RTEMS 6.2-rc2
This header file defines the GRPCI2 register block interface. More...
#include <stdint.h>Go to the source code of this file.
| struct | grpci2 |
| This structure defines the GRPCI2 register block memory map. More... | |
| #define | GRPCI2_CTRL_RE 0x80000000U |
| #define | GRPCI2_CTRL_MR 0x40000000U |
| #define | GRPCI2_CTRL_TR 0x20000000U |
| #define | GRPCI2_CTRL_SI 0x8000000U |
| #define | GRPCI2_CTRL_PE 0x4000000U |
| #define | GRPCI2_CTRL_ER 0x2000000U |
| #define | GRPCI2_CTRL_EI 0x1000000U |
| #define | GRPCI2_CTRL_BUS_NUMBER_SHIFT 16 |
| #define | GRPCI2_CTRL_BUS_NUMBER_MASK 0xff0000U |
| #define | GRPCI2_CTRL_BUS_NUMBER_GET(_reg) |
| #define | GRPCI2_CTRL_BUS_NUMBER_SET(_reg, _val) |
| #define | GRPCI2_CTRL_BUS_NUMBER(_val) |
| #define | GRPCI2_CTRL_DFA 0x800U |
| #define | GRPCI2_CTRL_IB 0x400U |
| #define | GRPCI2_CTRL_CB 0x200U |
| #define | GRPCI2_CTRL_DIF 0x100U |
| #define | GRPCI2_CTRL_DEVICE_INT_MASK_SHIFT 4 |
| #define | GRPCI2_CTRL_DEVICE_INT_MASK_MASK 0xf0U |
| #define | GRPCI2_CTRL_DEVICE_INT_MASK_GET(_reg) |
| #define | GRPCI2_CTRL_DEVICE_INT_MASK_SET(_reg, _val) |
| #define | GRPCI2_CTRL_DEVICE_INT_MASK(_val) |
| #define | GRPCI2_CTRL_HOST_INT_MASK_SHIFT 0 |
| #define | GRPCI2_CTRL_HOST_INT_MASK_MASK 0xfU |
| #define | GRPCI2_CTRL_HOST_INT_MASK_GET(_reg) |
| #define | GRPCI2_CTRL_HOST_INT_MASK_SET(_reg, _val) |
| #define | GRPCI2_CTRL_HOST_INT_MASK(_val) |
| #define | GRPCI2_STATCAP_HOST 0x80000000U |
| #define | GRPCI2_STATCAP_MST 0x40000000U |
| #define | GRPCI2_STATCAP_TAR 0x20000000U |
| #define | GRPCI2_STATCAP_DMA 0x10000000U |
| #define | GRPCI2_STATCAP_DI 0x8000000U |
| #define | GRPCI2_STATCAP_HI 0x4000000U |
| #define | GRPCI2_STATCAP_IRQ_MODE_SHIFT 24 |
| #define | GRPCI2_STATCAP_IRQ_MODE_MASK 0x3000000U |
| #define | GRPCI2_STATCAP_IRQ_MODE_GET(_reg) |
| #define | GRPCI2_STATCAP_IRQ_MODE_SET(_reg, _val) |
| #define | GRPCI2_STATCAP_IRQ_MODE(_val) |
| #define | GRPCI2_STATCAP_TRACE 0x800000U |
| #define | GRPCI2_STATCAP_CFGDO 0x100000U |
| #define | GRPCI2_STATCAP_CFGER 0x80000U |
| #define | GRPCI2_STATCAP_CORE_INT_STATUS_SHIFT 12 |
| #define | GRPCI2_STATCAP_CORE_INT_STATUS_MASK 0x7f000U |
| #define | GRPCI2_STATCAP_CORE_INT_STATUS_GET(_reg) |
| #define | GRPCI2_STATCAP_CORE_INT_STATUS_SET(_reg, _val) |
| #define | GRPCI2_STATCAP_CORE_INT_STATUS(_val) |
| #define | GRPCI2_STATCAP_HOST_INT_STATUS_SHIFT 8 |
| #define | GRPCI2_STATCAP_HOST_INT_STATUS_MASK 0xf00U |
