RTEMS 6.2-rc2
This file provides firmware functions to manage the following functionalities of the Analog to Digital Converter (ADC) peripheral: More...
#include "stm32h7xx_hal.h"This file provides firmware functions to manage the following functionalities of the Analog to Digital Converter (ADC) peripheral:
##### ADC peripheral features #####
(+) 16-bit, 14-bit, 12-bit, 10-bit or 8-bit configurable resolution.
Note: On devices STM32H72xx and STM32H73xx, these resolution are applicable to instances ADC1 and ADC2.
ADC3 is featuring resolutions 12-bit, 10-bit, 8-bit, 6-bit.
(+) Interrupt generation at the end of regular conversion and in case of
analog watchdog or overrun events.
(+) Single and continuous conversion modes.
(+) Scan mode for conversion of several channels sequentially.
(+) Data alignment with in-built data coherency.
(+) Programmable sampling time (channel wise)
(+) External trigger (timer or EXTI) with configurable polarity
(+) DMA request generation for transfer of conversions data of regular group.
(+) Configurable delay between conversions in Dual interleaved mode.
(+) ADC channels selectable single/differential input.
(+) ADC offset shared on 4 offset instances.
(+) ADC calibration
(+) ADC conversion of regular group.
(+) ADC supply requirements: 1.62 V to 3.6 V.
(+) ADC input range: from Vref- (connected to Vssa) to Vref+ (connected to
Vdda or to an external voltage reference).
##### How to use this driver #####
*** Configuration of top level parameters related to ADC ***
(#) Enable the ADC interface
(++) As prerequisite, ADC clock must be configured at RCC top level.
(++) Two clock settings are mandatory:
(+++) ADC clock (core clock, also possibly conversion clock).
(+++) ADC clock (conversions clock).
Two possible clock sources: synchronous clock derived from AHB clock
or asynchronous clock derived from system clock, the PLL2 or the PLL3 running up to 400MHz.
(+++) Example:
Into HAL_ADC_MspInit() (recommended code location) or with
other device clock parameters configuration:
(+++) __HAL_RCC_ADC_CLK_ENABLE(); (mandatory)
RCC_ADCCLKSOURCE_PLL2 enable: (optional: if asynchronous clock selected)
(+++) RCC_PeriphClkInitTypeDef RCC_PeriphClkInit;
(+++) PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_ADC;
(+++) PeriphClkInit.AdcClockSelection = RCC_ADCCLKSOURCE_PLL2;
(+++) HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit);
(++) ADC clock source and clock prescaler are configured at ADC level with
parameter "ClockPrescaler" using function HAL_ADC_Init().
(#) ADC pins configuration
(++) Enable the clock for the ADC GPIOs
using macro __HAL_RCC_GPIOx_CLK_ENABLE()
(++) Configure these ADC pins in analog mode
using function HAL_GPIO_Init()
(#) Optionally, in case of usage of ADC with interruptions:
(++) Configure the NVIC for ADC
using function HAL_NVIC_EnableIRQ(ADCx_IRQn)
(++) Insert the ADC interruption handler function HAL_ADC_IRQHandler()
into the function of corresponding ADC interruption vector
ADCx_IRQHandler().
(#) Optionally, in case of usage of DMA:
(++) Configure the DMA (DMA channel, mode normal or circular, ...)
using function HAL_DMA_Init().
(++) Configure the NVIC for DMA
using function HAL_NVIC_EnableIRQ(DMAx_Channelx_IRQn)
into the function of corresponding DMA interruption vector
DMAx_Channelx_IRQHandler().
*** Configuration of ADC, group regular, channels parameters ***
(#) Configure the ADC parameters (resolution, data alignment, ...)
and regular group parameters (conversion trigger, sequencer, ...)
(#) Configure the channels for regular group parameters (channel number,
channel rank into sequencer, ..., into regular group)
using function HAL_ADC_ConfigChannel().
(#) Optionally, configure the analog watchdog parameters (channels
monitored, thresholds, ...)
using function HAL_ADC_AnalogWDGConfig().
*** Execution of ADC conversions ***
(#) Optionally, perform an automatic ADC calibration to improve the
conversion accuracy
using function HAL_ADCEx_Calibration_Start().
(#) ADC driver can be used among three modes: polling, interruption,
transfer by DMA.
