RTEMS 6.2-rc2
#include <ofw/ofw.h>Go to the source code of this file.
| #define | OF_peer rtems_ofw_peer |
| #define | OF_child rtems_ofw_child |
| #define | OF_parent rtems_ofw_parent |
| #define | OF_getproplen rtems_ofw_get_prop_len |
| #define | OF_getprop rtems_ofw_get_prop |
| #define | OF_getencprop rtems_ofw_get_enc_prop |
| #define | OF_hasprop rtems_ofw_has_prop |
| #define | OF_searchprop rtems_ofw_search_prop |
| #define | OF_searchencprop rtems_ofw_search_enc_prop |
| #define | OF_getprop_alloc rtems_ofw_get_prop_alloc |
| #define | OF_getprop_alloc_multi rtems_ofw_get_prop_alloc_multi |
| #define | OF_getencprop_alloc_multi rtems_ofw_get_enc_prop_alloc_multi |
| #define | OF_getencprop_alloc rtems_ofw_get_enc_prop_alloc |
| #define | OF_prop_free rtems_ofw_free |
| #define | OF_nextprop rtems_ofw_next_prop |
| #define | OF_setprop rtems_ofw_set_prop |
| #define | OF_canon rtems_ofw_canon |
| #define | OF_finddevice rtems_ofw_find_device |
| #define | OF_package_to_path rtems_ofw_package_to_path |
| #define | OF_node_from_xref rtems_ofw_node_from_xref |
| #define | OF_xref_from_node rtems_ofw_xref_from_node |
| #define | OF_instance_to_package rtems_ofw_instance_to_package |
| #define | OF_instance_to_path rtems_ofw_instance_to_path |
This file defines necessary symbols to make the RTEMS OFW API compatible with FreeBSD OFW.