| #define | GRPCI2_STATCAP_HOST_INT_STATUS_GET(_reg) |
| #define | GRPCI2_STATCAP_HOST_INT_STATUS_SET(_reg, _val) |
| #define | GRPCI2_STATCAP_HOST_INT_STATUS(_val) |
| #define | GRPCI2_STATCAP_FDEPTH_SHIFT 2 |
| #define | GRPCI2_STATCAP_FDEPTH_MASK 0x1cU |
| #define | GRPCI2_STATCAP_FDEPTH_GET(_reg) |
| #define | GRPCI2_STATCAP_FDEPTH_SET(_reg, _val) |
| #define | GRPCI2_STATCAP_FDEPTH(_val) |
| #define | GRPCI2_STATCAP_FNUM_SHIFT 0 |
| #define | GRPCI2_STATCAP_FNUM_MASK 0x3U |
| #define | GRPCI2_STATCAP_FNUM_GET(_reg) |
| #define | GRPCI2_STATCAP_FNUM_SET(_reg, _val) |
| #define | GRPCI2_STATCAP_FNUM(_val) |
| #define | GRPCI2_BCIM_AHB_MASTER_UNMASK_SHIFT 16 |
| #define | GRPCI2_BCIM_AHB_MASTER_UNMASK_MASK 0xffff0000U |
| #define | GRPCI2_BCIM_AHB_MASTER_UNMASK_GET(_reg) |
| #define | GRPCI2_BCIM_AHB_MASTER_UNMASK_SET(_reg, _val) |
| #define | GRPCI2_BCIM_AHB_MASTER_UNMASK(_val) |
| #define | GRPCI2_BCIM_BURST_LENGTH_SHIFT 0 |
| #define | GRPCI2_BCIM_BURST_LENGTH_MASK 0xffU |
| #define | GRPCI2_BCIM_BURST_LENGTH_GET(_reg) |
| #define | GRPCI2_BCIM_BURST_LENGTH_SET(_reg, _val) |
| #define | GRPCI2_BCIM_BURST_LENGTH(_val) |
| #define | GRPCI2_AHB2PCI_AHB_TO_PCI_IO_SHIFT 16 |
| #define | GRPCI2_AHB2PCI_AHB_TO_PCI_IO_MASK 0xffff0000U |
| #define | GRPCI2_AHB2PCI_AHB_TO_PCI_IO_GET(_reg) |
| #define | GRPCI2_AHB2PCI_AHB_TO_PCI_IO_SET(_reg, _val) |
| #define | GRPCI2_AHB2PCI_AHB_TO_PCI_IO(_val) |
| #define | GRPCI2_DMACTRL_SAFE 0x80000000U |
| #define | GRPCI2_DMACTRL_CHIRQ_SHIFT 12 |
| #define | GRPCI2_DMACTRL_CHIRQ_MASK 0xff000U |
| #define | GRPCI2_DMACTRL_CHIRQ_GET(_reg) |
| #define | GRPCI2_DMACTRL_CHIRQ_SET(_reg, _val) |
| #define | GRPCI2_DMACTRL_CHIRQ(_val) |
| #define | GRPCI2_DMACTRL_MA 0x800U |
| #define | GRPCI2_DMACTRL_TA 0x400U |
| #define | GRPCI2_DMACTRL_PE 0x200U |
| #define | GRPCI2_DMACTRL_AE 0x100U |
| #define | GRPCI2_DMACTRL_DE 0x80U |
| #define | GRPCI2_DMACTRL_NUMCH_SHIFT 4 |
| #define | GRPCI2_DMACTRL_NUMCH_MASK 0x70U |
| #define | GRPCI2_DMACTRL_NUMCH_GET(_reg) |
| #define | GRPCI2_DMACTRL_NUMCH_SET(_reg, _val) |
| #define | GRPCI2_DMACTRL_NUMCH(_val) |
| #define | GRPCI2_DMACTRL_ACTIVE 0x8U |
| #define | GRPCI2_DMACTRL_DIS 0x4U |
| #define | GRPCI2_DMACTRL_IE 0x2U |
| #define | GRPCI2_DMACTRL_EN 0x1U |
| #define | GRPCI2_DMABASE_BASE_SHIFT 0 |
| #define | GRPCI2_DMABASE_BASE_MASK 0xffffffffU |
| #define | GRPCI2_DMABASE_BASE_GET(_reg) |
| #define | GRPCI2_DMABASE_BASE_SET(_reg, _val) |
| #define | GRPCI2_DMABASE_BASE(_val) |