(++) ADC conversion by polling:
(+++) Activate the ADC peripheral and start conversions
using function HAL_ADC_Start()
(+++) Wait for ADC conversion completion
using function HAL_ADC_PollForConversion()
(+++) Retrieve conversion results
using function HAL_ADC_GetValue()
(+++) Stop conversion and disable the ADC peripheral
using function HAL_ADC_Stop()
(++) ADC conversion by interruption:
using function HAL_ADC_Start_IT()
(+++) Wait for ADC conversion completion by call of function
HAL_ADC_ConvCpltCallback()
(this function must be implemented in user program)
using function HAL_ADC_Stop_IT()
(++) ADC conversion with transfer by DMA:
using function HAL_ADC_Start_DMA()
HAL_ADC_ConvCpltCallback() or HAL_ADC_ConvHalfCpltCallback()
(these functions must be implemented in user program)
(+++) Conversion results are automatically transferred by DMA into
destination variable address.
using function HAL_ADC_Stop_DMA()
(@) Callback functions must be implemented in user program:
(+@) HAL_ADC_ErrorCallback()
(+@) HAL_ADC_LevelOutOfWindowCallback() (callback of analog watchdog)
(+@) HAL_ADC_ConvCpltCallback()
(+@) HAL_ADC_ConvHalfCpltCallback
*** Deinitialization of ADC ***
(#) Disable the ADC interface
(++) ADC clock can be hard reset and disabled at RCC top level.
(++) Hard reset of ADC peripherals
using macro __HAL_RCC_ADCx_FORCE_RESET(), __HAL_RCC_ADCx_RELEASE_RESET().
(++) ADC clock disable
using the equivalent macro/functions as configuration step.
(+++) Example:
Into HAL_ADC_MspDeInit() (recommended code location) or with
(+++) __HAL_RCC_ADC_CLK_DISABLE(); (if not used anymore)
RCC_ADCCLKSOURCE_CLKP restore: (optional)
(+++) PeriphClkInit.AdcClockSelection = RCC_ADCCLKSOURCE_CLKP;
(++) Disable the clock for the ADC GPIOs
using macro __HAL_RCC_GPIOx_CLK_DISABLE()
(++) Disable the NVIC for ADC
(++) Deinitialize the DMA
(++) Disable the NVIC for DMA
*** Callback registration ***
The compilation flag USE_HAL_ADC_REGISTER_CALLBACKS, when set to 1,
allows the user to configure dynamically the driver callbacks.
Use Functions HAL_ADC_RegisterCallback()
to register an interrupt callback.
Function HAL_ADC_RegisterCallback() allows to register following callbacks:
(+) ConvCpltCallback : ADC conversion complete callback
(+) ConvHalfCpltCallback : ADC conversion DMA half-transfer callback
(+) LevelOutOfWindowCallback : ADC analog watchdog 1 callback
(+) ErrorCallback : ADC error callback
(+) InjectedConvCpltCallback : ADC group injected conversion complete callback
(+) InjectedQueueOverflowCallback : ADC group injected context queue overflow callback
(+) LevelOutOfWindow2Callback : ADC analog watchdog 2 callback
(+) LevelOutOfWindow3Callback : ADC analog watchdog 3 callback
(+) EndOfSamplingCallback : ADC end of sampling callback
(+) MspInitCallback : ADC Msp Init callback
(+) MspDeInitCallback : ADC Msp DeInit callback
This function takes as parameters the HAL peripheral handle, the Callback ID
and a pointer to the user callback function.
Use function HAL_ADC_UnRegisterCallback to reset a callback to the default
weak function.
HAL_ADC_UnRegisterCallback takes as parameters the HAL peripheral handle,
and the Callback ID.
This function allows to reset following callbacks:
By default, after the HAL_ADC_Init() and when the state is HAL_ADC_STATE_RESET
all callbacks are set to the corresponding weak functions:
examples HAL_ADC_ConvCpltCallback(), HAL_ADC_ErrorCallback().
Exception done for MspInit and MspDeInit functions that are
reset to the legacy weak functions in the HAL_ADC_Init()/ HAL_ADC_DeInit() only when
these callbacks are null (not registered beforehand).
If MspInit or MspDeInit are not null, the HAL_ADC_Init()/ HAL_ADC_DeInit()
keep and use the user MspInit/MspDeInit callbacks (registered beforehand) whatever the state.
Callbacks can be registered/unregistered in HAL_ADC_STATE_READY state only.
Exception done MspInit/MspDeInit functions that can be registered/unregistered
in HAL_ADC_STATE_READY or HAL_ADC_STATE_RESET state,
thus registered (user) MspInit/DeInit callbacks can be used during the Init/DeInit.
Then, the user first registers the MspInit/MspDeInit user callbacks
using HAL_ADC_RegisterCallback() before calling HAL_ADC_DeInit()
or HAL_ADC_Init() function.
When the compilation flag USE_HAL_ADC_REGISTER_CALLBACKS is set to 0 or
not defined, the callback registration feature is not available and all callbacks
are set to the corresponding weak functions.
