: most significant octet containing four flags for control information,
(+++) t The octet length of the MAC.
(##) B1 block (header) : associated data length(a) concatenated with Associated Data (A)
the associated data length expressed in bytes (a) defined as below:
(+++) If 0 < a < 216-28, then it is encoded as [a]16, i.e. two octets
(+++) If 216-28 < a < 232, then it is encoded as 0xff || 0xfe || [a]32, i.e. six octets
(+++) If 232 < a < 264, then it is encoded as 0xff || 0xff || [a]64, i.e. ten octets
(##) CTRx block : control blocks
(+++) Generation of CTR1 from first block B0 information :
equal to B0 with first 5 bits zeroed and most significant bits storing octet
length of P also zeroed, then incremented by one ( see below Table 4)
(+++) Generation of CTR0: same as CTR1 with bit[0] set to zero.
(#) Four phases are performed in CCM for CRYP1 IP:
computation only.
HAL_CRYPEx_AESCCM_GenerateAuthTAG API used in this phase to generate 4 words which correspond to the Tag.
*** Callback registration ***
The compilation define USE_HAL_CRYP_REGISTER_CALLBACKS when set to 1
allows the user to configure dynamically the driver callbacks.
Use Functions @ref HAL_CRYP_RegisterCallback() or HAL_CRYP_RegisterXXXCallback()
to register an interrupt callback.
Function @ref HAL_CRYP_RegisterCallback() allows to register following callbacks:
(+) InCpltCallback : Input FIFO transfer completed callback.
(+) OutCpltCallback : Output FIFO transfer completed callback.
(+) ErrorCallback : callback for error detection.
(+) MspInitCallback : CRYP MspInit.
(+) MspDeInitCallback : CRYP MspDeInit.
This function takes as parameters the HAL peripheral handle, the Callback ID
and a pointer to the user callback function.
Use function @ref HAL_CRYP_UnRegisterCallback() to reset a callback to the default
weak function.
@ref HAL_CRYP_UnRegisterCallback() takes as parameters the HAL peripheral handle,
and the Callback ID.
This function allows to reset following callbacks:
By default, after the @ref HAL_CRYP_Init() and when the state is HAL_CRYP_STATE_RESET
all callbacks are set to the corresponding weak functions :
examples @ref HAL_CRYP_InCpltCallback() , @ref HAL_CRYP_OutCpltCallback().
Exception done for MspInit and MspDeInit functions that are
reset to the legacy weak function in the @ref HAL_CRYP_Init()/ @ref HAL_CRYP_DeInit() only when
these callbacks are null (not registered beforehand).
if not, MspInit or MspDeInit are not null, the @ref HAL_CRYP_Init() / @ref HAL_CRYP_DeInit()
keep and use the user MspInit/MspDeInit functions (registered beforehand)
Callbacks can be registered/unregistered in HAL_CRYP_STATE_READY state only.
Exception done MspInit/MspDeInit callbacks that can be registered/unregistered
in HAL_CRYP_STATE_READY or HAL_CRYP_STATE_RESET state,
thus registered (user) MspInit/DeInit callbacks can be used during the Init/DeInit.
In that case first register the MspInit/MspDeInit user callbacks
using @ref HAL_CRYP_RegisterCallback() before calling @ref HAL_CRYP_DeInit()
or @ref HAL_CRYP_Init() function.
When The compilation define USE_HAL_CRYP_REGISTER_CALLBACKS is set to 0 or
not defined, the callback registration feature is not available and all callbacks
are set to the corresponding weak functions.Table 1. Initial Counter Block (ICB) +----------------------------------------------------—+ | Initialization vector (IV) | Counter | |-------------—|-------------—|--------—|------—| 127 95 63 31 0
Bit Number Register Contents
127 ...96 CRYP_IV1R[31:0] ICB[127:96]
95 ...64 CRYP_IV1L[31:0] B0[95:64]
63 ... 32 CRYP_IV0R[31:0] ICB[63:32]
31 ... 0 CRYP_IV0L[31:0] ICB[31:0], where 32-bit counter= 0x2
Table 2. GCM last block definition
| Bit[0] | Bit[32] | Bit[64] | Bit[96] |
| 0x0 | Header length[31:0]| 0x0 | Payload length[31:0] |
Table 3. B0 block Octet Number Contents
0 Flags 1 ... 15-q Nonce N 16-q ... 15 Q
the Flags field is formatted as follows:
Bit Number Contents ---------- ---------------------- 7 Reserved (always zero) 6 Adata 5 ... 3 (t-2)/2 2 ... 0 [q-1]3
Table 4. CTRx block Bit Number Register Contents
127 ...96 CRYP_IV1R[31:0] B0[127:96], where Q length bits are set to 0, except for bit 0 that is set to 1 95 ...64 CRYP_IV1L[31:0] B0[95:64] 63 ... 32 CRYP_IV0R[31:0] B0[63:32] 31 ... 0 CRYP_IV0L[31:0] B0[31:0], where flag bits set to 0