| #define | GRPCI2_DMACHAN_CHAN_SHIFT 0 |
| #define | GRPCI2_DMACHAN_CHAN_MASK 0xffffffffU |
| #define | GRPCI2_DMACHAN_CHAN_GET(_reg) |
| #define | GRPCI2_DMACHAN_CHAN_SET(_reg, _val) |
| #define | GRPCI2_DMACHAN_CHAN(_val) |
| #define | GRPCI2_PCI2AHB_ADDR_SHIFT 0 |
| #define | GRPCI2_PCI2AHB_ADDR_MASK 0xffffffffU |
| #define | GRPCI2_PCI2AHB_ADDR_GET(_reg) |
| #define | GRPCI2_PCI2AHB_ADDR_SET(_reg, _val) |
| #define | GRPCI2_PCI2AHB_ADDR(_val) |
| #define | GRPCI2_AHBM2PCI_ADDR_SHIFT 0 |
| #define | GRPCI2_AHBM2PCI_ADDR_MASK 0xffffffffU |
| #define | GRPCI2_AHBM2PCI_ADDR_GET(_reg) |
| #define | GRPCI2_AHBM2PCI_ADDR_SET(_reg, _val) |
| #define | GRPCI2_AHBM2PCI_ADDR(_val) |
| #define | GRPCI2_TCTRC_TRIG_INDEX_SHIFT 16 |
| #define | GRPCI2_TCTRC_TRIG_INDEX_MASK 0xffff0000U |
| #define | GRPCI2_TCTRC_TRIG_INDEX_GET(_reg) |
| #define | GRPCI2_TCTRC_TRIG_INDEX_SET(_reg, _val) |
| #define | GRPCI2_TCTRC_TRIG_INDEX(_val) |
| #define | GRPCI2_TCTRC_AR 0x8000U |
| #define | GRPCI2_TCTRC_EN 0x4000U |
| #define | GRPCI2_TCTRC_DEPTH_SHIFT 4 |
| #define | GRPCI2_TCTRC_DEPTH_MASK 0xff0U |
| #define | GRPCI2_TCTRC_DEPTH_GET(_reg) |
| #define | GRPCI2_TCTRC_DEPTH_SET(_reg, _val) |
| #define | GRPCI2_TCTRC_DEPTH(_val) |
| #define | GRPCI2_TCTRC_SO 0x2U |
| #define | GRPCI2_TCTRC_SA 0x1U |
| #define | GRPCI2_TMODE_TRACING_MODE_SHIFT 24 |
| #define | GRPCI2_TMODE_TRACING_MODE_MASK 0xf000000U |
| #define | GRPCI2_TMODE_TRACING_MODE_GET(_reg) |
| #define | GRPCI2_TMODE_TRACING_MODE_SET(_reg, _val) |
| #define | GRPCI2_TMODE_TRACING_MODE(_val) |
| #define | GRPCI2_TMODE_TRIG_COUNT_SHIFT 16 |
| #define | GRPCI2_TMODE_TRIG_COUNT_MASK 0xff0000U |
| #define | GRPCI2_TMODE_TRIG_COUNT_GET(_reg) |
| #define | GRPCI2_TMODE_TRIG_COUNT_SET(_reg, _val) |
| #define | GRPCI2_TMODE_TRIG_COUNT(_val) |
| #define | GRPCI2_TMODE_DELAYED_STOP_SHIFT 0 |
| #define | GRPCI2_TMODE_DELAYED_STOP_MASK 0xffffU |
| #define | GRPCI2_TMODE_DELAYED_STOP_GET(_reg) |
| #define | GRPCI2_TMODE_DELAYED_STOP_SET(_reg, _val) |
| #define | GRPCI2_TMODE_DELAYED_STOP(_val) |
| #define | GRPCI2_TADP_PATTERN_SHIFT 0 |
| #define | GRPCI2_TADP_PATTERN_MASK 0xffffffffU |
| #define | GRPCI2_TADP_PATTERN_GET(_reg) |
| #define | GRPCI2_TADP_PATTERN_SET(_reg, _val) |
| #define | GRPCI2_TADP_PATTERN(_val) |
| #define | GRPCI2_TADM_MASK_SHIFT 0 |
| #define | GRPCI2_TADM_MASK_MASK 0xffffffffU |
| #define | GRPCI2_TADM_MASK_GET(_reg) |
| #define | GRPCI2_TADM_MASK_SET(_reg, _val) |
| #define | GRPCI2_TADM_MASK(_val) |
| #define | GRPCI2_TCP_CBE_3_0_SHIFT 16 |
| #define | GRPCI2_TCP_CBE_3_0_MASK 0xf0000U |
| #define | GRPCI2_TCP_CBE_3_0_GET(_reg) |
| #define | GRPCI2_TCP_CBE_3_0_SET(_reg, _val) |
| #define | GRPCI2_TCP_CBE_3_0(_val) |
| #define | GRPCI2_TCP_FRAME 0x8000U |
| #define | GRPCI2_TCP_IRDY 0x4000U |
| #define | GRPCI2_TCP_TRDY 0x2000U |
| #define | GRPCI2_TCP_STOP 0x1000U |
| #define | GRPCI2_TCP_DEVSEL 0x800U |
| #define | GRPCI2_TCP_PAR 0x400U |
| #define | GRPCI2_TCP_PERR 0x200U |
| #define | GRPCI2_TCP_SERR 0x100U |
| #define | GRPCI2_TCP_IDSEL 0x80U |
| #define | GRPCI2_TCP_REQ 0x40U |
| #define | GRPCI2_TCP_GNT 0x20U |
| #define | GRPCI2_TCP_LOCK 0x10U |
| #define | GRPCI2_TCP_RST 0x8U |
| #define | GRPCI2_TCM_CBE_3_0_SHIFT 16 |
| #define | GRPCI2_TCM_CBE_3_0_MASK 0xf0000U |
| #define | GRPCI2_TCM_CBE_3_0_GET(_reg) |
| #define | GRPCI2_TCM_CBE_3_0_SET(_reg, _val) |
| #define | GRPCI2_TCM_CBE_3_0(_val) |
| #define | GRPCI2_TCM_FRAME 0x8000U |
| #define | GRPCI2_TCM_IRDY 0x4000U |
| #define | GRPCI2_TCM_TRDY 0x2000U |
| #define | GRPCI2_TCM_STOP 0x1000U |
| #define | GRPCI2_TCM_DEVSEL 0x800U |
| #define | GRPCI2_TCM_PAR 0x400U |
| #define | GRPCI2_TCM_PERR 0x200U |
| #define | GRPCI2_TCM_SERR 0x100U |
| #define | GRPCI2_TCM_IDSEL 0x80U |
| #define | GRPCI2_TCM_REQ 0x40U |
| #define | GRPCI2_TCM_GNT 0x20U |
| #define | GRPCI2_TCM_LOCK 0x10U |
| #define | GRPCI2_TCM_RST 0x8U |
| #define | GRPCI2_TADS_SIGNAL_SHIFT 0 |
| #define | GRPCI2_TADS_SIGNAL_MASK 0xffffffffU |
| #define | GRPCI2_TADS_SIGNAL_GET(_reg) |
| #define | GRPCI2_TADS_SIGNAL_SET(_reg, _val) |
| #define | GRPCI2_TADS_SIGNAL(_val) |
| #define | GRPCI2_TCS_CBE_3_0_SHIFT 16 |
| #define | GRPCI2_TCS_CBE_3_0_MASK 0xf0000U |
| #define | GRPCI2_TCS_CBE_3_0_GET(_reg) |
| #define | GRPCI2_TCS_CBE_3_0_SET(_reg, _val) |
| #define | GRPCI2_TCS_CBE_3_0(_val) |
| #define | GRPCI2_TCS_FRAME 0x8000U |
| #define | GRPCI2_TCS_IRDY 0x4000U |
| #define | GRPCI2_TCS_TRDY 0x2000U |
| #define | GRPCI2_TCS_STOP 0x1000U |
| #define | GRPCI2_TCS_DEVSEL 0x800U |
| #define | GRPCI2_TCS_PAR 0x400U |
| #define | GRPCI2_TCS_PERR 0x200U |
| #define | GRPCI2_TCS_SERR 0x100U |
| #define | GRPCI2_TCS_IDSEL 0x80U |
| #define | GRPCI2_TCS_REQ 0x40U |
| #define | GRPCI2_TCS_GNT 0x20U |
| #define | GRPCI2_TCS_LOCK 0x10U |
| #define | GRPCI2_TCS_RST 0x8U |
Typedefs | |
| typedef struct grpci2 | grpci2 |
| This structure defines the GRPCI2 register block memory map. | |
